[OpenLayers-Commits] r10990 - in trunk/openlayers/lib/OpenLayers: .
Feature Filter
commits-20090109 at openlayers.org
Sat Jan 1 18:48:08 EST 2011
Author: tschaub
Date: 2011-01-01 15:48:08 -0800 (Sat, 01 Jan 2011)
New Revision: 10990
trunk/openlayers/lib/OpenLayers/Events.js
trunk/openlayers/lib/OpenLayers/Feature/Vector.js
trunk/openlayers/lib/OpenLayers/Filter/Comparison.js
trunk/openlayers/lib/OpenLayers/Filter/Logical.js
A bit of lint removal.
Modified: trunk/openlayers/lib/OpenLayers/Events.js
--- trunk/openlayers/lib/OpenLayers/Events.js 2011-01-01 23:41:47 UTC (rev 10989)
+++ trunk/openlayers/lib/OpenLayers/Events.js 2011-01-01 23:48:08 UTC (rev 10990)
@@ -742,7 +742,7 @@
// fast path
if(!listeners || listeners.length == 0) {
- return;
+ return undefined;
// prep evt object with object & div references
@@ -758,7 +758,8 @@
// execute all callbacks registered for specified type
// get a clone of the listeners array to
// allow for splicing during callbacks
- var listeners = listeners.slice(), continueChain;
+ listeners = listeners.slice();
+ var continueChain;
for (var i=0, len=listeners.length; i<len; i++) {
var callback = listeners[i];
// bind the context to callback.obj
Modified: trunk/openlayers/lib/OpenLayers/Feature/Vector.js
--- trunk/openlayers/lib/OpenLayers/Feature/Vector.js 2011-01-01 23:41:47 UTC (rev 10989)
+++ trunk/openlayers/lib/OpenLayers/Feature/Vector.js 2011-01-01 23:48:08 UTC (rev 10990)
@@ -267,7 +267,7 @@
if(!this.layer || !this.geometry.move){
//do nothing if no layer or immoveable geometry
- return;
+ return undefined;
var pixel;
Modified: trunk/openlayers/lib/OpenLayers/Filter/Comparison.js
--- trunk/openlayers/lib/OpenLayers/Filter/Comparison.js 2011-01-01 23:41:47 UTC (rev 10989)
+++ trunk/openlayers/lib/OpenLayers/Filter/Comparison.js 2011-01-01 23:48:08 UTC (rev 10990)
@@ -109,9 +109,10 @@
var result = false;
var got = context[this.property];
+ var exp;
switch(this.type) {
case OpenLayers.Filter.Comparison.EQUAL_TO:
- var exp = this.value;
+ exp = this.value;
if(!this.matchCase &&
typeof got == "string" && typeof exp == "string") {
result = (got.toUpperCase() == exp.toUpperCase());
@@ -120,7 +121,7 @@
break;
case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:
+ exp = this.value;
result = (got.toUpperCase() != exp.toUpperCase());
Modified: trunk/openlayers/lib/OpenLayers/Filter/Logical.js
--- trunk/openlayers/lib/OpenLayers/Filter/Logical.js 2011-01-01 23:41:47 UTC (rev 10989)
+++ trunk/openlayers/lib/OpenLayers/Filter/Logical.js 2011-01-01 23:48:08 UTC (rev 10990)
@@ -70,9 +70,10 @@
* {Boolean} The filter applies.
evaluate: function(context) {
+ var i, len;
switch(this.type) {
case OpenLayers.Filter.Logical.AND:
- for (var i=0, len=this.filters.length; i<len; i++) {
+ for (i=0, len=this.filters.length; i<len; i++) {
if (this.filters[i].evaluate(context) == false) {
return false;
@@ -80,7 +81,7 @@
return true;
case OpenLayers.Filter.Logical.OR:
if (this.filters[i].evaluate(context) == true) {
return true;
@@ -90,6 +91,7 @@
case OpenLayers.Filter.Logical.NOT:
return (!this.filters[0].evaluate(context));
+ return undefined;
More information about the Commits
