[OpenLayers-Commits] r12209 - in trunk/openlayers:
lib/OpenLayers/Format/WMSCapabilities tests/Format/WMSCapabilities
commits-20090109 at openlayers.org
Mon Aug 8 00:45:42 EDT 2011
Author: erilem
Date: 2011-08-07 21:45:41 -0700 (Sun, 07 Aug 2011)
New Revision: 12209
trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js
trunk/openlayers/tests/Format/WMSCapabilities/v1_1_1.html
trunk/openlayers/tests/Format/WMSCapabilities/v1_3_0.html
WMSCapabilities format may fail to correctly read BoundingBox of layers, r=fredj (closes #3449)
Modified: trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js 2011-08-05 07:58:57 UTC (rev 12208)
+++ trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1.js 2011-08-08 04:45:41 UTC (rev 12209)
@@ -133,8 +133,8 @@
"dimensions",
"authorityURLs"];
- var key;
- for (var j=0; j<attributes.length; j++) {
+ var key, j;
+ for (j=0; j<attributes.length; j++) {
key = attributes[j];
if (key in parentLayer) {
// only take parent value if not present (null or undefined)
@@ -157,9 +157,9 @@
- for (var j=0; j<complexAttr.length; j++) {
+ for (j=0; j<complexAttr.length; j++) {
key = complexAttr[j];
- layer[key] = OpenLayers.Util.extend(
+ layer[key] = OpenLayers.Util.applyDefaults(
layer[key], parentLayer[key]);
Modified: trunk/openlayers/tests/Format/WMSCapabilities/v1_1_1.html
--- trunk/openlayers/tests/Format/WMSCapabilities/v1_1_1.html 2011-08-05 07:58:57 UTC (rev 12208)
+++ trunk/openlayers/tests/Format/WMSCapabilities/v1_1_1.html 2011-08-08 04:45:41 UTC (rev 12209)
@@ -111,7 +111,7 @@
function test_layers(t) {
- t.plan(22);
+ t.plan(24);
var xml = document.getElementById("ogcsample").firstChild.nodeValue;
var doc = new OpenLayers.Format.XML().read(xml);
@@ -143,7 +143,11 @@
[189000, 834000, 285000, 962000],
"Correct bbox from BoundingBox");
t.eq(bbox.res, {x: 1, y: 1}, "Correct resolution");
+ bbox = layers["ROADS_RIVERS"].bbox["EPSG:4326"];
+ t.eq(bbox.bbox,
+ [-71.63, 41.75, -70.78, 42.90],
+ "Correct bbox from BoundingBox (override)");
+ t.eq(bbox.res, {x: 0.01, y: 0.01}, "Correct resolution (override)");
bbox = layers["ROADS_1M"].bbox["EPSG:26986"];
t.eq(bbox.bbox,
@@ -535,8 +539,9 @@
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
xlink:href="http://gcmd.gsfc.nasa.gov/difguide/whatisadif.html" />
</AuthorityURL>
+ <BoundingBox SRS="EPSG:4326"
+ minx="-1" miny="-1" maxx="1" maxy="1" resx="0.0" resy="0.0"/>
<Layer>
<Name>ROADS_RIVERS</Name>
<Title>Roads and Rivers</Title>
Modified: trunk/openlayers/tests/Format/WMSCapabilities/v1_3_0.html
--- trunk/openlayers/tests/Format/WMSCapabilities/v1_3_0.html 2011-08-05 07:58:57 UTC (rev 12208)
+++ trunk/openlayers/tests/Format/WMSCapabilities/v1_3_0.html 2011-08-08 04:45:41 UTC (rev 12209)
@@ -14,7 +14,7 @@
- t.plan(22);
+ t.plan(24);
@@ -46,6 +46,11 @@
+ bbox = layers["ROADS_RIVERS"].bbox["CRS:84"];
+ t.eq(bbox.bbox,
t.eq(bbox.bbox,
@@ -432,6 +437,8 @@
</AuthorityURL>
+ <BoundingBox CRS="CRS:84"
<Layer>
More information about the Commits
