[OpenLayers-Commits] r12203 -
trunk/openlayers/lib/OpenLayers/BaseTypes
commits-20090109 at openlayers.org
Wed Aug 3 10:35:21 EDT 2011
Author: fredj
Date: 2011-08-03 07:35:20 -0700 (Wed, 03 Aug 2011)
New Revision: 12203
Added:
trunk/openlayers/lib/OpenLayers/BaseTypes/Date.js
add missing BaseTypes/Date.js (see #3440)
Added: trunk/openlayers/lib/OpenLayers/BaseTypes/Date.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Date.js (rev 0)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Date.js 2011-08-03 14:35:20 UTC (rev 12203)
@@ -0,0 +1,118 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * Namespace: OpenLayers.Date
+ * Contains implementations of Date.parse and date.toISOString that match the
+ * ECMAScript 5 specification for parsing RFC 3339 dates.
+ * http://tools.ietf.org/html/rfc3339
+OpenLayers.Date = {
+ * APIMethod: toISOString
+ * Generates a string representing a date. The format of the string follows
+ * the profile of ISO 8601 for date and time on the Internet (see
+ * http://tools.ietf.org/html/rfc3339). If the toISOString method is
+ * available on the Date prototype, that is used. The toISOString
+ * method for Date instances is defined in ECMA-262.
+ * Parameters:
+ * date - {Date} A date object.
+ * Returns:
+ * {String} A string representing the date (e.g.
+ * "2010-08-07T16:58:23.123Z"). If the date does not have a valid time
+ * (i.e. isNaN(date.getTime())) this method returns the string "Invalid
+ * Date". The ECMA standard says the toISOString method should throw
+ * RangeError in this case, but Firefox returns a string instead. For
+ * best results, use isNaN(date.getTime()) to determine date validity
+ * before generating date strings.
+ toISOString: (function() {
+ if ("toISOString" in Date.prototype) {
+ return function(date) {
+ return date.toISOString();
+ } else {
+ function pad(num, len) {
+ var str = num + "";
+ while (str.length < len) {
+ str = "0" + str;
+ return str;
+ var str;
+ if (isNaN(date.getTime())) {
+ // ECMA-262 says throw RangeError, Firefox returns
+ // "Invalid Date"
+ str = "Invalid Date";
+ } else {
+ str =
+ date.getUTCFullYear() + "-" +
+ pad(date.getUTCMonth() + 1, 2) + "-" +
+ pad(date.getUTCDate(), 2) + "T" +
+ pad(date.getUTCHours(), 2) + ":" +
+ pad(date.getUTCMinutes(), 2) + ":" +
+ pad(date.getUTCSeconds(), 2) + "." +
+ pad(date.getUTCMilliseconds(), 3) + "Z";
+ return str;
+ * APIMethod: parse
+ * Generate a date object from a string. The format for the string follows
+ * http://tools.ietf.org/html/rfc3339). We don't call the native
+ * Date.parse because of inconsistency between implmentations. In
+ * Chrome, calling Date.parse with a string that doesn't contain any
+ * indication of the timezone (e.g. "2011"), the date is interpreted
+ * in local time. On Firefox, the assumption is UTC.
+ * Parameters:
+ * str - {String} A string representing the date (e.g.
+ * "2010", "2010-08", "2010-08-07", "2010-08-07T16:58:23.123Z",
+ * "2010-08-07T11:58:23.123-06").
+ * Returns:
+ * {Date} A date object. If the string could not be parsed, an invalid
+ * date is returned (i.e. isNaN(date.getTime())).
+ parse: function(str) {
+ var date;
+ var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
+ if (match && (match[1] || match[7])) { // must have at least year or time
+ var year = parseInt(match[1], 10) || 0;
+ var month = (parseInt(match[2], 10) - 1) || 0;
+ var day = parseInt(match[3], 10) || 1;
+ date = new Date(Date.UTC(year, month, day));
+ // optional time
+ var type = match[7];
+ if (type) {
+ var hours = parseInt(match[4], 10);
+ var minutes = parseInt(match[5], 10);
+ var secFrac = parseFloat(match[6]);
+ var seconds = secFrac | 0;
+ var milliseconds = Math.round(1000 * (secFrac - seconds));
+ date.setUTCHours(hours, minutes, seconds, milliseconds);
+ // check offset
+ if (type !== "Z") {
+ var hoursOffset = parseInt(type, 10);
+ var minutesOffset = parseInt(match[8], 10) || 0;
+ var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
+ date = new Date(date.getTime() + offset);
+ } else {
+ date = new Date("invalid");
+ return date;
More information about the Commits
