[OpenLayers-Commits] r11141 - in sandbox/elemoine/draw-feature: .
doc examples lib lib/OpenLayers lib/OpenLayers/Control
lib/OpenLayers/Format lib/OpenLayers/Layer
lib/OpenLayers/Layer/Google tests
tests/Format/WMTSCapabilities tests/Layer/Google theme/default
commits-20090109 at openlayers.org
Thu Feb 17 18:02:32 EST 2011
Author: erilem
Date: 2011-02-17 15:02:31 -0800 (Thu, 17 Feb 2011)
New Revision: 11141
Added:
sandbox/elemoine/draw-feature/examples/mobile-jq.html
sandbox/elemoine/draw-feature/examples/mobile-sencha.html
sandbox/elemoine/draw-feature/examples/mobile.js
sandbox/elemoine/draw-feature/doc/authors.txt
sandbox/elemoine/draw-feature/lib/OpenLayers.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoom.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoomBar.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WMTSCapabilities.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Google/v3.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/HTTPRequest.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/MultiMap.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/SphericalMercator.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/XYZ.js
sandbox/elemoine/draw-feature/lib/OpenLayers/Request.js
sandbox/elemoine/draw-feature/tests/Format/WMTSCapabilities/v1_0_0.html
sandbox/elemoine/draw-feature/tests/Layer/Google/v3.html
sandbox/elemoine/draw-feature/tests/Request.html
sandbox/elemoine/draw-feature/tests/Util.html
sandbox/elemoine/draw-feature/tests/list-tests.html
sandbox/elemoine/draw-feature/theme/default/style.css
svn merge -r 11093:HEAD http://svn.openlayers.org/trunk/openlayers/ .
Property changes on: sandbox/elemoine/draw-feature
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11027-11037,11040-11091
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11027-11037,11040-11091,11094-11140
Modified: sandbox/elemoine/draw-feature/doc/authors.txt
--- sandbox/elemoine/draw-feature/doc/authors.txt 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/doc/authors.txt 2011-02-17 23:02:31 UTC (rev 11141)
@@ -15,6 +15,7 @@
John Frank
Sean Gilles
Pierre Giraud
+Ivan Grcic
Andreas Hocevar
Ian Johnson
Eric Lemoine
Copied: sandbox/elemoine/draw-feature/examples/mobile-jq.html (from rev 11140, trunk/openlayers/examples/mobile-jq.html)
--- sandbox/elemoine/draw-feature/examples/mobile-jq.html (rev 0)
+++ sandbox/elemoine/draw-feature/examples/mobile-jq.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -0,0 +1,132 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>OpenLayers with jQuery Mobile</title>
+ <meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">
+ <meta name="apple-mobile-web-app-capable" content="yes">
+ <link rel="stylesheet" href="http://code.jquery.com/mobile/1.0a3/jquery.mobile-1.0a3.min.css">
+ <script src="http://code.jquery.com/jquery-1.5.min.js"></script>
+ <script src="http://code.jquery.com/mobile/1.0a3/jquery.mobile-1.0a3.min.js"></script>
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+ <script src="../lib/OpenLayers.js"></script>
+ <script src="mobile.js"></script>
+ <style>
+ html {
+ height: 100%;
+ body {
+ margin: 0;
+ padding: 0;
+ height: 100%;
+ .ui-content {
+ padding: 0;
+ .ui-footer, .ui-header {
+ text-align: center;
+ padding: 5px 0;
+ #map {
+ width: 100%;
+ height: 100%;
+ .olControlAttribution {
+ font-size: 10px;
+ bottom: 5px;
+ right: 5px;
+ </style>
+ <script>
+ $(document).ready(function() {
+ // fix height of content to allow for header & footer
+ function fixContentHeight() {
+ var header = $("div[data-role='header']:visible");
+ var footer = $("div[data-role='footer']:visible");
+ var content = $("div[data-role='content']:visible:visible");
+ var viewHeight = $(window).height();
+ var contentHeight = viewHeight - header.outerHeight() - footer.outerHeight();
+ if ((content.outerHeight() + header.outerHeight() + footer.outerHeight()) !== viewHeight) {
+ contentHeight -= (content.outerHeight() - content.height());
+ content.height(contentHeight);
+ if (window.map) {
+ map.updateSize();
+ } else {
+ // initialize map
+ init();
+ $(window).bind("orientationchange resize pageshow", fixContentHeight);
+ fixContentHeight();
+ // add behavior to navigation buttons
+ $("#west").click(function() {
+ pan(-0.25, 0);
+ $("#north").click(function() {
+ pan(0, -0.25);
+ $("#south").click(function() {
+ pan(0, 0.25);
+ $("#east").click(function() {
+ pan(0.25, 0);
+ // add behavior to drawing controls
+ function deactivateControls() {
+ $.each(map.getControlsByClass(/DrawFeature/), function(index, control) {
+ control.deactivate();
+ map.getControlsBy("id", "mod-control")[0].deactivate();
+ $("#nav, #point, #line, #poly, #mod").change(function(event) {
+ deactivateControls();
+ // jquery mobile bug regarding change makes us go through all inputs
+ // https://github.com/jquery/jquery-mobile/issues/issue/1088
+ var val = $("input:radio[name=controls]:checked").val();
+ if (val !== "nav") {
+ map.getControlsBy("id", val + "-control")[0].activate();
+ $("#nav").click();
+ $("#nav").click(); // jquery mobile bug forces 2 calls to refresh radio ui
+ </script>
+ </head>
+ <body>
+ <div data-role="page">
+ <div data-role="header">
+ <input id="west" type="button" data-icon="arrow-l" value="west">
+ <input id="north" type="button" data-icon="arrow-u" value="north">
+ <input id="south" type="button" data-icon="arrow-d" value="south">
+ <input id="east" type="button" data-icon="arrow-r" value="east">
+ </div>
+ <div data-role="content">
+ <div id="map"></div>
+ </div>
+ <div data-role="footer">
+ <form id="controls">
+ <fieldset data-role="controlgroup" data-type="horizontal" data-role="fieldcontain">
+ <input id="nav" type="radio" name="controls" value="nav" checked="checked">
+ <label for="nav">navigate</label>
+ <input id="point" type="radio" name="controls" value="point">
+ <label for="point">point</label>
+ <input id="line" type="radio" name="controls" value="line">
+ <label for="line">line</label>
+ <input id="poly" type="radio" name="controls" value="poly">
+ <label for="poly">poly</label>
+ <input id="mod" type="radio" name="controls" value="mod">
+ <label for="mod">modify</label>
+ </fieldset>
+ </form>
+ </div>
+ </div>
+ </body>
+</html>
Copied: sandbox/elemoine/draw-feature/examples/mobile-sencha.html (from rev 11140, trunk/openlayers/examples/mobile-sencha.html)
--- sandbox/elemoine/draw-feature/examples/mobile-sencha.html (rev 0)
+++ sandbox/elemoine/draw-feature/examples/mobile-sencha.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -0,0 +1,123 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <title>OpenLayers with Sencha Touch</title>
+ <link rel="stylesheet" href="http://dev.sencha.com/deploy/touch/resources/css/sencha-touch.css">
+ <script src="http://dev.sencha.com/deploy/touch/sencha-touch.js"></script>
+ <style>
+ #map {
+ width: 100%;
+ height: 100%;
+ font-size: 10px;
+ bottom: 5px;
+ right: 5px;
+ </style>
+ <script>
+ new Ext.Application({
+ name: "ol",
+ launch: function() {
+ this.viewport = new Ext.Panel({
+ fullscreen: true,
+ dockedItems: [{
+ dock: "top",
+ xtype: "toolbar",
+ ui: "light",
+ layout: {
+ pack: "center"
+ defaults: {
+ ui: "plain",
+ iconMask: true
+ items: [{
+ iconCls: "arrow_left",
+ handler: function() {
+ pan(-0.25, 0);
+ iconCls: "arrow_up",
+ pan(0, -0.25);
+ iconCls: "arrow_down",
+ pan(0, 0.25);
+ iconCls: "arrow_right",
+ pan(0.25, 0);
+ dock: "bottom",
+ xtype: "toolbar",
+ ui: "light",
+ layout: {
+ pack: "center"
+ items: [{
+ xtype: "segmentedbutton",
+ items: [{
+ text: "navigate",
+ pressed: true
+ text: "point",
+ id: "point"
+ text: "line",
+ id: "line"
+ text: "poly",
+ id: "poly"
+ text: "modify",
+ id: "mod"
+ listeners: {
+ toggle: function(container, button, pressed) {
+ Ext.each(map.getControlsByClass(/DrawFeature/), function(control) {
+ if (pressed) {
+ var id = button.id + "-control";
+ var control = map.getControlsBy("id", id)[0];
+ if (control) {
+ control.activate();
+ items: [{
+ xtype: "component",
+ scroll: false,
+ monitorResize: true,
+ id: "map",
+ listeners: {
+ render: init,
+ resize: function() {
+ if (window.map) {
+ map.updateSize();
+ </script>
+ </head>
+ <body></body>
+</html>
Copied: sandbox/elemoine/draw-feature/examples/mobile.js (from rev 11140, trunk/openlayers/examples/mobile.js)
--- sandbox/elemoine/draw-feature/examples/mobile.js (rev 0)
+++ sandbox/elemoine/draw-feature/examples/mobile.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -0,0 +1,82 @@
+// initialize map when page ready
+var map;
+function init() {
+ var gg = new OpenLayers.Projection("EPSG:4326");
+ var sm = new OpenLayers.Projection("EPSG:900913");
+ // layer for drawn features
+ var vector = new OpenLayers.Layer.Vector();
+ // create map
+ map = new OpenLayers.Map({
+ div: "map",
+ projection: sm,
+ units: "m",
+ numZoomLevels: 18,
+ maxResolution: 156543.0339,
+ maxExtent: new OpenLayers.Bounds(
+ -20037508.34, -20037508.34, 20037508.34, 20037508.34
+ controls: [
+ new OpenLayers.Control.Navigation(),
+ new OpenLayers.Control.Attribution(),
+ new OpenLayers.Control.DrawFeature(
+ vector, OpenLayers.Handler.Point, {id: "point-control"}
+ vector, OpenLayers.Handler.Path, {id: "line-control"}
+ vector, OpenLayers.Handler.Polygon, {id: "poly-control"}
+ new OpenLayers.Control.ModifyFeature(vector, {id: "mod-control"}),
+ layers: [new OpenLayers.Layer.OSM(), vector],
+ center: new OpenLayers.LonLat(0, 0),
+ zoom: 1
+ // attempt to get position
+ if (window.navigator && navigator.geolocation) {
+ navigator.geolocation.getCurrentPosition(
+ updatePosition,
+ function failure(error) {
+ updateLog(error.message);
+ enableHighAccuracy: true
+// get position if possible
+var position;
+function updatePosition(pos) {
+ position = pos;
+ var lon = position.coords.longitude;
+ var lat = position.coords.latitude;
+ updateLog("position: lon " + lon + ", lat " + lat);
+ map.setCenter(
+ new OpenLayers.LonLat(lon, lat).transform(gg, sm)
+// allow simple logging
+var log = [];
+function updateLog(message) {
+ log.push(message);
+ if (window.console) {
+ console.log(message);
+function clearLog() {
+ log.length = 0;
+function pan(fx, fy) {
+ var size = map.getSize();
+ map.pan(size.w * fx, size.h * fy);
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoom.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoom.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoom.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -123,7 +123,7 @@
var btn = OpenLayers.Util.createAlphaImageDiv(
this.id + "_" + id,
xy, sz, imgLocation, "absolute");
+ btn.style.cursor = "pointer";
//we want to add the outer div
this.div.appendChild(btn);
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoomBar.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoomBar.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Control/PanZoomBar.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -180,6 +180,7 @@
new OpenLayers.Size(20,9),
imgLocation+"slider.png",
"absolute");
+ slider.style.cursor = "move";
this.slider = slider;
this.sliderEvents = new OpenLayers.Events(this, slider, null, true,
@@ -212,7 +213,7 @@
sz,
imgLocation+"zoombar.png");
+ div.style.cursor = "pointer";
this.zoombarDiv = div;
this.divEvents = new OpenLayers.Events(this, div, null, true,
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WMTSCapabilities.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WMTSCapabilities.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Format/WMTSCapabilities.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -149,7 +149,7 @@
OpenLayers.Util.applyDefaults(config, {
url: capabilities.operationsMetadata.GetTile.dcp.http.get,
- style: style,
+ style: style.identifier,
matrixIds: matrixSet.matrixIds
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Google/v3.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Google/v3.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/Google/v3.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -26,13 +26,13 @@
* (code)
* maxExtent: new OpenLayers.Bounds(
- * -128 * 156543.0339,
- * 128 * 156543.0339,
+ * -128 * 156543.03390625,
+ * 128 * 156543.03390625,
* sphericalMercator: true,
- * maxResolution: 156543.0339,
+ * maxResolution: 156543.03390625,
* units: "m",
* projection: "EPSG:900913"
@@ -40,13 +40,13 @@
DEFAULTS: {
- -128 * 156543.0339,
- 128 * 156543.0339,
- 128 * 156543.0339
+ -128 * 156543.03390625,
+ 128 * 156543.03390625,
- maxResolution: 156543.0339,
+ maxResolution: 156543.03390625,
units: "m",
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/HTTPRequest.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/HTTPRequest.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/HTTPRequest.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -38,7 +38,7 @@
* APIProperty: reproject
- * *Deprecated*. See http://trac.openlayers.org/wiki/SpatialMercator
+ * *Deprecated*. See http://docs.openlayers.org/library/spherical_mercator.html
* for information on the replacement for this functionality.
* {Boolean} Whether layer should reproject itself based on base layer
* locations. This allows reprojection onto commercial layers.
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/MultiMap.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/MultiMap.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/MultiMap.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -13,6 +13,7 @@
* Class: OpenLayers.Layer.MultiMap
* Note that MultiMap does not fully support the sphericalMercator
* option. See Ticket #953 for more details.
+ * *Deprecated*. Use OpenLayers.Layer.Bing instead. See #3063
* Inherits from:
* - <OpenLayers.Layer.EventPane>
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/SphericalMercator.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/SphericalMercator.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/SphericalMercator.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -95,7 +95,7 @@
initMercatorParameters: function() {
// set up properties for Mercator - assume EPSG:900913
this.RESOLUTIONS = [];
- var maxResolution = 156543.0339;
+ var maxResolution = 156543.03390625;
for(var zoom=0; zoom<=this.MAX_ZOOM_LEVEL; ++zoom) {
this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/XYZ.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/XYZ.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Layer/XYZ.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -65,12 +65,12 @@
if (options && options.sphericalMercator || this.sphericalMercator) {
options = OpenLayers.Util.extend({
- 128 * 156543.0339
numZoomLevels: 19,
units: "m",
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Request.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Request.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Request.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -125,14 +125,8 @@
// create request, open, and set headers
var request = new OpenLayers.Request.XMLHttpRequest();
- var url = config.url;
- if(config.params) {
- var paramString = OpenLayers.Util.getParameterString(config.params);
- if(paramString.length > 0) {
- var separator = (url.indexOf('?') > -1) ? '&' : '?';
- url += separator + paramString;
+ var url = OpenLayers.Util.urlAppend(config.url,
+ OpenLayers.Util.getParameterString(config.params || {}));
var sameOrigin = !(url.indexOf("http") == 0);
var urlParts = !sameOrigin && url.match(this.URL_SPLIT_REGEX);
if (urlParts) {
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers.js 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers.js 2011-02-17 23:02:31 UTC (rev 11141)
@@ -29,7 +29,28 @@
* Relative path of this script.
var scriptName = (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js";
+ * If window.OpenLayers isn't set when this script (OpenLayers.js) is
+ * evaluated (and if singleFile is false) then this script will load
+ * *all* OpenLayers scripts. If window.OpenLayers is set to an array
+ * then this script will attempt to load scripts for each string of
+ * the array, using the string as the src of the script.
+ * Example:
+ * (code)
+ * <script type="text/javascript">
+ * window.OpenLayers = [
+ * "OpenLayers/Util.js",
+ * "OpenLayers/BaseTypes.js"
+ * </script>
+ * <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+ * (end)
+ * In this example OpenLayers.js will load Util.js and BaseTypes.js only.
+ var jsFiles = window.OpenLayers;
* Namespace: OpenLayers
* The OpenLayers object provides a namespace for all things OpenLayers
@@ -60,6 +81,7 @@
return (function() { return l; });
* OpenLayers.singleFile is a flag indicating this file is being included
* in a Single File Library build of the OpenLayers Library.
@@ -71,260 +93,264 @@
* OpenLayers library code as it will be appended at the end of this file.
if(!singleFile) {
- var jsfiles = new Array(
- "OpenLayers/BaseTypes/Class.js",
- "OpenLayers/Util.js",
- "OpenLayers/BaseTypes.js",
- "OpenLayers/BaseTypes/Bounds.js",
- "OpenLayers/BaseTypes/Element.js",
- "OpenLayers/BaseTypes/LonLat.js",
- "OpenLayers/BaseTypes/Pixel.js",
- "OpenLayers/BaseTypes/Size.js",
- "OpenLayers/Console.js",
- "OpenLayers/Tween.js",
- "Rico/Corner.js",
- "Rico/Color.js",
- "OpenLayers/Ajax.js",
- "OpenLayers/Events.js",
- "OpenLayers/Request.js",
- "OpenLayers/Request/XMLHttpRequest.js",
- "OpenLayers/Projection.js",
- "OpenLayers/Map.js",
- "OpenLayers/Layer.js",
- "OpenLayers/Icon.js",
- "OpenLayers/Marker.js",
- "OpenLayers/Marker/Box.js",
- "OpenLayers/Popup.js",
- "OpenLayers/Tile.js",
- "OpenLayers/Tile/Image.js",
- "OpenLayers/Tile/Image/IFrame.js",
- "OpenLayers/Tile/WFS.js",
- "OpenLayers/Layer/Image.js",
- "OpenLayers/Layer/SphericalMercator.js",
- "OpenLayers/Layer/EventPane.js",
- "OpenLayers/Layer/FixedZoomLevels.js",
- "OpenLayers/Layer/Google.js",
- "OpenLayers/Layer/Google/v3.js",
- "OpenLayers/Layer/VirtualEarth.js",
- "OpenLayers/Layer/Yahoo.js",
- "OpenLayers/Layer/HTTPRequest.js",
- "OpenLayers/Layer/Grid.js",
- "OpenLayers/Layer/MapGuide.js",
- "OpenLayers/Layer/MapServer.js",
- "OpenLayers/Layer/MapServer/Untiled.js",
- "OpenLayers/Layer/KaMap.js",
- "OpenLayers/Layer/KaMapCache.js",
- "OpenLayers/Layer/MultiMap.js",
- "OpenLayers/Layer/Markers.js",
- "OpenLayers/Layer/Text.js",
- "OpenLayers/Layer/WorldWind.js",
- "OpenLayers/Layer/ArcGIS93Rest.js",
- "OpenLayers/Layer/WMS.js",
- "OpenLayers/Layer/WMS/Untiled.js",
- "OpenLayers/Layer/WMS/Post.js",
- "OpenLayers/Layer/WMTS.js",
- "OpenLayers/Layer/ArcIMS.js",
- "OpenLayers/Layer/GeoRSS.js",
- "OpenLayers/Layer/Boxes.js",
- "OpenLayers/Layer/XYZ.js",
- "OpenLayers/Layer/Bing.js",
- "OpenLayers/Layer/TMS.js",
- "OpenLayers/Layer/TileCache.js",
- "OpenLayers/Layer/Zoomify.js",
- "OpenLayers/Popup/Anchored.js",
- "OpenLayers/Popup/AnchoredBubble.js",
- "OpenLayers/Popup/Framed.js",
- "OpenLayers/Popup/FramedCloud.js",
- "OpenLayers/Feature.js",
- "OpenLayers/Feature/Vector.js",
- "OpenLayers/Feature/WFS.js",
- "OpenLayers/Handler.js",
- "OpenLayers/Handler/Click.js",
- "OpenLayers/Handler/Hover.js",
- "OpenLayers/Handler/Point.js",
- "OpenLayers/Handler/Path.js",
- "OpenLayers/Handler/Polygon.js",
- "OpenLayers/Handler/Feature.js",
- "OpenLayers/Handler/Drag.js",
- "OpenLayers/Handler/RegularPolygon.js",
- "OpenLayers/Handler/Box.js",
- "OpenLayers/Handler/MouseWheel.js",
- "OpenLayers/Handler/Keyboard.js",
- "OpenLayers/Control.js",
- "OpenLayers/Control/Attribution.js",
- "OpenLayers/Control/Button.js",
- "OpenLayers/Control/ZoomBox.js",
- "OpenLayers/Control/ZoomToMaxExtent.js",
- "OpenLayers/Control/DragPan.js",
- "OpenLayers/Control/Navigation.js",
- "OpenLayers/Control/MouseDefaults.js",
- "OpenLayers/Control/MousePosition.js",
- "OpenLayers/Control/OverviewMap.js",
- "OpenLayers/Control/KeyboardDefaults.js",
- "OpenLayers/Control/PanZoom.js",
- "OpenLayers/Control/PanZoomBar.js",
- "OpenLayers/Control/ArgParser.js",
- "OpenLayers/Control/Permalink.js",
- "OpenLayers/Control/Scale.js",
- "OpenLayers/Control/ScaleLine.js",
- "OpenLayers/Control/Snapping.js",
- "OpenLayers/Control/Split.js",
- "OpenLayers/Control/LayerSwitcher.js",
- "OpenLayers/Control/DrawFeature.js",
- "OpenLayers/Control/DragFeature.js",
- "OpenLayers/Control/ModifyFeature.js",
- "OpenLayers/Control/Panel.js",
- "OpenLayers/Control/SelectFeature.js",
- "OpenLayers/Control/NavigationHistory.js",
- "OpenLayers/Control/Measure.js",
- "OpenLayers/Control/WMSGetFeatureInfo.js",
- "OpenLayers/Control/WMTSGetFeatureInfo.js",
- "OpenLayers/Control/Graticule.js",
- "OpenLayers/Control/TransformFeature.js",
- "OpenLayers/Control/SLDSelect.js",
- "OpenLayers/Geometry.js",
- "OpenLayers/Geometry/Rectangle.js",
- "OpenLayers/Geometry/Collection.js",
- "OpenLayers/Geometry/Point.js",
- "OpenLayers/Geometry/MultiPoint.js",
- "OpenLayers/Geometry/Curve.js",
- "OpenLayers/Geometry/LineString.js",
- "OpenLayers/Geometry/LinearRing.js",
- "OpenLayers/Geometry/Polygon.js",
- "OpenLayers/Geometry/MultiLineString.js",
- "OpenLayers/Geometry/MultiPolygon.js",
- "OpenLayers/Geometry/Surface.js",
- "OpenLayers/Renderer.js",
- "OpenLayers/Renderer/Elements.js",
- "OpenLayers/Renderer/SVG.js",
- "OpenLayers/Renderer/Canvas.js",
- "OpenLayers/Renderer/VML.js",
- "OpenLayers/Layer/Vector.js",
- "OpenLayers/Layer/Vector/RootContainer.js",
- "OpenLayers/Strategy.js",
- "OpenLayers/Strategy/Filter.js",
- "OpenLayers/Strategy/Fixed.js",
- "OpenLayers/Strategy/Cluster.js",
- "OpenLayers/Strategy/Paging.js",
- "OpenLayers/Strategy/BBOX.js",
- "OpenLayers/Strategy/Save.js",
- "OpenLayers/Strategy/Refresh.js",
- "OpenLayers/Filter.js",
- "OpenLayers/Filter/FeatureId.js",
- "OpenLayers/Filter/Logical.js",
- "OpenLayers/Filter/Comparison.js",
- "OpenLayers/Filter/Spatial.js",
- "OpenLayers/Protocol.js",
- "OpenLayers/Protocol/HTTP.js",
- "OpenLayers/Protocol/SQL.js",
- "OpenLayers/Protocol/SQL/Gears.js",
- "OpenLayers/Protocol/WFS.js",
- "OpenLayers/Protocol/WFS/v1.js",
- "OpenLayers/Protocol/WFS/v1_0_0.js",
- "OpenLayers/Protocol/WFS/v1_1_0.js",
- "OpenLayers/Protocol/SOS.js",
- "OpenLayers/Protocol/SOS/v1_0_0.js",
- "OpenLayers/Layer/PointTrack.js",
- "OpenLayers/Layer/GML.js",
- "OpenLayers/Style.js",
- "OpenLayers/Style2.js",
- "OpenLayers/StyleMap.js",
- "OpenLayers/Rule.js",
- "OpenLayers/Format.js",
- "OpenLayers/Format/XML.js",
- "OpenLayers/Format/Context.js",
- "OpenLayers/Format/ArcXML.js",
- "OpenLayers/Format/ArcXML/Features.js",
- "OpenLayers/Format/GML.js",
- "OpenLayers/Format/GML/Base.js",
- "OpenLayers/Format/GML/v2.js",
- "OpenLayers/Format/GML/v3.js",
- "OpenLayers/Format/Atom.js",
- "OpenLayers/Format/KML.js",
- "OpenLayers/Format/GeoRSS.js",
- "OpenLayers/Format/WFS.js",
- "OpenLayers/Format/WFSCapabilities.js",
- "OpenLayers/Format/WFSCapabilities/v1.js",
- "OpenLayers/Format/WFSCapabilities/v1_0_0.js",
- "OpenLayers/Format/WFSCapabilities/v1_1_0.js",
- "OpenLayers/Format/WFSDescribeFeatureType.js",
- "OpenLayers/Format/WMSDescribeLayer.js",
- "OpenLayers/Format/WMSDescribeLayer/v1_1.js",
- "OpenLayers/Format/WKT.js",
- "OpenLayers/Format/CQL.js",
- "OpenLayers/Format/OSM.js",
- "OpenLayers/Format/GPX.js",
- "OpenLayers/Format/Filter.js",
- "OpenLayers/Format/Filter/v1.js",
- "OpenLayers/Format/Filter/v1_0_0.js",
- "OpenLayers/Format/Filter/v1_1_0.js",
- "OpenLayers/Format/SLD.js",
- "OpenLayers/Format/SLD/v1.js",
- "OpenLayers/Format/SLD/v1_0_0.js",
- "OpenLayers/Format/OWSCommon/v1.js",
- "OpenLayers/Format/OWSCommon/v1_0_0.js",
- "OpenLayers/Format/OWSCommon/v1_1_0.js",
- "OpenLayers/Format/CSWGetDomain.js",
- "OpenLayers/Format/CSWGetDomain/v2_0_2.js",
- "OpenLayers/Format/CSWGetRecords.js",
- "OpenLayers/Format/CSWGetRecords/v2_0_2.js",
- "OpenLayers/Format/WFST.js",
- "OpenLayers/Format/WFST/v1.js",
- "OpenLayers/Format/WFST/v1_0_0.js",
- "OpenLayers/Format/WFST/v1_1_0.js",
- "OpenLayers/Format/Text.js",
- "OpenLayers/Format/JSON.js",
- "OpenLayers/Format/GeoJSON.js",
- "OpenLayers/Format/WMC.js",
- "OpenLayers/Format/WMC/v1.js",
- "OpenLayers/Format/WMC/v1_0_0.js",
- "OpenLayers/Format/WMC/v1_1_0.js",
- "OpenLayers/Format/WMSCapabilities.js",
- "OpenLayers/Format/WMSCapabilities/v1.js",
- "OpenLayers/Format/WMSCapabilities/v1_1.js",
- "OpenLayers/Format/WMSCapabilities/v1_1_0.js",
- "OpenLayers/Format/WMSCapabilities/v1_1_1.js",
- "OpenLayers/Format/WMSCapabilities/v1_3.js",
- "OpenLayers/Format/WMSCapabilities/v1_3_0.js",
- "OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js",
- "OpenLayers/Format/WMSGetFeatureInfo.js",
- "OpenLayers/Format/SOSCapabilities.js",
- "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
- "OpenLayers/Format/SOSGetFeatureOfInterest.js",
- "OpenLayers/Format/SOSGetObservation.js",
- "OpenLayers/Format/OWSContext.js",
- "OpenLayers/Format/OWSContext/v0_3_1.js",
- "OpenLayers/Format/WMTSCapabilities.js",
- "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
- "OpenLayers/Layer/WFS.js",
- "OpenLayers/Control/GetFeature.js",
- "OpenLayers/Control/MouseToolbar.js",
- "OpenLayers/Control/NavToolbar.js",
- "OpenLayers/Control/PanPanel.js",
- "OpenLayers/Control/Pan.js",
- "OpenLayers/Control/ZoomIn.js",
- "OpenLayers/Control/ZoomOut.js",
- "OpenLayers/Control/ZoomPanel.js",
- "OpenLayers/Control/EditingToolbar.js",
- "OpenLayers/Symbolizer.js",
- "OpenLayers/Symbolizer/Point.js",
- "OpenLayers/Symbolizer/Line.js",
- "OpenLayers/Symbolizer/Polygon.js",
- "OpenLayers/Symbolizer/Text.js",
- "OpenLayers/Symbolizer/Raster.js",
- "OpenLayers/Lang.js",
- "OpenLayers/Lang/en.js"
- ); // etc.
+ if (!jsFiles) {
+ jsFiles = [
+ "OpenLayers/BaseTypes/Class.js",
+ "OpenLayers/Util.js",
+ "OpenLayers/BaseTypes.js",
+ "OpenLayers/BaseTypes/Bounds.js",
+ "OpenLayers/BaseTypes/Element.js",
+ "OpenLayers/BaseTypes/LonLat.js",
+ "OpenLayers/BaseTypes/Pixel.js",
+ "OpenLayers/BaseTypes/Size.js",
+ "OpenLayers/Console.js",
+ "OpenLayers/Tween.js",
+ "Rico/Corner.js",
+ "Rico/Color.js",
+ "OpenLayers/Ajax.js",
+ "OpenLayers/Events.js",
+ "OpenLayers/Request.js",
+ "OpenLayers/Request/XMLHttpRequest.js",
+ "OpenLayers/Projection.js",
+ "OpenLayers/Map.js",
+ "OpenLayers/Layer.js",
+ "OpenLayers/Icon.js",
+ "OpenLayers/Marker.js",
+ "OpenLayers/Marker/Box.js",
+ "OpenLayers/Popup.js",
+ "OpenLayers/Tile.js",
+ "OpenLayers/Tile/Image.js",
+ "OpenLayers/Tile/Image/IFrame.js",
+ "OpenLayers/Tile/WFS.js",
+ "OpenLayers/Layer/Image.js",
+ "OpenLayers/Layer/SphericalMercator.js",
+ "OpenLayers/Layer/EventPane.js",
+ "OpenLayers/Layer/FixedZoomLevels.js",
+ "OpenLayers/Layer/Google.js",
+ "OpenLayers/Layer/Google/v3.js",
+ "OpenLayers/Layer/VirtualEarth.js",
+ "OpenLayers/Layer/Yahoo.js",
+ "OpenLayers/Layer/HTTPRequest.js",
+ "OpenLayers/Layer/Grid.js",
+ "OpenLayers/Layer/MapGuide.js",
+ "OpenLayers/Layer/MapServer.js",
+ "OpenLayers/Layer/MapServer/Untiled.js",
+ "OpenLayers/Layer/KaMap.js",
+ "OpenLayers/Layer/KaMapCache.js",
+ "OpenLayers/Layer/MultiMap.js",
+ "OpenLayers/Layer/Markers.js",
+ "OpenLayers/Layer/Text.js",
+ "OpenLayers/Layer/WorldWind.js",
+ "OpenLayers/Layer/ArcGIS93Rest.js",
+ "OpenLayers/Layer/WMS.js",
+ "OpenLayers/Layer/WMS/Untiled.js",
+ "OpenLayers/Layer/WMS/Post.js",
+ "OpenLayers/Layer/WMTS.js",
+ "OpenLayers/Layer/ArcIMS.js",
+ "OpenLayers/Layer/GeoRSS.js",
+ "OpenLayers/Layer/Boxes.js",
+ "OpenLayers/Layer/XYZ.js",
+ "OpenLayers/Layer/Bing.js",
+ "OpenLayers/Layer/TMS.js",
+ "OpenLayers/Layer/TileCache.js",
+ "OpenLayers/Layer/Zoomify.js",
+ "OpenLayers/Popup/Anchored.js",
+ "OpenLayers/Popup/AnchoredBubble.js",
+ "OpenLayers/Popup/Framed.js",
+ "OpenLayers/Popup/FramedCloud.js",
+ "OpenLayers/Feature.js",
+ "OpenLayers/Feature/Vector.js",
+ "OpenLayers/Feature/WFS.js",
+ "OpenLayers/Handler.js",
+ "OpenLayers/Handler/Click.js",
+ "OpenLayers/Handler/Hover.js",
+ "OpenLayers/Handler/Point.js",
+ "OpenLayers/Handler/Path.js",
+ "OpenLayers/Handler/Polygon.js",
+ "OpenLayers/Handler/Feature.js",
+ "OpenLayers/Handler/Drag.js",
+ "OpenLayers/Handler/RegularPolygon.js",
+ "OpenLayers/Handler/Box.js",
+ "OpenLayers/Handler/MouseWheel.js",
+ "OpenLayers/Handler/Keyboard.js",
+ "OpenLayers/Control.js",
+ "OpenLayers/Control/Attribution.js",
+ "OpenLayers/Control/Button.js",
+ "OpenLayers/Control/ZoomBox.js",
+ "OpenLayers/Control/ZoomToMaxExtent.js",
+ "OpenLayers/Control/DragPan.js",
+ "OpenLayers/Control/Navigation.js",
+ "OpenLayers/Control/MouseDefaults.js",
+ "OpenLayers/Control/MousePosition.js",
+ "OpenLayers/Control/OverviewMap.js",
+ "OpenLayers/Control/KeyboardDefaults.js",
+ "OpenLayers/Control/PanZoom.js",
+ "OpenLayers/Control/PanZoomBar.js",
+ "OpenLayers/Control/ArgParser.js",
+ "OpenLayers/Control/Permalink.js",
+ "OpenLayers/Control/Scale.js",
+ "OpenLayers/Control/ScaleLine.js",
+ "OpenLayers/Control/Snapping.js",
+ "OpenLayers/Control/Split.js",
+ "OpenLayers/Control/LayerSwitcher.js",
+ "OpenLayers/Control/DrawFeature.js",
+ "OpenLayers/Control/DragFeature.js",
+ "OpenLayers/Control/ModifyFeature.js",
+ "OpenLayers/Control/Panel.js",
+ "OpenLayers/Control/SelectFeature.js",
+ "OpenLayers/Control/NavigationHistory.js",
+ "OpenLayers/Control/Measure.js",
+ "OpenLayers/Control/WMSGetFeatureInfo.js",
+ "OpenLayers/Control/WMTSGetFeatureInfo.js",
+ "OpenLayers/Control/Graticule.js",
+ "OpenLayers/Control/TransformFeature.js",
+ "OpenLayers/Control/SLDSelect.js",
+ "OpenLayers/Geometry.js",
+ "OpenLayers/Geometry/Rectangle.js",
+ "OpenLayers/Geometry/Collection.js",
+ "OpenLayers/Geometry/Point.js",
+ "OpenLayers/Geometry/MultiPoint.js",
+ "OpenLayers/Geometry/Curve.js",
+ "OpenLayers/Geometry/LineString.js",
+ "OpenLayers/Geometry/LinearRing.js",
+ "OpenLayers/Geometry/Polygon.js",
+ "OpenLayers/Geometry/MultiLineString.js",
+ "OpenLayers/Geometry/MultiPolygon.js",
+ "OpenLayers/Geometry/Surface.js",
+ "OpenLayers/Renderer.js",
+ "OpenLayers/Renderer/Elements.js",
+ "OpenLayers/Renderer/SVG.js",
+ "OpenLayers/Renderer/Canvas.js",
+ "OpenLayers/Renderer/VML.js",
+ "OpenLayers/Layer/Vector.js",
+ "OpenLayers/Layer/Vector/RootContainer.js",
+ "OpenLayers/Strategy.js",
+ "OpenLayers/Strategy/Filter.js",
+ "OpenLayers/Strategy/Fixed.js",
+ "OpenLayers/Strategy/Cluster.js",
+ "OpenLayers/Strategy/Paging.js",
+ "OpenLayers/Strategy/BBOX.js",
+ "OpenLayers/Strategy/Save.js",
+ "OpenLayers/Strategy/Refresh.js",
+ "OpenLayers/Filter.js",
+ "OpenLayers/Filter/FeatureId.js",
+ "OpenLayers/Filter/Logical.js",
+ "OpenLayers/Filter/Comparison.js",
+ "OpenLayers/Filter/Spatial.js",
+ "OpenLayers/Protocol.js",
+ "OpenLayers/Protocol/HTTP.js",
+ "OpenLayers/Protocol/SQL.js",
+ "OpenLayers/Protocol/SQL/Gears.js",
+ "OpenLayers/Protocol/WFS.js",
+ "OpenLayers/Protocol/WFS/v1.js",
+ "OpenLayers/Protocol/WFS/v1_0_0.js",
+ "OpenLayers/Protocol/WFS/v1_1_0.js",
+ "OpenLayers/Protocol/SOS.js",
+ "OpenLayers/Protocol/SOS/v1_0_0.js",
+ "OpenLayers/Layer/PointTrack.js",
+ "OpenLayers/Layer/GML.js",
+ "OpenLayers/Style.js",
+ "OpenLayers/Style2.js",
+ "OpenLayers/StyleMap.js",
+ "OpenLayers/Rule.js",
+ "OpenLayers/Format.js",
+ "OpenLayers/Format/XML.js",
+ "OpenLayers/Format/Context.js",
+ "OpenLayers/Format/ArcXML.js",
+ "OpenLayers/Format/ArcXML/Features.js",
+ "OpenLayers/Format/GML.js",
+ "OpenLayers/Format/GML/Base.js",
+ "OpenLayers/Format/GML/v2.js",
+ "OpenLayers/Format/GML/v3.js",
+ "OpenLayers/Format/Atom.js",
+ "OpenLayers/Format/KML.js",
+ "OpenLayers/Format/GeoRSS.js",
+ "OpenLayers/Format/WFS.js",
+ "OpenLayers/Format/WFSCapabilities.js",
+ "OpenLayers/Format/WFSCapabilities/v1.js",
+ "OpenLayers/Format/WFSCapabilities/v1_0_0.js",
+ "OpenLayers/Format/WFSCapabilities/v1_1_0.js",
+ "OpenLayers/Format/WFSDescribeFeatureType.js",
+ "OpenLayers/Format/WMSDescribeLayer.js",
+ "OpenLayers/Format/WMSDescribeLayer/v1_1.js",
+ "OpenLayers/Format/WKT.js",
+ "OpenLayers/Format/CQL.js",
+ "OpenLayers/Format/OSM.js",
+ "OpenLayers/Format/GPX.js",
+ "OpenLayers/Format/Filter.js",
+ "OpenLayers/Format/Filter/v1.js",
+ "OpenLayers/Format/Filter/v1_0_0.js",
+ "OpenLayers/Format/Filter/v1_1_0.js",
+ "OpenLayers/Format/SLD.js",
+ "OpenLayers/Format/SLD/v1.js",
+ "OpenLayers/Format/SLD/v1_0_0.js",
+ "OpenLayers/Format/OWSCommon/v1.js",
+ "OpenLayers/Format/OWSCommon/v1_0_0.js",
+ "OpenLayers/Format/OWSCommon/v1_1_0.js",
+ "OpenLayers/Format/CSWGetDomain.js",
+ "OpenLayers/Format/CSWGetDomain/v2_0_2.js",
+ "OpenLayers/Format/CSWGetRecords.js",
+ "OpenLayers/Format/CSWGetRecords/v2_0_2.js",
+ "OpenLayers/Format/WFST.js",
+ "OpenLayers/Format/WFST/v1.js",
+ "OpenLayers/Format/WFST/v1_0_0.js",
+ "OpenLayers/Format/WFST/v1_1_0.js",
+ "OpenLayers/Format/Text.js",
+ "OpenLayers/Format/JSON.js",
+ "OpenLayers/Format/GeoJSON.js",
+ "OpenLayers/Format/WMC.js",
+ "OpenLayers/Format/WMC/v1.js",
+ "OpenLayers/Format/WMC/v1_0_0.js",
+ "OpenLayers/Format/WMC/v1_1_0.js",
+ "OpenLayers/Format/WMSCapabilities.js",
+ "OpenLayers/Format/WMSCapabilities/v1.js",
+ "OpenLayers/Format/WMSCapabilities/v1_1.js",
+ "OpenLayers/Format/WMSCapabilities/v1_1_0.js",
+ "OpenLayers/Format/WMSCapabilities/v1_1_1.js",
+ "OpenLayers/Format/WMSCapabilities/v1_3.js",
+ "OpenLayers/Format/WMSCapabilities/v1_3_0.js",
+ "OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js",
+ "OpenLayers/Format/WMSGetFeatureInfo.js",
+ "OpenLayers/Format/SOSCapabilities.js",
+ "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
+ "OpenLayers/Format/SOSGetFeatureOfInterest.js",
+ "OpenLayers/Format/SOSGetObservation.js",
+ "OpenLayers/Format/OWSContext.js",
+ "OpenLayers/Format/OWSContext/v0_3_1.js",
+ "OpenLayers/Format/WMTSCapabilities.js",
+ "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+ "OpenLayers/Layer/WFS.js",
+ "OpenLayers/Control/GetFeature.js",
+ "OpenLayers/Control/MouseToolbar.js",
+ "OpenLayers/Control/NavToolbar.js",
+ "OpenLayers/Control/PanPanel.js",
+ "OpenLayers/Control/Pan.js",
+ "OpenLayers/Control/ZoomIn.js",
+ "OpenLayers/Control/ZoomOut.js",
+ "OpenLayers/Control/ZoomPanel.js",
+ "OpenLayers/Control/EditingToolbar.js",
+ "OpenLayers/Symbolizer.js",
+ "OpenLayers/Symbolizer/Point.js",
+ "OpenLayers/Symbolizer/Line.js",
+ "OpenLayers/Symbolizer/Polygon.js",
+ "OpenLayers/Symbolizer/Text.js",
+ "OpenLayers/Symbolizer/Raster.js",
+ "OpenLayers/Lang.js",
+ "OpenLayers/Lang/en.js"
+ ]; // etc.
// use "parser-inserted scripts" for guaranteed execution order
// http://hsivonen.iki.fi/script-execution/
- var allScriptTags = new Array(jsfiles.length);
- var host = OpenLayers._getScriptLocation() + "lib/";
- for (var i=0, len=jsfiles.length; i<len; i++) {
- allScriptTags[i] = "<script src='" + host + jsfiles[i] +
+ var scriptTags = new Array(jsFiles.length);
+ var host = OpenLayers._getScriptLocation() + "lib/";
+ for (var i=0, len=jsFiles.length; i<len; i++) {
+ scriptTags[i] = "<script src='" + host + jsFiles[i] +
"'></script>";
- document.write(allScriptTags.join(""));
+ if (scriptTags.length > 0) {
+ document.write(scriptTags.join(""));
Modified: sandbox/elemoine/draw-feature/tests/Format/WMTSCapabilities/v1_0_0.html
--- sandbox/elemoine/draw-feature/tests/Format/WMTSCapabilities/v1_0_0.html 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/tests/Format/WMTSCapabilities/v1_0_0.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -110,7 +110,7 @@
function test_createLayer(t) {
- t.plan(6);
+ t.plan(7);
var format = new OpenLayers.Format.WMTSCapabilities();
@@ -153,7 +153,7 @@
t.eq(layer.matrixIds.length, 2, "correct matrixIds length");
t.eq(layer.name, "Coastlines", "correct layer title");
+ t.eq(layer.style, "DarkBlue", "correct style identifier");
</script>
Modified: sandbox/elemoine/draw-feature/tests/Layer/Google/v3.html
--- sandbox/elemoine/draw-feature/tests/Layer/Google/v3.html 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/tests/Layer/Google/v3.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -3,6 +3,7 @@
<script src="http://maps.google.com/maps/api/js?sensor=false"></script>
<script src="../../../lib/OpenLayers.js"></script>
var layer;
function test_Layer_Google_constructor (t) {
@@ -265,6 +266,12 @@
t.plan(8);
+ var origPrecision = OpenLayers.Util.DEFAULT_PRECISION;
+ // GMaps v3 seems to use a default precision of 13, which is lower
+ // than what we use in OpenLayers.
+ // See http://trac.osgeo.org/openlayers/ticket/3059
+ OpenLayers.Util.DEFAULT_PRECISION = 13;
var map = new OpenLayers.Map('map', {allOverlays: true});
var gmap = new OpenLayers.Layer.Google("Google Streets");
@@ -275,16 +282,18 @@
map.setCenter(origin, 4);
var resolution = map.getResolution();
- var dx, dy, center, expectedX, expectedY;
+ var dx, dy, center, expected;
// confirm that panning works with Google visible
dx = 100, dy = -100;
map.pan(dx, dy, {animate: false});
center = map.getCenter();
- expectedX = origin.lon + (resolution * dx);
- expectedY = origin.lat - (resolution * dy);
- t.eq(center.lon, expectedX, "x panning with Google visible " + dx + ", " + dy);
- t.eq(center.lat, expectedY, "y panning with Google visible " + dx + ", " + dy);
+ expected = new OpenLayers.LonLat(
+ origin.lon + (resolution * dx),
+ origin.lat - (resolution * dy)
+ t.eq(center.lon, expected.lon, "x panning with Google visible " + dx + ", " + dy);
+ t.eq(center.lat, expected.lat, "y panning with Google visible " + dx + ", " + dy);
map.pan(-dx, -dy, {animate: false});
t.eq(center.lon, origin.lon, "x panning with Google visible " + (-dx) + ", " + (-dy));
@@ -295,22 +304,30 @@
- t.eq(center.lon, expectedX, "x panning with Google invisible " + dx + ", " + dy);
- t.eq(center.lat, expectedY, "y panning with Google invisible " + dx + ", " + dy);
+ t.eq(center.lon, expected.lon, "x panning with Google invisible " + dx + ", " + dy);
+ t.eq(center.lat, expected.lat, "y panning with Google invisible " + dx + ", " + dy);
t.eq(center.lon, origin.lon, "x panning with Google invisible " + (-dx) + ", " + (-dy));
t.eq(center.lat, origin.lat, "y panning with Google invisible " + (-dx) + ", " + (-dy));
map.destroy();
+ OpenLayers.Util.DEFAULT_PRECISION = origPrecision;
function test_wrapDateLine(t) {
t.plan(2);
var map = new OpenLayers.Map("map");
@@ -322,14 +339,15 @@
// pan to the edge of the world
map.pan(256, 0, {animate: false});
- t.eq(center.lon, 20037508.3392, "edge of the world");
+ t.eq(center.lon, 20037508.34, "edge of the world");
// pan off the edge of the world
map.pan(100, 0, {animate: false});
- t.eq(center.lon, -12210356.6442, "magically back in the western hemisphere");
+ var expect = OpenLayers.Util.toFloat(100 * map.getResolution() - 20037508.34);
+ t.eq(center.lon, expect, "magically back in the western hemisphere");
map.destroy();
function test_respectDateLine(t) {
@@ -346,16 +364,16 @@
- t.eq(center.lon, 20037508.3392, "whew, still on the edge");
+ t.eq(center.lon, 20037508.34, "whew, still on the edge");
map.destroy();
</script>
</head>
<body>
Modified: sandbox/elemoine/draw-feature/tests/Request.html
--- sandbox/elemoine/draw-feature/tests/Request.html 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/tests/Request.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -20,7 +20,7 @@
function test_issue(t) {
setup();
- t.plan(21);
+ t.plan(22);
var request, config;
var proto = OpenLayers.Request.XMLHttpRequest.prototype;
var issue = OpenLayers.Function.bind(OpenLayers.Request.issue,
@@ -81,7 +81,18 @@
t.eq(url, config.url + "&foo=bar", "existing query string gets extended with &");
request = issue(config);
+ // test that query string doesn't get ? followed by &
+ config = {
+ method: "GET",
+ url: "http://example.com/service?",
+ params: {"foo": "bar"}
+ proto.open = function(method, url, async, user, password) {
+ t.eq(url, config.url + "foo=bar", "existing query string ending with ? gets extended without &");
+ request = issue(config);
// reset open method
proto.open = _open;
Modified: sandbox/elemoine/draw-feature/tests/Util.html
--- sandbox/elemoine/draw-feature/tests/Util.html 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/tests/Util.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -5,16 +5,20 @@
var custom$ = function() {};
window.$ = custom$;
</script>
- <script src="../lib/OpenLayers/SingleFile.js"></script>
- <script src="../lib/OpenLayers/BaseTypes/Class.js"></script>
- <script src="../lib/OpenLayers/Util.js"></script>
- <script src="../lib/OpenLayers/BaseTypes.js"></script>
- <script src="../lib/OpenLayers/BaseTypes/Element.js"></script>
- <script src="../lib/OpenLayers/BaseTypes/LonLat.js"></script>
- <script src="../lib/OpenLayers/BaseTypes/Pixel.js"></script>
- <script src="../lib/OpenLayers/BaseTypes/Size.js"></script>
- <script src="../lib/OpenLayers/Lang.js"></script>
- <script src="../lib/OpenLayers/Console.js"></script>
+ <script>
+ var OpenLayers = [
+ </script>
var isMozilla = (navigator.userAgent.indexOf("compatible") == -1);
var map;
Modified: sandbox/elemoine/draw-feature/tests/list-tests.html
--- sandbox/elemoine/draw-feature/tests/list-tests.html 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/tests/list-tests.html 2011-02-17 23:02:31 UTC (rev 11141)
@@ -163,6 +163,7 @@
<li>OpenLayers2.html</li>
<li>OpenLayers3.html</li>
<li>OpenLayers4.html</li>
+ <li>OpenLayersJsFiles.html</li>
<li>Popup.html</li>
<li>Popup/Anchored.html</li>
<li>Popup/AnchoredBubble.html</li>
Modified: sandbox/elemoine/draw-feature/theme/default/style.css
--- sandbox/elemoine/draw-feature/theme/default/style.css 2011-02-17 22:21:50 UTC (rev 11140)
+++ sandbox/elemoine/draw-feature/theme/default/style.css 2011-02-17 23:02:31 UTC (rev 11141)
@@ -93,11 +93,13 @@
.olControlOverviewMapMinimizeButton {
right: 0px;
bottom: 80px;
+ cursor: pointer;
.olControlOverviewMapMaximizeButton {
right: 0px;
bottom: 80px;
+ cursor: pointer;
.olControlOverviewMapExtentRectangle {
@@ -402,6 +404,7 @@
.olControlLayerSwitcher .minimizeDiv {
top: 5px;
right: 0px;
+ cursor: pointer;
.olBingAttribution {
More information about the Commits
