[OpenLayers-Commits] r11095 -
sandbox/elemoine/draw-feature/tests/Control
commits-20090109 at openlayers.org
Thu Feb 10 09:44:58 EST 2011
Author: erilem
Date: 2011-02-10 06:44:58 -0800 (Thu, 10 Feb 2011)
New Revision: 11095
sandbox/elemoine/draw-feature/tests/Control/Split.html
fix the Split tests
Modified: sandbox/elemoine/draw-feature/tests/Control/Split.html
--- sandbox/elemoine/draw-feature/tests/Control/Split.html 2011-02-10 14:44:51 UTC (rev 11094)
+++ sandbox/elemoine/draw-feature/tests/Control/Split.html 2011-02-10 14:44:58 UTC (rev 11095)
@@ -35,13 +35,20 @@
function test_setSource(t) {
t.plan(5);
- var layer1 = new OpenLayers.Layer.Vector();
- var layer2 = new OpenLayers.Layer.Vector();
+ var layer1 = new OpenLayers.Layer.Vector("foo", {
+ maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+ isBaseLayer: true
+ var layer2 = new OpenLayers.Layer.Vector("foo", {
+ isBaseLayer: true
var control = new OpenLayers.Control.Split({layer: layer1});
var map = new OpenLayers.Map("map");
map.addLayers([layer1, layer2]);
+ map.zoomToMaxExtent();
map.addControl(control);
control.activate();
@@ -64,12 +71,16 @@
function test_activate(t) {
t.plan(8);
- var layer = new OpenLayers.Layer.Vector();
+ var layer = new OpenLayers.Layer.Vector("foo", {
+ isBaseLayer: true
var control = new OpenLayers.Control.Split({layer: layer});
map.addLayer(layer);
// test activation with no source layer
control.activate();
t.eq(control.active, true, "control is active");
@@ -93,12 +104,16 @@
t.plan(7);
+ isBaseLayer: true
// activate and check sketch handler
control.activate();
t.ok(control.handler, "sketch handler present");
More information about the Commits
