[OpenLayers-Commits] r10858 -
trunk/openlayers/lib/OpenLayers/BaseTypes
commits-20090109 at openlayers.org
Fri Oct 22 16:34:22 EDT 2010
Author: ahocevar
Date: 2010-10-22 13:34:21 -0700 (Fri, 22 Oct 2010)
New Revision: 10858
trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
Remove overhead from OpenLayers.Class, using erilem's fancy OpenLayers.inherit function. r=erilem (closes #2899)
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js 2010-10-22 11:11:59 UTC (rev 10857)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js 2010-10-22 20:34:21 UTC (rev 10858)
@@ -23,49 +23,22 @@
OpenLayers.Class = function() {
- var Class = function() {
- * This following condition can be removed at 3.0 - this is only for
- * backwards compatibility while the Class.inherit method is still
- * in use. So at 3.0, the following three lines would be replaced with
- * simply:
- * this.initialize.apply(this, arguments);
- if (arguments && arguments[0] != OpenLayers.Class.isPrototype) {
- this.initialize.apply(this, arguments);
- var extended = {};
- var parent, initialize, Type;
- for(var i=0, len=arguments.length; i<len; ++i) {
- Type = arguments[i];
- if(typeof Type == "function") {
- // make the class passed as the first argument the superclass
- if(i == 0 && len > 1) {
- initialize = Type.prototype.initialize;
- // replace the initialize method with an empty function,
- // because we do not want to create a real instance here
- Type.prototype.initialize = function() {};
- // the line below makes sure that the new class has a
- // superclass
- extended = new Type();
- // restore the original initialize method
- if(initialize === undefined) {
- delete Type.prototype.initialize;
- } else {
- Type.prototype.initialize = initialize;
- // get the prototype of the superclass
- parent = Type.prototype;
- } else {
- // in this case we're extending with the prototype
- parent = Type;
- OpenLayers.Util.extend(extended, parent);
+ var len = arguments.length;
+ var P = arguments[0];
+ var F = arguments[len-1];
+ var C = typeof F.initialize == "function" ?
+ F.initialize :
+ function(){ P.apply(this, arguments); };
+ if (len > 1) {
+ var newArgs = [C, P].concat(
+ Array.prototype.slice.call(arguments).slice(1, len-1), F);
+ OpenLayers.inherit.apply(null, newArgs);
+ } else {
+ C.prototype = F;
- Class.prototype = extended;
- return Class;
+ return C;
@@ -90,7 +63,6 @@
* APIFunction: inherit
* *Deprecated*. Old method to inherit from one or more OpenLayers style
@@ -102,15 +74,35 @@
* Returns:
* An object prototype
-OpenLayers.Class.inherit = function () {
- var superClass = arguments[0];
- var proto = new superClass(OpenLayers.Class.isPrototype);
- for (var i=1, len=arguments.length; i<len; i++) {
- if (typeof arguments[i] == "function") {
- var mixin = arguments[i];
- arguments[i] = new mixin(OpenLayers.Class.isPrototype);
- OpenLayers.Util.extend(proto, arguments[i]);
- return proto;
+OpenLayers.Class.inherit = function (P) {
+ var C = function() {
+ P.call(this);
+ var newArgs = [C].concat(Array.prototype.slice.call(arguments));
+ return C.prototype;
+ * Function: OpenLayers.inherit
+ * Parameters:
+ * C - {Object} the class that inherits
+ * P - {Object} the superclass to inherit from
+ * In addition to the mandatory C and P parameters, an arbitrary number of
+ * objects can be passed, which will extend C.
+OpenLayers.inherit = function(C, P) {
+ var F = function() {};
+ F.prototype = P.prototype;
+ C.prototype = new F;
+ var i, l, o;
+ for(i=2, l=arguments.length; i<l; i++) {
+ o = arguments[i];
+ if(typeof o === "function") {
+ o = o.prototype;
+ OpenLayers.Util.extend(C.prototype, o);
More information about the Commits
