[OpenLayers-Commits] r11142 - in trunk/openlayers:
lib/OpenLayers/Format/WMTSCapabilities tests/Format/WMTSCapabilities
commits-20090109 at openlayers.org
Fri Feb 18 02:14:27 EST 2011
Author: fredj
Date: 2011-02-17 23:14:27 -0800 (Thu, 17 Feb 2011)
New Revision: 11142
trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities/v1_0_0.js
trunk/openlayers/tests/Format/WMTSCapabilities/v1_0_0.html
save the resourceUrl elements into the WMTS capabilities object. r=bartvde (closes #2986)
Modified: trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities/v1_0_0.js 2011-02-17 23:02:31 UTC (rev 11141)
+++ trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities/v1_0_0.js 2011-02-18 07:14:27 UTC (rev 11142)
@@ -191,7 +191,14 @@
"MatrixHeight": function(node, obj) {
obj.matrixHeight = parseInt(this.getChildValue(node));
+ "ResourceURL": function(node, obj) {
+ obj.resourceUrl = obj.resourceUrl || {};
+ obj.resourceUrl[node.getAttribute("resourceType")] = {
+ format: node.getAttribute("format"),
+ template: node.getAttribute("template")
// not used for now, can be added in the future though
/*"Themes": function(node, obj) {
obj.themes = [];
Modified: trunk/openlayers/tests/Format/WMTSCapabilities/v1_0_0.html
--- trunk/openlayers/tests/Format/WMTSCapabilities/v1_0_0.html 2011-02-17 23:02:31 UTC (rev 11141)
+++ trunk/openlayers/tests/Format/WMTSCapabilities/v1_0_0.html 2011-02-18 07:14:27 UTC (rev 11142)
@@ -36,7 +36,7 @@
function test_layers(t) {
- t.plan(21);
+ t.plan(25);
var xml = document.getElementById("ogcsample").firstChild.nodeValue;
var doc = new OpenLayers.Format.XML().read(xml);
@@ -75,7 +75,14 @@
t.eq(wgs84Bbox.right, 180.0, "wgs84BoudingBox right is correct");
t.eq(wgs84Bbox.bottom, -90.0, "wgs84BoudingBox bottom is correct");
t.eq(wgs84Bbox.top, 90.0, "wgs84BoudingBox top is correct");
+ t.eq(layer.resourceUrl.tile.format, "image/png", "resourceUrl.tile.format is correct");
+ t.eq(layer.resourceUrl.tile.template, "http://www.example.com/wmts/coastlines/{TileMatrix}/{TileRow}/{TileCol}.png",
+ "resourceUrl.tile.template is correct");
+ t.eq(layer.resourceUrl.FeatureInfo.format, "application/gml+xml; version=3.1", "resourceUrl.FeatureInfo.format is correct");
+ t.eq(layer.resourceUrl.FeatureInfo.template, "http://www.example.com/wmts/coastlines/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}/{J}/{I}.xml",
+ "resourceUrl.FeatureInfo.template is correct");
function test_tileMatrixSets(t) {
@@ -240,6 +247,10 @@
<ows:UpperCorner>180 90</ows:UpperCorner>
</ows:WGS84BoundingBox>
<ows:Identifier>coastlines</ows:Identifier>
+ <ResourceURL format="image/png" resourceType="tile"
+ template="http://www.example.com/wmts/coastlines/{TileMatrix}/{TileRow}/{TileCol}.png" />
+ <ResourceURL format="application/gml+xml; version=3.1" resourceType="FeatureInfo"
+ template="http://www.example.com/wmts/coastlines/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}/{J}/{I}.xml" />
<Style isDefault="true">
<ows:Title>Dark Blue</ows:Title>
<ows:Identifier>DarkBlue</ows:Identifier>
More information about the Commits
