[OpenLayers-Commits] r12202 - in trunk/openlayers: apidoc_config doc_config lib lib/OpenLayers lib/OpenLayers/Format tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Aug 3 10:32:11 EDT 2011
Author: fredj
Date: 2011-08-03 07:32:10 -0700 (Wed, 03 Aug 2011)
New Revision: 12202
   trunk/openlayers/apidoc_config/Menu.txt
   trunk/openlayers/doc_config/Menu.txt
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/lib/OpenLayers/BaseTypes.js
   trunk/openlayers/lib/OpenLayers/Format/KML.js
   trunk/openlayers/tests/BaseTypes.html
   trunk/openlayers/tests/list-tests.html
move the OpenLayers.Date.* from BaseTypes.js to BaseTypes/Date.js. r=erilem (closes #3440)
Modified: trunk/openlayers/apidoc_config/Menu.txt
--- trunk/openlayers/apidoc_config/Menu.txt	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/apidoc_config/Menu.txt	2011-08-03 14:32:10 UTC (rev 12202)
@@ -55,6 +55,7 @@
       File: Base Types  (no auto-title, OpenLayers/BaseTypes.js)
       File: Bounds  (no auto-title, OpenLayers/BaseTypes/Bounds.js)
       File: Class  (no auto-title, OpenLayers/BaseTypes/Class.js)
+      File: Date  (no auto-title, OpenLayers/BaseTypes/Date.js)
       File: Element  (no auto-title, OpenLayers/BaseTypes/Element.js)
       File: LonLat  (no auto-title, OpenLayers/BaseTypes/LonLat.js)
       File: Pixel  (no auto-title, OpenLayers/BaseTypes/Pixel.js)
Modified: trunk/openlayers/doc_config/Menu.txt
--- trunk/openlayers/doc_config/Menu.txt	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/doc_config/Menu.txt	2011-08-03 14:32:10 UTC (rev 12202)
@@ -55,6 +55,7 @@
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-08-03 14:32:10 UTC (rev 12202)
@@ -564,118 +564,3 @@
- * Namespace: OpenLayers.Date
- * Contains implementations of Date.parse and date.toISOString that match the
- *     ECMAScript 5 specification for parsing RFC 3339 dates.
- *     http://tools.ietf.org/html/rfc3339
-OpenLayers.Date = {
-     * APIMethod: toISOString
-     * Generates a string representing a date.  The format of the string follows
-     *     the profile of ISO 8601 for date and time on the Internet (see
-     *     http://tools.ietf.org/html/rfc3339).  If the toISOString method is
-     *     available on the Date prototype, that is used.  The toISOString
-     *     method for Date instances is defined in ECMA-262.
-     * Parameters:
-     * date - {Date} A date object.
-     * Returns:
-     * {String} A string representing the date (e.g.
-     *     "2010-08-07T16:58:23.123Z").  If the date does not have a valid time
-     *     (i.e. isNaN(date.getTime())) this method returns the string "Invalid
-     *     Date".  The ECMA standard says the toISOString method should throw
-     *     RangeError in this case, but Firefox returns a string instead.  For
-     *     best results, use isNaN(date.getTime()) to determine date validity
-     *     before generating date strings.
-    toISOString: (function() {
-        if ("toISOString" in Date.prototype) {
-            return function(date) {
-                return date.toISOString();
-        } else {
-            function pad(num, len) {
-                var str = num + "";
-                while (str.length < len) {
-                    str = "0" + str;
-                return str;
-                var str;
-                if (isNaN(date.getTime())) {
-                    // ECMA-262 says throw RangeError, Firefox returns
-                    // "Invalid Date"
-                    str = "Invalid Date";
-                } else {
-                    str =
-                        date.getUTCFullYear() + "-" +
-                        pad(date.getUTCMonth() + 1, 2) + "-" +
-                        pad(date.getUTCDate(), 2) + "T" +
-                        pad(date.getUTCHours(), 2) + ":" +
-                        pad(date.getUTCMinutes(), 2) + ":" +
-                        pad(date.getUTCSeconds(), 2) + "." +
-                        pad(date.getUTCMilliseconds(), 3) + "Z";
-                return str;
-     * APIMethod: parse
-     * Generate a date object from a string.  The format for the string follows
-     *     http://tools.ietf.org/html/rfc3339).  We don't call the native
-     *     Date.parse because of inconsistency between implmentations.  In
-     *     Chrome, calling Date.parse with a string that doesn't contain any
-     *     indication of the timezone (e.g. "2011"), the date is interpreted
-     *     in local time.  On Firefox, the assumption is UTC.
-     * Parameters:
-     * str - {String} A string representing the date (e.g.
-     *     "2010", "2010-08", "2010-08-07", "2010-08-07T16:58:23.123Z",
-     *     "2010-08-07T11:58:23.123-06").
-     * Returns:
-     * {Date} A date object.  If the string could not be parsed, an invalid
-     *     date is returned (i.e. isNaN(date.getTime())).
-    parse: function(str) {
-        var date;
-        var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-        if (match && (match[1] || match[7])) { // must have at least year or time
-            var year = parseInt(match[1], 10) || 0;
-            var month = (parseInt(match[2], 10) - 1) || 0;
-            var day = parseInt(match[3], 10) || 1;
-            date = new Date(Date.UTC(year, month, day));
-            // optional time
-            var type = match[7];
-            if (type) {
-                var hours = parseInt(match[4], 10);
-                var minutes = parseInt(match[5], 10);
-                var secFrac = parseFloat(match[6]);
-                var seconds = secFrac | 0;
-                var milliseconds = Math.round(1000 * (secFrac - seconds));
-                date.setUTCHours(hours, minutes, seconds, milliseconds);
-                // check offset
-                if (type !== "Z") {
-                    var hoursOffset = parseInt(type, 10);
-                    var minutesOffset = parseInt(match[8], 10) || 0;
-                    var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
-                    date = new Date(date.getTime() + offset);
-        } else {
-            date = new Date("invalid");
-        return date;
Modified: trunk/openlayers/lib/OpenLayers/Format/KML.js
--- trunk/openlayers/lib/OpenLayers/Format/KML.js	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/lib/OpenLayers/Format/KML.js	2011-08-03 14:32:10 UTC (rev 12202)
@@ -4,6 +4,7 @@
  * full text of the license. */
+ * @requires OpenLayers/BaseTypes/Date.js
  * @requires OpenLayers/Format/XML.js
  * @requires OpenLayers/Feature/Vector.js
  * @requires OpenLayers/Geometry/Point.js
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/lib/OpenLayers.js	2011-08-03 14:32:10 UTC (rev 12202)
@@ -99,6 +99,7 @@
                 "OpenLayers/Util.js",
                 "OpenLayers/BaseTypes.js",
                 "OpenLayers/BaseTypes/Bounds.js",
+                "OpenLayers/BaseTypes/Date.js",
                 "OpenLayers/BaseTypes/Element.js",
                 "OpenLayers/BaseTypes/LonLat.js",
                 "OpenLayers/BaseTypes/Pixel.js",
Modified: trunk/openlayers/tests/BaseTypes.html
--- trunk/openlayers/tests/BaseTypes.html	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/tests/BaseTypes.html	2011-08-03 14:32:10 UTC (rev 12202)
@@ -364,160 +364,6 @@
-    function test_Date_toISOString(t) {
-        t.plan(3);
-        var date, str;
-        // check valid date
-        date = new Date(Date.UTC(2010, 10, 27, 18, 19, 15, 123));
-        str = OpenLayers.Date.toISOString(date);
-        t.eq(str, "2010-11-27T18:19:15.123Z", "valid date");
-        // check zero padding
-        date = new Date(Date.UTC(2010, 7, 7, 18, 9, 5, 12));
-        t.eq(str, "2010-08-07T18:09:05.012Z", "zero padding");
-        // check invalid date
-        date = new Date("foo");
-        t.eq(str, "Invalid Date", "invalid date");
-    function test_Date_parse(t) {
-        t.plan(93);
-        var cases = {
-            "2000": {
-                year: 2000,
-                month: 0,
-                date: 1
-            "2005-10": {
-                year: 2005,
-                month: 9,
-                date: 1
-            "1971-07-23": {
-                year: 1971,
-                month: 6,
-                date: 23
-            "1801-11-20T04:30:15Z": {
-                year: 1801,
-                month: 10,
-                date: 20,
-                hour: 4,
-                minutes: 30,
-                seconds: 15
-            "1989-06-15T18:30:15.91Z": {
-                year: 1989,
-                month: 5,
-                date: 15,
-                hour: 18,
-                minutes: 30,
-                seconds: 15,
-                milliseconds: 910
-            "1989-06-15T18:30:15.091Z": {
-                year: 1989,
-                month: 5,
-                date: 15,
-                hour: 18,
-                minutes: 30,
-                seconds: 15,
-                milliseconds: 91
-            "1989-06-15T13:30:15.091-05": {
-                year: 1989,
-                month: 5,
-                date: 15,
-                hour: 18,
-                minutes: 30,
-                seconds: 15,
-                milliseconds: 91
-            "2010-08-06T15:21:25-06": { // MDT
-                year: 2010,
-                month: 7,
-                date: 6,
-                hour: 21,
-                minutes: 21,
-                seconds: 25
-            "2010-08-07T06:21:25+9": { // JSP
-                year: 2010,
-                month: 7,
-                date: 6,
-                hour: 21,
-                minutes: 21,
-                seconds: 25
-            "2010-08-07T02:51:25+05:30": { // IST
-                year: 2010,
-                month: 7,
-                date: 6,
-                hour: 21,
-                minutes: 21,
-                seconds: 25
-            "T21:51:25Z": {
-                hour: 21,
-                minutes: 51,
-                seconds: 25
-            "T02:51:25+05:30": { // IST
-                hour: 21,
-                minutes: 21,
-                seconds: 25
-            "T2:51:25.1234-7": { // lenient
-                hour: 9,
-                minutes: 51,
-                seconds: 25,
-                milliseconds: 123
-        var o, got, exp;
-        for (var str in cases) {
-            o = cases[str];
-            got = OpenLayers.Date.parse(str);
-            exp = new Date(Date.UTC(o.year || 0, o.month || 0, o.date || 1, o.hour || 0, o.minutes || 0, o.seconds || 0, o.milliseconds || 0));
-            if ("year" in o) {
-                t.eq(got.getUTCFullYear(), exp.getUTCFullYear(), str + ": correct UTCFullYear");
-                t.eq(got.getUTCMonth(), exp.getUTCMonth(), str + ": correct UTCMonth");
-                t.eq(got.getUTCDate(), exp.getUTCDate(), str + ": correct UTCDate");
-            } else {
-                t.ok(true, str + ": ECMA doesn't specify how years are handled in time only strings");
-                t.ok(true, str + ": ECMA doesn't specify how months are handled in time only strings");
-                t.ok(true, str + ": ECMA doesn't specify how days are handled in time only strings");
-            if ("hour" in o) {
-                t.eq(got.getUTCHours(), exp.getUTCHours(), str + ": correct UTCHours");
-                t.eq(got.getUTCMinutes(), exp.getUTCMinutes(), str + ": correct UTCMinutes");
-                t.eq(got.getUTCSeconds(), exp.getUTCSeconds(), str + ": correct UTCSeconds");
-                t.eq(got.getUTCMilliseconds(), exp.getUTCMilliseconds(), str + ": correct UTCMilliseconds");
-            } else {
-                t.ok(true, str + ": ECMA doesn't specify how hours are handled in date only strings");
-                t.ok(true, str + ": ECMA doesn't specify how minutes are handled in date only strings");
-                t.ok(true, str + ": ECMA doesn't specify how seconds are handled in date only strings");
-                t.ok(true, str + ": ECMA doesn't specify how milliseconds are handled in date only strings");
-        // check invalid date parsing
-        var invalid = OpenLayers.Date.parse("foo");
-        t.ok(invalid instanceof Date, "invalid is a date");
-        t.ok(isNaN(invalid.getTime()), "invalid has no time");
   </script>
 </head>
 <body>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-07-29 14:00:39 UTC (rev 12201)
+++ trunk/openlayers/tests/list-tests.html	2011-08-03 14:32:10 UTC (rev 12202)
@@ -3,6 +3,7 @@
     <li>BaseTypes.html</li>
     <li>BaseTypes/Bounds.html</li>
     <li>BaseTypes/Class.html</li>
+    <li>BaseTypes/Date.html</li>
     <li>BaseTypes/Element.html</li>
     <li>BaseTypes/LonLat.html</li>
     <li>BaseTypes/Pixel.html</li>
More information about the Commits mailing list
