[OpenLayers-Commits] r11094 -
sandbox/elemoine/draw-feature/tests/Control
commits-20090109 at openlayers.org
Thu Feb 10 09:44:51 EST 2011
Author: erilem
Date: 2011-02-10 06:44:51 -0800 (Thu, 10 Feb 2011)
New Revision: 11094
sandbox/elemoine/draw-feature/tests/Control/DrawFeature.html
fix the DrawFeature tests
Modified: sandbox/elemoine/draw-feature/tests/Control/DrawFeature.html
--- sandbox/elemoine/draw-feature/tests/Control/DrawFeature.html 2011-02-10 13:43:52 UTC (rev 11093)
+++ sandbox/elemoine/draw-feature/tests/Control/DrawFeature.html 2011-02-10 14:44:51 UTC (rev 11094)
@@ -60,7 +60,7 @@
function test_sketch_events(t) {
- t.plan(6);
+ t.plan(12);
var map = new OpenLayers.Map("map", {
resolutions: [1]
@@ -69,37 +69,62 @@
isBaseLayer: true
var control = new OpenLayers.Control.DrawFeature(
- layer, OpenLayers.Handler.Point
+ layer, OpenLayers.Handler.Path, {
+ handlerOptions: {persist: true}
map.addLayer(layer);
map.addControl(control);
map.zoomToMaxExtent();
- control.activate();
- var log = {};
+ var log;
layer.events.on({
sketchstarted: function(event) {
- log.event = event;
+ log['sketchstarted'] = event;
sketchmodified: function(event) {
+ log['sketchmodified'] = event;
sketchcomplete: function(event) {
+ log['sketchcomplete'] = event;
// mock up draw/modify of a point
+ log = {};
+ control.activate();
+ t.eq(log.sketchstarted.type, "sketchstarted", "[activate] sketchstarted triggered");
+ t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[activate] correct vertex");
+ log = {};
+ map.events.triggerEvent("mousemove", {xy: new OpenLayers.Pixel(0, 0)});
+ t.eq(log.sketchmodified.type, "sketchmodified", "[mousemove] sketchmodified triggered");
+ t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mousemove] correct vertex");
map.events.triggerEvent("mousedown", {xy: new OpenLayers.Pixel(0, 0)});
- t.eq(log.event.type, "sketchstarted", "[mousedown] sketchstarted triggered");
- t.geom_eq(log.event.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mousedown] correct vertex");
+ log = {};
+ map.events.triggerEvent("mouseup", {xy: new OpenLayers.Pixel(0, 0)});
+ t.eq(log.sketchmodified.type, "sketchmodified", "[mouseup] sketchmodified triggered");
+ t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-200, 125), "[mouseup] correct vertex");
+ log = {};
map.events.triggerEvent("mousemove", {xy: new OpenLayers.Pixel(10, 10)});
- t.eq(log.event.type, "sketchmodified", "[mousemove] sketchmodified triggered");
- t.geom_eq(log.event.vertex, new OpenLayers.Geometry.Point(-190, 115), "[mousemove] correct vertex");
- map.events.triggerEvent("mouseup", {xy: new OpenLayers.Pixel(10, 10)});
- t.eq(log.event.type, "sketchcomplete", "[mouseup] sketchcomplete triggered");
- t.geom_eq(log.event.feature.geometry, new OpenLayers.Geometry.Point(-190, 115), "[mouseup] correct geometry");
+ t.geom_eq(log.sketchmodified.vertex, new OpenLayers.Geometry.Point(-190, 115), "[mousemove] correct vertex");
+ log = {};
+ map.events.triggerEvent("dblclick", {xy: new OpenLayers.Pixel(10, 10)});
+ t.eq(log.sketchcomplete.type, "sketchcomplete", "[dblclick] sketchcomplete triggered");
+ t.geom_eq(log.sketchcomplete.feature.geometry,
+ new OpenLayers.Geometry.LineString([
+ new OpenLayers.Geometry.Point(-200, 125),
+ new OpenLayers.Geometry.Point(-190, 115)
+ "[dblclick] correct geometry");
+ t.eq(log.sketchstarted.type, "sketchstarted", "[dblclick] sketchstarted triggered");
+ t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[dblclick] correct vertex");
map.destroy();
More information about the Commits
