[OpenDroneMap-users] Errors installing in Lubuntu 17.04
Carlos Grohmann
carlos.grohmann at gmail.com
Wed Apr 26 07:51:00 PDT 2017
I see.
Ok, trying the version 0.3 (downloaded as tar.gz, since the git repo is
about 1.4GB...), and running
docker build -t packages -f Dockerfile .
gives me an error with opencv:
-- Installing:
/code/SuperBuild/install/share/OpenCV/lbpcascades/lbpcascade_profileface.xml
-- Installing:
/code/SuperBuild/install/share/OpenCV/lbpcascades/lbpcascade_silverware.xml
[ 59%] Completed 'opencv'
[ 59%] Built target opencv
make: *** [all] Error 2
Makefile:83: recipe for target 'all' failed
The command '/bin/sh -c cd SuperBuild && mkdir build && cd build && cmake
.. && make -j$(nproc) && cd ../.. && mkdir build && cd build && cmake
.. && make -j$(nproc)' returned a non-zero code: 2
thanks
Carlos
On Wed, Apr 26, 2017 at 11:21 AM, Dakota M. Benjamin <
dmb2 at clevelandmetroparks.com> wrote:
> All,
> I think this issue is related: https://github.com/
> OpenDroneMap/OpenDroneMap/issues/410
> For now I would suggest trying the docker install process detailed in the
> README while we look into these issues.
> [image: http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
> Geospatial Developer
> 216-635-3255 <(216)%20635-3255> (Office)
> clevelandmetroparks.com <http://www.clemetparks.com/>
> *From:* OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org>
> on behalf of Carlos Grohmann <carlos.grohmann at gmail.com>
> *Sent:* Wednesday, April 26, 2017 9:52:57 AM
> *To:* opendronemap-users at lists.osgeo.org
> *Subject:* Re: [OpenDroneMap-users] Errors installing in Lubuntu 17.04
> Thanks Martin
> Those errors were fized by installing libpcl-dev and libopencv-dev.
> Now I'm getting errors in the compilation step:
> modules/odm_georef/CMakeFiles/odm_georef.dir/build.make:86: recipe for
> target 'modules/odm_georef/CMakeFiles/odm_georef.dir/src/Georef.cpp.o'
> failed
> make[2]: *** [modules/odm_georef/CMakeFiles/odm_georef.dir/src/Georef.cpp.o]
> Error 1
> CMakeFiles/Makefile2:170: recipe for target 'modules/odm_georef/CMakeFiles/odm_georef.dir/all'
> failed
> make[1]: *** [modules/odm_georef/CMakeFiles/odm_georef.dir/all] Error 2
> Configuration Finished
> From what I see, it's looking for Georef.cpp at
> ???/modules/odm_georef/CMakeFiles/odm_georef.dir/src/
> but I only found this file at
> OpenDroneMap/modules/odm_georef/src
> thanks again
> Carlos
> On Wed, Apr 26, 2017 at 2:23 AM, Martin Weis <
> martin.weis.newsadress at gmx.de> wrote:
>> Hello!
>> Am 26.04.2017 um 03:57 schrieb Carlos Grohmann:
>> > I'm trying to install ODM on a Lubuntu 17.04 virtual machine (VirtualBox
>> > running in MacOS).
>> > I'm getting errors with PCL and PDAL. (I'm running as root due some
>> > permissions errors in earlier attempts)
>> pcl and opencv, as it seems...
>> > CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
>> > Could not find a package configuration file provided by "PCL"
>> (requested
>> > version 1.7) with any of the following names:
>> > PCLConfig.cmake
>> > pcl-config.cmake
>> > Could not find a package configuration file provided by "OpenCV" with
>> any
>> > OpenCVConfig.cmake
>> > opencv-config.cmake
>> On U16.04 these files are in packages:
>> apt-file search PCLConfig.cmake
>> libpcl-dev: /usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake
>> apt-file search OpenCVConfig.cmake
>> libopencv-dev: /usr/share/OpenCV/OpenCVConfig.cmake
>> Did you install these packages?
>> apt install libpcl-dev libopencv-dev
>> # maybe redo cmake config to update cached content.
>> Good luck
>> Martin
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/opendronemap-users
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
________________
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170426/0d1818f3/attachment.html>
More information about the OpenDroneMap-users
