[OpenDroneMap-users] Errors installing in Lubuntu 17.04
Martin Weis
martin.weis.newsadress at gmx.de
Tue Apr 25 22:23:57 PDT 2017
Hello!
Am 26.04.2017 um 03:57 schrieb Carlos Grohmann:
> I'm trying to install ODM on a Lubuntu 17.04 virtual machine (VirtualBox
> running in MacOS).
> I'm getting errors with PCL and PDAL. (I'm running as root due some
> permissions errors in earlier attempts)
pcl and opencv, as it seems...
> CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
> Could not find a package configuration file provided by "PCL" (requested
> version 1.7) with any of the following names:
> PCLConfig.cmake
> pcl-config.cmake
> Could not find a package configuration file provided by "OpenCV" with any
> OpenCVConfig.cmake
> opencv-config.cmake
On U16.04 these files are in packages:
apt-file search PCLConfig.cmake
libpcl-dev: /usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake
apt-file search OpenCVConfig.cmake
libopencv-dev: /usr/share/OpenCV/OpenCVConfig.cmake
Did you install these packages?
apt install libpcl-dev libopencv-dev
# maybe redo cmake config to update cached content.
Good luck
Martin
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170426/f220aa7c/attachment.sig>
More information about the OpenDroneMap-users
