[OpenDroneMap-users] No orthophoto output
Simon Stock
simon.stock at web.de
Sat Sep 26 02:55:01 PDT 2015
Hi Steve,
I had a look at the "Running ODM with Ground Control" section of the
mentioned link but I have no clue what I have to write in the
gcp_list.txt file. As mentioned before I'm using the pacifica sample
dataset and that doesn't include GPS coordinates.
Isn't it possible to generate an orthophoto without georeferencing it
but doing this afterwards in GIS?
Thanks,
Simon
Am 25.09.2015 um 03:44 schrieb Stephen Mather:
> Ok, so you'll have to create a ground control file to create an ortho
> -- otherwise there's no way for the software to know which way is up
> (Z). See:
> https://github.com/OpenDroneMap/OpenDroneMap/wiki/2.-Running-OpenDroneMap
> If you use the python-port branch:
> https://github.com/OpenDroneMap/OpenDroneMap/tree/python-port
> you can use a proper proj4 line at the top to get a georeferenced
> orthophoto.
> Dakota, do we have documentation of this yet?
> Cheers!
> Best,
> Steve
More information about the OpenDroneMap-users
