[OpenLayers-Commits] r11831 - in trunk/openlayers:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Thu Mar 31 05:52:35 EDT 2011
Author: sbrunner
Date: 2011-03-31 02:52:33 -0700 (Thu, 31 Mar 2011)
New Revision: 11831
trunk/openlayers/lib/OpenLayers/Handler/Feature.js
trunk/openlayers/tests/Handler/Feature.html
fix Don't let the browser to zoom or select the map on feature selection, r=erilem (closes #3212)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Feature.js
--- trunk/openlayers/lib/OpenLayers/Handler/Feature.js 2011-03-31 09:49:41 UTC (rev 11830)
+++ trunk/openlayers/lib/OpenLayers/Handler/Feature.js 2011-03-31 09:52:33 UTC (rev 11831)
@@ -56,6 +56,13 @@
* {<OpenLayers.Pixel>} The location of the last mouseup.
up: null,
+ * Property: touch
+ * {Boolean} When a touchstart event is fired, touch will be true and all
+ * mouse related listeners will do nothing.
+ touch: false,
* Property: clickTolerance
@@ -129,10 +136,34 @@
* {Boolean} Let the event propagate.
touchstart: function(evt) {
+ if(!this.touch) {
+ this.touch = true;
+ this.map.events.un({
+ mousedown: this.mousedown,
+ mouseup: this.mouseup,
+ mousemove: this.mousemove,
+ click: this.click,
+ dblclick: this.dblclick,
+ scope: this
return this.mousedown(evt);
+ * Method: touchmove
+ * Handle touchmove events. We just prevent the browser default behavior,
+ * for Android Safari not to select text when moving the finger after
+ * selecting a feature.
+ * Parameters:
+ * evt - {Event}
+ touchmove: function(evt) {
+ OpenLayers.Event.stop(evt);
* Method: mousedown
* Handle mouse down. Stop propagation if a feature is targeted by this
* event (stops map dragging during feature selection).
@@ -251,6 +282,11 @@
this.lastFeature = null;
if(this.feature) {
+ if(evt.type === "touchstart") {
+ // stop the event to prevent Android Safari from
+ // "flashing" the map div
var inNew = (this.feature != this.lastFeature);
if(this.geometryTypeMatches(this.feature)) {
// in to a feature
@@ -349,6 +385,7 @@
this.down = null;
this.up = null;
+ this.touch = false;
"removelayer": this.handleMapEvents,
"changelayer": this.handleMapEvents,
Modified: trunk/openlayers/tests/Handler/Feature.html
--- trunk/openlayers/tests/Handler/Feature.html 2011-03-31 09:49:41 UTC (rev 11830)
+++ trunk/openlayers/tests/Handler/Feature.html 2011-03-31 09:52:33 UTC (rev 11831)
@@ -53,7 +53,7 @@
function test_events(t) {
- t.plan(30);
+ t.plan(35);
var map = new OpenLayers.Map('map');
var control = new OpenLayers.Control();
@@ -64,8 +64,8 @@
// list below events that should be handled (events) and those
// that should not be handled (nonevents) by the handler
- var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart"];
- var nonevents = ["mouseout", "resize", "focus", "blur"];
+ var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart", "touchmove"];
+ var nonevents = ["mouseout", "resize", "focus", "blur", "touchend"];
map.events.registerPriority = function(type, obj, func) {
var output = func();
// Don't listen for setEvent handlers (#902)
@@ -255,6 +255,82 @@
map.events.triggerEvent('touchstart', evtPx);
+ function test_touchstart(t) {
+ // a test to verify that the touchstart function does
+ // unregister the mouse listeners when it's called the
+ // first time
+ t.plan(4);
+ // set up
+ var map = new OpenLayers.Map('map', {controls: []});
+ var control = new OpenLayers.Control();
+ map.addControl(control);
+ var layer = new OpenLayers.Layer();
+ map.addLayer(layer);
+ var handler = new OpenLayers.Handler.Feature(control, layer, {});
+ handler.mousedown = function() {}; // mock mousedown
+ handler.activate();
+ function allRegistered() {
+ var eventTypes = ['mousedown', 'mouseup', 'mousemove', 'click', 'dblclick'],
+ eventType,
+ listeners,
+ listener,
+ flag;
+ for(var i=0, ilen=eventTypes.length; i<ilen; i++) {
+ flag = false;
+ eventType = eventTypes[i];
+ listeners = map.events.listeners[eventType];
+ for(var j=0, jlen=listeners.length; j<jlen; j++) {
+ listener = listeners[j];
+ if(listener.func === handler[eventType] && listener.obj === handler) {
+ flag = true;
+ break;
+ if(!flag) {
+ return false;
+ return true;
+ function noneRegistered() {
+ eventType,
+ listeners,
+ listener;
+ return false;
+ return true;
+ // test
+ t.ok(allRegistered(), 'mouse listeners are registered');
+ handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
+ t.ok(noneRegistered(), 'mouse listeners are unregistered');
+ t.ok(handler.touch, 'handler.touch is set');
+ handler.deactivate();
+ t.ok(!handler.touch, 'handler.touch is not set');
+ // tear down
+ map.destroy();
function test_deactivate(t) {
t.plan(3);
More information about the Commits
