[OpenDroneMap-users] Docker Error: float division by zero
Dennis Baldwin
db at unmannedairlines.com
Tue Jun 21 15:34:14 PDT 2016
Today was my first experience running ODM with Docker and I ran into the
following error:
[DEBUG] running
PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages
/code/SuperBuild/src/opensfm/bin/run_all /images/opensfm
2016-06-21 22:27:08,640 Extracting focal lengths for image DJI_0160.JPG
File "/code/SuperBuild/src/opensfm/bin/focal_from_exif", line 27, in
<module>
d = exif.extract_exif_from_file(data.load_image(image))
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 88, in
d = exif_data.extract_exif()
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 238, in
extract_exif
focal_35, focal_ratio = self.extract_focal()
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 169, in
extract_focal
get_frac_tag(self.tags, 'EXIF FocalLength'),
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 41, in
get_frac_tag
return eval_frac(tags[key].values[0])
File "/code/SuperBuild/src/opensfm/opensfm/exif.py", line 21, in eval_frac
return float(value.num) / float(value.den)
ZeroDivisionError: float division by zero
[ERROR] quitting cause:
returned with code 256.
I was manually forcing the focal and ccd params with the following command:
docker run -v $IMAGES:/images opendronemap:latest --force-focal 3.5
--force-ccd 6.17
Any insight how to get around this? I've run ODM successfully many times on
my VM, but Docker seems to have stopped me.
Thanks,
Dennis
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160621/25c0d2ce/attachment.html>
More information about the OpenDroneMap-users
