[OpenDroneMap-users] Segmentation fault
Stephen Mather stephen at smathermather.com
Thu May 14 09:01:15 PDT 2015
Oops. Thanks Dennis.
On Thu, May 14, 2015 at 11:45 AM, Dennis Baldwin <db at unmannedairlines.com>
wrote:
> Gregor,
> Make sure you change this line:
> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L572
> Steve pointed you to a link that I posted referencing an older run script.
> Modifying the line above should do the trick.
> Let us know if you run into any problems.
> Dennis
> On Thu, May 14, 2015 at 10:24 AM, Stephen Mather <
> stephen at smathermather.com> wrote:
>> Hi Gregor,
>> This looks like you don't have enough RAM relative to the number of
>> cores. Try using just 4 of your cores as a start.
>> https://github.com/OpenDroneMap/OpenDroneMap/issues/28
>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L478
>> Cheers,
>> Best,
>> Steve
>> On Wed, May 13, 2015 at 9:37 PM, Gregor MacLennan <
>> gmaclennan+odm at digital-democracy.org> wrote:
>>> I am getting a segmentation fault when trying to process 562 images
>>> under the default settings on a 16GB 8-core virtual machine. Any ideas what
>>> is wrong? Other log files I should post?
>>> Segmentation fault (core dumped)
>>> .......parallel: Starting no more jobs. Waiting for 8 jobs to finish.
>>> This job failed:
>>> echo -n "." && touch
>>> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" &&
>>> "/root/marudi/../OpenDroneMap/bin/KeyMatch"
>>> "/root/marudi/reconstruction-with-image-size-2400/G0020035_geotag.key"
>>> "/root/marudi/reconstruction-with-image-size-2400/G0020363_geotag.key"
>>> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" 0.6 2
>>> quitting cause:
>>> "/root/marudi/../OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
>>> "/root/marudi/reconstruction-with-image-size-2400/_matches_jobs.templist.txt"
>>> returned with code 35584
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150514/2b53542a/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
