[OpenLayers-Commits] r10857 - in sandbox/sonxurxo/wfs-t: examples lib/OpenLayers/Control theme/default/img
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Oct 22 07:11:59 EDT 2010
Author: sonxurxo
Date: 2010-10-22 04:11:59 -0700 (Fri, 22 Oct 2010)
New Revision: 10857
Added:
   sandbox/sonxurxo/wfs-t/lib/OpenLayers/Control/LoadingPanel.js
   sandbox/sonxurxo/wfs-t/theme/default/img/loading.gif
   sandbox/sonxurxo/wfs-t/examples/wfs-transaction-optimized.html
Adding forgotten files
Modified: sandbox/sonxurxo/wfs-t/examples/wfs-transaction-optimized.html
--- sandbox/sonxurxo/wfs-t/examples/wfs-transaction-optimized.html	2010-10-22 11:09:16 UTC (rev 10856)
+++ sandbox/sonxurxo/wfs-t/examples/wfs-transaction-optimized.html	2010-10-22 11:11:59 UTC (rev 10857)
@@ -73,8 +73,8 @@
         <script>
             var map;
-            OpenLayers.ProxyHost= "/cgi-bin/proxy.cgi?url=";
-            //OpenLayers.ProxyHost = "proxy.cgi?url=";
+            //OpenLayers.ProxyHost= "/cgi-bin/proxy.cgi?url=";
+            OpenLayers.ProxyHost = "proxy.cgi?url=";
             function init() {
                 map = new OpenLayers.Map("the_map", {
Added: sandbox/sonxurxo/wfs-t/lib/OpenLayers/Control/LoadingPanel.js
--- sandbox/sonxurxo/wfs-t/lib/OpenLayers/Control/LoadingPanel.js	                        (rev 0)
+++ sandbox/sonxurxo/wfs-t/lib/OpenLayers/Control/LoadingPanel.js	2010-10-22 11:11:59 UTC (rev 10857)
@@ -0,0 +1,220 @@
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Control.js
+ * Class: OpenLayers.Control.LoadingPanel
+ * In some applications, it makes sense to alert the user that something is
+ * happening while tiles are loading. This control displays a div across the
+ * map when this is going on.
+ * Inherits from:
+ *  - <OpenLayers.Control>
+OpenLayers.Control.LoadingPanel = OpenLayers.Class(OpenLayers.Control, {
+     * Property: counter
+     * {Integer} A counter for the number of layers loading
+    counter: 0,
+     * Property: maximized
+     * {Boolean} A boolean indicating whether or not the control is maximized
+    maximized: false,
+     * Property: visible
+     * {Boolean} A boolean indicating whether or not the control is visible
+    visible: true,
+     * Constructor: OpenLayers.Control.LoadingPanel
+     * Display a panel across the map that says 'loading'.
+     * Parameters:
+     * options - {Object} additional options.
+    initialize: function(options) {
+         OpenLayers.Control.prototype.initialize.apply(this, [options]);
+     * Function: setVisible
+     * Set the visibility of this control
+     * Parameters:
+     * visible - {Boolean} should the control be visible or not?
+    setVisible: function(visible) {
+        this.visible = visible;
+        if (visible) {
+            OpenLayers.Element.show(this.div);
+        } else {
+            OpenLayers.Element.hide(this.div);
+     * Function: getVisible
+     * Get the visibility of this control
+     * Returns:
+     * {Boolean} the current visibility of this control
+    getVisible: function() {
+        return this.visible;
+     * APIMethod: hide
+     * Hide the loading panel control
+    hide: function() {
+        this.setVisible(false);
+     * APIMethod: show
+     * Show the loading panel control
+    show: function() {
+        this.setVisible(true);
+     * APIMethod: toggle
+     * Toggle the visibility of the loading panel control
+    toggle: function() {
+        this.setVisible(!this.getVisible());
+     * Method: addLayer
+     * Attach event handlers when new layer gets added to the map
+     * Parameters:
+     * evt - {Event}
+    addLayer: function(evt) {
+        if (evt.layer) {
+            evt.layer.events.register('loadstart', this, this.increaseCounter);
+            evt.layer.events.register('loadend', this, this.decreaseCounter);
+     * Method: setMap
+     * Set the map property for the control and all handlers.
+     * Parameters:
+     * map - {<OpenLayers.Map>} The control's map.
+    setMap: function(map) {
+        OpenLayers.Control.prototype.setMap.apply(this, arguments);
+        this.map.events.register('preaddlayer', this, this.addLayer);
+        for (var i = 0; i < this.map.layers.length; i++) {
+            var layer = this.map.layers[i];
+            layer.events.register('loadstart', this, this.increaseCounter);
+            layer.events.register('loadend', this, this.decreaseCounter);
+     * Method: increaseCounter
+     * Increase the counter and show control
+    increaseCounter: function() {
+        this.counter++;
+        if (this.counter > 0) {
+            if (!this.maximized && this.visible) {
+                this.maximizeControl();
+     * Method: decreaseCounter
+     * Decrease the counter and hide the control if finished
+    decreaseCounter: function() {
+            this.counter--;
+        if (this.counter == 0) {
+            if (this.maximized && this.visible) {
+                this.minimizeControl();
+     * Method: draw
+     * Create and return the element to be splashed over the map.
+    draw: function () {
+        OpenLayers.Control.prototype.draw.apply(this, arguments);
+        return this.div;
+     * Method: minimizeControl
+     * Set the display properties of the control to make it disappear.
+     * Parameters:
+     * evt - {Event}
+    minimizeControl: function(evt) {
+        this.div.style.display = "none";
+        this.maximized = false;
+        if (evt != null) {
+            OpenLayers.Event.stop(evt);
+     * Method: maximizeControl
+     * Make the control visible.
+     * Parameters:
+     * evt - {Event}
+    maximizeControl: function(evt) {
+        this.div.style.display = "block";
+        this.maximized = true;
+     * Method: destroy
+     * Destroy control.
+    destroy: function() {
+        if (this.map) {
+            this.map.events.unregister('preaddlayer', this, this.addLayer);
+            if (this.map.layers) {
+                    layer.events.unregister('loadstart', this,
+                        this.increaseCounter);
+                    layer.events.unregister('loadend', this,
+                        this.decreaseCounter);
+        OpenLayers.Control.prototype.destroy.apply(this, arguments);
+    CLASS_NAME: "OpenLayers.Control.LoadingPanel"
Added: sandbox/sonxurxo/wfs-t/theme/default/img/loading.gif
(Binary files differ)
Property changes on: sandbox/sonxurxo/wfs-t/theme/default/img/loading.gif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
More information about the Commits mailing list
