[OpenLayers-Commits] r11964 - in trunk/openlayers: examples
lib/OpenLayers/Control tests tests/Control
commits-20090109 at openlayers.org
Tue May 10 03:09:19 EDT 2011
Author: erilem
Date: 2011-05-10 00:09:17 -0700 (Tue, 10 May 2011)
New Revision: 11964
Added:
trunk/openlayers/tests/Control/EditingToolbar.html
trunk/openlayers/examples/navtoolbar-alwaysZoom.html
trunk/openlayers/lib/OpenLayers/Control/EditingToolbar.js
trunk/openlayers/lib/OpenLayers/Control/NavToolbar.js
trunk/openlayers/tests/Control/NavToolbar.html
trunk/openlayers/tests/list-tests.html
the default controls of the editing and navigation toolbars are not activated, p=jorix, r=me (closes #3268)
Modified: trunk/openlayers/examples/navtoolbar-alwaysZoom.html
--- trunk/openlayers/examples/navtoolbar-alwaysZoom.html 2011-05-09 23:31:32 UTC (rev 11963)
+++ trunk/openlayers/examples/navtoolbar-alwaysZoom.html 2011-05-10 07:09:17 UTC (rev 11964)
@@ -47,7 +47,7 @@
draw: function() {
var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
- this.activateControl(this.controls[0]);
+ this.defaultControl = this.controls[0];
return div;
Modified: trunk/openlayers/lib/OpenLayers/Control/EditingToolbar.js
--- trunk/openlayers/lib/OpenLayers/Control/EditingToolbar.js 2011-05-09 23:31:32 UTC (rev 11963)
+++ trunk/openlayers/lib/OpenLayers/Control/EditingToolbar.js 2011-05-10 07:09:17 UTC (rev 11964)
@@ -55,7 +55,9 @@
draw: function() {
+ if (this.defaultControl === null) {
return div;
Modified: trunk/openlayers/lib/OpenLayers/Control/NavToolbar.js
--- trunk/openlayers/lib/OpenLayers/Control/NavToolbar.js 2011-05-09 23:31:32 UTC (rev 11963)
+++ trunk/openlayers/lib/OpenLayers/Control/NavToolbar.js 2011-05-10 07:09:17 UTC (rev 11964)
@@ -47,7 +47,9 @@
draw: function() {
return div;
Added: trunk/openlayers/tests/Control/EditingToolbar.html
--- trunk/openlayers/tests/Control/EditingToolbar.html (rev 0)
+++ trunk/openlayers/tests/Control/EditingToolbar.html 2011-05-10 07:09:17 UTC (rev 11964)
@@ -0,0 +1,30 @@
+<html>
+<head>
+ <script src="../OLLoader.js"></script>
+ <script type="text/javascript">
+ function test_ctor_draw(t) {
+ t.plan(4);
+ var map = new OpenLayers.Map('map');
+ var vLayer = new OpenLayers.Layer.Vector();
+ map.addLayer(vLayer);
+ var editingToolbar = new OpenLayers.Control.EditingToolbar(vLayer);
+ map.addControl(editingToolbar);
+ t.ok(editingToolbar instanceof OpenLayers.Control.EditingToolbar,
+ "new OpenLayers.Control.EditingToolbar returns object" );
+ t.ok(editingToolbar.controls[0] instanceof OpenLayers.Control.Navigation,
+ "EditingToolbar contains Control.Navigation object" );
+ t.eq(editingToolbar.controls[0].active, true,
+ "First control is active" );
+ t.eq(editingToolbar.controls.length, 4,
+ "EditingToolbar contains 4 Controls" );
+ map.destroy();
+ </script>
+</head>
+<body>
+ <div id="map" style="width: 1024px; height: 512px;"/>
+</body>
+</html>
Modified: trunk/openlayers/tests/Control/NavToolbar.html
--- trunk/openlayers/tests/Control/NavToolbar.html 2011-05-09 23:31:32 UTC (rev 11963)
+++ trunk/openlayers/tests/Control/NavToolbar.html 2011-05-10 07:09:17 UTC (rev 11964)
@@ -25,7 +25,18 @@
// t.eq( control.div.style.top, "6px", "Control div top located correctly by default");
+ function test_Control_NavToolbar_defaultControl (t) {
+ t.plan( 1 );
+ var nav = new OpenLayers.Control.NavToolbar();
+ map.addControl(nav);
+ t.eq(nav.controls[0].active, true, "First control is active" );
+ map.destroy();
</script>
</head>
<body>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2011-05-09 23:31:32 UTC (rev 11963)
+++ trunk/openlayers/tests/list-tests.html 2011-05-10 07:09:17 UTC (rev 11964)
@@ -15,6 +15,7 @@
<li>Control/DragFeature.html</li>
<li>Control/DragPan.html</li>
<li>Control/DrawFeature.html</li>
+ <li>Control/EditingToolbar.html</li>
<li>Control/Geolocate.html</li>
<li>Control/GetFeature.html</li>
<li>Control/Graticule.html</li>
More information about the Commits
