[OpenLayers-Commits] r12208 - trunk/openlayers/lib/OpenLayers/Lang
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Aug 5 03:58:58 EDT 2011
Author: fredj
Date: 2011-08-05 00:58:57 -0700 (Fri, 05 Aug 2011)
New Revision: 12208
   trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js
   trunk/openlayers/lib/OpenLayers/Lang/br.js
   trunk/openlayers/lib/OpenLayers/Lang/ca.js
   trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js
   trunk/openlayers/lib/OpenLayers/Lang/da-DK.js
   trunk/openlayers/lib/OpenLayers/Lang/de.js
   trunk/openlayers/lib/OpenLayers/Lang/en.js
   trunk/openlayers/lib/OpenLayers/Lang/es.js
   trunk/openlayers/lib/OpenLayers/Lang/fr.js
   trunk/openlayers/lib/OpenLayers/Lang/gl.js
   trunk/openlayers/lib/OpenLayers/Lang/gsw.js
   trunk/openlayers/lib/OpenLayers/Lang/hr.js
   trunk/openlayers/lib/OpenLayers/Lang/hsb.js
   trunk/openlayers/lib/OpenLayers/Lang/hu.js
   trunk/openlayers/lib/OpenLayers/Lang/ia.js
   trunk/openlayers/lib/OpenLayers/Lang/id.js
   trunk/openlayers/lib/OpenLayers/Lang/it.js
   trunk/openlayers/lib/OpenLayers/Lang/ja.js
   trunk/openlayers/lib/OpenLayers/Lang/ksh.js
   trunk/openlayers/lib/OpenLayers/Lang/lt.js
   trunk/openlayers/lib/OpenLayers/Lang/nb.js
   trunk/openlayers/lib/OpenLayers/Lang/nds.js
   trunk/openlayers/lib/OpenLayers/Lang/nl.js
   trunk/openlayers/lib/OpenLayers/Lang/oc.js
   trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js
   trunk/openlayers/lib/OpenLayers/Lang/pt.js
   trunk/openlayers/lib/OpenLayers/Lang/ru.js
   trunk/openlayers/lib/OpenLayers/Lang/sk.js
   trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js
   trunk/openlayers/lib/OpenLayers/Lang/vi.js
   trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js
   trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js
remove 'pagePositionFailed' from Lang/*.js (closes #2247). Non-functional change.
Modified: trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js
--- trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/be-tarask.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "Тып геамэтрыі не падтрымліваецца: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition failed: верагодна элемэнт з ідэнтыфікатарам ${elemId} займае няслушнае месца.",
     'filterEvaluateNotImplemented': "evaluate не рэалізаваны для гэтага тыпу фільтру."
Modified: trunk/openlayers/lib/OpenLayers/Lang/br.js
--- trunk/openlayers/lib/OpenLayers/Lang/br.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/br.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Seurt mentoniezh anskoret : ${geomType}",
-    'pagePositionFailed': "C\'hwitet eo OpenLayers.Util.pagePosition : marteze emañ lec\'hiet fall an elfenn id ${elemId}.",
     'filterEvaluateNotImplemented': "N\'eo ket bet emplementet ar priziañ evit seurt siloù c\'hoazh."
Modified: trunk/openlayers/lib/OpenLayers/Lang/ca.js
--- trunk/openlayers/lib/OpenLayers/Lang/ca.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/ca.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -113,10 +113,6 @@
     'unsupportedGeometryType': "Tipus de geometria no suportada: ${geomType}",
     // console message
-        "OpenLayers.Util.pagePosition ha fallat: l'element amb id ${elemId} pot estar fora de lloc.",
-    // console message
     'filterEvaluateNotImplemented': "evaluate no està implementat per aquest tipus de filtre.",
     // **** end ****
Modified: trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js
--- trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/cs-CZ.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -60,8 +60,6 @@
     'pixelAddError': "Pro přídavnou funkci musíte zadat obě souřadnice x a y.",
-    'unsupportedGeometryType': "Nepodporovaný typ geometrie: ${geomType}",
+    'unsupportedGeometryType': "Nepodporovaný typ geometrie: ${geomType}"
-    'pagePositionFailed': "OpenLayers.Util.pagePosition selhalo: element s  id ${elemId} je asi umístěn chybně."
Modified: trunk/openlayers/lib/OpenLayers/Lang/da-DK.js
--- trunk/openlayers/lib/OpenLayers/Lang/da-DK.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/da-DK.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -108,9 +108,5 @@
     'unsupportedGeometryType': "Geometri typen: ${geomType} er ikke understøttet.",
     // console message
-        "OpenLayers.Util.pagePosition fejlede: elementet med id ${elemId} er måske placeret forkert.",
     'filterEvaluateNotImplemented': "evaluering er ikke implementeret for denne filter type."
Modified: trunk/openlayers/lib/OpenLayers/Lang/de.js
--- trunk/openlayers/lib/OpenLayers/Lang/de.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/de.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -72,8 +72,6 @@
     'unsupportedGeometryType': "Nicht unterstützter Geometrie-Typ: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition fehlgeschlagen: Element mit Id ${elemId} möglicherweise falsch platziert.",
     'filterEvaluateNotImplemented': "„evaluate“ ist für diesen Filter-Typ nicht implementiert."
Modified: trunk/openlayers/lib/OpenLayers/Lang/en.js
--- trunk/openlayers/lib/OpenLayers/Lang/en.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/en.js	2011-08-05 07:58:57 UTC (rev 12208)
     'unsupportedGeometryType': "Unsupported geometry type: ${geomType}",
     // console message
-        "OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",
     'filterEvaluateNotImplemented': "evaluate is not implemented for this filter type.",
     'proxyNeeded': "You probably need to set OpenLayers.ProxyHost to access ${url}."+
Modified: trunk/openlayers/lib/OpenLayers/Lang/es.js
--- trunk/openlayers/lib/OpenLayers/Lang/es.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/es.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -114,10 +114,6 @@
     'unsupportedGeometryType': "Tipo de geometría no soportada: ${geomType}",
     // console message
-        "OpenLayers.Util.pagePosition falló: el elemento con id ${elemId} puede haberse colocado de manera errónea.",
     'filterEvaluateNotImplemented': "evaluate no está implementado para este tipo de filtro.",
     // **** end ****
Modified: trunk/openlayers/lib/OpenLayers/Lang/fr.js
--- trunk/openlayers/lib/OpenLayers/Lang/fr.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/fr.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "Type de géométrie non supporté : ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition a échoué: l\'élément d\'id ${elemId} pourrait être mal positionné.",
     'filterEvaluateNotImplemented': "évaluer n\'a pas encore été implémenté pour ce type de filtre.",
     'proxyNeeded': "Vous avez très probablement besoin de renseigner OpenLayers.ProxyHost pour accéder à ${url}. Voir http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#ProxyHost"
Modified: trunk/openlayers/lib/OpenLayers/Lang/gl.js
--- trunk/openlayers/lib/OpenLayers/Lang/gl.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/gl.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Tipo xeométrico non soportado: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition fallou: o elemento con id ${elemId} pode non estar na súa posición.",
     'filterEvaluateNotImplemented': "avaliar non está implementado para este tipo de filtro."
Modified: trunk/openlayers/lib/OpenLayers/Lang/gsw.js
--- trunk/openlayers/lib/OpenLayers/Lang/gsw.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/gsw.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Nit unterstitze Geometrii-Typ: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition fählgschlaa: Elemänt mit ID ${elemId} isch villicht falsch gsetzt.",
     'filterEvaluateNotImplemented': "evaluiere isch nit implemäntiert in däm Filtertyp."
Modified: trunk/openlayers/lib/OpenLayers/Lang/hr.js
--- trunk/openlayers/lib/OpenLayers/Lang/hr.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/hr.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -52,8 +52,6 @@
     'pixelAddError': "Morate dati obje vrijednosti ,  x i y  da bi dodali funkciju.",
-    'unsupportedGeometryType': "Nepodržani tip geometrije: ${geomType}",
+    'unsupportedGeometryType': "Nepodržani tip geometrije: ${geomType}"
-    'pagePositionFailed': "OpenLayers.Util.pagePosition nije uspjelo: element sa id ${elemId} može biti krivo smješten."
Modified: trunk/openlayers/lib/OpenLayers/Lang/hsb.js
--- trunk/openlayers/lib/OpenLayers/Lang/hsb.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/hsb.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Njepodpěrowany geometrijowy typ: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition je so njeporadźił: element z id ${elemId} bu snano wopak zaměstnjeny.",
     'filterEvaluateNotImplemented': "wuhódnoćenje njeje za tutón filtrowy typ implementowany."
Modified: trunk/openlayers/lib/OpenLayers/Lang/hu.js
--- trunk/openlayers/lib/OpenLayers/Lang/hu.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/hu.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "Nem támogatott geometriatípus: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition sikertelen: lehetséges, hogy a(z) ${elemId} azonosítójú elem téves helyre került.",
     'filterEvaluateNotImplemented': "ennél a szűrőtípusnál kiértékelés nem hajtódik végre."
Modified: trunk/openlayers/lib/OpenLayers/Lang/ia.js
--- trunk/openlayers/lib/OpenLayers/Lang/ia.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/ia.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Typo de geometria non supportate: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition falleva: le elemento con id ${elemId} pote esser mal placiate.",
     'filterEvaluateNotImplemented': "\"evaluate\" non es implementate pro iste typo de filtro."
Modified: trunk/openlayers/lib/OpenLayers/Lang/id.js
--- trunk/openlayers/lib/OpenLayers/Lang/id.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/id.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "Tipe geometri tak didukung: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition gagal: elemen dengan id ${elemId} mungkin salah tempat.",
     'filterEvaluateNotImplemented': "evaluasi tidak tersedia untuk tipe filter ini."
Modified: trunk/openlayers/lib/OpenLayers/Lang/it.js
--- trunk/openlayers/lib/OpenLayers/Lang/it.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/it.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -105,9 +105,5 @@
     // console message
     'unsupportedGeometryType': "Tipo di geometria non supportata: ${geomType}",
-        "OpenLayers.Util.pagePosition fallita: l'elemento con id ${elemId} è posizionato in modo errato.",
     'end': ''
Modified: trunk/openlayers/lib/OpenLayers/Lang/ja.js
--- trunk/openlayers/lib/OpenLayers/Lang/ja.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/ja.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "未対応の形状型: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition が失敗しました: id ${elemId} をもつ要素が誤った位置にある可能性があります。",
     'filterEvaluateNotImplemented': "このフィルター型について evaluate は実装されていません。"
Modified: trunk/openlayers/lib/OpenLayers/Lang/ksh.js
--- trunk/openlayers/lib/OpenLayers/Lang/ksh.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/ksh.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "De Zoot Jommetrii dom_mer nit ongershtöze: \x3ccode\x3e${geomType}\x3c/code\x3e",
-    'pagePositionFailed': "\x3ccode lang=\"en\"\x3eOpenLayers.Util.pagePosition\x3c/code\x3e es donevve jejange: dat Denge met dä Kännong \x3ccode\x3e${elemId}\x3c/code\x3e künnt am verkeehte Plaz sin.",
     'filterEvaluateNotImplemented': "„\x3ccode lang=\"en\"\x3eevaluate\x3c/code\x3e“ es för di Zoot Fellter nit enjereschdt."
Modified: trunk/openlayers/lib/OpenLayers/Lang/lt.js
--- trunk/openlayers/lib/OpenLayers/Lang/lt.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/lt.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -69,10 +69,6 @@
     // console message
     'unsupportedGeometryType': "Nepalaikomas geometrijos tipas: ${geomType}",
-        "OpenLayers.Util.pagePosition žlugo: elementas su id ${elemId} gali būti neteisingoje vietoje.",
     // **** end ****
     'end': ''
Modified: trunk/openlayers/lib/OpenLayers/Lang/nb.js
--- trunk/openlayers/lib/OpenLayers/Lang/nb.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/nb.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -105,10 +105,6 @@
     // console message
     'unsupportedGeometryType': "Geometritypen ${geomType} er ikke støttet",
-        "OpenLayers.Util.pagePosition feilet: elementet med id ${elemId} kan være feilplassert.",
     'end': ''
Modified: trunk/openlayers/lib/OpenLayers/Lang/nds.js
--- trunk/openlayers/lib/OpenLayers/Lang/nds.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/nds.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -52,8 +52,6 @@
     'pixelAddError': "De Weert x un y, de mööt all beid an de add-Funkschoon övergeven warrn.",
-    'unsupportedGeometryType': "Nich ünnerstütt Geometrie-Typ: ${geomType}",
+    'unsupportedGeometryType': "Nich ünnerstütt Geometrie-Typ: ${geomType}"
-    'pagePositionFailed': "OpenLayers.Util.pagePosition güng nich: Element mit de Id ${elemId} is villicht an’n verkehrten Platz."
Modified: trunk/openlayers/lib/OpenLayers/Lang/nl.js
--- trunk/openlayers/lib/OpenLayers/Lang/nl.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/nl.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Dit geometrietype wordt niet ondersteund: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition is mislukt: het element met id ${elemId} is wellicht onjuist geplaatst.",
     'filterEvaluateNotImplemented': "evalueren is niet geïmplementeerd voor dit filtertype."
Modified: trunk/openlayers/lib/OpenLayers/Lang/oc.js
--- trunk/openlayers/lib/OpenLayers/Lang/oc.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/oc.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Tipe de geometria pas suportat : ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition a fracassat : l\'element d\'id ${elemId} poiriá èsser mal posicionat.",
     'filterEvaluateNotImplemented': "evaluar es pas encara estat implementat per aqueste tipe de filtre."
Modified: trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js
--- trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/pt-BR.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -71,8 +71,6 @@
     'unsupportedGeometryType': "Tipo geométrico não suportado: ${geomType}.",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition falhou: o elemento de id ${elemId} deve estar fora do lugar.",
     'filterEvaluateNotImplemented': "evaluete não está implementado para este tipo de filtro."
Modified: trunk/openlayers/lib/OpenLayers/Lang/pt.js
--- trunk/openlayers/lib/OpenLayers/Lang/pt.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/pt.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -72,8 +72,6 @@
     'unsupportedGeometryType': "Tipo de geometria não suportado: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition falhou: o elemento com o id ${elemId} poderá estar mal-posicionado.",
     'filterEvaluateNotImplemented': "avaliar não está implementado para este tipo de filtro."
Modified: trunk/openlayers/lib/OpenLayers/Lang/ru.js
--- trunk/openlayers/lib/OpenLayers/Lang/ru.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/ru.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -73,8 +73,6 @@
     'unsupportedGeometryType': "Неподдерживаемый тип геометрии: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition failed: элемент с id ${elemId} может находиться не в нужном месте.",
     'filterEvaluateNotImplemented': "evaluate не реализовано для фильтра данного типа."
Modified: trunk/openlayers/lib/OpenLayers/Lang/sk.js
--- trunk/openlayers/lib/OpenLayers/Lang/sk.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/sk.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -62,8 +62,6 @@
-    'pagePositionFailed': "OpenLayers.Util.pagePosition zlyhalo: prvok s id ${elemId} môže byť zle umiestnený.",
     'filterEvaluateNotImplemented': "evaluate nie je implementovaný pre tento typ filtra"
Modified: trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js
--- trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/sv-SE.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -62,8 +62,6 @@
     'unsupportedGeometryType': "Stöd saknas för geometritypen: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition misslyckades: elementet med id ${elemId} kan placeras fel.",
     'filterEvaluateNotImplemented': "evaluering har ej implementerats för denna typ av filter."
Modified: trunk/openlayers/lib/OpenLayers/Lang/vi.js
--- trunk/openlayers/lib/OpenLayers/Lang/vi.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/vi.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -70,8 +70,6 @@
     'unsupportedGeometryType': "Không hỗ trợ kiểu địa lý: ${geomType}",
-    'pagePositionFailed': "OpenLayers.Util.pagePosition bị thất bại: nguyên tố với ID ${elemId} có thể ở chỗ sai.",
     'filterEvaluateNotImplemented': "chưa hỗ trợ evaluate cho loại bộ lọc này."
Modified: trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js
--- trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/zh-CN.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -105,9 +105,5 @@
     // console message
     'unsupportedGeometryType': "不支持的几何体类型: ${geomType}",
-        "OpenLayers.Util.pagePosition 失败:id 为 ${elemId} 的元素可能被错置。",
     'end': ''
Modified: trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js
--- trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js	2011-08-05 07:51:20 UTC (rev 12207)
+++ trunk/openlayers/lib/OpenLayers/Lang/zh-TW.js	2011-08-05 07:58:57 UTC (rev 12208)
@@ -106,9 +106,5 @@
     // console message
     'unsupportedGeometryType': "未支援的幾何型別: ${geomType}。",
-        "OpenLayers.Util.pagePosition 失敗: id ${elemId} 的 element 可能被錯置。",
     'end': ''
More information about the Commits mailing list
