[OpenLayers-Commits] r10991 - trunk/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Jan 2 11:59:08 EST 2011
Author: ahocevar
Date: 2011-01-02 08:59:07 -0800 (Sun, 02 Jan 2011)
New Revision: 10991
Added:
   trunk/openlayers/examples/graphic-name.js
Missing graphic-name.js which should have been committed with r10976 (closes #2985)
Added: trunk/openlayers/examples/graphic-name.js
--- trunk/openlayers/examples/graphic-name.js	                        (rev 0)
+++ trunk/openlayers/examples/graphic-name.js	2011-01-02 16:59:07 UTC (rev 10991)
@@ -0,0 +1,62 @@
+// user custom graphicname
+OpenLayers.Renderer.symbol.lightning = [0, 0, 4, 2, 6, 0, 10, 5, 6, 3, 4, 5, 0, 0];
+OpenLayers.Renderer.symbol.rectangle = [0, 0, 4, 0, 4, 10, 0, 10, 0, 0];
+OpenLayers.Renderer.symbol.church = [4, 0, 6, 0, 6, 4, 10, 4, 10, 6, 6, 6, 6, 14, 4, 14, 4, 6, 0, 6, 0, 4, 4, 4, 4, 0];
+var map;
+function init(){
+    map = new OpenLayers.Map('map', {
+        controls: []
+    // list of well-known graphic names
+    var graphics = ["star", "cross", "x", "square", "triangle", "circle", "lightning", "rectangle", "church"];
+    // Create one feature for each well known graphic.
+    // Give features a type attribute with the graphic name.
+    var num = graphics.length;
+    var slot = map.maxExtent.getWidth() / num;
+    var features = Array(num);
+    for (var i = 0; i < graphics.length; ++i) {
+        lon = map.maxExtent.left + (i * slot) + (slot / 2);
+        features[i] = new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(map.maxExtent.left + (i * slot) + (slot / 2), 0), {
+            type: graphics[i]
+    // Create a style map for painting the features.
+    // The graphicName property of the symbolizer is evaluated using
+    // the type attribute on each feature (set above).
+    var styles = new OpenLayers.StyleMap({
+        "default": {
+            graphicName: "${type}",
+            pointRadius: 10,
+            strokeColor: "fuchsia",
+            strokeWidth: 2,
+            fillColor: "lime",
+            fillOpacity: 0.6
+        "select": {
+            pointRadius: 20,
+            fillOpacity: 1,
+            rotation: 45
+    // Create a vector layer and give it your style map.
+    var layer = new OpenLayers.Layer.Vector("Graphics", {
+        styleMap: styles,
+        isBaseLayer: true
+    layer.addFeatures(features);
+    map.addLayer(layer);
+    // Create a select feature control and add it to the map.
+    var select = new OpenLayers.Control.SelectFeature(layer, {
+        hover: true
+    map.addControl(select);
+    select.activate();
+    map.zoomToMaxExtent();
More information about the Commits mailing list
