[OpenDroneMap-users] [OpenDroneMap-dev] library error in OdmTexturing
Dakota Benjamin
dmb2 at clevelandmetroparks.com
Tue Sep 15 06:25:33 PDT 2015
Try switching to the python-port branch. We are beginning to shift over to using run.py instead of run.pl, which now has more functionality and is seeing rapid improvements.
Dakota Benjamin
Cleveland Metroparks
Planning, Design, and Natural Resources
http://www.clevelandmetroparks.com/<http://www.clemetparks.com/>
From: opendronemap-dev-bounces at lists.osgeo.org <opendronemap-dev-bounces at lists.osgeo.org> on behalf of Giuseppe Amatulli <giuseppe.amatulli at gmail.com>
Sent: Tuesday, September 15, 2015 9:14 AM
To: opendronemap-dev at lists.osgeo.org; opendronemap-users at lists.osgeo.org
Cc: Stefano Casalegno
Subject: [OpenDroneMap-dev] library error in OdmTexturing
Hi
I'm preparing some material for a Drone-Course at Yale and I'm encountering sum problems in using OpenDroneMap.
In particular:
I run run.pl<http://run.pl> but I get the below error due to libdc1394 dependency (see log file below).
I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
I try to manually install
sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg libdc1394-22-dev libdc1394-22-doc libdc1394-utils
and re-install the sw but the error persist.
Any solution?
Thanks
Best
Giuseppe
############### error #######
- running texturing - Tue Sep 15 12:37:55 UTC 2015
libdc1394 error: Failed to initialize libdc1394
Error in OdmTexturing:
Failed to read image:
'/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
For more detailed information, see log file.
quitting cause:
"/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing" -bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
age-size-2400/pmvs/bundle.rd.out -imagesPath /home/ubuntu/drone/dati/103MSDCF/ -imagesListPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-
2400/pmvs/list.rd.txt -inputModelPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -outputFolder /home/ubuntu
/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/ -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600 -logFile /h
ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
returned with code 256
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net<http://spatial-ecology.net>
Work: http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150915/d439f1c4/attachment.html>
More information about the OpenDroneMap-users
