[OpenDroneMap-users] [OpenDroneMap-dev] library error in OdmTexturing
Dakota Benjamin dmb2 at clevelandmetroparks.com
Wed Sep 16 05:17:38 PDT 2015
I'm not sure what the problem is as I have been unable to reproduce it. I just merged a big update that uses OpenSFM in place of bundler. Try running run.py with the following: '--use-opensfm True'.
Dakota Benjamin
Cleveland Metroparks
Planning, Design, and Natural Resources
http://www.clevelandmetroparks.com/<http://www.clemetparks.com/>
From: Giuseppe Amatulli <giuseppe.amatulli at gmail.com>
Sent: Tuesday, September 15, 2015 10:00 PM
To: Dakota Benjamin
Cc: opendronemap-users at lists.osgeo.org; Stefano Casalegno
Subject: Re: [OpenDroneMap-dev] library error in OdmTexturing
Thanks Benjamin,
yes i was able to install python-port but when i run run.py i got the below error.
Is the error related to a dataset or to an installation issues?
Please consider that, I have a dataset of 268 photos got with a "SONY ILCE-QX1": 23.2 ( I got value from the following page http://www.dpreview.com/products/sony/slrs/sony_ilceqx1 ).
Thanks
Best
Giuseppe
--constrain_focal_weight 0.0
--estimate_distortion
--run_bundle" > "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt"
b
running "/home/ubuntu/drone/OpenDroneMap/bin/bundler" "/home/ubuntu/drone/dati/103MSDCSegmentation fault (core dumped)
F/reconstruction-with-image-size-2400/list.txt" --options_file "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt" > bundle/out
b
quitting cause:
    "/home/ubuntu/drone/OpenDroneMap/bin/bundler" "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/list.txt" --options_file "/home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/options.txt" > bundle/out
returned with code 35584.
On 15 September 2015 at 09:25, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
Try switching to the python-port branch. We are beginning to shift over to using run.py instead of run.pl<http://run.pl>, which now has more functionality and is seeing rapid improvements.
Dakota Benjamin
From: opendronemap-dev-bounces at lists.osgeo.org<mailto:opendronemap-dev-bounces at lists.osgeo.org> <opendronemap-dev-bounces at lists.osgeo.org<mailto:opendronemap-dev-bounces at lists.osgeo.org>> on behalf of Giuseppe Amatulli <giuseppe.amatulli at gmail.com<mailto:giuseppe.amatulli at gmail.com>>
Sent: Tuesday, September 15, 2015 9:14 AM
To: opendronemap-dev at lists.osgeo.org<mailto:opendronemap-dev at lists.osgeo.org>; opendronemap-users at lists.osgeo.org<mailto:opendronemap-users at lists.osgeo.org>
Cc: Stefano Casalegno
Subject: [OpenDroneMap-dev] library error in OdmTexturing
Hi
I'm preparing some material for a Drone-Course at Yale and I'm encountering sum problems in using OpenDroneMap.
In particular:
I run run.pl<http://run.pl> but I get the below error due to libdc1394 dependency (see log file below).
I'm running Ubuntu 14.04 with ubuntugis-unstable repository.
I try to manually install
sudo apt-get install libpcl1 libpcl1-dev libdc1394-22 libdc1394-22-dbg libdc1394-22-dev libdc1394-22-doc libdc1394-utils
and re-install the sw but the error persist.
Any solution?
Thanks
Best
Giuseppe
############### error #######
  - running texturing - Tue Sep 15 12:37:55 UTC 2015
libdc1394 error: Failed to initialize libdc1394
Error in OdmTexturing:
Failed to read image:
'/home/ubuntu/drone/dati/103MSDCF//DSC01529.jpg'
For more detailed information, see log file.
quitting cause:
    "/home/ubuntu/drone/dati/103MSDCF/../../sw/OpenDroneMap-gh-pages/bin/odm_texturing" -bundleFile /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-im
age-size-2400/pmvs/bundle.rd.out -imagesPath /home/ubuntu/drone/dati/103MSDCF/ -imagesListPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-
2400/pmvs/list.rd.txt -inputModelPath /home/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -outputFolder /home/ubuntu
/drone/dati/103MSDCF/reconstruction-with-image-size-2400-results/odm_texturing/ -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600 -logFile /h
ome/ubuntu/drone/dati/103MSDCF/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
returned with code 256
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net<http://spatial-ecology.net>
Work:  http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
P.O. Box 208106
165 PROSPECT ST
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150916/2967aa26/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
