[OpenDroneMap-users] [OpenDroneMap-dev] library error in OdmTexturing
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Tue Sep 15 19:00:37 PDT 2015
Thanks Benjamin,
yes i was able to install python-port but when i run run.py i got the below
error.
Is the error related to a dataset or to an installation issues?
Please consider that, I have a dataset of 268 photos got with a "SONY
ILCE-QX1": 23.2 ( I got value from the following page
http://www.dpreview.com/products/sony/slrs/sony_ilceqx1 ).
Thanks
Best
Giuseppe
--constrain_focal_weight 0.0
--estimate_distortion
--run_bundle" >
"/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt"
b
running "/home/ubuntu/drone/OpenDroneMap/bin/bundler"
"/home/ubuntu/drone/dati/103MSDCSegmentation fault (core dumped)
F/reconstruction-with-image-size-2400/list.txt" --options_file
> bundle/out
b
quitting cause:
"/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/list.txt"
--options_file
> bundle/out
returned with code 35584.
On 15 September 2015 at 09:25, Dakota Benjamin <dmb2 at clevelandmetroparks.com
> wrote:
> Hi,
> Try switching to the python-port branch. We are beginning to shift over to
> using run.py instead of run.pl, which now has more functionality and is
> seeing rapid improvements.
> Dakota Benjamin
> Cleveland Metroparks
> Planning, Design, and Natural Resources
> http://www.clevelandmetroparks.com/ <http://www.clemetparks.com/>
> *From:* opendronemap-dev-bounces at lists.osgeo.org <
> opendronemap-dev-bounces at lists.osgeo.org> on behalf of Giuseppe Amatulli <
> giuseppe.amatulli at gmail.com>
> *Sent:* Tuesday, September 15, 2015 9:14 AM
> *To:* opendronemap-dev at lists.osgeo.org; opendronemap-users at lists.osgeo.org
> *Cc:* Stefano Casalegno
> *Subject:* [OpenDroneMap-dev] library error in OdmTexturing
> Hi
> I'm preparing some material for a Drone-Course at Yale and I'm
> encountering sum problems in using OpenDroneMap.
> In particular:
> I run run.pl but I get the below error due to libdc1394 dependency (see
> log file below).
> I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
> I try to manually install
> sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg
> libdc1394-22-dev libdc1394-22-doc libdc1394-utils
> and re-install the sw but the error persist.
> Any solution?
> Thanks
> Best
> Giuseppe
> ############### error #######
>   - running texturing - Tue Sep 15 12:37:55 UTC 2015
> libdc1394 error: Failed to initialize libdc1394
> Error in OdmTexturing:
> Failed to read image:
> '/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
> For more detailed information, see log file.
> quitting cause:
> "/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing"
> -bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
> age-size-2400/pmvs/bundle.rd.out -imagesPath
> /home/ubuntu/drone/dati/103MSDCF/ -imagesListPath
> 2400/pmvs/list.rd.txt -inputModelPath
> /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
> -outputFolder /home/ubuntu
> /drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/
> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
> -logFile /h
> ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
> returned with code 256
> Giuseppe Amatulli, Ph.D.
> Department of Ecology and Evolutionary Biology, Yale University.
> Jetz Lab, OML Room 405
> P.O. Box 208106
> 165 PROSPECT ST
> New Haven, CT 06520-8106
> Teaching: spatial-ecology.net
> Work:  http://sbsc.yale.edu/giuseppe-amatulli
> <http://www.spatial-ecology.net>
P.O. Box 208106
165 PROSPECT ST
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150915/41f8f67c/attachment.html>
More information about the OpenDroneMap-users mailing list
