[OpenLayers-Commits] r12249 - in trunk/openlayers/tests: Layer Tile
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Aug 15 12:30:44 EDT 2011
Author: ahocevar
Date: 2011-08-15 09:30:43 -0700 (Mon, 15 Aug 2011)
New Revision: 12249
   trunk/openlayers/tests/Layer/ArcGIS93Rest.html
   trunk/openlayers/tests/Layer/Image.html
   trunk/openlayers/tests/Layer/MapServer.html
   trunk/openlayers/tests/Layer/WMS.html
   trunk/openlayers/tests/Tile/Image.html
Fixing tests after r12247 - img.src is now only available after a delay, because it is set in the load handler after setting a blank image as src. There is no need to check for img.src in layer tests, because this is asserted by Tile.Image tests (see #3419)
Modified: trunk/openlayers/tests/Layer/ArcGIS93Rest.html
--- trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-08-15 16:26:34 UTC (rev 12248)
+++ trunk/openlayers/tests/Layer/ArcGIS93Rest.html	2011-08-15 16:30:43 UTC (rev 12249)
@@ -72,20 +72,15 @@
         tParams = OpenLayers.Util.extend(tParams, {
             FORMAT: "png", BBOX: "1,2,3,4", SIZE: "256,256", F: "image", BBOXSR: "4326", IMAGESR: "4326"
-        t.eq( img.src,
+        t.eq( tile.url,
              url + "?" + OpenLayers.Util.getParameterString(tParams),
              "image src is created correctly via addtile" );
         t.eq( tile.frame.style.top, "6px", "image top is set correctly via addtile" );
         t.eq( tile.frame.style.left, "5px", "image top is set correctly via addtile" );
         var firstChild = layer.div.firstChild.firstChild;
-        if (!isMozilla)
-            t.ok( true, "skipping element test outside of Mozilla");
-        else
-            t.ok( firstChild instanceof HTMLElement, "div first child is an image object" );
-        t.eq( firstChild.src,
-             url + "?" + OpenLayers.Util.getParameterString(tParams),
-             "div first child is correct image object" );
+        t.eq( firstChild.nodeName.toLowerCase(), "img", "div first child is an image object" );
+        t.ok( firstChild == img, "div first child is correct image object" );
         t.eq( tile.position.toString(), "x=5,y=6", "Position of tile is set correctly." );
         map.destroy();
@@ -302,55 +297,46 @@
         var encodingHack = document.createElement("img");
         tile.draw();
-        encodingHack.src = (url + "?" + OpenLayers.Util.getParameterString(tParams));
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src no filter" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src no filter" );
         layer.setLayerFilter('1', "MR_TOAD = 'FLYING'");
         tParams["LAYERDEFS"] = "1:MR_TOAD = 'FLYING';";
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src one filter" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src one filter" );
         layer.setLayerFilter('1', "MR_TOAD = 'NOT FLYING'");
         tParams["LAYERDEFS"] = "1:MR_TOAD = 'NOT FLYING';";
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src change one filter" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src change one filter" );
         layer.setLayerFilter('2', "true = false");
         tParams["LAYERDEFS"] = "1:MR_TOAD = 'NOT FLYING';2:true = false;";
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src two filters" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src two filters" );
         layer.setLayerFilter('99', "some_col > 5");
         tParams["LAYERDEFS"] = "1:MR_TOAD = 'NOT FLYING';2:true = false;99:some_col > 5;";
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src three filters" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src three filters" );
         layer.clearLayerFilter('2');
         tParams["LAYERDEFS"] = "1:MR_TOAD = 'NOT FLYING';99:some_col > 5;";
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src removed middle filter" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src removed middle filter" );
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src removed missing filter (no change)" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src removed missing filter (no change)" );
         layer.clearLayerFilter();
         delete tParams["LAYERDEFS"];
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src removed all filters" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src removed all filters" );
         tile.draw();
-        t.eq( tile.imgDiv.src, encodingHack.src, "image src removed all (no) filters" );
+        t.eq( tile.url, url + "?" + OpenLayers.Util.getParameterString(tParams), "image src removed all (no) filters" );
Modified: trunk/openlayers/tests/Layer/Image.html
--- trunk/openlayers/tests/Layer/Image.html	2011-08-15 16:26:34 UTC (rev 12248)
+++ trunk/openlayers/tests/Layer/Image.html	2011-08-15 16:30:43 UTC (rev 12249)
@@ -77,11 +77,11 @@
         t.eq(layer.tile.position.x,-42, "Tile x positioned correctly at maxextent");
         t.eq(layer.tile.position.y,106, "Tile y positioned correctly at maxextent");
-        t.eq(layer.tile.imgDiv.src, "http://earthtrends.wri.org/images/maps/4_m_citylights_lg.gif", "URL is correct");
+        t.eq(layer.tile.url, "http://earthtrends.wri.org/images/maps/4_m_citylights_lg.gif", "URL is correct");
         map.zoomIn();
         layer.setUrl('http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256');
-        t.eq(layer.tile.imgDiv.src, "http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256", "URL is correct after setURL");
+        t.eq(layer.tile.url, "http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-180,-90,0,90&WIDTH=256&HEIGHT=256", "URL is correct after setURL");
Modified: trunk/openlayers/tests/Layer/MapServer.html
--- trunk/openlayers/tests/Layer/MapServer.html	2011-08-15 16:26:34 UTC (rev 12248)
+++ trunk/openlayers/tests/Layer/MapServer.html	2011-08-15 16:30:43 UTC (rev 12249)
@@ -53,20 +53,15 @@
                  imgy:128,
                  imgxy:[256,256]
-        t.eq( img.src,
+        t.eq( tile.url,
              url + "?" + OpenLayers.Util.getParameterString(tParams).replace(/,/g, "+"),
-        if (!isMozilla)
-        else
-             url + "?" + OpenLayers.Util.getParameterString(tParams).replace(/,/g, "+"),
         map.destroy();
Modified: trunk/openlayers/tests/Layer/WMS.html
--- trunk/openlayers/tests/Layer/WMS.html	2011-08-15 16:26:34 UTC (rev 12248)
+++ trunk/openlayers/tests/Layer/WMS.html	2011-08-15 16:30:43 UTC (rev 12249)
@@ -83,20 +83,15 @@
             BBOX: [1,2,3,4],
             WIDTH: "256", HEIGHT: "256"
-        t.eq( img.src,
+        t.eq( tile.url,
              layer.getFullRequestString(tParams),
-        if (!isMozilla)
-        else
-             layer.getFullRequestString(tParams),
         map.destroy();
@@ -119,20 +114,15 @@
             BBOX: "1,2,3,4",
-        t.eq( img.src,
+        t.eq( tile.url,
-        if (!isMozilla)
-        else
+        t.ok( firstChild, img, "div first child is correct image object" );
         map.destroy();
Modified: trunk/openlayers/tests/Tile/Image.html
--- trunk/openlayers/tests/Tile/Image.html	2011-08-15 16:26:34 UTC (rev 12248)
+++ trunk/openlayers/tests/Tile/Image.html	2011-08-15 16:30:43 UTC (rev 12249)
@@ -79,13 +79,17 @@
         var bounds = new OpenLayers.Bounds(1,2,3,4);
         tile = layer.addTile(bounds, position);
         tile.renderTile();
-        t.eq(tile.imgDiv.src, layer.getURL(bounds), "image src correct for async request");
-        t.eq(tile.asyncRequestId, 1, "asyncRequestId correct after renderTile");
-        tile.renderTile();
-        t.eq(tile.asyncRequestId, 2, "asyncRequestId correct after subsequent renderTile");
-        tile.destroy();
-        layer.destroy();
-        map.destroy();
+        t.delay_call(0.1, function() {
+            t.eq(tile.imgDiv.src, layer.getURL(bounds), "image src correct for async request");
+            t.eq(tile.asyncRequestId, 1, "asyncRequestId correct after renderTile");
+            tile.renderTile();
+        t.delay_call(0.2, function() {
+            t.eq(tile.asyncRequestId, 2, "asyncRequestId correct after subsequent renderTile");
+            tile.destroy();
+            layer.destroy();
+            map.destroy();
     function test_Tile_Image_draw (t) {
@@ -131,9 +135,11 @@
             SRS: "EPSG:4326", BBOX: [1,2,3,4],
             WIDTH: String(size.w), HEIGHT: String(size.h)
-        t.eq( img.src,
-             "http://labs.metacarta.com/TESTURL?" + OpenLayers.Util.getParameterString(tParams),
-             "tile.draw creates an image");
+            t.eq( img.src,
+                 "http://labs.metacarta.com/TESTURL?" + OpenLayers.Util.getParameterString(tParams),
+                 "tile.draw creates an image");
         t.eq( tile.imgDiv.style.width, "100%", "Image width is correct" );
         t.eq( tile.imgDiv.style.height, "100%", "Image height is correct" );
@@ -164,31 +170,31 @@
             SRS: "EPSG:4326", BBOX: "-181,-91,180,90",
+        t.eq(tile.url,
              "http://labs.metacarta.com/wms/vmap0?" + OpenLayers.Util.getParameterString(tParams),
              "Images over edges of maxextent do load");
         tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-181,-90,180,90), url, size);
         tile.draw()
         tParams = OpenLayers.Util.extend(tParams, {BBOX: "-181,-90,180,90"});
+        t.eq(tile.url,
         tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-180,-90,180,90), url, size);
         tile.draw()
         tParams = OpenLayers.Util.extend(tParams, {BBOX: "-180,-90,180,90"});
+        t.eq(tile.url,
              "Image covering all of extent loads");
         tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-80,-45,80,45), url, size);
         tile.draw()
         tParams = OpenLayers.Util.extend(tParams, {BBOX: "-80,-45,80,45"});
+        t.eq(tile.url,
              "Image covering small part of extent loads");
         tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-185,-95,185,95), url, size);
         tile.draw()
         tParams = OpenLayers.Util.extend(tParams, {BBOX: "-185,-95,185,95"});
+        t.eq(tile.url,
              "Image covering more than all of extent loads");
@@ -196,31 +202,31 @@
         tile = new OpenLayers.Tile.Image(layer, position, new OpenLayers.Bounds(-185,-90,-180,90), url, size);
         tile.draw()
         tParams = OpenLayers.Util.extend(tParams, {BBOX: "-185,-90,-180,90"});
+        t.eq(tile.url,
              "Images against side of maxextent do load with displayOutsideMaxExtent");
         tile.draw()
+        t.eq(tile.url,
              "Images over edges of maxextent do load with displayOutsideMaxExtent set");
         tile.draw()
+        t.eq(tile.url,
              "Image covering all of extent loads with display outside max extent");
         tile.draw()
+        t.eq(tile.url,
              "Image covering small part of extent loads with display outside max extent");
         tile.draw()
+        t.eq(tile.url,
More information about the Commits mailing list
