[OpenDroneMap-users] Errors installing in Lubuntu 17.04
Dakota M. Benjamin dmb2 at clevelandmetroparks.com
Wed Apr 26 07:21:10 PDT 2017
All,
I think this issue is related: https://github.com/OpenDroneMap/OpenDroneMap/issues/410
For now I would suggest trying the docker install process detailed in the README while we look into these issues.
[http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
Geospatial Developer
216-635-3255 (Office)
clevelandmetroparks.com<http://www.clemetparks.com/>
From: OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org> on behalf of Carlos Grohmann <carlos.grohmann at gmail.com>
Sent: Wednesday, April 26, 2017 9:52:57 AM
To: opendronemap-users at lists.osgeo.org
Subject: Re: [OpenDroneMap-users] Errors installing in Lubuntu 17.04
Thanks Martin
Those errors were fized by installing libpcl-dev and libopencv-dev.
Now I'm getting errors in the compilation step:
modules/odm_georef/CMakeFiles/odm_georef.dir/build.make:86: recipe for target 'modules/odm_georef/CMakeFiles/odm_georef.dir/src/Georef.cpp.o' failed
make[2]: *** [modules/odm_georef/CMakeFiles/odm_georef.dir/src/Georef.cpp.o] Error 1
CMakeFiles/Makefile2:170: recipe for target 'modules/odm_georef/CMakeFiles/odm_georef.dir/all' failed
make[1]: *** [modules/odm_georef/CMakeFiles/odm_georef.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
Configuration Finished
>From what I see, it's looking for Georef.cpp at
???/modules/odm_georef/CMakeFiles/odm_georef.dir/src/
but I only found this file at
OpenDroneMap/modules/odm_georef/src
thanks again
Carlos
On Wed, Apr 26, 2017 at 2:23 AM, Martin Weis <martin.weis.newsadress at gmx.de<mailto:martin.weis.newsadress at gmx.de>> wrote:
Hello!
Am 26.04.2017 um 03:57 schrieb Carlos Grohmann:
> I'm trying to install ODM on a Lubuntu 17.04 virtual machine (VirtualBox
> running in MacOS).
> I'm getting errors with PCL and PDAL. (I'm running as root due some
> permissions errors in earlier attempts)
pcl and opencv, as it seems...
> CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
>   Could not find a package configuration file provided by "PCL" (requested
>   version 1.7) with any of the following names:
>     PCLConfig.cmake
>     pcl-config.cmake
>   Could not find a package configuration file provided by "OpenCV" with any
>     OpenCVConfig.cmake
>     opencv-config.cmake
On U16.04 these files are in packages:
apt-file search PCLConfig.cmake
libpcl-dev: /usr/lib/x86_64-linux-gnu/cmake/pcl/PCLConfig.cmake
apt-file search OpenCVConfig.cmake
libopencv-dev: /usr/share/OpenCV/OpenCVConfig.cmake
Did you install these packages?
apt install libpcl-dev libopencv-dev
# maybe redo cmake config to update cached content.
Good luck
Martin
OpenDroneMap-users mailing list
OpenDroneMap-users at lists.osgeo.org<mailto:OpenDroneMap-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/opendronemap-users
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com<http://carlosgrohmann.com/>
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170426/96b0bdd5/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
