[OpenDroneMap-users] Errors installing in Lubuntu 17.04
Carlos Grohmann
carlos.grohmann at gmail.com
Tue Apr 25 18:57:59 PDT 2017
Hello all
I'm trying to install ODM on a Lubuntu 17.04 virtual machine (VirtualBox
running in MacOS).
I'm getting errors with PCL and PDAL. (I'm running as root due some
permissions errors in earlier attempts)
Below is the final part of the output messages.
Thanks for any help.
Carlos
Compiling SuperBuild
-- The C compiler identification is GNU 6.3.0
-- The CXX compiler identification is GNU 6.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- SuperBuild files will be downloaded to:
/home/guano/OpenDroneMap/SuperBuild/download
-- SuperBuild source files will be extracted to:
/home/guano/OpenDroneMap/SuperBuild/src
-- SuperBuild source files will be installed to:
/home/guano/OpenDroneMap/SuperBuild/install
-- SuperBuild binary files will be located to:
/home/guano/OpenDroneMap/SuperBuild/build
-- OpenCV 2.4.11 not found --- Adding internal version
-- PCL 1.7.2 not found --- Adding internal version
-- GFlags 2.1.2 found
-- Ceres 1.10.0 not found --- Adding internal version
CMake Error at /usr/share/cmake-3.7/Modules/ExternalProject.cmake:2192
(get_property):
get_property could not find TARGET gflags. Perhaps it has not yet been
created.
Call Stack (most recent call first):
/usr/share/cmake-3.7/Modules/ExternalProject.cmake:2528
(_ep_add_configure_command)
cmake/External-Ceres.cmake:4 (ExternalProject_Add)
cmake/ExternalProject-Setup.cmake:15 (include)
CMakeLists.txt:90 (SETUP_EXTERNAL_PROJECT)
-- OpenGV force build --- Adding internal version
-- OpenSfM force build --- Adding internal version
-- CMVS force build --- Adding internal version
-- Catkin force build --- Adding internal version
-- Ecto force build --- Adding internal version
-- PDAL force build --- Adding internal version
-- MvsTexturing force build --- Adding internal version
-- Configuring incomplete, errors occurred!
See also
"/home/guano/OpenDroneMap/SuperBuild/build/CMakeFiles/CMakeOutput.log".
Compiling build
CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
Could not find a package configuration file provided by "PCL" (requested
version 1.7) with any of the following names:
PCLConfig.cmake
pcl-config.cmake
Add the installation prefix of "PCL" to CMAKE_PREFIX_PATH or set "PCL_DIR"
to a directory containing one of the above files. If "PCL" provides a
separate development package or SDK, be sure it has been installed.
CMake Error at modules/odm_georef/CMakeLists.txt:19 (find_package):
Could not find a package configuration file provided by "OpenCV" with any
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
"OpenCV_DIR" to a directory containing one of the above files. If
"OpenCV"
provides a separate development package or SDK, be sure it has been
installed.
See also "/home/guano/OpenDroneMap/build/CMakeFiles/CMakeOutput.log".
Configuration Finished
root at linux-vbox:/home/guano/OpenDroneMap#
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170425/d6b41cd5/attachment.html>
More information about the OpenDroneMap-users
