[OpenLayers-Commits] r11047 - in trunk/openlayers: examples
lib/OpenLayers/Layer/Google
commits-20090109 at openlayers.org
Thu Jan 20 08:31:30 EST 2011
Author: ahocevar
Date: 2011-01-20 05:31:30 -0800 (Thu, 20 Jan 2011)
New Revision: 11047
trunk/openlayers/examples/google-v3.html
trunk/openlayers/examples/google-v3.js
trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
giving Layer.Google.v3 an animationEnabled option, like the one we already have for Layer.VirtualEarth. r=bartvde (closes #3020)
Modified: trunk/openlayers/examples/google-v3.html
--- trunk/openlayers/examples/google-v3.html 2011-01-20 13:20:03 UTC (rev 11046)
+++ trunk/openlayers/examples/google-v3.html 2011-01-20 13:31:30 UTC (rev 11047)
@@ -19,6 +19,8 @@
</p>
<div id="map" class="smallmap"></div>
<div id="docs">
+ <p><input id="animate" type="checkbox" checked="checked">Animated
+ zoom (if supported by GMaps on your device)</input></p>
<p>
If you use the Google Maps v3 API with a Google layer, you don't
need to include an API key. This layer only works in the
Modified: trunk/openlayers/examples/google-v3.js
--- trunk/openlayers/examples/google-v3.js 2011-01-20 13:20:03 UTC (rev 11046)
+++ trunk/openlayers/examples/google-v3.js 2011-01-20 13:31:30 UTC (rev 11047)
@@ -29,4 +29,12 @@
new OpenLayers.Projection("EPSG:4326"),
map.getProjectionObject()
), 5);
+ // add behavior to html
+ var animate = document.getElementById("animate");
+ animate.onclick = function() {
+ for (var i=map.layers.length-1; i>=0; --i) {
+ map.layers[i].animationEnabled = this.checked;
Modified: trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
--- trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-01-20 13:20:03 UTC (rev 11046)
+++ trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-01-20 13:31:30 UTC (rev 11047)
@@ -51,6 +51,19 @@
projection: "EPSG:900913"
+ * APIProperty: animationEnabled
+ * {Boolean} If set to true, the transition between zoom levels will be
+ * animated (if supported by the GMaps API for the device used). Set to
+ * false to match the zooming experience of other layer types. Default
+ * is true. Note that the GMaps API does not give us control over zoom
+ * animation, so if set to false, when zooming, this will make the
+ * layer temporarily invisible, wait until GMaps reports the map being
+ * idle, and make it visible again. The result will be a blank layer
+ * for a few moments while zooming.
+ animationEnabled: true,
* Method: loadMapObject
* Load the GMap and register appropriate event listeners. If we can't
@@ -340,6 +353,17 @@
* zoom - {int} MapObject zoom format
setMapObjectCenter: function(center, zoom) {
+ if (this.animationEnabled === false && zoom != this.mapObject.zoom) {
+ var mapContainer = this.getMapContainer();
+ google.maps.event.addListenerOnce(
+ this.mapObject,
+ "idle",
+ function() {
+ mapContainer.style.visibility = "";
+ mapContainer.style.visibility = "hidden";
this.mapObject.setOptions({
center: center,
zoom: zoom
More information about the Commits
