[OpenLayers-Commits] r11046 - in trunk/openlayers:
lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org
Thu Jan 20 08:20:03 EST 2011
Author: bartvde
Date: 2011-01-20 05:20:03 -0800 (Thu, 20 Jan 2011)
New Revision: 11046
trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
trunk/openlayers/tests/Control/WMSGetFeatureInfo.html
WMS GetFeatureInfo control should use integers for X and Y, r=ahocevar (closes #3019)
Modified: trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
--- trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js 2011-01-20 11:37:17 UTC (rev 11045)
+++ trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js 2011-01-20 13:20:03 UTC (rev 11046)
@@ -370,13 +370,13 @@
}, (parseFloat(firstLayer.params.VERSION) >= 1.3) ?
crs: projection,
- i: clickPosition.x,
- j: clickPosition.y
+ i: parseInt(clickPosition.x),
+ j: parseInt(clickPosition.y)
srs: projection,
- x: clickPosition.x,
- y: clickPosition.y
+ x: parseInt(clickPosition.x),
+ y: parseInt(clickPosition.y)
OpenLayers.Util.applyDefaults(params, this.vendorParams);
Modified: trunk/openlayers/tests/Control/WMSGetFeatureInfo.html
--- trunk/openlayers/tests/Control/WMSGetFeatureInfo.html 2011-01-20 11:37:17 UTC (rev 11045)
+++ trunk/openlayers/tests/Control/WMSGetFeatureInfo.html 2011-01-20 13:20:03 UTC (rev 11046)
@@ -233,7 +233,7 @@
// Verify that things work all right when we combine different types for the STYLES and LAYERS
// params in the WMS Layers involved
function test_mixedParams(t) {
- t.plan(3);
+ t.plan(5);
var map = new OpenLayers.Map("map", {
getExtent: function() {return(new OpenLayers.Bounds(-180,-90,180,90));}
@@ -271,10 +271,22 @@
log.options = options;
click.activate();
- click.getInfoForClick({xy: {x: 50, y: 50}});
+ click.getInfoForClick({xy: {x: 50.2, y: 50.1}});
OpenLayers.Request.GET = _request;
t.eq(
+ log.options && log.options.params.X,
+ 50,
+ "X should be an integer"
+ t.eq(
+ log.options && log.options.params.Y,
+ 50,
+ "Y should be an integer"
+ t.eq(
log.options && log.options.url,
"http://localhost/wms",
"url from first layer used"
@@ -506,7 +518,7 @@
click.activate();
- click.getInfoForClick({xy: {x: 50, y: 60}});
+ click.getInfoForClick({xy: {x: 50.1, y: 60.2}});
t.eq(
log.options && log.options.params.CRS,
More information about the Commits
