[OpenLayers-Commits] r10819 - in sandbox/tschaub/donut: . build examples lib/OpenLayers lib/OpenLayers/Layer lib/OpenLayers/Layer/Google tests/Control tools
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Oct 11 18:13:13 EDT 2010
Author: tschaub
Date: 2010-10-11 15:13:13 -0700 (Mon, 11 Oct 2010)
New Revision: 10819
Added:
   sandbox/tschaub/donut/examples/strategy-cluster-extended.html
   sandbox/tschaub/donut/examples/strategy-cluster-extended.js
   sandbox/tschaub/donut/build/full.cfg
   sandbox/tschaub/donut/build/library.cfg
   sandbox/tschaub/donut/examples/vector-features.html
   sandbox/tschaub/donut/lib/OpenLayers/Control.js
   sandbox/tschaub/donut/lib/OpenLayers/Layer/Google/v3.js
   sandbox/tschaub/donut/lib/OpenLayers/Layer/TileCache.js
   sandbox/tschaub/donut/release-license.txt
   sandbox/tschaub/donut/tests/Control/Panel.html
   sandbox/tschaub/donut/tools/mergejs.py
Merge r10804:10818 from trunk.
Property changes on: sandbox/tschaub/donut
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10804-10818
Modified: sandbox/tschaub/donut/build/full.cfg
--- sandbox/tschaub/donut/build/full.cfg	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/build/full.cfg	2010-10-11 22:13:13 UTC (rev 10819)
@@ -14,19 +14,5 @@
 [include]
 [exclude]
-Firebug/firebug.js
-Firebug/firebugx.js
-OpenLayers/Lang/ca.js
-OpenLayers/Lang/cs-CZ.js
-OpenLayers/Lang/da-DK.js
-OpenLayers/Lang/de.js
-OpenLayers/Lang/en-CA.js
-OpenLayers/Lang/es.js
-OpenLayers/Lang/fr.js
-OpenLayers/Lang/it.js
-OpenLayers/Lang/nb.js
-OpenLayers/Lang/nl.js
-OpenLayers/Lang/pt-BR.js
-OpenLayers/Lang/sv-SE.js
-OpenLayers/Lang/zh-TW.js
-OpenLayers/Lang/zh-CN.js
+Firebug
+OpenLayers/Lang
Modified: sandbox/tschaub/donut/build/library.cfg
--- sandbox/tschaub/donut/build/library.cfg	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/build/library.cfg	2010-10-11 22:13:13 UTC (rev 10819)
@@ -15,8 +15,7 @@
 [include]
 [exclude]
-Firebug/firebug.js
+Firebug
 OpenLayers/Format/GeoRSS.js
 OpenLayers/Format/GML.js
 OpenLayers/Format/WKT.js
@@ -50,19 +49,6 @@
 OpenLayers/Renderer/SVG.js
 OpenLayers/Renderer/VML.js
 OpenLayers/Renderer.js
+OpenLayers/Lang
Copied: sandbox/tschaub/donut/examples/strategy-cluster-extended.html (from rev 10818, trunk/openlayers/examples/strategy-cluster-extended.html)
--- sandbox/tschaub/donut/examples/strategy-cluster-extended.html	                        (rev 0)
+++ sandbox/tschaub/donut/examples/strategy-cluster-extended.html	2010-10-11 22:13:13 UTC (rev 10819)
@@ -0,0 +1,122 @@
+<!DOCTYPE html>
+<html>
+    <head>
+        <title>Extended clustering example</title>
+        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+        <link rel="stylesheet" href="style.css" type="text/css">
+        <style type="text/css">
+            label {
+                cursor: pointer
+            #wrap {
+                width: 925px;
+                margin: 10px;
+            #strategy-chooser, #generalinfo, #info {
+                width: 400px;
+                padding: 0;
+                float: right;
+                clear: right;
+                margin-bottom: 4px;
+            #map {
+                float: left;
+        </style>
+    </head>
+    <body>
+        <h1 id="title">Extended clustering</h1>
+        <div id="tags">
+            cluster, advanced
+        </div>
+        <p id="shortdesc">
+            Shows the usage of custom classes for a fine grained control about
+            the clustering behaviour.
+        </p>
+        <div id="wrap">
+            <div id="map" class="smallmap">
+            </div>
+            <div id="strategy-chooser">
+                <p>
+                    Select the desired clustering strategy:
+                </p>
+                <label>
+                    <input type="radio" name="strategy" value="none" id="no-strategy" checked="checked">No strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="cluster" id="cluster-strategy">Simple cluster-strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="attribute-cluster" id="attributive-cluster-strategy">Attributive cluster-strategy
+                </label>
+                <br/>
+                <label>
+                    <input type="radio" name="strategy" value="rule-cluster" id="rulebased-cluster-strategy">Rulebased cluster-strategy
+                </label>
+            </div>
+            <div id="generalinfo">
+            </div>
+            <div id="info">
+            </div>
+        </div>
+        <div id="docs" style="clear: both; padding-top: 10px">
+            <p>
+                The vectorlayer in this example contains random data with an
+                attribute "clazz" that can take the values 1, 2, 3 and 4. The
+                features with clazz = 4 are considered more important than the
+                others.
+            </p>
+            <p>
+                The radiobuttons on the right of the map control the
+                cluster strategy to be applied to the features.
+            </p>
+            <ul>
+                <li>
+                    <strong>No strategy</strong>
+                    means that all features are
+                    rendered, no clustering shall be applied
+                </li>
+                <li>
+                    <strong>Simple cluster-strategy</strong>
+                    applies the cluster
+                    strategy with default options to the layer. You should notice
+                    that many of the important features with clazz = 4 are getting
+                    lost, since clustering happens regardless of feature attributes
+                </li>
+                <li>
+                    <strong>Attributive cluster-strategy</strong>
+                    uses a
+                    customized cluster strategy. This strategy is configured to
+                    cluster features of the same clazz only. You should be able to see all
+                    red points (clazz = 4) even though the data is clustered. A
+                    cluster now contains only features of the same clazz.
+                </li>
+                <li>
+                    <strong>Rulebased cluster-strategy</strong>
+                    uses another
+                    cluster features that follow a certain rule only. In this case only
+                    features with a clazz different from 4 are considered as
+                    candidates for clustering. That means that usually you have fewer
+                    clusters on the map, yet all with clazz = 4 are easily
+                    distinguishable
+                </li>
+            </ul>
+            <p>
+                Hover over the features to get a short infomation about the
+                feature or cluster of features.
+            </p>
+        </div>
+        <p>
+            View the <a href="strategy-cluster-extended.js" target="_blank">strategy-cluster-extended.js</a>
+            source to see how this is done.
+        </p>
+        <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+        <script type="text/javascript" src="strategy-cluster-extended.js"></script>
+    </body>
+</html>
Copied: sandbox/tschaub/donut/examples/strategy-cluster-extended.js (from rev 10818, trunk/openlayers/examples/strategy-cluster-extended.js)
--- sandbox/tschaub/donut/examples/strategy-cluster-extended.js	                        (rev 0)
+++ sandbox/tschaub/donut/examples/strategy-cluster-extended.js	2010-10-11 22:13:13 UTC (rev 10819)
@@ -0,0 +1,247 @@
+ * Class: OpenLayers.Strategy.AttributeCluster
+ * Strategy for vector feature clustering based on feature attributes.
+ * Inherits from:
+ *  - <OpenLayers.Strategy.Cluster>
+OpenLayers.Strategy.AttributeCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
+     * the attribute to use for comparison
+    attribute: null,
+     * Method: shouldCluster
+     * Determine whether to include a feature in a given cluster.
+     * Parameters:
+     * cluster - {<OpenLayers.Feature.Vector>} A cluster.
+     * feature - {<OpenLayers.Feature.Vector>} A feature.
+     * Returns:
+     * {Boolean} The feature should be included in the cluster.
+    shouldCluster: function(cluster, feature) {
+        var cc_attrval = cluster.cluster[0].attributes[this.attribute];
+        var fc_attrval = feature.attributes[this.attribute];
+        var superProto = OpenLayers.Strategy.Cluster.prototype;
+        return cc_attrval === fc_attrval &&
+               superProto.shouldCluster.apply(this, arguments);
+    CLASS_NAME: "OpenLayers.Strategy.AttributeCluster"
+ * Class: OpenLayers.Strategy.RuleCluster
+ * Strategy for vector feature clustering according to a given rule.
+ * Inherits from:
+OpenLayers.Strategy.RuleCluster = OpenLayers.Class(OpenLayers.Strategy.Cluster, {
+     * the rule to use for comparison
+    rule: null,
+     * Parameters:
+     * Returns:
+        return this.rule.evaluate(cluster.cluster[0]) &&
+               this.rule.evaluate(feature) &&
+    CLASS_NAME: "OpenLayers.Strategy.RuleCluster"
+// global variables
+var map, vectorlayer, features, stylemap, select;
+// wrap the instanciation code in an anonymous function that gets executed
+// immeadeately
+(function(){
+    // The function that gets called on feature selection: shows information
+    // about the feature/cluser in a div on the page
+	var showInformation = function(evt){
+        var feature = evt.feature;
+		var info = 'Last hovered feature:<br>';
+		if (feature.cluster) {
+			info += '&nbsp;&nbsp;Cluster of ' + feature.attributes.count + ' features:';
+			var clazzes = {
+				'1': 0,
+				'2': 0,
+				'3': 0,
+				'4': 0
+			for (var i = 0; i < feature.attributes.count; i++) {
+				var feat = feature.cluster[i];
+				clazzes[feat.attributes.clazz]++;
+			for (var j=1; j<=4; j++) {
+				var plural_s = (clazzes[j] !== 1) ? 's' : '';
+				info += '<br>&nbsp;&nbsp;&nbsp;&nbsp;&bull;&nbsp;clazz ' + j + ': ' + clazzes[j] + ' feature' + plural_s;
+		} else {
+			info += '&nbsp;&nbsp;Single feature of clazz = ' + feature.attributes.clazz;
+		$('info').innerHTML = info;
+	// The function that gets called on feature selection. Shows information
+    // about the number of "points" on the map.
+	var updateGeneralInformation = function() {
+		var info = 'Currently ' + vectorlayer.features.length + ' points are shown on the map.';
+		$('generalinfo').innerHTML = info;
+	// instanciate the map
+	map = new OpenLayers.Map("map");
+	// background WMS
+    var ol_wms = new OpenLayers.Layer.WMS("OpenLayers WMS", "http://vmap0.tiles.osgeo.org/wms/vmap0", {
+        layers: "basic"
+	// context to style the vectorlayer
+    var context = {
+        getColor: function(feature){
+            var color = '#aaaaaa';
+			if (feature.attributes.clazz && feature.attributes.clazz === 4) {
+				color = '#ee0000';
+			} else if(feature.cluster) {
+				var onlyFour = true;
+				for (var i = 0; i < feature.cluster.length; i++) {
+					if (onlyFour && feature.cluster[i].attributes.clazz !== 4) {
+						onlyFour = false;
+				if (onlyFour === true) {
+			return color;
+    // style the vectorlayer
+    stylemap = new OpenLayers.StyleMap({
+        'default': new OpenLayers.Style({
+            pointRadius: 5,
+            fillColor: "${getColor}",
+            fillOpacity: 0.7,
+            strokeColor: "#666666",
+            strokeWidth: 1,
+            strokeOpacity: 1,
+			graphicZIndex: 1
+            context: context
+		'select' : new OpenLayers.Style({
+            pointRadius: 5,
+            fillColor: "#ffff00",
+            fillOpacity: 1,
+            strokeWidth: 1,
+            strokeOpacity: 1,
+			graphicZIndex: 2
+    // the vectorlayer
+    vectorlayer = new OpenLayers.Layer.Vector('Vectorlayer', {styleMap: stylemap, strategies: []});
+	// the select control
+	select = new OpenLayers.Control.SelectFeature(
+        vectorlayer, {hover: true}
+    map.addControl(select);
+    select.activate();
+    vectorlayer.events.on({"featureselected": showInformation});
+    map.addLayers([ol_wms, vectorlayer]);
+    map.addControl(new OpenLayers.Control.LayerSwitcher());
+    map.zoomToMaxExtent();
+    features = [];
+    // adding lots of features:
+    for (var i = 0; i < 700; i++) {
+        var r1 = Math.random();
+        var r2 = Math.random();
+        var r3 = Math.random();
+        var r4 = Math.random();
+        var px = r1 * 180 * ((r2 < 0.5) ? -1 : 1);
+        var py = r3 * 90 * ((r4 < 0.5) ? -1 : 1);
+        var p = new OpenLayers.Geometry.Point(px, py);
+        var clazz = (i % 10 === 0) ? 4 : Math.ceil(r4 * 3);
+        var f = new OpenLayers.Feature.Vector(p, {clazz: clazz});
+        features.push(f);
+    vectorlayer.addFeatures(features);
+    updateGeneralInformation();
+    // the behaviour and methods for the radioboxes
+    var changeStrategy = function() {
+        var strategies = [];
+        // this is the checkbox
+        switch(this.value) {
+            case 'cluster':
+                // standard clustering
+				strategies.push(new OpenLayers.Strategy.Cluster());
+                break;
+            case 'attribute-cluster':
+                // use the custom class: only cluster features of the same clazz
+				strategies.push(new OpenLayers.Strategy.AttributeCluster({
+                    attribute:'clazz'
+                break;
+            case 'rule-cluster':
+                // use the custom class: only cluster features that have a
+				// clazz smaller than 4
+				strategies.push(new OpenLayers.Strategy.RuleCluster({
+                    rule: new OpenLayers.Rule({
+                        filter: new OpenLayers.Filter.Comparison({
+                            type: OpenLayers.Filter.Comparison.LESS_THAN,
+                            property: "clazz",
+                            value: 4
+                break;
+		// remove layer and control
+        map.removeLayer(vectorlayer);
+		map.removeControl(select);
+		// rebuild layer
+        vectorlayer = new OpenLayers.Layer.Vector('Vectorlayer', {styleMap: stylemap, strategies: strategies});
+        map.addLayer( vectorlayer );
+        // rebuild select control
+		// update meta information
+	// bind the behviour to the radios
+    var inputs = document.getElementsByTagName('input');
+    for( var cnt = 0; cnt < inputs.length; cnt++) {
+      var input = inputs[cnt];
+      if (input.name === 'strategy') {
+         input.onclick = changeStrategy;
Modified: sandbox/tschaub/donut/examples/vector-features.html
--- sandbox/tschaub/donut/examples/vector-features.html	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/examples/vector-features.html	2010-10-11 22:13:13 UTC (rev 10819)
@@ -1,3 +1,4 @@
+<!DOCTYPE html>
 <html xmlns="http://www.w3.org/1999/xhtml">
   <head>
     <title>OpenLayers: Vector Features</title>
Modified: sandbox/tschaub/donut/lib/OpenLayers/Control.js
--- sandbox/tschaub/donut/lib/OpenLayers/Control.js	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/lib/OpenLayers/Control.js	2010-10-11 22:13:13 UTC (rev 10819)
@@ -343,7 +343,10 @@
                     this.displayClass.replace(/ /g, "") + "Active"
-            this.events.triggerEvent("deactivate");
+            // deal with the case where the control is destroyed
+            if(this.events) {
+                this.events.triggerEvent("deactivate");
             return true;
         return false;
Modified: sandbox/tschaub/donut/lib/OpenLayers/Layer/Google/v3.js
--- sandbox/tschaub/donut/lib/OpenLayers/Layer/Google/v3.js	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/lib/OpenLayers/Layer/Google/v3.js	2010-10-11 22:13:13 UTC (rev 10819)
@@ -90,7 +90,8 @@
                 keyboardShortcuts: false,
                 draggable: false,
                 disableDoubleClickZoom: true,
-                scrollwheel: false
+                scrollwheel: false,
+                streetViewControl: false
             // cache elements for use by any other google layers added to
Modified: sandbox/tschaub/donut/lib/OpenLayers/Layer/TileCache.js
--- sandbox/tschaub/donut/lib/OpenLayers/Layer/TileCache.js	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/lib/OpenLayers/Layer/TileCache.js	2010-10-11 22:13:13 UTC (rev 10819)
@@ -6,6 +6,7 @@
  * @requires OpenLayers/Layer/Grid.js
+ * @requires OpenLayers/Tile/Image.js
Modified: sandbox/tschaub/donut/release-license.txt
--- sandbox/tschaub/donut/release-license.txt	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/release-license.txt	2010-10-11 22:13:13 UTC (rev 10819)
@@ -1,3 +1,3 @@
 This license information is now available at:
 http://svn.openlayers.org/trunk/openlayers/license.txt
Modified: sandbox/tschaub/donut/tests/Control/Panel.html
--- sandbox/tschaub/donut/tests/Control/Panel.html	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/tests/Control/Panel.html	2010-10-11 22:13:13 UTC (rev 10819)
@@ -243,7 +243,7 @@
         panel.activate();
         var div = panel.div;
         panel.destroy();
-        t.ok(panel.div.innerHTML == "",
+        t.eq(panel.div, null,
             "Panel is not displayed after destroy without any active control");
         map.destroy();
Modified: sandbox/tschaub/donut/tools/mergejs.py
--- sandbox/tschaub/donut/tools/mergejs.py	2010-10-11 18:40:55 UTC (rev 10818)
+++ sandbox/tschaub/donut/tools/mergejs.py	2010-10-11 22:13:13 UTC (rev 10819)
@@ -94,6 +94,7 @@
         [exclude]
         3rd/logger.js
+        exclude/this/dir
     All headings are required.
@@ -122,6 +123,20 @@
         self.include =  lines[lines.index("[include]") + 1:lines.index("[exclude]")]
         self.exclude =  lines[lines.index("[exclude]") + 1:]
+def undesired(filepath, excludes):
+    # exclude file if listed
+    exclude = filepath in excludes
+    if not exclude:
+        # check if directory is listed
+        for excludepath in excludes:
+            if not excludepath.endswith("/"):
+                excludepath += "/"
+            if filepath.startswith(excludepath):
+                exclude = True
+                break
+    return exclude
 def run (sourceDirectory, outputFilename = None, configFile = None):
     cfg = None
     if configFile:
@@ -138,7 +153,7 @@
                 if cfg and cfg.include:
                     if filepath in cfg.include or filepath in cfg.forceFirst:
                         allFiles.append(filepath)
-                elif (not cfg) or (filepath not in cfg.exclude):
+                elif (not cfg) or (not undesired(filepath, cfg.exclude)):
     ## Header inserted at the start of each file in the output
More information about the Commits mailing list
