[OpenDroneMap-users] ODM processing issue on 1)Ubuntu 14.04 and 2)Docker
Debell, Leon
ld384 at exeter.ac.uk
Mon May 23 08:35:32 PDT 2016
How do,
I've made several attempts at processing a data set using ODM on an Ubuntu 14.04 distro.
The git clone and install all went without a hitch, but when I process the images I get this error appearing;
" - source files - Mon May 23 14:25:05 2016
File "/home/leond/OpenDroneMap/run.py", line 986, in <module>
prepare_objects()
File "/home/leond/OpenDroneMap/run.py", line 415, in prepare_objects
fileObject["ccd"] = float(ccdWidths[fileObject["id"]])
KeyError: u'RICOH IMAGING COMPANY, LTD. GR II' "
I've managed to circumvent this issue by using --force-focal and --force-ccd, however, the final outputs are terrible, an example would be the orthophoto only being just over a 100kb and completely pixelated. The point cloud isn't as bad but has large chunks of data missing.
I know there's nothing wrong with the data set as I have a very nice output from Agisoft. I've also ran one of the test datasets that are provided and that worked without issue.
Trying to run the build from a docker container, my first issue here is following the instructions on the wiki for a git clone docker build, I get;
" export IMAGES=/run/media/leond/PhD/ODMOptimise/
[leond at mandy OpenDroneMap]$ docker build -t opendronemap:latest
docker: "build" requires 1 argument.
See 'docker build --help'.
Usage: docker build [OPTIONS] PATH | URL | -
Build an image from a Dockerfile "
I've then tried to use the dbrgn/opendronemap docker container and I get similar to running natively on Ubuntu;
" Traceback (most recent call last):
File "/code/run.py", line 986, in <module>
prepare_objects()
File "/code/run.py", line 415, in prepare_objects
I'd also read on the mailing list about using the /tree/dev version available on git but I'm unable to clone that url.
I appreciate there's probably more than one unrelated issue here (and a couple that are). I'd really like to try and get ODM working and with usable outputs, so any advice would be welcomed.
Cheers,
Leon
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20160523/a4f0c3d0/attachment.html>
More information about the OpenDroneMap-users
