[OpenLayers-Commits] r10820 - in sandbox/tschaub/donut: examples
lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Mon Oct 11 18:37:37 EDT 2010
Author: tschaub
Date: 2010-10-11 15:37:36 -0700 (Mon, 11 Oct 2010)
New Revision: 10820
sandbox/tschaub/donut/examples/donut.html
sandbox/tschaub/donut/examples/donut.js
sandbox/tschaub/donut/lib/OpenLayers/Handler/Polygon.js
Re-trigger sketchcomplete so other listeners can be notified when interior ring drawing completes.
Modified: sandbox/tschaub/donut/examples/donut.html
--- sandbox/tschaub/donut/examples/donut.html 2010-10-11 22:13:13 UTC (rev 10819)
+++ sandbox/tschaub/donut/examples/donut.html 2010-10-11 22:37:36 UTC (rev 10820)
@@ -12,6 +12,10 @@
font-size: 9px;
bottom: 2px;
+ #output {
+ margin: 1em;
+ font-size: 0.9em;
</style>
</head>
<body>
@@ -35,7 +39,7 @@
<label for="polygonToggle">draw polygon</label>
</li>
</ul>
+ <div id="output"></div>
<div id="docs">
<p>
To digitize holes in polygons, hold down the <code>Alt</code>
Modified: sandbox/tschaub/donut/examples/donut.js
--- sandbox/tschaub/donut/examples/donut.js 2010-10-11 22:13:13 UTC (rev 10819)
+++ sandbox/tschaub/donut/examples/donut.js 2010-10-11 22:37:36 UTC (rev 10820)
@@ -15,6 +15,17 @@
map.addControl(draw);
+// optionally listen for sketch events on the layer
+map.layers[1].events.on({
+ sketchmodified: function(event) {
+ document.getElementById("output").innerHTML = "modified " + event.feature.id;
+ sketchcomplete: function(event) {
+ document.getElementById("output").innerHTML = "completed " + event.feature.id;
+// add behavior to UI elements
function toggleControl(element) {
if (element.value === "polygon" && element.checked) {
draw.activate();
@@ -22,5 +33,4 @@
draw.deactivate();
document.getElementById("noneToggle").checked = true;
\ No newline at end of file
Modified: sandbox/tschaub/donut/lib/OpenLayers/Handler/Polygon.js
--- sandbox/tschaub/donut/lib/OpenLayers/Handler/Polygon.js 2010-10-11 22:13:13 UTC (rev 10819)
+++ sandbox/tschaub/donut/lib/OpenLayers/Handler/Polygon.js 2010-10-11 22:37:36 UTC (rev 10820)
@@ -190,7 +190,7 @@
cancel: function() {
if (this.drawingHole) {
this.polygon.geometry.removeComponent(this.line.geometry);
- this.restoreFeature();
+ this.restoreFeature(true);
return OpenLayers.Handler.Path.prototype.cancel.apply(this, arguments);
@@ -198,8 +198,12 @@
* Method: restoreFeature
* Move the feature from the sketch layer to the target layer.
+ * Properties:
+ * cancel - {Boolean} Cancel drawing. If falsey, the "sketchcomplete" event
+ * will be fired.
- restoreFeature: function() {
+ restoreFeature: function(cancel) {
this.control.layer.events.unregister(
"sketchcomplete", this, this.finalizeInteriorRing
@@ -208,7 +212,19 @@
this.layer.removeFeatures([this.polygon], {silent: true});
this.control.layer.addFeatures([this.polygon], {silent: true});
- this.drawingHole = false;
+ this.drawingHole = false;
+ if (!cancel) {
+ // Re-trigger "sketchcomplete" so other listeners can do their
+ // business. While this is somewhat sloppy (if a listener is
+ // registered with registerPriority - not common - between the start
+ // and end of a single ring drawing - very uncommon - it will be
+ // called twice).
+ // TODO: In 3.0, collapse sketch handlers into geometry specific
+ // drawing controls.
+ this.control.layer.events.triggerEvent(
+ "sketchcomplete", {feature : this.polygon}
More information about the Commits
