[OpenDroneMap-users] Docker Error: float division by zero
Dakota Benjamin dmb2 at clevelandmetroparks.com
Wed Jun 22 05:55:48 PDT 2016
It looks to me like this line in OpenSfM doesn't check for division by 0: https://github.com/mapillary/OpenSfM/blob/odm-2/opensfm/exif.py#L21
But I bet it has to do with the --force-focal tag not properly being passed over to OpenSfM either.
Why don't you document your problem and post it as an issue?
[http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
Geospatial Developer
clevelandmetroparks.com<http://www.clemetparks.com/>
From: OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org> on behalf of Dennis Baldwin <db at unmannedairlines.com>
Sent: Tuesday, June 21, 2016 6:34:14 PM
To: opendronemap-users at lists.osgeo.org
Subject: [OpenDroneMap-users] Docker Error: float division by zero
Today was my first experience running ODM with Docker and I ran into the following error:
[DEBUG]   running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/run_all /images/opensfm
2016-06-21 22:27:08,640 Extracting focal lengths for image DJI_0160.JPG
  File "/code/SuperBuild/src/opensfm/bin/focal_from_exif", line 27, in <module>
    d = exif.extract_exif_from_file(data.load_image(image))
  File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 88, in extract_exif_from_file
    d = exif_data.extract_exif()
  File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 238, in extract_exif
    focal_35, focal_ratio = self.extract_focal()
  File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 169, in extract_focal
    get_frac_tag(self.tags, 'EXIF FocalLength'),
  File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 41, in get_frac_tag
    return eval_frac(tags[key].values[0])
  File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 21, in eval_frac
    return float(value.num) / float(value.den)
ZeroDivisionError: float division by zero
[ERROR]   quitting cause:
returned with code 256.
I was manually forcing the focal and ccd params with the following command:
docker run -v $IMAGES:/images opendronemap:latest --force-focal 3.5 --force-ccd 6.17
Any insight how to get around this? I've run ODM successfully many times on my VM, but Docker seems to have stopped me.
Thanks,
Dennis
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160622/2f7067f0/attachment.html>
More information about the OpenDroneMap-users mailing list
