[OpenLayers-Commits] r12250 - in trunk/openlayers:
	lib/OpenLayers/Protocol tests/Protocol
    commits-20090109 at openlayers.org
    Mon Aug 15 14:27:56 EDT 2011
Author: tschaub
Date: 2011-08-15 11:27:55 -0700 (Mon, 15 Aug 2011)
New Revision: 12250
   trunk/openlayers/lib/OpenLayers/Protocol/Script.js
   trunk/openlayers/tests/Protocol/Script.html
Changing the named callback to avoid having the returned script call a function.  This allows the protocol to be used with servers that sanitize callback identifiers for security.  Great patch from vmische.  r=me (closes 3417).
Modified: trunk/openlayers/lib/OpenLayers/Protocol/Script.js
--- trunk/openlayers/lib/OpenLayers/Protocol/Script.js	2011-08-15 16:30:43 UTC (rev 12249)
+++ trunk/openlayers/lib/OpenLayers/Protocol/Script.js	2011-08-15 18:27:55 UTC (rev 12250)
@@ -207,7 +207,7 @@
     createRequest: function(url, params, callback) {
         var id = OpenLayers.Protocol.Script.register(callback);
-        var name = "OpenLayers.Protocol.Script.getCallback(" + id + ")";
+        var name = "OpenLayers.Protocol.Script.registry[" + id + "]";
         params = OpenLayers.Util.extend({}, params);
         params[this.callbackKey] = this.callbackPrefix + name;
         url = OpenLayers.Util.urlAppend(
@@ -328,7 +328,7 @@
 (function() {
     var o = OpenLayers.Protocol.Script;
     var counter = 0;
-    var registry = {};
+    o.registry = [];
      * Function: OpenLayers.Protocol.Script.register
@@ -344,7 +344,10 @@
     o.register = function(callback) {
         var id = ++counter;
-        registry[id] = callback;
+        o.registry[id] = function() {
+            o.unregister(id);
+            callback.apply(this, arguments);
         return id;
@@ -356,22 +359,6 @@
      * id: {Number} The identifer returned by the register function.
     o.unregister = function(id) {
-        delete registry[id];
+        delete o.registry[id];
-     * Function: OpenLayers.Protocol.Script.getCallback
-     * Retreive and unregister a callback.  A call to this function is the "P"
-     * in JSONP.  For example, a script may be added with a src attribute
-     * http://example.com/features.json?callback=OpenLayers.Protocol.Script.getCallback(1)
-     * Parameters:
-     * id: {Number} The identifer returned by the register function.
-    o.getCallback = function(id) {
-        var callback = registry[id];
-        o.unregister(id);
-        return callback;
Modified: trunk/openlayers/tests/Protocol/Script.html
--- trunk/openlayers/tests/Protocol/Script.html	2011-08-15 16:30:43 UTC (rev 12249)
+++ trunk/openlayers/tests/Protocol/Script.html	2011-08-15 18:27:55 UTC (rev 12250)
@@ -150,7 +150,7 @@
         t.eq(script.type, 'text/javascript',
             'created script has a correct type');
-        t.eq(script.src, 'http://bar_url/?k=bar_param&cb_key=cb_prefix%3AOpenLayers.Protocol.Script.getCallback(bar)',
+        t.eq(script.src, 'http://bar_url/?k=bar_param&cb_key=cb_prefix%3AOpenLayers.Protocol.Script.registry%5Bbar%5D',
             'created script has a correct url');
         t.eq(script.id, 'OpenLayers_Protocol_Script_bar',
             'created script has a correct id');
More information about the Commits
