[OpenLayers-Commits] r11830 - in trunk/openlayers: examples
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Thu Mar 31 05:49:42 EDT 2011
Author: sbrunner
Date: 2011-03-31 02:49:41 -0700 (Thu, 31 Mar 2011)
New Revision: 11830
trunk/openlayers/examples/mobile.html
trunk/openlayers/examples/mobile.js
trunk/openlayers/lib/OpenLayers/Handler/Feature.js
trunk/openlayers/lib/OpenLayers/Handler/Path.js
trunk/openlayers/tests/Handler/Feature.html
revert mistake [11829]
Modified: trunk/openlayers/examples/mobile.html
--- trunk/openlayers/examples/mobile.html 2011-03-31 09:45:50 UTC (rev 11829)
+++ trunk/openlayers/examples/mobile.html 2011-03-31 09:49:41 UTC (rev 11830)
@@ -7,10 +7,6 @@
<meta name="apple-mobile-web-app-capable" content="yes">
<link rel="stylesheet" href="style.mobile.css" type="text/css">
<script src="../lib/OpenLayers.js?mobile"></script>
- <script src="http://192.168.1.49:8124/debug.js?ns=OpenLayers.Console"></script>
- <script>
- OpenLayers.Console.log("start");
- </script>
<script src="mobile.js"></script>
<style>
html, body {
Modified: trunk/openlayers/examples/mobile.js
--- trunk/openlayers/examples/mobile.js 2011-03-31 09:45:50 UTC (rev 11829)
+++ trunk/openlayers/examples/mobile.js 2011-03-31 09:49:41 UTC (rev 11830)
@@ -1,14 +1,34 @@
// initialize map when page ready
var map;
+// Get rid of address bar on iphone/ipod
+var fixSize = function() {
+ window.scrollTo(0,0);
+ document.body.style.height = '100%';
+ if (!(/(iphone|ipod)/.test(navigator.userAgent.toLowerCase()))) {
+ if (document.body.parentNode) {
+ document.body.parentNode.style.height = '100%';
+setTimeout(fixSize, 700);
+setTimeout(fixSize, 1500);
var init = function () {
// create map
map = new OpenLayers.Map({
div: "map",
theme: null,
- controls: [],
+ controls: [
+ new OpenLayers.Control.Attribution(),
+ new OpenLayers.Control.TouchNavigation({
+ dragPanOptions: {
+ interval: 100,
+ enableKinetic: true
+ new OpenLayers.Control.ZoomPanel()
layers: [
new OpenLayers.Layer.OSM("OpenStreetMap", null, {
transitionEffect: 'resize'
Modified: trunk/openlayers/lib/OpenLayers/Handler/Feature.js
--- trunk/openlayers/lib/OpenLayers/Handler/Feature.js 2011-03-31 09:45:50 UTC (rev 11829)
+++ trunk/openlayers/lib/OpenLayers/Handler/Feature.js 2011-03-31 09:49:41 UTC (rev 11830)
@@ -56,13 +56,6 @@
* {<OpenLayers.Pixel>} The location of the last mouseup.
up: null,
- * Property: touch
- * {Boolean} When a touchstart event is fired, touch will be true and all
- * mouse related listeners will do nothing.
- touch: false,
* Property: clickTolerance
@@ -136,34 +129,10 @@
* {Boolean} Let the event propagate.
touchstart: function(evt) {
- if(!this.touch) {
- this.touch = true;
- this.map.events.un({
- mousedown: this.mousedown,
- mouseup: this.mouseup,
- mousemove: this.mousemove,
- click: this.click,
- dblclick: this.dblclick,
- scope: this
return this.mousedown(evt);
- * Method: touchmove
- * Handle touchmove events. We just prevent the browser default behavior,
- * for Android Webkit not to select text when moving the finger after
- * selecting a feature.
- * Parameters:
- * evt - {Event}
- touchmove: function(evt) {
- OpenLayers.Event.stop(evt);
* Method: mousedown
* Handle mouse down. Stop propagation if a feature is targeted by this
* event (stops map dragging during feature selection).
@@ -282,11 +251,6 @@
this.lastFeature = null;
if(this.feature) {
- if(evt.type === "touchstart") {
- // stop the event to prevent Android Webkit from
- // "flashing" the map div
var inNew = (this.feature != this.lastFeature);
if(this.geometryTypeMatches(this.feature)) {
// in to a feature
@@ -385,7 +349,6 @@
this.down = null;
this.up = null;
- this.touch = false;
"removelayer": this.handleMapEvents,
"changelayer": this.handleMapEvents,
Modified: trunk/openlayers/lib/OpenLayers/Handler/Path.js
--- trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-31 09:45:50 UTC (rev 11829)
+++ trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-03-31 09:49:41 UTC (rev 11830)
@@ -60,12 +60,6 @@
timerId: null,
- * Propery: stopTouchEnd
- * {Boolean} Stop event propagation of the next touch up.
- stopTouchEnd: false,
* Constructor: OpenLayers.Handler.Path
* Create a new path hander
@@ -250,8 +244,6 @@
// double-tap, finalize the geometry
this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
this.finishGeometry();
- this.stopTouchEnd = true;
window.clearTimeout(this.timerId);
this.timerId = null;
return false;
@@ -267,27 +259,6 @@
return OpenLayers.Handler.Point.prototype.touchstart.call(this, evt);
- * Method: touchend
- * Handle touchend.
- * Parameters:
- * evt - {Event} The browser event
- * Returns:
- * {Boolean} Allow event propagation
- touchend: function(evt) {
- evt.xy = this.lastTouchPx;
- if (this.stopTouchEnd) {
- // don't zoom on the page at feature end
- this.stopTouchEnd = false;
- return false;
- return this.up(evt);
* Method: mousedown
@@ -359,8 +330,6 @@
} else {
if (this.passesTolerance(this.lastDown, evt.xy, this.pixelTolerance)) {
if (this.touch) {
- // don't allow the browser to zoom
this.modifyFeature(evt.xy);
if(this.lastUp == null && this.persist) {
@@ -401,9 +370,6 @@
dblclick: function(evt) {
- if (this.touch) {
- return;
if(!this.freehandMode(evt)) {
Modified: trunk/openlayers/tests/Handler/Feature.html
--- trunk/openlayers/tests/Handler/Feature.html 2011-03-31 09:45:50 UTC (rev 11829)
+++ trunk/openlayers/tests/Handler/Feature.html 2011-03-31 09:49:41 UTC (rev 11830)
@@ -53,7 +53,7 @@
function test_events(t) {
- t.plan(35);
+ t.plan(30);
var map = new OpenLayers.Map('map');
var control = new OpenLayers.Control();
@@ -64,8 +64,8 @@
// list below events that should be handled (events) and those
// that should not be handled (nonevents) by the handler
- var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart", "touchmove"];
- var nonevents = ["mouseout", "resize", "focus", "blur", "touchend"];
+ var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart"];
+ var nonevents = ["mouseout", "resize", "focus", "blur"];
map.events.registerPriority = function(type, obj, func) {
var output = func();
// Don't listen for setEvent handlers (#902)
@@ -255,82 +255,6 @@
map.events.triggerEvent('touchstart', evtPx);
- function test_touchstart(t) {
- // a test to verify that the touchstart function does
- // unregister the mouse listeners when it's called the
- // first time
- t.plan(4);
- // set up
- var map = new OpenLayers.Map('map', {controls: []});
- var control = new OpenLayers.Control();
- map.addControl(control);
- var layer = new OpenLayers.Layer();
- map.addLayer(layer);
- var handler = new OpenLayers.Handler.Feature(control, layer, {});
- handler.mousedown = function() {}; // mock mousedown
- handler.activate();
- function allRegistered() {
- var eventTypes = ['mousedown', 'mouseup', 'mousemove', 'click', 'dblclick'],
- eventType,
- listeners,
- listener,
- flag;
- for(var i=0, ilen=eventTypes.length; i<ilen; i++) {
- flag = false;
- eventType = eventTypes[i];
- listeners = map.events.listeners[eventType];
- for(var j=0, jlen=listeners.length; j<jlen; j++) {
- listener = listeners[j];
- if(listener.func === handler[eventType] && listener.obj === handler) {
- flag = true;
- break;
- if(!flag) {
- return false;
- return true;
- function noneRegistered() {
- eventType,
- listeners,
- listener;
- return false;
- return true;
- // test
- t.ok(allRegistered(), 'mouse listeners are registered');
- handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
- t.ok(noneRegistered(), 'mouse listeners are unregistered');
- t.ok(handler.touch, 'handler.touch is set');
- handler.deactivate();
- t.ok(!handler.touch, 'handler.touch is not set');
- // tear down
- map.destroy();
function test_deactivate(t) {
t.plan(3);
More information about the Commits
