[OpenDroneMap-users] library error in OdmTexturing
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Tue Sep 15 06:14:41 PDT 2015
Hi
I'm preparing some material for a Drone-Course at Yale and I'm encountering
sum problems in using OpenDroneMap.
In particular:
I run run.pl but I get the below error due to libdc1394 dependency (see log
file below).
I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
I try to manually install
sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg
libdc1394-22-dev libdc1394-22-doc libdc1394-utils
and re-install the sw but the error persist.
Any solution?
Thanks
Best
Giuseppe
############### error #######
  - running texturing - Tue Sep 15 12:37:55 UTC 2015
libdc1394 error: Failed to initialize libdc1394
Error in OdmTexturing:
Failed to read image:
'/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
For more detailed information, see log file.
quitting cause:
"/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing"
-bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
age-size-2400/pmvs/bundle.rd.out -imagesPath
/home/ubuntu/drone/dati/103MSDCF/ -imagesListPath
/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-
2400/pmvs/list.rd.txt -inputModelPath
/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
-outputFolder /home/ubuntu
/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/
-textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
-logFile /h
ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
returned with code 256
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net
Work:  http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150915/024ed6f8/attachment.html>
More information about the OpenDroneMap-users mailing list
