[OpenDroneMap-users] Fwd: Georeferencing Failed Error with gcp_list.txt File
Hakan Atak
hakanatak at gmail.com
Wed Apr 12 04:08:15 PDT 2017
Hi All,
I tried to process Pix4d cadaster
<https://support.pix4d.com/hc/en-us/articles/202561399-Example-Datasets-Available-for-Download-Cadastre->
dataset, to compare the results for an academic research.
After started the run.py, I had a georeferencing error.
I prepared the "gcp_list.txt" file manually by using resized photos .
What do you advice to me ? Thanks.
Here is my gcp_list.txt file and error lines.
WGS84 UTM 32N
here is the error log
Running ODM Georeferencing Cell
[DEBUG] /home/odm/OpendroneMap/ODMProjects/project3/images/gcp_list.txt
[INFO] Found /home/odm/OpendroneMap/ODMProjects/project3/images/
gcp_list.txt
[DEBUG] running /home/odm/OpenDroneMap/build/bin/odm_georef -bundleFile
/home/odm/OpenDroneMap/ODMProjects/project3/opensfm/bundle_r000.out
-imagesPath /home/odm/OpenDroneMap/ODMProjects/project3/images_resize
-imagesListPath
/home/odm/OpenDroneMap/ODMProjects/project3/opensfm/list_r000.out
-bundleResizedTo 2400 -inputFile /home/odm/OpenDroneMap/
ODMProjects/project3/odm_texturing/odm_textured_model.obj -outputFile
/home/odm/OpenDroneMap/ODMProjects/project3/odm_
texturing/odm_textured_model_geo.obj -inputPointCloudFile
/home/odm/OpenDroneMap/ODMProjects/project3/opensfm/depthmaps/merged.ply
-outputPointCloudFile /home/odm/OpenDroneMap/ODMProjects/project3/odm_
georeferencing/odm_georeferenced_model.ply -logFile /home/odm/OpenDroneMap/
ODMProjects/project3/odm_georeferencing/odm_georeferencing_log.txt
-georefFileOutputPath /home/odm/OpenDroneMap/ODMProjects/project3/odm_
georeferencing/odm_georeferencing_model_geo.txt -gcpFile
-outputCoordFile /home/odm/OpenDroneMap/ODMProjects/project3/odm_
georeferencing/coords.txt
Error in Georef:
Failed opening gcp file
for reading.
[ERROR] Georeferencing failed.
File "/home/odm/OpenDroneMap/scripts/odm_georeferencing.py", line 124, in
process
'-outputCoordFile {coords}'.format(**kwargs))
File "/home/odm/OpenDroneMap/opendm/system.py", line 28, in run
raise Exception("Child returned {}".format(retcode))
Exception: Child returned 1
[INFO] OpenDroneMap app finished - Wed Apr 12 11:44:13 2017
Best Regards,
Hakan ATAK
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170412/6ce09e4e/attachment.html>
More information about the OpenDroneMap-users
