[OpenLayers-Commits] r11375 - in sandbox/ahocevar/layercontainer: . examples lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Handler tests tests/BaseTypes tests/Control tests/Handler tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 17:52:52 EST 2011
Author: ahocevar
Date: 2011-02-23 14:52:52 -0800 (Wed, 23 Feb 2011)
New Revision: 11375
   sandbox/ahocevar/layercontainer/
   sandbox/ahocevar/layercontainer/examples/controls.html
   sandbox/ahocevar/layercontainer/examples/geolocation.html
   sandbox/ahocevar/layercontainer/examples/geolocation.js
   sandbox/ahocevar/layercontainer/examples/mobile-navigation.html
   sandbox/ahocevar/layercontainer/examples/style.css
   sandbox/ahocevar/layercontainer/lib/OpenLayers/BaseTypes.js
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Control/Geolocate.js
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Handler/Drag.js
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Kinetic.js
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
   sandbox/ahocevar/layercontainer/tests/BaseTypes/Bounds.html
   sandbox/ahocevar/layercontainer/tests/BaseTypes/LonLat.html
   sandbox/ahocevar/layercontainer/tests/BaseTypes/Pixel.html
   sandbox/ahocevar/layercontainer/tests/Control/Geolocate.html
   sandbox/ahocevar/layercontainer/tests/Control/PanZoom.html
   sandbox/ahocevar/layercontainer/tests/Control/Scale.html
   sandbox/ahocevar/layercontainer/tests/Handler/Drag.html
   sandbox/ahocevar/layercontainer/tests/Layer/EventPane.html
   sandbox/ahocevar/layercontainer/tests/Map.html
   sandbox/ahocevar/layercontainer/tests/run-tests.html
merging from trunk
Property changes on: sandbox/ahocevar/layercontainer
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11266-11374
Modified: sandbox/ahocevar/layercontainer/examples/controls.html
--- sandbox/ahocevar/layercontainer/examples/controls.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/examples/controls.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -64,8 +64,8 @@
             Attach zooming, panning, layer switcher, overview map, and permalink map controls to an OpenLayers window.
         </p>
-        <a style="float:right" href="" id="permalink">Permalink</a>
         <div id="map" class="smallmap"></div>
+        <a href="#" id="permalink">Permalink</a>
         <div id="docs"></div>
     </body>
Modified: sandbox/ahocevar/layercontainer/examples/geolocation.html
--- sandbox/ahocevar/layercontainer/examples/geolocation.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/examples/geolocation.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -13,7 +13,7 @@
         </style>
     </head>
-    <body onload="init()">
+    <body>
         <h1 id="title">Geolocation Example</h1>
         <div id="tags">
Modified: sandbox/ahocevar/layercontainer/examples/geolocation.js
--- sandbox/ahocevar/layercontainer/examples/geolocation.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/examples/geolocation.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -1,8 +1,7 @@
 var style = {
+    fillColor: '#000',
     fillOpacity: 0.1,
-    fillColor: '#000',
-    strokeColor: '#f00',
-    strokeOpacity: 0.6
+    strokeWidth: 0
 var map = new OpenLayers.Map('map');
@@ -17,6 +16,34 @@
     ), 12
+var pulsate = function(feature) {
+    var point = feature.geometry.getCentroid(),
+        bounds = feature.geometry.getBounds(),
+        radius = Math.abs((bounds.right - bounds.left)/2),
+        count = 0,
+        grow = 'up';
+    var resize = function(){
+        if (count>16) clearInterval(window.resizeInterval);
+        var interval = radius * 0.03;
+        var ratio = interval/radius;
+        switch(count) {
+            case 4:
+            case 12:
+                grow = 'down'; break;
+            case 8:
+                grow = 'up'; break;
+        if (grow!=='up') {
+            ratio = - Math.abs(ratio);
+        feature.geometry.resize(1+ratio, point);
+        vector.drawFeature(feature);
+        count++;
+    window.resizeInterval = window.setInterval(resize, 50, point, radius);
 var geolocate = new OpenLayers.Control.Geolocate({
     geolocationOptions: {
         enableHighAccuracy: false,
@@ -27,6 +54,16 @@
 map.addControl(geolocate);
 geolocate.events.register("locationupdated",this,function(e) {
     vector.removeAllFeatures();
+    var circle = new OpenLayers.Feature.Vector(
+        OpenLayers.Geometry.Polygon.createRegularPolygon(
+            new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+            e.position.coords.accuracy/2,
+            40,
+            0
+        style
     vector.addFeatures([
             e.point,
@@ -39,34 +76,28 @@
                 pointRadius: 10
-        new OpenLayers.Feature.Vector(
-            OpenLayers.Geometry.Polygon.createRegularPolygon(
-                new OpenLayers.Geometry.Point(e.point.x, e.point.y),
-                e.position.coords.accuracy/2,
-                50,
-                0
-            style
+        circle
     map.zoomToExtent(vector.getDataExtent());
+    pulsate(circle);
 geolocate.events.register("locationfailed",this,function() {
     OpenLayers.Console.log('Location detection failed');
 $('locate').onclick = function() {
+    vector.removeAllFeatures();
     geolocate.deactivate();
     $('track').checked = false;
     geolocate.watch = false;
     geolocate.activate();
 $('track').onclick = function() {
     if (this.checked) {
         geolocate.watch = true;
-$('track').checked = false;
\ No newline at end of file
+$('track').checked = false;
Modified: sandbox/ahocevar/layercontainer/examples/mobile-navigation.html
--- sandbox/ahocevar/layercontainer/examples/mobile-navigation.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/examples/mobile-navigation.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -3,7 +3,7 @@
   <head>
     <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
     <meta name="apple-mobile-web-app-capable" content="yes" />
-    <title>OpenLayers TouchNavigation Control</title>
+    <title>Mobile Navigation Example</title>
     <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
     <link rel="stylesheet" href="style.mobile.css" type="text/css" />
     <link rel="stylesheet" href="style.css" type="text/css" />
Modified: sandbox/ahocevar/layercontainer/examples/style.css
--- sandbox/ahocevar/layercontainer/examples/style.css	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/examples/style.css	2011-02-23 22:52:52 UTC (rev 11375)
@@ -121,3 +121,19 @@
         display : none;
+ at media only screen and (orientation: landscape) and (max-width: 600px) {
+    #shortdesc {
+       float: right;
+       width: 25%;
+    #map {
+        width: 70%;
+    #docs {
+        font-size: 12px;
+body {
+    -webkit-text-size-adjust: none;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/BaseTypes.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/BaseTypes.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/BaseTypes.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -632,9 +632,11 @@
      * APIMethod: parse
      * Generate a date object from a string.  The format for the string follows
      *     the profile of ISO 8601 for date and time on the Internet (see
-     *     http://tools.ietf.org/html/rfc3339).  If the parse method on
-     *     the Date constructor returns a valid date for the given string,
-     *     that method is used.
+     *     http://tools.ietf.org/html/rfc3339).  We don't call the native
+     *     Date.parse because of inconsistency between implmentations.  In
+     *     Chrome, calling Date.parse with a string that doesn't contain any
+     *     indication of the timezone (e.g. "2011"), the date is interpreted
+     *     in local time.  On Firefox, the assumption is UTC.
      * Parameters:
      * str - {String} A string representing the date (e.g.
@@ -647,37 +649,31 @@
     parse: function(str) {
         var date;
-        // first check if the native parse method can parse it
-        var elapsed = Date.parse(str);
-        if (!isNaN(elapsed)) {
-            date = new Date(elapsed);
-        } else {
-            var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-            if (match && (match[1] || match[7])) { // must have at least year or time
-                var year = parseInt(match[1], 10) || 0;
-                var month = (parseInt(match[2], 10) - 1) || 0;
-                var day = parseInt(match[3], 10) || 1;
-                date = new Date(Date.UTC(year, month, day));
-                // optional time
-                var type = match[7];
-                if (type) {
-                    var hours = parseInt(match[4], 10);
-                    var minutes = parseInt(match[5], 10);
-                    var secFrac = parseFloat(match[6]);
-                    var seconds = secFrac | 0;
-                    var milliseconds = Math.round(1000 * (secFrac - seconds));
-                    date.setUTCHours(hours, minutes, seconds, milliseconds);
-                    // check offset
-                    if (type !== "Z") {
-                        var hoursOffset = parseInt(type, 10);
-                        var minutesOffset = parseInt(match[8], 10) || 0;
-                        var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
-                        date = new Date(date.getTime() + offset);
+        var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
+        if (match && (match[1] || match[7])) { // must have at least year or time
+            var year = parseInt(match[1], 10) || 0;
+            var month = (parseInt(match[2], 10) - 1) || 0;
+            var day = parseInt(match[3], 10) || 1;
+            date = new Date(Date.UTC(year, month, day));
+            // optional time
+            var type = match[7];
+            if (type) {
+                var hours = parseInt(match[4], 10);
+                var minutes = parseInt(match[5], 10);
+                var secFrac = parseFloat(match[6]);
+                var seconds = secFrac | 0;
+                var milliseconds = Math.round(1000 * (secFrac - seconds));
+                date.setUTCHours(hours, minutes, seconds, milliseconds);
+                // check offset
+                if (type !== "Z") {
+                    var hoursOffset = parseInt(type, 10);
+                    var minutesOffset = parseInt(match[8], 10) || 0;
+                    var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
+                    date = new Date(date.getTime() + offset);
-            } else {
-                date = new Date("invalid");
+        } else {
+            date = new Date("invalid");
         return date;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Control/Geolocate.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Control/Geolocate.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Control/Geolocate.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -85,7 +85,7 @@
             this.events.triggerEvent("locationuncapable");
             return false;
-        if (!this.active) {
+        if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
             if (this.watch) {
                 this.watchId = this.geolocation.watchPosition(
                     OpenLayers.Function.bind(this.geolocate, this),
@@ -93,16 +93,11 @@
                     this.geolocationOptions
             } else {
-                this.geolocation.getCurrentPosition(
-                    OpenLayers.Function.bind(this.geolocate, this),
-                    OpenLayers.Function.bind(this.failure, this),
-                    this.geolocationOptions
+                this.getCurrentLocation();
+            return true;
-        return OpenLayers.Control.prototype.activate.apply(
-            this, arguments
+        return false;
@@ -146,6 +141,25 @@
+     * APIMethod: getCurrentLocation
+     * Returns:
+     * {Boolean} Returns true if a event will be fired (successfull
+     * registration)
+    getCurrentLocation: function() {
+        if (!this.active || this.watch) {
+            return false;
+        this.geolocation.getCurrentPosition(
+            OpenLayers.Function.bind(this.geolocate, this),
+            OpenLayers.Function.bind(this.failure, this),
+            this.geolocationOptions
+        return true;
      * Method: failure
      * method called on browser's geolocation failure
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Handler/Drag.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Handler/Drag.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Handler/Drag.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -156,9 +156,7 @@
             this.down(evt);
             this.callback("down", [evt.xy]);
-            if (evt.type === "mousedown") {
-                OpenLayers.Event.stop(evt);
+            OpenLayers.Event.stop(evt);
             if(!this.oldOnselectstart) {
                 this.oldOnselectstart = document.onselectstart ?
@@ -204,9 +202,7 @@
                     this.interval);
             this.dragging = true;
-            if (evt.type === "touchmove") {
             this.move(evt);
             this.callback("move", [evt.xy]);
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Kinetic.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Kinetic.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Kinetic.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -63,7 +63,6 @@
      * Method: begin
      * Begins the dragging.
     begin: function() {
@@ -74,8 +73,10 @@
      * Method: update
+     * Updates during the dragging.
-     * Updates during the dragging.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The new position.
     update: function(xy) {
         this.points.unshift({xy: xy, tick: new Date().getTime()});
@@ -86,8 +87,15 @@
      * Method: end
+     * Ends the dragging, start the kinetic.
-     * Ends the dragging, start the kinetic.
+     * Parameters:
+     * xy - {<OpenLayers.Pixel>} The last position.
+     * Returns:
+     * {Object} An object with two properties: "speed", and "theta". The
+     *     "speed" and "theta" values are to be passed to the move
+     *     function when starting the animation.
     end: function(xy) {
         var last, now = new Date().getTime();
@@ -117,12 +125,13 @@
      * Method: move
      * Launch the kinetic move pan.
      * Parameters:
-     * info - {Object}
-     * callback - arguments x, y (values to pan), end (is the last point)
+     * info - {Object} An object with two properties, "speed", and "theta".
+     *     These values are those returned from the "end" call.
+     * callback - {Function} Function called on every step of the animation,
+     *     receives x, y (values to pan), end (is the last point).
     move: function(info, callback) {
         var v0 = info.speed;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-23 22:52:52 UTC (rev 11375)
@@ -506,18 +506,27 @@
         this.viewPortDiv.className = "olMapViewport";
         this.div.appendChild(this.viewPortDiv);
+        // the eventsDiv is where we listen for all map events
+        var eventsDiv = document.createElement("div");
+        eventsDiv.id = this.id + "_events";
+        eventsDiv.style.position = "absolute";
+        eventsDiv.style.width = "100%";
+        eventsDiv.style.height = "100%";
+        eventsDiv.style.zIndex = this.Z_INDEX_BASE.Control - 1;
+        this.viewPortDiv.appendChild(eventsDiv);
+        this.eventsDiv = eventsDiv;
+        this.events = new OpenLayers.Events(
+            this, this.eventsDiv, this.EVENT_TYPES, this.fallThrough,
+            {includeXY: true}
         // the layerContainerDiv is the one that holds all the layers
         id = this.id + "_OpenLayers_Container";
         this.layerContainerDiv = OpenLayers.Util.createDiv(id);
         this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;
-        this.viewPortDiv.appendChild(this.layerContainerDiv);
+        this.eventsDiv.appendChild(this.layerContainerDiv);
-        this.events = new OpenLayers.Events(this,
-                                            this.viewPortDiv,
-                                            this.EVENT_TYPES,
-                                            this.fallThrough,
-                                            {includeXY: true});
         this.updateSize();
         if(this.eventListeners instanceof Object) {
             this.events.on(this.eventListeners);
Modified: sandbox/ahocevar/layercontainer/tests/BaseTypes/Bounds.html
--- sandbox/ahocevar/layercontainer/tests/BaseTypes/Bounds.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/BaseTypes/Bounds.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -606,6 +606,7 @@
         t.ok( bounds.equals(b), "bounds is set correctly");
     //null values
+        OpenLayers.Lang.setCode('en');
         var desiredMsg = "You must pass both x and y values to the add function.";
         OpenLayers.Console.error = function(msg) {
             t.eq(msg, desiredMsg, "error correctly reported");
Modified: sandbox/ahocevar/layercontainer/tests/BaseTypes/LonLat.html
--- sandbox/ahocevar/layercontainer/tests/BaseTypes/LonLat.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/BaseTypes/LonLat.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -64,6 +64,7 @@
         t.ok( addpx.equals(ll), "addpx is set correctly");
     //null values
         var desiredMsg = "You must pass both lon and lat values to the add function.";
Modified: sandbox/ahocevar/layercontainer/tests/BaseTypes/Pixel.html
--- sandbox/ahocevar/layercontainer/tests/BaseTypes/Pixel.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/BaseTypes/Pixel.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -74,6 +74,7 @@
         t.ok( pixel.equals(px), "returned pixel is correct");
     //null values
Modified: sandbox/ahocevar/layercontainer/tests/Control/Geolocate.html
--- sandbox/ahocevar/layercontainer/tests/Control/Geolocate.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Control/Geolocate.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -62,6 +62,31 @@
         map.removeControl(control);
         map.setCenter(centerLL);
+    function test_getCurrentLocation(t) {
+        t.plan(5);
+        var control = new OpenLayers.Control.Geolocate({
+            geolocation: geolocation
+        map.addControl(control);
+        t.eq(control.getCurrentLocation(), false, 'getCurrentLocation return false if control hasnt been activated');
+        control.activate();
+        map.setCenter(centerLL);
+        t.eq(control.getCurrentLocation(), true, 'getCurrentLocation return true if control has been activated');
+        var center = map.getCenter();
+        t.eq(center.lon, 10, 'bound control sets the map lon when calling getCurrentLocation');
+        t.eq(center.lat, 10, 'bound control sets the map lat when calling getCurrentLocation');
+        control.deactivate();
+        map.removeControl(control);
+        var control2 = new OpenLayers.Control.Geolocate({
+        map.addControl(control2);
+        t.eq(control2.getCurrentLocation(), false, 'getCurrentLocation return false if control is in watch mode');
+        control2.deactivate();
+        map.removeControl(control2);
     function test_watch(t) {
         t.plan(2);
Modified: sandbox/ahocevar/layercontainer/tests/Control/PanZoom.html
--- sandbox/ahocevar/layercontainer/tests/Control/PanZoom.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Control/PanZoom.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -72,65 +72,65 @@
                     simulateClick(wnd, wnd.control.buttons[0]);
                     t.delay_call(2, function() {
-                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "Pan up works correctly" );
-                        t.ok(!flag.mousedown, "mousedown does not get to the map");
-                        t.ok(flag.mouseup, "mouseup does get to the map");
-                        t.ok(!flag.click, "click does not get to the map");
-                        t.ok(!flag.dblclick, "dblclick does not get to the map");
+                        t.ok( wnd.mapper.getCenter().lat > wnd.centerLL.lat, "1) Pan up works correctly" );
+                        t.ok(!flag.mousedown, "1) mousedown does not get to the map");
+                        t.ok(!flag.mouseup, "1) mouseup does not get to the map");
+                        t.ok(!flag.click, "1) click does not get to the map");
+                        t.ok(!flag.dblclick, "1) dblclick does not get to the map");
                         resetFlags();
                         simulateClick(wnd, wnd.control.buttons[1]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "Pan left works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon < wnd.centerLL.lon, "2) Pan left works correctly" );
+                    t.ok(!flag.mousedown, "2) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "2) mouseup does not get to the map");
+                    t.ok(!flag.click, "2) click does not get to the map");
+                    t.ok(!flag.dblclick, "2) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[2]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "Pan right works correctly" );
+                    t.ok( wnd.mapper.getCenter().lon == wnd.centerLL.lon, "3) Pan right works correctly" );
+                    t.ok(!flag.mousedown, "3) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "3) mouseup does not get to the map");
+                    t.ok(!flag.click, "3) click does not get to the map");
+                    t.ok(!flag.dblclick, "3) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[3]);
                     }, 2, function() {
-                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "Pan down works correctly" );
+                    t.ok( wnd.mapper.getCenter().lat == wnd.centerLL.lat, "4) Pan down works correctly" );
+                    t.ok(!flag.mousedown, "4) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "4) mouseup does not get to the map");
+                    t.ok(!flag.click, "4) click does not get to the map");
+                    t.ok(!flag.dblclick, "4) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[4]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 6, "zoomin works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 6, "5) zoomin works correctly" );
+                    t.ok(!flag.mousedown, "5) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "5) mouseup does not get to the map");
+                    t.ok(!flag.click, "5) click does not get to the map");
+                    t.ok(!flag.dblclick, "5) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[6]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 5, "zoomout works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 5, "6) zoomout works correctly" );
+                    t.ok(!flag.mousedown, "6) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "6) mouseup does not get to the map");
+                    t.ok(!flag.click, "6) click does not get to the map");
+                    t.ok(!flag.dblclick, "6) dblclick does not get to the map");
                     resetFlags();
                     simulateClick(wnd, wnd.control.buttons[5]);
                     }, 2, function() {
-                    t.eq( wnd.mapper.getZoom(), 2, "zoomworld works correctly" );
+                    t.eq( wnd.mapper.getZoom(), 2, "7) zoomworld works correctly" );
+                    t.ok(!flag.mousedown, "7) mousedown does not get to the map");
+                    t.ok(!flag.mouseup, "7) mouseup does not get to the map");
+                    t.ok(!flag.click, "7) click does not get to the map");
+                    t.ok(!flag.dblclick, "7) dblclick does not get to the map");
                     resetFlags();
Modified: sandbox/ahocevar/layercontainer/tests/Control/Scale.html
--- sandbox/ahocevar/layercontainer/tests/Control/Scale.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Control/Scale.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -2,6 +2,7 @@
 <head>
   <script src="../OLLoader.js"></script>
   <script type="text/javascript">
     var map;
     function test_Control_Scale_constructor (t) {
         t.plan( 2 );
Modified: sandbox/ahocevar/layercontainer/tests/Handler/Drag.html
--- sandbox/ahocevar/layercontainer/tests/Handler/Drag.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Handler/Drag.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -294,7 +294,7 @@
         // "touchend" events set expected states in the drag handler.
         // We also verify that we stop event bubbling as appropriate.
-        t.plan(12);
+        t.plan(14);
         // set up
@@ -302,37 +302,44 @@
         var c = new OpenLayers.Control();
         m.addControl(c);
         var h = new OpenLayers.Handler.Drag(c, {
-            done: function(px) { log = px; }});
+            done: function(px) {
+                log.push(px);
         h.activate();
         var _stop = OpenLayers.Event.stop;
-        OpenLayers.Event.stop = function(e) { log = e; };
+        OpenLayers.Event.stop = function(e) {
+            log.push(e);
-        var Px = OpenLayers.Pixel, e, log;
+        var Px = OpenLayers.Pixel, e;
+        var log = [];
         // test
         e = {touches: [{}], xy: new Px(0, 0)};
         m.events.triggerEvent('touchstart', e);
         t.eq(h.started, true, '[touchstart] started is set');
         t.eq(h.start.x, 0, '[touchstart] start.x is correct');
         t.eq(h.start.y, 0, '[touchstart] start.y is correct');
-        t.eq(log, undefined, '[touchstart] event is not stopped');
+        t.eq(log.length, 1, '[touchstart] one item in log');
+        t.ok(log[0] === e, "touchstart", '[touchstart] event is stopped');
         e = {xy: new Px(1, 1)};
         m.events.triggerEvent('touchmove', e);
         t.eq(h.dragging, true, '[touchmove] dragging is set');
-        t.eq(h.last.x, 1, '[touchstart] last.x is correct');
-        t.eq(h.last.y, 1, '[touchstart] last.y is correct');
-        t.ok(log == e, '[touchmove] event is stopped');
+        t.eq(h.last.x, 1, '[touchmove] last.x is correct');
+        t.eq(h.last.y, 1, '[touchmove] last.y is correct');
+        t.eq(log.length, 1, '[touchmove] one item in log (event is not stopped)');
         e = {xy: new Px(2, 2)};
         m.events.triggerEvent('touchend', e);
         t.eq(h.started, false, '[touchend] started is reset');
         // the "done" callback gets the position of the last touchmove
-        t.eq(log.x, 1, '[touchend] done callback got correct x position');
-        t.eq(log.y, 1, '[touchend] done callback got correct y position');
+        t.eq(log.length, 2, '[touchend] two items in log');
+        t.ok(log[1] instanceof Px, '[touchend] got');
+        t.ok(log[1].equals(e.xy), '[touchend] done callback got correct position');
         // tear down
Modified: sandbox/ahocevar/layercontainer/tests/Layer/EventPane.html
--- sandbox/ahocevar/layercontainer/tests/Layer/EventPane.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Layer/EventPane.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -58,11 +58,11 @@
 //         t.plan( 2 );
         if (OpenLayers.BROWSER_NAME != "firefox" && OpenLayers.BROWSER_NAME != "mozilla") {
-          t.plan(4);
+            t.plan(4);
         } else {
-          t.plan(0);
-          t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
-          return;
+            t.plan(0);
+            t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
+            return;
@@ -84,19 +84,23 @@
         layer2.getWarningHTML = function() { this.warning = true; return ""; }
         map.addLayer(layer2);
-        t.ok( !layer2.warning, "warning not registered on mapObject load" );
+        t.ok(!layer2.warning, "warning not registered on mapObject load");
-        map.events.register("mousemove", map, function () {
-            t.ok(true, "got mouse move");
+        var log = [];
+        map.events.register("mousemove", map, function(event) {
+            log.push(event);
-        if( document.createEvent ) { // Mozilla
-          var evObj = document.createEvent('MouseEvents');
-          evObj.initEvent( 'mousemove', true, false );
-          layer.pane.dispatchEvent(evObj);
-        } else if( document.createEventObject ) { // IE
-          layer.pane.fireEvent('onmousemove');
+        if (document.createEvent) { // Mozilla
+            var evObj = document.createEvent('MouseEvents');
+            evObj.initEvent('mousemove', true, false);
+            map.eventsDiv.dispatchEvent(evObj);
+        } else if(document.createEventObject) { // IE
+            map.eventsDiv.fireEvent('onmousemove');
+        t.eq(log.length, 1, "got one event");
     function test_Layer_EventPane_setVisibility (t) {
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -1664,7 +1664,26 @@
         map.destroy();
+    function test_pixel_lonlat(t) {
+        t.plan(4);
+        var map = new OpenLayers.Map({
+            div: "map",
+            layers: [
+                new OpenLayers.Layer("name", {isBaseLayer:true})
+        map.zoomToMaxExtent();
+        var px = map.getPixelFromLonLat(map.getLonLatFromPixel(new OpenLayers.Pixel(100, 100)));
+        t.eq(px.x, 100, "x is the same in and ot");
+        t.eq(px.y, 100, "y is the same in and out");
+        var ll = map.getLonLatFromPixel(map.getPixelFromLonLat(new OpenLayers.LonLat(100, 100)));
+        t.ok((ll.lon > (100 -map.getResolution()) && (ll.lon < (100 + map.getResolution()))), "lon is the same in and ot");
+        t.ok((ll.lat > (100 -map.getResolution()) && (ll.lat < (100 + map.getResolution()))), "lat is the same in and ot");
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/ahocevar/layercontainer/tests/run-tests.html
--- sandbox/ahocevar/layercontainer/tests/run-tests.html	2011-02-23 22:24:35 UTC (rev 11374)
+++ sandbox/ahocevar/layercontainer/tests/run-tests.html	2011-02-23 22:52:52 UTC (rev 11375)
@@ -686,7 +686,7 @@
 		timeout_seconds=4;
 	var no_close=document.getElementById( "dont_close_test_windows" );
-	var action={ action_kind: "window", wnd_url: url.toString(), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
+	var action={ action_kind: "window", wnd_url: url.toString() + (window.location.search || ""), wnd_wnd: null, wnd_fn: fn, wnd_timeout_milliseconds: timeout_seconds*1000, wnd_no_close: no_close.checked };
 	this.delay_total_milliseconds_left+=Test.AnotherWay._action_estimate_milliseconds( action );
 	this.delay_actions.push( action );
@@ -2410,4 +2410,10 @@
 </div>
 </span>
+<script>
+    if (/noscroll/.test(location.href)) {
+        document.getElementById('scroller').style.height='auto';
+        document.getElementById('right_frame').style.height='auto';
+</script>
 </body></html>
More information about the Commits mailing list
