[OpenLayers-Commits] r11965 - in trunk/openlayers:
lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org
Tue May 10 03:13:26 EDT 2011
Author: erilem
Date: 2011-05-10 00:13:22 -0700 (Tue, 10 May 2011)
New Revision: 11965
trunk/openlayers/lib/OpenLayers/Control/Panel.js
trunk/openlayers/tests/Control/Panel.html
allow toggling TYPE_TOOL controls in panels, p=jorix, r=me (closes #3294)
Modified: trunk/openlayers/lib/OpenLayers/Control/Panel.js
--- trunk/openlayers/lib/OpenLayers/Control/Panel.js 2011-05-10 07:09:17 UTC (rev 11964)
+++ trunk/openlayers/lib/OpenLayers/Control/Panel.js 2011-05-10 07:13:22 UTC (rev 11965)
@@ -47,6 +47,14 @@
saveState: false,
+ * APIProperty: allowDepress
+ * {Boolean} If is true the <OpenLayers.Control.TYPE_TOOL> controls can
+ * be deactivated by clicking the icon that represents them. Default
+ * is false.
+ allowDepress: false,
* Property: activeState
* {Object} stores the active state of this panel's controls.
@@ -199,15 +207,19 @@
return;
- var c;
- for (var i=0, len=this.controls.length; i<len; i++) {
- c = this.controls[i];
- if (c != control &&
- (c.type === OpenLayers.Control.TYPE_TOOL || c.type == null)) {
- c.deactivate();
+ if (this.allowDepress && control.active) {
+ control.deactivate();
+ } else {
+ var c;
+ for (var i=0, len=this.controls.length; i<len; i++) {
+ c = this.controls[i];
+ if (c != control &&
+ (c.type === OpenLayers.Control.TYPE_TOOL || c.type == null)) {
+ c.deactivate();
+ control.activate();
- control.activate();
Modified: trunk/openlayers/tests/Control/Panel.html
--- trunk/openlayers/tests/Control/Panel.html 2011-05-10 07:09:17 UTC (rev 11964)
+++ trunk/openlayers/tests/Control/Panel.html 2011-05-10 07:13:22 UTC (rev 11965)
@@ -247,6 +247,7 @@
t.ok(!controlNoDeactive.active, "Tool control autoActivate:true is not active");
function test_Control_Panel_deactivate (t) {
t.plan(2);
var map = new OpenLayers.Map('map');
@@ -262,6 +263,31 @@
map.destroy();
+ function test_allowDepress (t) {
+ t.plan(2);
+ var map = new OpenLayers.Map('map');
+ var panel = new OpenLayers.Control.Panel();
+ panel.addControls([new OpenLayers.Control(),new OpenLayers.Control()]);
+ map.addControl(panel);
+ var control1 = panel.controls[1]
+ panel.activateControl(control1);
+ panel.allowDepress = false;
+ t.eq(control1.active, true,
+ "control1 remains active after calling again activateControl when allowDepress = false");
+ panel.allowDepress = true;
+ t.eq(control1.active, false,
+ "control1 is inactive after calling again activateControl when allowDepress = true");
+ // panel.deactivate();
+ map.destroy();
</script>
</head>
<body>
More information about the Commits
