[OpenDroneMap-users] No orthophoto output
Stephen Mather stephen at smathermather.com
Thu Sep 24 18:44:30 PDT 2015
Ok, so you'll have to create a ground control file to create an ortho --
otherwise there's no way for the software to know which way is up (Z). See:
https://github.com/OpenDroneMap/OpenDroneMap/wiki/2.-Running-OpenDroneMap
If you use the python-port branch:
https://github.com/OpenDroneMap/OpenDroneMap/tree/python-port
you can use a proper proj4 line at the top to get a georeferenced
orthophoto.
Dakota, do we have documentation of this yet?
Cheers!
Best,
Steve
On Thu, Sep 24, 2015 at 3:09 AM, Simon Stock <simon.stock at web.de> wrote:
> No, they don't have any GPS information in the EXIF data.
> Am 22.09.2015 um 21:31 schrieb Dakota Benjamin:
> Do your photos have GPS coordinates in the EXIF data? That would prevent
> the program from running orthophoto generation.
> Sent from Outlook <http://aka.ms/Ox5hz3>
> _____________________________
> From: Simon Stock <simon.stock at web.de>
> Sent: Tuesday, September 22, 2015 2:46 PM
> Subject: [OpenDroneMap-users] No orthophoto output
> To: <opendronemap-users at lists.osgeo.org>
> Dear List,
> I'm interested in using pictures taken with my Drone as one big
> orthophoto in GIS. So I installed OpenDroneMap on a machine running
> Linux Mint 17.2 yesterday and started playing around with the pacifica
> sample dataset.
> When I use the run.pl script without any options it runs for 40 minutes
> and finishes with this messages:
> - running georeferencing - Di 22. Sep 20:40:02 CEST 2015
> Warning: No GCP file. Consider rerunning with argument
> --odm_georeferencing-useGcp false --start-with odm_georeferencing
> Skipping orthophoto
> Compressing results - Di 22. Sep 20:40:02 CEST 2015
> - done - Di 22. Sep 20:40:05 CEST 2015
> When I rerun and use the suggested options (--odm_georeferencing-useGcp
> false --start-with odm_georeferencing) the script stops after just a few
> seconds with this messages:
> Error in OdmExtractUtm:
> No valid GPS position found
> For more detailed information, see log file.
> Error in Georef:
> Failed opening
> /home/simon/OpenDroneMap/ortho2/reconstruction-with-image-size-2400/odm_georeferencing/coordFile.txt
> for reading.
> quitting cause:
> "/home/simon/OpenDroneMap/ortho2/../bin/odm_georef" -bundleFile
> /home/simon/OpenDroneMap/ortho2/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> -coordFile
> -inputFile
> /home/simon/OpenDroneMap/ortho2/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> -outputFile
> /home/simon/OpenDroneMap/ortho2/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> -logFile
> /home/simon/OpenDroneMap/ortho2/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> returned with code 256
> What am I doing wrong?
> Thanks a lot,
> Simon
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150924/a7d60e62/attachment.html>
More information about the OpenDroneMap-users mailing list
