[OpenLayers-Commits] r11376 - in sandbox/ahocevar/layercontainer:
lib/OpenLayers lib/OpenLayers/Layer tests
commits-20090109 at openlayers.org
Wed Feb 23 18:00:17 EST 2011
Author: ahocevar
Date: 2011-02-23 15:00:17 -0800 (Wed, 23 Feb 2011)
New Revision: 11376
sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js
sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
sandbox/ahocevar/layercontainer/tests/Map.html
pixel based panning with moveByPx method - currently not working for EventPane layers and Layer.Bing (likely because of layer.addOptions and/or layer.restrictedMinZoom issues)
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js 2011-02-23 22:52:52 UTC (rev 11375)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js 2011-02-23 23:00:17 UTC (rev 11376)
@@ -126,6 +126,19 @@
this._moveGriddedTiles = OpenLayers.Function.bind(
this.moveGriddedTiles, this
+ this.events.register("move", this, function() {
+ if (!this._forceReTile) {
+ if (this.timerId != null) {
+ window.clearTimeout(this.timerId);
+ this.timerId = window.setTimeout(
+ this._moveGriddedTiles,
+ this.tileLoadingDelay
+ delete this._forceReTile;
@@ -232,17 +245,8 @@
// then we want to reTile (thus, partial true).
if (forceReTile || !tilesBounds.containsBounds(bounds, true)) {
+ this._forceReTile = true;
this.initGriddedTiles(bounds);
- } else {
- // we might have to shift our buffer tiles, schedule
- // that
- if (this.timerId != null) {
- window.clearTimeout(this.timerId);
- this.timerId = window.setTimeout(
- this._moveGriddedTiles,
- this.tileLoadingDelay
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-23 22:52:52 UTC (rev 11375)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-23 23:00:17 UTC (rev 11376)
@@ -77,7 +77,8 @@
* loadcancel - Triggered when layer loading is canceled.
* visibilitychanged - Triggered when layer visibility is changed.
* move - Triggered when layer moves (triggered with every mousemove
- * during a drag).
+ * during a drag). If available, the delta of the movement will be
+ * passed in an argument as dx and dy properties.
* moveend - Triggered when layer is done moving, object passed as
* argument has a zoomChanged boolean property which tells that the
* zoom has changed.
@@ -1200,21 +1201,12 @@
getLonLatFromViewPortPx: function (viewPortPx) {
var lonlat = null;
if (viewPortPx != null) {
- var size = this.map.getSize();
- var center = this.map.getCenter();
- if (center) {
- var res = this.map.getResolution();
- var delta_x = viewPortPx.x - (size.w / 2);
- var delta_y = viewPortPx.y - (size.h / 2);
- lonlat = new OpenLayers.LonLat(center.lon + delta_x * res ,
- center.lat - delta_y * res);
- if (this.wrapDateLine) {
- lonlat = lonlat.wrapDateLine(this.maxExtent);
- } // else { DEBUG STATEMENT }
+ var map = this.map;
+ var res = map.getResolution();
+ var maxExtent = map.getMaxExtent();
+ var lon = (viewPortPx.x - map.minPx.x) * res + maxExtent.left;
+ var lat = (map.minPx.y - viewPortPx.y) * res + maxExtent.top;
+ lonlat = new OpenLayers.LonLat(lon, lat);
return lonlat;
@@ -1234,15 +1226,12 @@
getViewPortPxFromLonLat: function (lonlat) {
var px = null;
if (lonlat != null) {
- var res = this.map.resolution;
- var center = this.map.extent.getCenterLonLat();
- var lonDelta = lonlat.lon - center.lon;
- var latDelta = center.lat - lonlat.lat;
- var halfViewPortWidth = this.map.size.w / 2;
- var halfViewPortHeight = this.map.size.h / 2;
- var left = halfViewPortWidth + lonDelta / res;
- var top = halfViewPortHeight + latDelta / res;
- px = new OpenLayers.Pixel(left, top);
+ var x = map.minPx.x + (lonlat.lon - maxExtent.left) / res;
+ var y = map.minPx.y + (maxExtent.top - lonlat.lat) / res;
+ px = new OpenLayers.Pixel(x, y);
return px;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-23 22:52:52 UTC (rev 11375)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-23 23:00:17 UTC (rev 11376)
@@ -220,6 +220,8 @@
* {<OpenLayers.LonLat>} The current center of the map
center: null,
+ centerPx: null,
* Property: resolution
@@ -415,6 +417,22 @@
paddingForPopups : null,
+ * Property: minPx
+ * {<OpenLayers.Pixel>}
+ * lower left of maxExtent in viewport pixel space
+ minPx: null,
+ * Property: maxPx
+ * top right of maxExtent in viewport pixel space
+ maxPx: null,
* Constructor: OpenLayers.Map
* Constructor for a new OpenLayers.Map instance. There are two possible
* ways to call the map constructor. See the examples below.
@@ -1123,7 +1141,7 @@
if (OpenLayers.Util.indexOf(this.layers, newBaseLayer) != -1) {
// preserve center and scale when changing base layers
- var center = this.center;
+ var center = this.getCachedCenter();
var newResolution = OpenLayers.Util.getResolutionFromScale(
this.getScale(), newBaseLayer.units
@@ -1385,7 +1403,7 @@
this.layers[i].onMapResize();
if (this.baseLayer != null && center != null) {
var zoom = this.zoom;
@@ -1436,10 +1454,10 @@
var extent = null;
if (center == null) {
- center = this.center;
+ center = this.getCachedCenter();
if (resolution == null) {
- resolution = this.resolution;
+ resolution = this.getResolution();
if ((center != null) && (resolution != null)) {
@@ -1476,12 +1494,38 @@
getCenter: function () {
var center = null;
- if (this.center) {
- center = this.center.clone();
+ var cachedCenter = this.getCachedCenter();
+ if (cachedCenter) {
+ center = cachedCenter.clone();
return center;
+ * Method: getCachedCenter
+ * Returns:
+ * {<OpenLayers.LonLat>}
+ getCachedCenter: function() {
+ if (!this.center) {
+ this.center = this.getLonLatFromViewPortPx(this.centerPx);
+ return this.center;
+ * Method: getCachedCenterPx
+ * Returns:
+ getCachedCenterPx: function() {
+ if (!this.centerPx) {
+ this.centerPx = this.getViewPortPxFromLonLat(this.center);
+ return this.centerPx;
* APIMethod: getZoom
@@ -1510,23 +1554,31 @@
animate: true,
dragging: false
- // getCenter
- var centerPx = this.getViewPortPxFromLonLat(this.getCenter());
- // adjust
- var newCenterPx = centerPx.add(dx, dy);
- // only call setCenter if not dragging or there has been a change
- if (!options.dragging || !newCenterPx.equals(centerPx)) {
- var newCenterLonLat = this.getLonLatFromViewPortPx(newCenterPx);
- if (options.animate) {
- this.panTo(newCenterLonLat);
+ if (options.dragging || this._draggedByMoveByPx) {
+ this.moveByPx(dx, dy);
+ if (options.dragging) {
+ this._draggedByMoveByPx = true
} else {
- this.setCenter(newCenterLonLat, null, options.dragging);
+ delete this._draggedByMoveByPx;
+ this.events.triggerEvent("moveend");
+ } else {
+ // getCenter
+ var centerPx = this.getCachedCenterPx();
+ // adjust
+ var newCenterPx = centerPx.add(dx, dy);
+ if (!newCenterPx.equals(centerPx)) {
+ var newCenterLonLat = this.getLonLatFromViewPortPx(newCenterPx);
+ if (options.animate) {
+ this.panTo(newCenterLonLat);
+ } else {
+ this.setCenter(newCenterLonLat, null, options.dragging);
@@ -1538,11 +1590,11 @@
* lonlat - {<OpenLayers.Lonlat>}
panTo: function(lonlat) {
- if (this.panMethod && this.extent.scale(this.panRatio).containsLonLat(lonlat)) {
+ if (this.panMethod && this.getCachedExtent().scale(this.panRatio).containsLonLat(lonlat)) {
if (!this.panTween) {
this.panTween = new OpenLayers.Tween(this.panMethod);
// center will not change, don't do nothing
if (lonlat.lon == center.lon &&
@@ -1605,6 +1657,43 @@
'caller': 'setCenter'
+ * Method: moveByPx
+ * Drag the map by pixels
+ * Parameters:
+ * dx - {Number}
+ * dy - {Number}
+ moveByPx: function(dx, dy) {
+ var centerPx = this.getCachedCenterPx().add(dx, dy);
+ var valid = centerPx.x <= this.maxPx.x &&
+ centerPx.x >= this.minPx.x &&
+ centerPx.y <= this.maxPx.y &&
+ centerPx.y >= this.minPx.y;
+ if (valid === true) {
+ this.center = null;
+ if (dx) {
+ this.layerContainerDiv.style.left =
+ parseInt(this.layerContainerDiv.style.left) - dx + "px";
+ this.minPx.x -= dx;
+ this.maxPx.x -= dx;
+ if (dy) {
+ this.layerContainerDiv.style.top =
+ parseInt(this.layerContainerDiv.style.top) - dy + "px";
+ this.minPx.y -= dy;
+ this.maxPx.y -= dy;
+ this.events.triggerEvent("move");
+ var layer;
+ for (var i=0, ii=this.layers.length; i<ii; ++i) {
+ layer = this.layers[i];
+ layer.visibility && layer.events.triggerEvent("move");
* Method: moveTo
@@ -1675,6 +1764,8 @@
+ var oldCenter = this.getCachedCenter();
if (zoomChanged) {
var maxExtent = this.getMaxExtent();
this.layerContainerDiv.style.width =
@@ -1687,18 +1778,24 @@
var centerChanged =
- this.isValidLonLat(lonlat) && !lonlat.equals(this.center);
- if (centerChanged || !this.center) {
- if (!this.center && !this.isValidLonLat(lonlat)) {
+ this.isValidLonLat(lonlat) && !lonlat.equals(oldCenter);
+ if (centerChanged || !oldCenter) {
+ if (!oldCenter && !this.isValidLonLat(lonlat)) {
lonlat = this.maxExtent.getCenterLonLat();
- this.centerLayerContainer(lonlat);
- this.center = lonlat;
// if neither center nor zoom will change, no need to do anything
if (zoomChanged || centerChanged || !dragging) {
+ if (zoomChanged || centerChanged) {
+ if (!lonlat) {
+ lonlat = oldCenter;
+ this.center = lonlat;
+ this.centerLayerContainer(lonlat);
if (!this.dragging && !noEvent) {
this.events.triggerEvent("movestart");
@@ -1781,14 +1878,16 @@
var center = this.getMaxExtent().getCenterLonLat();
- var halfExtentWidth = parseInt(this.layerContainerDiv.style.width) / 2;
- var halfExtentHeight = parseInt(this.layerContainerDiv.style.height) / 2;
+ var extentWidth = parseInt(this.layerContainerDiv.style.width);
+ var extentHeight = parseInt(this.layerContainerDiv.style.height);
var halfViewPortWidth = this.size.w / 2;
var halfViewPortHeight = this.size.h / 2;
- var left = halfViewPortWidth - halfExtentWidth - lonDelta / res;
- var top = halfViewPortHeight - halfExtentHeight - latDelta / res;
+ var left = halfViewPortWidth - extentWidth / 2 - lonDelta / res;
+ var top = halfViewPortHeight - extentHeight / 2 - latDelta / res;
this.layerContainerDiv.style.left = Math.round(left) + "px";
this.layerContainerDiv.style.top = Math.round(top) + "px";
+ this.minPx = new OpenLayers.Pixel(left, top);
+ this.maxPx = new OpenLayers.Pixel(left + extentWidth, top + extentHeight);
@@ -1957,11 +2056,25 @@
getExtent: function () {
var extent = null;
- if (this.extent != null) {
- extent = this.extent.clone();
+ var cachedExtent = this.getCachedExtent();
+ if (cachedExtent) {
+ extent = cachedExtent.clone();
return extent;
+ * Method: getCachedExtent
+ * Returns:
+ * {<OpenLayers.Bounds>}
+ getCachedExtent: function() {
+ if (!this.extent) {
+ this.extent = this.baseLayer.getExtent();
+ return this.extent;
* APIMethod: getResolution
@@ -2202,7 +2315,7 @@
var size = this.size;
var w_deg = size.w * res;
var h_deg = size.h * res;
var extent = new OpenLayers.Bounds(center.lon - w_deg / 2,
center.lat - h_deg / 2,
@@ -2314,8 +2427,8 @@
* {<OpenLayers.Size>} The geodesic size of the pixel in kilometers.
getGeodesicPixelSize: function(px) {
- var lonlat = px ? this.getLonLatFromPixel(px) : (this.center ||
- new OpenLayers.LonLat(0, 0));
+ var lonlat = px ? this.getLonLatFromPixel(px) :
+ (this.getCachedCenter() || new OpenLayers.LonLat(0, 0));
var res = this.getResolution();
var left = lonlat.add(-res / 2, 0);
var right = lonlat.add(res / 2, 0);
@@ -2357,9 +2470,10 @@
if (layerPx != null) {
var res = this.resolution;
- var deltaX = Math.round(center.lon / res - this.center.lon / res);
- var deltaY = Math.round(this.center.lat / res - center.lat / res);
- viewPortPx = layerPx.add(deltaX, deltaY);
+ var dx = Math.round(center.lon / res - oldCenter.lon / res);
+ var dy = Math.round(oldCenter.lat / res - center.lat / res);
+ viewPortPx = layerPx.add(dx, dy);
return viewPortPx;
@@ -2379,9 +2493,10 @@
- var deltaX = Math.round(this.center.lon / res - center.lon / res);
- var deltaY = Math.round(center.lat / res - this.center.lat / res);
- layerPx = viewPortPx.add(deltaX, deltaY);
+ var dx = Math.round(oldCenter.lon / res - center.lon / res);
+ var dy = Math.round(center.lat / res - oldCenter.lat / res);
+ layerPx = viewPortPx.add(dx, dy);
return layerPx;
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-23 22:52:52 UTC (rev 11375)
+++ sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-23 23:00:17 UTC (rev 11376)
@@ -1316,7 +1316,7 @@
var m = {
'baseLayer': { 'units': {} },
'size': {'w': 10, 'h': 15},
- 'center': {'lon': -5, 'lat': -25},
+ 'getCachedCenter': function() {return {'lon': -5, 'lat': -25};},
'zoomToExtent': function(extent, closest) {
t.ok(extent.equals(g_ExpectedExtent), "extent correctly calculated for zoomToExtent()");
t.ok(closest == g_Closest, "closest correctly passed on to zoomToExtent()");
More information about the Commits
