[OpenDroneMap-users] [OpenDroneMap-dev] Beta v0.1 Release and Changelog
Dakota Benjamin dmb2 at clevelandmetroparks.com
Fri Jun 24 06:15:26 PDT 2016
I think I know what might be the problem, but I'll need more information. What is happening is the orthophoto is being improperly scaled.
How do you georeference your photos? using EXIF or gcp_list.txt?
[http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
Geospatial Developer
clevelandmetroparks.com<http://www.clemetparks.com/>
Sent: Friday, June 24, 2016 9:01:27 AM
To: Dakota Benjamin
Cc: opendronemap-users at lists.osgeo.org; opendronemap-dev at lists.osgeo.org
Subject: Re: [OpenDroneMap-dev] Beta v0.1 Release and Changelog
I am trying to figure out the way to transfer this file to you:
$ ls -larth odm_orthphoto.tif
-rw-rw-r-- 1 ubuntu ubuntu 2.1G May 24 23:30 odm_orthphoto.tif
The one created by the new version is attached here. Sorry, it is not 188K, but approx. 1M. I am sorry for the confusion.
Thanks,
kshitij
Kshitij Sharma
https://www.linkedin.com/in/kshitijsharma
+91 9632366466
On Fri, Jun 24, 2016 at 6:25 PM, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
Can you post a sample of the differences in the orthophoto?
Thanks,
Dakota
From: Kshitij Sharma <ksharma at gmail.com<mailto:ksharma at gmail.com>>
Sent: Friday, June 24, 2016 7:32:41 AM
To: Dakota Benjamin
Cc: opendronemap-users at lists.osgeo.org<mailto:opendronemap-users at lists.osgeo.org>; opendronemap-dev at lists.osgeo.org<mailto:opendronemap-dev at lists.osgeo.org>
Hello Dakota,
I have used ODM on similar sized Ubuntu server before and after update. I ran the two versions on the same set of images. However, the version after the update does not provide repeatable results. I did a quick comparison and there is a difference in the quality and extent of the image.
Prior to the update, a set of mining images generated a very high quality GeoTIFF. The size of the image was also huge - the TIFF was about 2Gigs with really good detail. Post update, the same geotiff is merely 180KB and there are no details to focus on the image. I had run pretty much the default command line parameters there.
Could you please help understand the difference and discrepancy?
Thanks,
kshitij
Kshitij Sharma
+91 9632366466<tel:%2B91%209632366466>
On Wed, Jun 22, 2016 at 6:10 PM, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
I removed some repository-specific images and the test data to make the zip file (much) smaller.  It should in no way impact the running of the program, but if there are issues let me know.
Sent: Monday, June 20, 2016 10:00:51 PM
To: Dakota Benjamin
Hello Dakota,
Thanks for the information. As of now, what is the difference between the release zip file vs. https://github.com/OpenDroneMap/OpenDroneMap/wiki/1.-Installation? If we were to follow the instructions from the wiki, would we get the same release that you have sent the email for?
Thanks much.
kshitij
Kshitij Sharma
On Wed, Jun 15, 2016 at 7:59 PM, Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>> wrote:
And we are live! Thanks to everyone who has contributed to OpenDroneMap thus far.
The link to download the release is here: https://github.com/OpenDroneMap/OpenDroneMap/releases/download/v0.1/OpenDroneMap-v0_1.zip
Dakota
From: OpenDroneMap-dev <opendronemap-dev-bounces at lists.osgeo.org<mailto:opendronemap-dev-bounces at lists.osgeo.org>> on behalf of Dakota Benjamin <dmb2 at clevelandmetroparks.com<mailto:dmb2 at clevelandmetroparks.com>>
Sent: Tuesday, June 14, 2016 10:50:30 AM
To: opendronemap-users at lists.osgeo.org<mailto:opendronemap-users at lists.osgeo.org>; opendronemap-dev at lists.osgeo.org<mailto:opendronemap-dev at lists.osgeo.org>
Subject: [OpenDroneMap-dev] Beta v0.1 Release and Changelog
OpenDroneMap users,
Tomorrow we will be publishing a huge update. We've incorporated a processing framework for the ODM toolchain and improved the installation process. If you've been using the "dev" branch on GitHub recently, this is nothing new for you. Read below for the changelog and watch for another email tomorrow when the release is finalized.
Installation
  *   cmake superbuild for all components
  *   Now you will run the following to install or update ODM:
bash ./configure.sh
mkdir build && cd build && cmake .. && make && cd ..
# copy paste the following (with correct directory structure) into your ~/.bashrc (or other preferred method) (requires logout/in to work)
export PYTHONPATH=$PYTHONPATH:<ODMDIR>/SuperBuild/install/lib/python2.7/dist-packages:<ODMDIR>/SuperBuild/src/opensfm
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<ODMDIR>/SuperBuild/install/lib
Running ODM
Use these instructions to run the processing script<https://github.com/OpenDroneMap/OpenDroneMap/tree/dev#running-opendronemap>. Note there are significant differences from the previous version, namely you have to specify --project-path
Code restructure
  *   Object Oriented Code
  *   Ecto<https://plasmodic.github.io/ecto/> processing framework
  *   Project tree:
     *   Your ODM project will have a more organized structure. One big change is that your images must be placed in a "images/" subdirectory in the project folder.
  *   Testing framework
Feature additions / changes
  *   Add XYZ pointcloud output
  *   benchmarking with --time
  *   Replacement of LASTools with PDAL
  *   Control script updates - --rerun-from, --rerun-all
  *   Remove local ccd_defs in lieu of OpenSfM sensor data file.
Please email me with questions or comments. If you want to use the updates before the release, simply run "git checkout dev" and use the installation method above.
Happy Processing!
Dakota
OpenDroneMap-dev mailing list
OpenDroneMap-dev at lists.osgeo.org<mailto:OpenDroneMap-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160624/84b5369e/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
