[OpenLayers-Commits] r11970 - in
sandbox/camptocamp/ifremer/openlayers: build
lib/OpenLayers/Format/CSWGetRecords
commits-20090109 at openlayers.org
Tue May 17 08:57:24 EDT 2011
Author: fvanderbiest
Date: 2011-05-17 05:57:23 -0700 (Tue, 17 May 2011)
New Revision: 11970
Removed:
sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
sandbox/camptocamp/ifremer/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js
camptocamp/ifremer sandbox: csw getrecords format addition to parse GetRecordByIdResponse node
Deleted: sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
--- sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js 2011-05-16 07:12:03 UTC (rev 11969)
+++ sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js 2011-05-17 12:57:23 UTC (rev 11970)
@@ -1,598 +0,0 @@
-var OpenLayers={VERSION_NUMBER:"$Revision: 10862 $",singleFile:true,_getScriptLocation:function(){for(var a=/(^|(.*?\/))(OpenLayers.js)(\?|$)/,b=document.getElementsByTagName("script"),c,d="",e=0,f=b.length;e<f;e++)if(c=b[e].getAttribute("src"))if(c=c.match(a)){d=c[1];break}return function(){return d}}()};
-OpenLayers.String={startsWith:function(a,b){return a.indexOf(b)==0},contains:function(a,b){return a.indexOf(b)!=-1},trim:function(a){return a.replace(/^\s\s*/,"").replace(/\s\s*$/,"")},camelize:function(a){a=a.split("-");for(var b=a[0],c=1,d=a.length;c<d;c++){var e=a[c];b+=e.charAt(0).toUpperCase()+e.substring(1)}return b},format:function(a,b,c){b||(b=window);return a.replace(OpenLayers.String.tokenRegEx,function(d,e){for(var f,g=e.split(/\.+/),h=0;h<g.length;h++){if(h==0)f=b;f=f[g[h]]}if(typeof f==
-"function")f=c?f.apply(null,c):f();return typeof f=="undefined"?"undefined":f})},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(a){return OpenLayers.String.numberRegEx.test(a)},numericIf:function(a){return OpenLayers.String.isNumeric(a)?parseFloat(a):a}};
-if(!String.prototype.startsWith)String.prototype.startsWith=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.startsWith"}));return OpenLayers.String.startsWith(this,a)};if(!String.prototype.contains)String.prototype.contains=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.contains"}));return OpenLayers.String.contains(this,a)};
-if(!String.prototype.trim)String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.trim"}));return OpenLayers.String.trim(this)};if(!String.prototype.camelize)String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.camelize"}));return OpenLayers.String.camelize(this)};
-OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(a,b){var c=0;if(b>0)c=parseFloat(a.toPrecision(b));return c},format:function(a,b,c,d){b=typeof b!="undefined"?b:0;c=typeof c!="undefined"?c:OpenLayers.Number.thousandsSeparator;d=typeof d!="undefined"?d:OpenLayers.Number.decimalSeparator;if(b!=null)a=parseFloat(a.toFixed(b));var e=a.toString().split(".");if(e.length==1&&b==null)b=0;a=e[0];if(c)for(var f=/(-?[0-9]+)([0-9]{3})/;f.test(a);)a=a.replace(f,"$1"+c+"$2");
-if(b==0)b=a;else{c=e.length>1?e[1]:"0";if(b!=null)c+=Array(b-c.length+1).join("0");b=a+d+c}return b}};if(!Number.prototype.limitSigDigs)Number.prototype.limitSigDigs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Number.limitSigDigs"}));return OpenLayers.Number.limitSigDigs(this,a)};
-OpenLayers.Function={bind:function(a,b){var c=Array.prototype.slice.apply(arguments,[2]);return function(){var d=c.concat(Array.prototype.slice.apply(arguments,[0]));return a.apply(b,d)}},bindAsEventListener:function(a,b){return function(c){return a.call(b,c||window.event)}},False:function(){return false},True:function(){return true}};
-if(!Function.prototype.bind)Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bind"}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments)};
-if(!Function.prototype.bindAsEventListener)Function.prototype.bindAsEventListener=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bindAsEventListener"}));return OpenLayers.Function.bindAsEventListener(this,a)};OpenLayers.Array={filter:function(a,b,c){var d=[];if(Array.prototype.filter)d=a.filter(b,c);else{var e=a.length;if(typeof b!="function")throw new TypeError;for(var f=0;f<e;f++)if(f in a){var g=a[f];b.call(c,g,f,a)&&d.push(g)}}return d}};
-OpenLayers.Date={toISOString:function(){if("toISOString"in Date.prototype)return function(b){return b.toISOString()};else{var a=function(b,c){for(var d=b+"";d.length<c;)d="0"+d;return d};return function(b){return isNaN(b.getTime())?"Invalid Date":b.getUTCFullYear()+"-"+a(b.getUTCMonth()+1,2)+"-"+a(b.getUTCDate(),2)+"T"+a(b.getUTCHours(),2)+":"+a(b.getUTCMinutes(),2)+":"+a(b.getUTCSeconds(),2)+"."+a(b.getUTCMilliseconds(),3)+"Z"}}}(),parse:function(a){var b;b=Date.parse(a);if(isNaN(b))if((a=a.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/))&&
-(a[1]||a[7])){b=parseInt(a[1],10)||0;var c=parseInt(a[2],10)-1||0,d=parseInt(a[3],10)||1;b=new Date(Date.UTC(b,c,d));if(c=a[7]){d=parseInt(a[4],10);var e=parseInt(a[5],10),f=parseFloat(a[6]),g=f|0;b.setUTCHours(d,e,g,Math.round(1E3*(f-g)));if(c!=="Z"){c=parseInt(c,10);a=parseInt(a[8])||0;a=-1E3*(60*c*60+a*60);b=new Date(b.getTime()+a)}}}else b=new Date("invalid");else b=new Date(b);return b}};
-OpenLayers.Class=function(){var a=arguments.length,b=arguments[0],c=arguments[a-1],d=typeof c.initialize=="function"?c.initialize:function(){b.apply(this,arguments)};if(a>1){a=[d,b].concat(Array.prototype.slice.call(arguments).slice(1,a-1),c);OpenLayers.inherit.apply(null,a)}else d.prototype=c;return d};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){arguments&&arguments[0]!=OpenLayers.Class.isPrototype&&this.initialize.apply(this,arguments)}};
-OpenLayers.Class.inherit=function(a){var b=function(){a.call(this)},c=[b].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,c);return b.prototype};OpenLayers.inherit=function(a,b){var c=function(){};c.prototype=b.prototype;a.prototype=new c;var d,e;c=2;for(d=arguments.length;c<d;c++){e=arguments[c];if(typeof e==="function")e=e.prototype;OpenLayers.Util.extend(a.prototype,e)}};OpenLayers.Util={};
-OpenLayers.Util.getElement=function(){for(var a=[],b=0,c=arguments.length;b<c;b++){var d=arguments[b];if(typeof d=="string")d=document.getElementById(d);if(arguments.length==1)return d;a.push(d)}return a};OpenLayers.Util.isElement=function(a){return!!(a&&a.nodeType===1)};if(typeof window.$==="undefined")window.$=OpenLayers.Util.getElement;
-OpenLayers.Util.extend=function(a,b){a=a||{};if(b){for(var c in b){var d=b[c];if(d!==undefined)a[c]=d}if(!(typeof window.Event=="function"&&b instanceof window.Event)&&b.hasOwnProperty&&b.hasOwnProperty("toString"))a.toString=b.toString}return a};OpenLayers.Util.removeItem=function(a,b){for(var c=a.length-1;c>=0;c--)a[c]==b&&a.splice(c,1);return a};OpenLayers.Util.clearArray=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"array = []"}));a.length=0};
-OpenLayers.Util.indexOf=function(a,b){if(typeof a.indexOf=="function")return a.indexOf(b);else{for(var c=0,d=a.length;c<d;c++)if(a[c]==b)return c;return-1}};
-OpenLayers.Util.modifyDOMElement=function(a,b,c,d,e,f,g,h){if(b)a.id=b;if(c){a.style.left=c.x+"px";a.style.top=c.y+"px"}if(d){a.style.width=d.w+"px";a.style.height=d.h+"px"}if(e)a.style.position=e;if(f)a.style.border=f;if(g)a.style.overflow=g;if(parseFloat(h)>=0&&parseFloat(h)<1){a.style.filter="alpha(opacity="+h*100+")";a.style.opacity=h}else if(parseFloat(h)==1){a.style.filter="";a.style.opacity=""}};
-OpenLayers.Util.createDiv=function(a,b,c,d,e,f,g,h){var i=document.createElement("div");if(d)i.style.backgroundImage="url("+d+")";a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="absolute");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,g,h);return i};
-OpenLayers.Util.createImage=function(a,b,c,d,e,f,g,h){var i=document.createElement("img");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="relative");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,null,g);if(h){i.style.display="none";OpenLayers.Event.observe(i,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,i));OpenLayers.Event.observe(i,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,i))}i.style.alt=a;i.galleryImg="no";if(d)i.src=d;return i};
-OpenLayers.Util.setOpacity=function(a,b){OpenLayers.Util.modifyDOMElement(a,null,null,null,null,null,null,b)};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||this.map&&this.viewRequestID==this.map.viewRequestID)this.style.display="";OpenLayers.Element.removeClass(this,"olImageLoadError")};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;
-OpenLayers.Util.onImageLoadError=function(){this._attempts=this._attempts?this._attempts+1:1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var a=this.urls;if(a&&a instanceof Array&&a.length>1){var b=this.src.toString(),c,d;for(d=0;c=a[d];d++)if(b.indexOf(c)!=-1)break;var e=Math.floor(a.length*Math.random());e=a[e];for(d=0;e==c&&d++<4;){e=Math.floor(a.length*Math.random());e=a[e]}this.src=b.replace(c,e)}else this.src=this.src}else OpenLayers.Element.addClass(this,"olImageLoadError");this.style.display=
-""};OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var a=navigator.appVersion.split("MSIE");a=parseFloat(a[1]);var b=false;try{b=!!document.body.filters}catch(c){}OpenLayers.Util.alphaHackNeeded=b&&a>=5.5&&a<7}return OpenLayers.Util.alphaHackNeeded};
-OpenLayers.Util.modifyAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){OpenLayers.Util.modifyDOMElement(a,b,c,d,f,null,null,i);b=a.childNodes[0];if(e)b.src=e;OpenLayers.Util.modifyDOMElement(b,a.id+"_innerImage",null,d,"relative",g);if(OpenLayers.Util.alphaHack()){if(a.style.display!="none")a.style.display="inline-block";if(h==null)h="scale";a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+b.src+"', sizingMethod='"+h+"')";if(parseFloat(a.style.opacity)>=0&&parseFloat(a.style.opacity)<
-1)a.style.filter+=" alpha(opacity="+a.style.opacity*100+")";b.style.filter="alpha(opacity=0)"}};
-OpenLayers.Util.createAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){var j=OpenLayers.Util.createDiv(),k=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);j.appendChild(k);if(i){k.style.display="none";OpenLayers.Event.observe(k,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,j));OpenLayers.Event.observe(k,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,j))}OpenLayers.Util.modifyAlphaImageDiv(j,a,b,c,d,e,f,g,h);return j};
-OpenLayers.Util.upperCaseObject=function(a){var b={},c;for(c in a)b[c.toUpperCase()]=a[c];return b};OpenLayers.Util.applyDefaults=function(a,b){a=a||{};var c=typeof window.Event=="function"&&b instanceof window.Event,d;for(d in b)if(a[d]===undefined||!c&&b.hasOwnProperty&&b.hasOwnProperty(d)&&!a.hasOwnProperty(d))a[d]=b[d];if(!c&&b&&b.hasOwnProperty&&b.hasOwnProperty("toString")&&!a.hasOwnProperty("toString"))a.toString=b.toString;return a};
-OpenLayers.Util.getParameterString=function(a){var b=[],c;for(c in a){var d=a[c];if(d!=null&&typeof d!="function"){if(typeof d=="object"&&d.constructor==Array){for(var e=[],f,g=0,h=d.length;g<h;g++){f=d[g];e.push(encodeURIComponent(f===null||f===undefined?"":f))}d=e.join(",")}else d=encodeURIComponent(d);b.push(encodeURIComponent(c)+"="+d)}}return b.join("&")};OpenLayers.Util.urlAppend=function(a,b){var c=a;if(b){var d=(a+" ").split(/[?&]/);c+=d.pop()===" "?b:d.length?"&"+b:"?"+b}return c};
-OpenLayers.ImgPath="";OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||OpenLayers._getScriptLocation()+"img/"};OpenLayers.Util.Try=function(){for(var a=null,b=0,c=arguments.length;b<c;b++){var d=arguments[b];try{a=d();break}catch(e){}}return a};OpenLayers.Util.getNodes=function(a,b){return OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(a.documentElement.childNodes,b)},function(){return OpenLayers.Util._getNodes(a.childNodes,b)})};
-OpenLayers.Util._getNodes=function(a,b){for(var c=[],d=0,e=a.length;d<e;d++)a[d].nodeName==b&&c.push(a[d]);return c};OpenLayers.Util.getTagText=function(a,b,c){if((a=OpenLayers.Util.getNodes(a,b))&&a.length>0){c||(c=0);if(a[c].childNodes.length>1)return a.childNodes[1].nodeValue;else if(a[c].childNodes.length==1)return a[c].firstChild.nodeValue}else return""};
-OpenLayers.Util.getXmlNodeValue=function(a){var b=null;OpenLayers.Util.Try(function(){b=a.text;if(!b)b=a.textContent;if(!b)b=a.firstChild.nodeValue},function(){b=a.textContent});return b};OpenLayers.Util.mouseLeft=function(a,b){for(var c=a.relatedTarget?a.relatedTarget:a.toElement;c!=b&&c!=null;)c=c.parentNode;return c!=b};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(a,b){if(b==null)b=OpenLayers.Util.DEFAULT_PRECISION;return a=b==0?parseFloat(a):parseFloat(parseFloat(a).toPrecision(b))};
-OpenLayers.Util.rad=function(a){return a*Math.PI/180};OpenLayers.Util.deg=function(a){return a*180/Math.PI};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};
-OpenLayers.Util.distVincenty=function(a,b){var c=OpenLayers.Util.VincentyConstants,d=c.a,e=c.b;c=c.f;var f=OpenLayers.Util.rad(b.lon-a.lon),g=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(a.lat))),h=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(b.lat))),i=Math.sin(g);g=Math.cos(g);var j=Math.sin(h);h=Math.cos(h);for(var k=f,n=2*Math.PI,m=20;Math.abs(k-n)>1.0E-12&&--m>0;){var l=Math.sin(k),o=Math.cos(k),p=Math.sqrt(h*l*h*l+(g*j-i*h*o)*(g*j-i*h*o));if(p==0)return 0;o=i*j+g*h*o;var r=Math.atan2(p,o),q=
-Math.asin(g*h*l/p),s=Math.cos(q)*Math.cos(q);l=o-2*i*j/s;var t=c/16*s*(4+c*(4-3*s));n=k;k=f+(1-t)*c*Math.sin(q)*(r+t*p*(l+t*o*(-1+2*l*l)))}if(m==0)return NaN;d=s*(d*d-e*e)/(e*e);c=d/1024*(256+d*(-128+d*(74-47*d)));return(e*(1+d/16384*(4096+d*(-768+d*(320-175*d))))*(r-c*p*(l+c/4*(o*(-1+2*l*l)-c/6*l*(-3+4*p*p)*(-3+4*l*l))))).toFixed(3)/1E3};
-OpenLayers.Util.destinationVincenty=function(a,b,c){var d=OpenLayers.Util,e=d.VincentyConstants,f=e.a,g=e.b;e=e.f;var h=a.lon,i=a.lat;a=d.rad(b);b=Math.sin(a);a=Math.cos(a);var j=(1-e)*Math.tan(d.rad(i));i=1/Math.sqrt(1+j*j);var k=j*i,n=Math.atan2(j,a);j=i*b;var m=1-j*j;f=m*(f*f-g*g)/(g*g);var l=1+f/16384*(4096+f*(-768+f*(320-175*f))),o=f/1024*(256+f*(-128+f*(74-47*f)));f=c/(g*l);for(var p=2*Math.PI;Math.abs(f-p)>1.0E-12;){var r=Math.cos(2*n+f),q=Math.sin(f),s=Math.cos(f),t=o*q*(r+o/4*(s*(-1+2*r*
-r)-o/6*r*(-3+4*q*q)*(-3+4*r*r)));p=f;f=c/(g*l)+t}c=k*q-i*s*a;c=Math.atan2(k*s+i*q*a,(1-e)*Math.sqrt(j*j+c*c));g=e/16*m*(4+e*(4-3*m));return new OpenLayers.LonLat(h+d.deg(Math.atan2(q*b,i*s-k*q*a)-(1-g)*e*j*(f+g*q*(r+g*s*(-1+2*r*r)))),d.deg(c))};
-OpenLayers.Util.getParameters=function(a){a=a||window.location.href;var b="";if(OpenLayers.String.contains(a,"?")){b=a.indexOf("?")+1;var c=OpenLayers.String.contains(a,"#")?a.indexOf("#"):a.length;b=a.substring(b,c)}a={};b=b.split(/[&;]/);c=0;for(var d=b.length;c<d;++c){var e=b[c].split("=");if(e[0]){var f=e[0];try{f=decodeURIComponent(f)}catch(g){f=unescape(f)}e=(e[1]||"").replace(/\+/g," ");try{e=decodeURIComponent(e)}catch(h){e=unescape(e)}e=e.split(",");if(e.length==1)e=e[0];a[f]=e}}return a};
-OpenLayers.Util.getArgs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Util.getParameters"}));return OpenLayers.Util.getParameters(a)};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(a){if(a==null)a="id_";OpenLayers.Util.lastSeqID+=1;return a+OpenLayers.Util.lastSeqID};OpenLayers.INCHES_PER_UNIT={inches:1,ft:12,mi:63360,m:39.3701,km:39370.1,dd:4374754,yd:36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;
-OpenLayers.INCHES_PER_UNIT.degrees=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT.nmi=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.0254000508001016;
-OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{Inch:OpenLayers.INCHES_PER_UNIT.inches,Meter:1/OpenLayers.METERS_PER_INCH,Foot:0.3048006096012192/OpenLayers.METERS_PER_INCH,IFoot:0.3048/OpenLayers.METERS_PER_INCH,ClarkeFoot:0.3047972651151/OpenLayers.METERS_PER_INCH,SearsFoot:0.30479947153867626/OpenLayers.METERS_PER_INCH,GoldCoastFoot:0.3047997101815088/OpenLayers.METERS_PER_INCH,IInch:0.0254/OpenLayers.METERS_PER_INCH,MicroInch:2.54E-5/OpenLayers.METERS_PER_INCH,Mil:2.54E-8/OpenLayers.METERS_PER_INCH,
-Centimeter:0.01/OpenLayers.METERS_PER_INCH,Kilometer:1E3/OpenLayers.METERS_PER_INCH,Yard:0.9144018288036576/OpenLayers.METERS_PER_INCH,SearsYard:0.914398414616029/OpenLayers.METERS_PER_INCH,IndianYard:0.9143985307444408/OpenLayers.METERS_PER_INCH,IndianYd37:0.91439523/OpenLayers.METERS_PER_INCH,IndianYd62:0.9143988/OpenLayers.METERS_PER_INCH,IndianYd75:0.9143985/OpenLayers.METERS_PER_INCH,IndianFoot:0.30479951/OpenLayers.METERS_PER_INCH,IndianFt37:0.30479841/OpenLayers.METERS_PER_INCH,IndianFt62:0.3047996/
-OpenLayers.METERS_PER_INCH,IndianFt75:0.3047995/OpenLayers.METERS_PER_INCH,Mile:1609.3472186944373/OpenLayers.METERS_PER_INCH,IYard:0.9144/OpenLayers.METERS_PER_INCH,IMile:1609.344/OpenLayers.METERS_PER_INCH,NautM:1852/OpenLayers.METERS_PER_INCH,"Lat-66":110943.31648893273/OpenLayers.METERS_PER_INCH,"Lat-83":110946.25736872235/OpenLayers.METERS_PER_INCH,Decimeter:0.1/OpenLayers.METERS_PER_INCH,Millimeter:0.0010/OpenLayers.METERS_PER_INCH,Dekameter:10/OpenLayers.METERS_PER_INCH,Decameter:10/OpenLayers.METERS_PER_INCH,
-Hectometer:100/OpenLayers.METERS_PER_INCH,GermanMeter:1.0000135965/OpenLayers.METERS_PER_INCH,CaGrid:0.999738/OpenLayers.METERS_PER_INCH,ClarkeChain:20.1166194976/OpenLayers.METERS_PER_INCH,GunterChain:20.11684023368047/OpenLayers.METERS_PER_INCH,BenoitChain:20.116782494375872/OpenLayers.METERS_PER_INCH,SearsChain:20.11676512155/OpenLayers.METERS_PER_INCH,ClarkeLink:0.201166194976/OpenLayers.METERS_PER_INCH,GunterLink:0.2011684023368047/OpenLayers.METERS_PER_INCH,BenoitLink:0.20116782494375873/OpenLayers.METERS_PER_INCH,
-SearsLink:0.2011676512155/OpenLayers.METERS_PER_INCH,Rod:5.02921005842012/OpenLayers.METERS_PER_INCH,IntnlChain:20.1168/OpenLayers.METERS_PER_INCH,IntnlLink:0.201168/OpenLayers.METERS_PER_INCH,Perch:5.02921005842012/OpenLayers.METERS_PER_INCH,Pole:5.02921005842012/OpenLayers.METERS_PER_INCH,Furlong:201.1684023368046/OpenLayers.METERS_PER_INCH,Rood:3.778266898/OpenLayers.METERS_PER_INCH,CapeFoot:0.3047972615/OpenLayers.METERS_PER_INCH,Brealey:375/OpenLayers.METERS_PER_INCH,ModAmFt:0.304812252984506/
-OpenLayers.METERS_PER_INCH,Fathom:1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":5E4/OpenLayers.METERS_PER_INCH,"150kilometers":15E4/OpenLayers.METERS_PER_INCH});
-OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{mm:OpenLayers.INCHES_PER_UNIT.Meter/1E3,cm:OpenLayers.INCHES_PER_UNIT.Meter/100,dm:OpenLayers.INCHES_PER_UNIT.Meter*100,km:OpenLayers.INCHES_PER_UNIT.Meter*1E3,kmi:OpenLayers.INCHES_PER_UNIT.nmi,fath:OpenLayers.INCHES_PER_UNIT.Fathom,ch:OpenLayers.INCHES_PER_UNIT.IntnlChain,link:OpenLayers.INCHES_PER_UNIT.IntnlLink,"us-in":OpenLayers.INCHES_PER_UNIT.inches,"us-ft":OpenLayers.INCHES_PER_UNIT.Foot,"us-yd":OpenLayers.INCHES_PER_UNIT.Yard,"us-ch":OpenLayers.INCHES_PER_UNIT.GunterChain,
-"us-mi":OpenLayers.INCHES_PER_UNIT.Mile,"ind-yd":OpenLayers.INCHES_PER_UNIT.IndianYd37,"ind-ft":OpenLayers.INCHES_PER_UNIT.IndianFt37,"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(a){return a>1?1/a:a};OpenLayers.Util.getResolutionFromScale=function(a,b){var c;if(a){if(b==null)b="degrees";c=1/(OpenLayers.Util.normalizeScale(a)*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH)}return c};
-OpenLayers.Util.getScaleFromResolution=function(a,b){if(b==null)b="degrees";return a*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH};OpenLayers.Util.safeStopPropagation=function(a){OpenLayers.Event.stop(a,true)};
-OpenLayers.Util.pagePosition=function(a){var b=[0,0],c=OpenLayers.Util.getViewportElement();if(!a||a==window||a==c)return b;var d=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(a,"position")=="absolute"&&(a.style.top==""||a.style.left==""),e=null;if(a.getBoundingClientRect){a=a.getBoundingClientRect();e=c.scrollTop;b[0]=a.left+c.scrollLeft;b[1]=a.top+e}else if(document.getBoxObjectFor&&!d){a=document.getBoxObjectFor(a);c=document.getBoxObjectFor(c);b[0]=a.screenX-c.screenX;
-b[1]=a.screenY-c.screenY}else{b[0]=a.offsetLeft;b[1]=a.offsetTop;e=a.offsetParent;if(e!=a)for(;e;){b[0]+=e.offsetLeft;b[1]+=e.offsetTop;e=e.offsetParent}c=OpenLayers.BROWSER_NAME;if(c=="opera"||c=="safari"&&OpenLayers.Element.getStyle(a,"position")=="absolute")b[1]-=document.body.offsetTop;for(e=a.offsetParent;e&&e!=document.body;){b[0]-=e.scrollLeft;if(c!="opera"||e.tagName!="TR")b[1]-=e.scrollTop;e=e.offsetParent}}return b};
-OpenLayers.Util.getViewportElement=function(){var a=arguments.callee.viewportElement;if(a==undefined){a=OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!="CSS1Compat"?document.body:document.documentElement;arguments.callee.viewportElement=a}return a};
-OpenLayers.Util.isEquivalentUrl=function(a,b,c){c=c||{};OpenLayers.Util.applyDefaults(c,{ignoreCase:true,ignorePort80:true,ignoreHash:true});a=OpenLayers.Util.createUrlObject(a,c);b=OpenLayers.Util.createUrlObject(b,c);for(var d in a)if(d!=="args")if(a[d]!=b[d])return false;for(d in a.args){if(a.args[d]!=b.args[d])return false;delete b.args[d]}for(d in b.args)return false;return true};
-OpenLayers.Util.createUrlObject=function(a,b){b=b||{};if(!/^\w+:\/\//.test(a)){var c=window.location,d=c.port?":"+c.port:"";d=c.protocol+"//"+c.host.split(":").shift()+d;if(a.indexOf("/")===0)a=d+a;else{c=c.pathname.split("/");c.pop();a=d+c.join("/")+"/"+a}}if(b.ignoreCase)a=a.toLowerCase();c=document.createElement("a");c.href=a;d={};d.host=c.host.split(":").shift();d.protocol=c.protocol;d.port=b.ignorePort80?c.port=="80"||c.port=="0"?"":c.port:c.port==""||c.port=="0"?"80":c.port;d.hash=b.ignoreHash||
-c.hash==="#"?"":c.hash;var e=c.search;if(!e){e=a.indexOf("?");e=e!=-1?a.substr(e):""}d.args=OpenLayers.Util.getParameters(e);d.pathname=c.pathname.charAt(0)=="/"?c.pathname:"/"+c.pathname;return d};OpenLayers.Util.removeTail=function(a){var b=null;b=a.indexOf("?");var c=a.indexOf("#");return b=b==-1?c!=-1?a.substr(0,c):a:c!=-1?a.substr(0,Math.min(b,c)):a.substr(0,b)};OpenLayers.IS_GECKO=function(){var a=navigator.userAgent.toLowerCase();return a.indexOf("webkit")==-1&&a.indexOf("gecko")!=-1}();
-OpenLayers.BROWSER_NAME=function(){var a="",b=navigator.userAgent.toLowerCase();if(b.indexOf("opera")!=-1)a="opera";else if(b.indexOf("msie")!=-1)a="msie";else if(b.indexOf("safari")!=-1)a="safari";else if(b.indexOf("mozilla")!=-1)a=b.indexOf("firefox")!=-1?"firefox":"mozilla";return a}();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME};
-OpenLayers.Util.getRenderedDimensions=function(a,b,c){var d,e,f=document.createElement("div");f.style.visibility="hidden";var g=c&&c.containerElement?c.containerElement:document.body;if(b)if(b.w){d=b.w;f.style.width=d+"px"}else if(b.h){e=b.h;f.style.height=e+"px"}if(c&&c.displayClass)f.className=c.displayClass;b=document.createElement("div");b.innerHTML=a;b.style.overflow="visible";if(b.childNodes){a=0;for(c=b.childNodes.length;a<c;a++)if(b.childNodes[a].style)b.childNodes[a].style.overflow="visible"}f.appendChild(b);
-g.appendChild(f);a=false;for(c=f.parentNode;c&&c.tagName.toLowerCase()!="body";){var h=OpenLayers.Element.getStyle(c,"position");if(h=="absolute"){a=true;break}else if(h&&h!="static")break;c=c.parentNode}if(!a)f.style.position="absolute";if(!d){d=parseInt(b.scrollWidth);f.style.width=d+"px"}e||(e=parseInt(b.scrollHeight));f.removeChild(b);g.removeChild(f);return new OpenLayers.Size(d,e)};
-OpenLayers.Util.getScrollbarWidth=function(){var a=OpenLayers.Util._scrollbarWidth;if(a==null){var b=null,c=null;b=a=0;b=document.createElement("div");b.style.position="absolute";b.style.top="-1000px";b.style.left="-1000px";b.style.width="100px";b.style.height="50px";b.style.overflow="hidden";c=document.createElement("div");c.style.width="100%";c.style.height="200px";b.appendChild(c);document.body.appendChild(b);a=c.offsetWidth;b.style.overflow="scroll";b=c.offsetWidth;document.body.removeChild(document.body.lastChild);
-OpenLayers.Util._scrollbarWidth=a-b;a=OpenLayers.Util._scrollbarWidth}return a};OpenLayers.Util.getFormattedLonLat=function(a,b,c){c||(c="dms");var d=Math.abs(a),e=Math.floor(d),f=d=(d-e)/(1/60);d=Math.floor(d);f=(f-d)/(1/60);f=Math.round(f*10);f/=10;if(e<10)e="0"+e;e=e+"\u00b0";if(c.indexOf("dm")>=0){if(d<10)d="0"+d;e+=d+"'";if(c.indexOf("dms")>=0){if(f<10)f="0"+f;e+=f+'"'}}e+=b=="lon"?a<0?OpenLayers.i18n("W"):OpenLayers.i18n("E"):a<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");return e};
-OpenLayers.Element={visible:function(a){return OpenLayers.Util.getElement(a).style.display!="none"},toggle:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]),d=OpenLayers.Element.visible(c)?"hide":"show";OpenLayers.Element[d](c)}},hide:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display="none"}},show:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);
-if(c)c.style.display=""}},remove:function(a){a=OpenLayers.Util.getElement(a);a.parentNode.removeChild(a)},getHeight:function(a){a=OpenLayers.Util.getElement(a);return a.offsetHeight},getDimensions:function(a){a=OpenLayers.Util.getElement(a);if(OpenLayers.Element.getStyle(a,"display")!="none")return{width:a.offsetWidth,height:a.offsetHeight};var b=a.style,c=b.visibility,d=b.position,e=b.display;b.visibility="hidden";b.position="absolute";b.display="";var f=a.clientWidth;a=a.clientHeight;b.display=
-e;b.position=d;b.visibility=c;return{width:f,height:a}},hasClass:function(a,b){var c=a.className;return!!c&&RegExp("(^|\\s)"+b+"(\\s|$)").test(c)},addClass:function(a,b){OpenLayers.Element.hasClass(a,b)||(a.className+=(a.className?" ":"")+b);return a},removeClass:function(a,b){var c=a.className;if(c)a.className=OpenLayers.String.trim(c.replace(RegExp("(^|\\s+)"+b+"(\\s+|$)")," "));return a},toggleClass:function(a,b){OpenLayers.Element.hasClass(a,b)?OpenLayers.Element.removeClass(a,b):OpenLayers.Element.addClass(a,
-b);return a},getStyle:function(a,b){a=OpenLayers.Util.getElement(a);var c=null;if(a&&a.style){c=a.style[OpenLayers.String.camelize(b)];if(!c)if(document.defaultView&&document.defaultView.getComputedStyle)c=(c=document.defaultView.getComputedStyle(a,null))?c.getPropertyValue(b):null;else if(a.currentStyle)c=a.currentStyle[OpenLayers.String.camelize(b)];var d=["left","top","right","bottom"];if(window.opera&&OpenLayers.Util.indexOf(d,b)!=-1&&OpenLayers.Element.getStyle(a,"position")=="static")c="auto"}return c==
-"auto"?null:c}};OpenLayers.Size=OpenLayers.Class({w:0,h:0,initialize:function(a,b){this.w=parseFloat(a);this.h=parseFloat(b)},toString:function(){return"w="+this.w+",h="+this.h},clone:function(){return new OpenLayers.Size(this.w,this.h)},equals:function(a){var b=false;if(a!=null)b=this.w==a.w&&this.h==a.h||isNaN(this.w)&&isNaN(this.h)&&isNaN(a.w)&&isNaN(a.h);return b},CLASS_NAME:"OpenLayers.Size"});
-OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(a){alert(a)},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};
-(function(){for(var a=document.getElementsByTagName("script"),b=0,c=a.length;b<c;++b)if(a[b].src.indexOf("firebug.js")!=-1)if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break}})();
-OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(a,b,c,d){this.url=a;this.size=b?b:new OpenLayers.Size(20,20);this.offset=c?c:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=d;a=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(a)},destroy:function(){this.erase();OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML=
-"";this.imageDiv=null},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset)},setSize:function(a){if(a!=null)this.size=a;this.draw()},setUrl:function(a){if(a!=null)this.url=a;this.draw()},draw:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(a);return this.imageDiv},erase:function(){this.imageDiv!=null&&this.imageDiv.parentNode!=null&&OpenLayers.Element.remove(this.imageDiv)},setOpacity:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,
-null,null,null,null,null,null,null,a)},moveTo:function(a){if(a!=null)this.px=a;if(this.imageDiv!=null)if(this.px==null)this.display(false);else{if(this.calculateOffset)this.offset=this.calculateOffset(this.size);a=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,a)}},display:function(a){this.imageDiv.style.display=a?"":"none"},isDrawn:function(){return this.imageDiv&&this.imageDiv.parentNode&&this.imageDiv.parentNode.nodeType!=11},CLASS_NAME:"OpenLayers.Icon"});
-OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,contentSize:null,size:null,contentHTML:null,backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,displayClass:"olPopup",contentDisplayClass:"olPopupContent",padding:0,disableFirefoxOverflowHack:false,fixPadding:function(){if(typeof this.padding=="number")this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding)},panMapIfOutOfView:false,
-keepInMap:false,closeOnMove:false,map:null,initialize:function(a,b,c,d,e,f){if(a==null)a=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.id=a;this.lonlat=b;this.contentSize=c!=null?c:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(d!=null)this.contentHTML=d;this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className=
-this.displayClass;this.groupDiv=OpenLayers.Util.createDiv(this.id+"_GroupDiv",null,null,null,"relative",null,"hidden");a=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(a,null,this.contentSize.clone(),null,"relative");this.contentDiv.className=this.contentDisplayClass;this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);e&&this.addCloseBox(f);this.registerEvents()},destroy:function(){this.border=this.opacity=this.backgroundColor=this.contentHTML=this.size=
-this.lonlat=this.id=null;this.closeOnMove&&this.map&&this.map.events.unregister("movestart",this,this.hide);this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv)}this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;this.map!=null&&this.map.removePopup(this);this.panMapIfOutOfView=this.padding=this.maxSize=this.minSize=this.autoSize=this.div=this.map=null},draw:function(a){if(a==null)if(this.lonlat!=
-null&&this.map!=null)a=this.map.getLayerPxFromLonLat(this.lonlat);this.closeOnMove&&this.map.events.register("movestart",this,this.hide);if(!this.disableFirefoxOverflowHack&&OpenLayers.BROWSER_NAME=="firefox"){this.map.events.register("movestart",this,function(){var b=document.defaultView.getComputedStyle(this.contentDiv,null).getPropertyValue("overflow");if(b!="hidden"){this.contentDiv._oldOverflow=b;this.contentDiv.style.overflow="hidden"}});this.map.events.register("moveend",this,function(){var b=
-this.contentDiv._oldOverflow;if(b){this.contentDiv.style.overflow=b;this.contentDiv._oldOverflow=null}})}this.moveTo(a);!this.autoSize&&!this.size&&this.setSize(this.contentSize);this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();this.panMapIfOutOfView&&this.panIntoView();return this.div},updatePosition:function(){if(this.lonlat&&this.map){var a=this.map.getLayerPxFromLonLat(this.lonlat);a&&this.moveTo(a)}},moveTo:function(a){if(a!=null&&this.div!=null){this.div.style.left=
-a.x+"px";this.div.style.top=a.y+"px"}},visible:function(){return OpenLayers.Element.visible(this.div)},toggle:function(){this.visible()?this.hide():this.show()},show:function(){OpenLayers.Element.show(this.div);this.panMapIfOutOfView&&this.panIntoView()},hide:function(){OpenLayers.Element.hide(this.div)},setSize:function(a){this.size=a.clone();var b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;
-if(this.closeDiv){var e=parseInt(this.closeDiv.style.width);c+=e+b.right}this.size.w+=c;this.size.h+=d;if(OpenLayers.BROWSER_NAME=="msie"){this.contentSize.w+=b.left+b.right;this.contentSize.h+=b.bottom+b.top}if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px"}if(this.contentDiv!=null){this.contentDiv.style.width=a.w+"px";this.contentDiv.style.height=a.h+"px"}},updateSize:function(){var a="<div class='"+this.contentDisplayClass+"'>"+this.contentDiv.innerHTML+
-"</div>",b=this.map?this.map.layerContainerDiv:document.body,c=OpenLayers.Util.getRenderedDimensions(a,null,{displayClass:this.displayClass,containerElement:b}),d=this.getSafeContentSize(c),e=null;if(d.equals(c))e=c;else{e=new OpenLayers.Size;e.w=d.w<c.w?d.w:null;e.h=d.h<c.h?d.h:null;if(e.w&&e.h)e=d;else{a=OpenLayers.Util.getRenderedDimensions(a,e,{displayClass:this.contentDisplayClass,containerElement:b});if(OpenLayers.Element.getStyle(this.contentDiv,"overflow")!="hidden"&&a.equals(d)){d=OpenLayers.Util.getScrollbarWidth();
-if(e.w)a.h+=d;else a.w+=d}e=this.getSafeContentSize(a)}}this.setSize(e)},setBackgroundColor:function(a){if(a!=undefined)this.backgroundColor=a;if(this.div!=null)this.div.style.backgroundColor=this.backgroundColor},setOpacity:function(a){if(a!=undefined)this.opacity=a;if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter="alpha(opacity="+this.opacity*100+")"}},setBorder:function(a){if(a!=undefined)this.border=a;if(this.div!=null)this.div.style.border=this.border},setContentHTML:function(a){if(a!=
-null)this.contentHTML=a;if(this.contentDiv!=null&&this.contentHTML!=null&&this.contentHTML!=this.contentDiv.innerHTML){this.contentDiv.innerHTML=this.contentHTML;if(this.autoSize){this.registerImageListeners();this.updateSize()}}},registerImageListeners:function(){for(var a=function(){this.popup.updateSize();this.popup.visible()&&this.popup.panMapIfOutOfView&&this.popup.panIntoView();OpenLayers.Event.stopObserving(this.img,"load",this.img._onImageLoad)},b=this.contentDiv.getElementsByTagName("img"),
-c=0,d=b.length;c<d;c++){var e=b[c];if(e.width==0||e.height==0){e._onImgLoad=OpenLayers.Function.bind(a,{popup:this,img:e});OpenLayers.Event.observe(e,"load",e._onImgLoad)}}},getSafeContentSize:function(a){a=a.clone();var b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;if(this.closeDiv){var e=parseInt(this.closeDiv.style.width);c+=e+b.right}if(this.minSize){a.w=Math.max(a.w,this.minSize.w-
-c);a.h=Math.max(a.h,this.minSize.h-d)}if(this.maxSize){a.w=Math.min(a.w,this.maxSize.w-c);a.h=Math.min(a.h,this.maxSize.h-d)}if(this.map&&this.map.size){e=b=0;if(this.keepInMap&&!this.panMapIfOutOfView){e=this.map.getPixelFromLonLat(this.lonlat);switch(this.relativePosition){case "tr":b=e.x;e=this.map.size.h-e.y;break;case "tl":b=this.map.size.w-e.x;e=this.map.size.h-e.y;break;case "bl":b=this.map.size.w-e.x;e=e.y;break;case "br":b=e.x;e=e.y;break;default:b=e.x;e=this.map.size.h-e.y}}d=this.map.size.h-
-this.map.paddingForPopups.top-this.map.paddingForPopups.bottom-d-e;a.w=Math.min(a.w,this.map.size.w-this.map.paddingForPopups.left-this.map.paddingForPopups.right-c-b);a.h=Math.min(a.h,d)}return a},getContentDivPadding:function(){var a=this._contentDivPadding;if(!a){if(this.div.parentNode==null){this.div.style.display="none";document.body.appendChild(this.div)}this._contentDivPadding=a=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,
-"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));if(this.div.parentNode==document.body){document.body.removeChild(this.div);this.div.style.display=""}}return a},addCloseBox:function(a){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var b=this.getContentDivPadding();this.closeDiv.style.right=b.right+"px";this.closeDiv.style.top=
-b.top+"px";this.groupDiv.appendChild(this.closeDiv);OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(a||function(c){this.hide();OpenLayers.Event.stop(c)},this))},panIntoView:function(){var a=this.map.getSize(),b=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top))),c=b.clone();if(b.x<this.map.paddingForPopups.left)c.x=this.map.paddingForPopups.left;else if(b.x+this.size.w>a.w-this.map.paddingForPopups.right)c.x=
-a.w-this.map.paddingForPopups.right-this.size.w;if(b.y<this.map.paddingForPopups.top)c.y=this.map.paddingForPopups.top;else if(b.y+this.size.h>a.h-this.map.paddingForPopups.bottom)c.y=a.h-this.map.paddingForPopups.bottom-this.size.h;this.map.pan(b.x-c.x,b.y-c.y)},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({mousedown:this.onmousedown,mousemove:this.onmousemove,mouseup:this.onmouseup,click:this.onclick,mouseout:this.onmouseout,dblclick:this.ondblclick,
-scope:this})},onmousedown:function(a){this.mousedown=true;OpenLayers.Event.stop(a,true)},onmousemove:function(a){this.mousedown&&OpenLayers.Event.stop(a,true)},onmouseup:function(a){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(a,true)}},onclick:function(a){OpenLayers.Event.stop(a,true)},onmouseout:function(){this.mousedown=false},ondblclick:function(a){OpenLayers.Event.stop(a,true)},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;
-OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";
-OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(a){this.container=OpenLayers.Util.getElement(a)},destroy:function(){this.map=this.resolution=this.size=this.extent=this.container=null},supported:function(){return false},setExtent:function(a,b){this.extent=a.clone();if(b)this.resolution=null},setSize:function(a){this.size=a.clone();this.resolution=null},getResolution:function(){return this.resolution=this.resolution||
-this.map.getResolution()},drawFeature:function(a,b){if(b==null)b=a.style;if(a.geometry){var c=a.geometry.getBounds();if(c){c.intersectsBounds(this.extent)||(b={display:"none"});c=this.drawGeometry(a.geometry,b,a.id);if(b.display!="none"&&b.label&&c!==false){var d=a.geometry.getCentroid();if(b.labelXOffset||b.labelYOffset){xOffset=isNaN(b.labelXOffset)?0:b.labelXOffset;yOffset=isNaN(b.labelYOffset)?0:b.labelYOffset;var e=this.getResolution();d.move(xOffset*e,yOffset*e)}this.drawText(a.id,b,d)}else this.removeText(a.id);
-return c}}},drawGeometry:function(){},drawText:function(){},removeText:function(){},clear:function(){},getFeatureIdFromEvent:function(){},eraseFeatures:function(a){a instanceof Array||(a=[a]);for(var b=0,c=a.length;b<c;++b){var d=a[b];this.eraseGeometry(d.geometry,d.id);this.removeText(d.id)}},eraseGeometry:function(){},moveRoot:function(){},getRenderLayerId:function(){return this.container.id},applyDefaultSymbolizer:function(a){var b=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);
-if(a.stroke===false){delete b.strokeWidth;delete b.strokeColor}a.fill===false&&delete b.fillColor;OpenLayers.Util.extend(b,a);return b},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};
-OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(a,b,c,d){if(a!=null)this.left=OpenLayers.Util.toFloat(a);if(b!=null)this.bottom=OpenLayers.Util.toFloat(b);if(c!=null)this.right=OpenLayers.Util.toFloat(c);if(d!=null)this.top=OpenLayers.Util.toFloat(d)},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top)},equals:function(a){var b=false;if(a!=null)b=this.left==a.left&&this.right==a.right&&this.top==
-a.top&&this.bottom==a.bottom;return b},toString:function(){return"left-bottom=("+this.left+","+this.bottom+") right-top=("+this.right+","+this.top+")"},toArray:function(a){return a===true?[this.bottom,this.left,this.top,this.right]:[this.left,this.bottom,this.right,this.top]},toBBOX:function(a,b){if(a==null)a=6;var c=Math.pow(10,a),d=Math.round(this.left*c)/c,e=Math.round(this.bottom*c)/c,f=Math.round(this.right*c)/c;c=Math.round(this.top*c)/c;return b===true?e+","+d+","+c+","+f:d+","+e+","+f+","+
-c},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])])},getWidth:function(){return this.right-this.left},getHeight:function(){return this.top-this.bottom},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight())},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+
-this.right)/2,(this.bottom+this.top)/2)},getCenterLonLat:function(){if(!this.centerLonLat)this.centerLonLat=new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);return this.centerLonLat},scale:function(a,b){if(b==null)b=this.getCenterLonLat();var c,d;if(b.CLASS_NAME=="OpenLayers.LonLat"){c=b.lon;d=b.lat}else{c=b.x;d=b.y}return new OpenLayers.Bounds((this.left-c)*a+c,(this.bottom-d)*a+d,(this.right-c)*a+c,(this.top-d)*a+d)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("boundsAddError");
-OpenLayers.Console.error(c);return null}return new OpenLayers.Bounds(this.left+a,this.bottom+b,this.right+a,this.top+b)},extend:function(a){var b=null;if(a){switch(a.CLASS_NAME){case "OpenLayers.LonLat":b=new OpenLayers.Bounds(a.lon,a.lat,a.lon,a.lat);break;case "OpenLayers.Geometry.Point":b=new OpenLayers.Bounds(a.x,a.y,a.x,a.y);break;case "OpenLayers.Bounds":b=a}if(b){this.centerLonLat=null;if(this.left==null||b.left<this.left)this.left=b.left;if(this.bottom==null||b.bottom<this.bottom)this.bottom=
-b.bottom;if(this.right==null||b.right>this.right)this.right=b.right;if(this.top==null||b.top>this.top)this.top=b.top}}},containsLonLat:function(a,b){return this.contains(a.lon,a.lat,b)},containsPixel:function(a,b){return this.contains(a.x,a.y,b)},contains:function(a,b,c){if(c==null)c=true;if(a==null||b==null)return false;a=OpenLayers.Util.toFloat(a);b=OpenLayers.Util.toFloat(b);var d=false;return d=c?a>=this.left&&a<=this.right&&b>=this.bottom&&b<=this.top:a>this.left&&a<this.right&&b>this.bottom&&
-b<this.top},intersectsBounds:function(a,b){if(b==null)b=true;var c=false,d=this.left==a.right||this.right==a.left||this.top==a.bottom||this.bottom==a.top;if(b||!d){c=a.top>=this.bottom&&a.top<=this.top||this.top>a.bottom&&this.top<a.top;d=a.left>=this.left&&a.left<=this.right||this.left>=a.left&&this.left<=a.right;var e=a.right>=this.left&&a.right<=this.right||this.right>=a.left&&this.right<=a.right;c=(a.bottom>=this.bottom&&a.bottom<=this.top||this.bottom>=a.bottom&&this.bottom<=a.top||c)&&(d||e)}return c},
-containsBounds:function(a,b,c){if(b==null)b=false;if(c==null)c=true;var d=this.contains(a.left,a.bottom,c),e=this.contains(a.right,a.bottom,c),f=this.contains(a.left,a.top,c);a=this.contains(a.right,a.top,c);return b?d||e||f||a:d&&e&&f&&a},determineQuadrant:function(a){var b="",c=this.getCenterLonLat();b+=a.lat<c.lat?"b":"t";b+=a.lon<c.lon?"l":"r";return b},transform:function(a,b){this.centerLonLat=null;var c=OpenLayers.Projection.transform({x:this.left,y:this.bottom},a,b),d=OpenLayers.Projection.transform({x:this.right,
-y:this.bottom},a,b),e=OpenLayers.Projection.transform({x:this.left,y:this.top},a,b),f=OpenLayers.Projection.transform({x:this.right,y:this.top},a,b);this.left=Math.min(c.x,e.x);this.bottom=Math.min(c.y,d.y);this.right=Math.max(d.x,f.x);this.top=Math.max(e.y,f.y);return this},wrapDateLine:function(a,b){b=b||{};var c=b.leftTolerance||0,d=b.rightTolerance||0,e=this.clone();if(a){for(;e.left<a.left&&e.right-d<=a.left;)e=e.add(a.getWidth(),0);for(;e.left+c>=a.right&&e.right>a.right;)e=e.add(-a.getWidth(),
-0)}return e},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(a){a=a.split(",");return OpenLayers.Bounds.fromArray(a)};OpenLayers.Bounds.fromArray=function(a){return new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(a[2]),parseFloat(a[3]))};OpenLayers.Bounds.fromSize=function(a){return new OpenLayers.Bounds(0,a.h,a.w,0)};OpenLayers.Bounds.oppositeQuadrant=function(a){var b="";b+=a.charAt(0)=="t"?"b":"t";b+=a.charAt(1)=="l"?"r":"l";return b};
-OpenLayers.LonLat=OpenLayers.Class({lon:0,lat:0,initialize:function(a,b){this.lon=OpenLayers.Util.toFloat(a);this.lat=OpenLayers.Util.toFloat(b)},toString:function(){return"lon="+this.lon+",lat="+this.lat},toShortString:function(){return this.lon+", "+this.lat},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(c);return null}return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(a),
-this.lat+OpenLayers.Util.toFloat(b))},equals:function(a){var b=false;if(a!=null)b=this.lon==a.lon&&this.lat==a.lat||isNaN(this.lon)&&isNaN(this.lat)&&isNaN(a.lon)&&isNaN(a.lat);return b},transform:function(a,b){var c=OpenLayers.Projection.transform({x:this.lon,y:this.lat},a,b);this.lon=c.x;this.lat=c.y;return this},wrapDateLine:function(a){var b=this.clone();if(a){for(;b.lon<a.left;)b.lon+=a.getWidth();for(;b.lon>a.right;)b.lon-=a.getWidth()}return b},CLASS_NAME:"OpenLayers.LonLat"});
-OpenLayers.LonLat.fromString=function(a){a=a.split(",");return new OpenLayers.LonLat(a[0],a[1])};
-OpenLayers.Pixel=OpenLayers.Class({x:0,y:0,initialize:function(a,b){this.x=parseFloat(a);this.y=parseFloat(b)},toString:function(){return"x="+this.x+",y="+this.y},clone:function(){return new OpenLayers.Pixel(this.x,this.y)},equals:function(a){var b=false;if(a!=null)b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y);return b},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(c);return null}return new OpenLayers.Pixel(this.x+
-a,this.y+b)},offset:function(a){var b=this.clone();if(a)b=this.add(a.x,a.y);return b},CLASS_NAME:"OpenLayers.Pixel"});
-OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(a){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);this.eventListeners instanceof Object&&this.events.on(this.eventListeners);
-if(this.id==null)this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){if(this.events){this.eventListeners&&this.events.un(this.eventListeners);this.events.destroy();this.events=null}this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null}if(this.handlers){for(var a in this.handlers)this.handlers.hasOwnProperty(a)&&typeof this.handlers[a].destroy=="function"&&this.handlers[a].destroy();this.handlers=null}if(this.map){this.map.removeControl(this);
-this.map=null}},setMap:function(a){this.map=a;this.handler&&this.handler.setMap(a)},draw:function(a){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False}if(this.title!="")this.div.title=this.title}if(a!=null)this.position=a.clone();this.moveTo(this.position);return this.div},moveTo:function(a){if(a!=
-null&&this.div!=null){this.div.style.left=a.x+"px";this.div.style.top=a.y+"px"}},activate:function(){if(this.active)return false;this.handler&&this.handler.activate();this.active=true;this.map&&OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");this.events.triggerEvent("activate");return true},deactivate:function(){if(this.active){this.handler&&this.handler.deactivate();this.active=false;this.map&&OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,
-"")+"Active");this.events.triggerEvent("deactivate");return true}return false},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;
-OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){OpenLayers.Lang.code||OpenLayers.Lang.setCode();return OpenLayers.Lang.code},setCode:function(a){var b;a||(a=OpenLayers.BROWSER_NAME=="msie"?navigator.userLanguage:navigator.language);a=a.split("-");a[0]=a[0].toLowerCase();if(typeof OpenLayers.Lang[a[0]]=="object")b=a[0];if(a[1]){var c=a[0]+"-"+a[1].toUpperCase();if(typeof OpenLayers.Lang[c]=="object")b=c}if(!b){OpenLayers.Console.warn("Failed to find OpenLayers.Lang."+a.join("-")+" dictionary, falling back to default language");
-b=OpenLayers.Lang.defaultCode}OpenLayers.Lang.code=b},translate:function(a,b){var c=OpenLayers.Lang[OpenLayers.Lang.getCode()][a];c||(c=a);if(b)c=OpenLayers.String.format(c,b);return c}};OpenLayers.i18n=OpenLayers.Lang.translate;
-OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,keepInMap:true,anchor:null,initialize:function(a,b,c,d,e,f,g){OpenLayers.Popup.prototype.initialize.apply(this,[a,b,c,d,f,g]);this.anchor=e!=null?e:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)}},destroy:function(){this.relativePosition=this.anchor=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments)},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments)},
-moveTo:function(a){var b=this.relativePosition;this.relativePosition=this.calculateRelativePosition(a);a=this.calculateNewPx(a);OpenLayers.Popup.prototype.moveTo.apply(this,Array(a));this.relativePosition!=b&&this.updateRelativePosition()},setSize:function(){OpenLayers.Popup.prototype.setSize.apply(this,arguments);this.lonlat&&this.map&&this.moveTo(this.map.getLayerPxFromLonLat(this.lonlat))},calculateRelativePosition:function(a){a=this.map.getLonLatFromLayerPx(a);a=this.map.getExtent().determineQuadrant(a);
-return OpenLayers.Bounds.oppositeQuadrant(a)},updateRelativePosition:function(){},calculateNewPx:function(a){a=a.offset(this.anchor.offset);var b=this.size||this.contentSize,c=this.relativePosition.charAt(0)=="t";a.y+=c?-b.h:this.anchor.size.h;c=this.relativePosition.charAt(1)=="l";a.x+=c?-b.w:this.anchor.size.w;return a},CLASS_NAME:"OpenLayers.Popup.Anchored"});
-OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(a){this.compare=a?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.order=[];this.indices={};this.maxZIndex=0},insert:function(a){this.exists(a)&&this.remove(a);var b=a.id;this.determineZIndex(a);for(var c=-1,d=this.order.length,e;d-c>1;){e=parseInt((c+d)/2);if(this.compare(this,a,OpenLayers.Util.getElement(this.order[e]))>
-0)c=e;else d=e}this.order.splice(d,0,b);this.indices[b]=this.getZIndex(a);return this.getNextElement(d)},remove:function(a){a=a.id;var b=OpenLayers.Util.indexOf(this.order,a);if(b>=0){this.order.splice(b,1);delete this.indices[a];this.maxZIndex=this.order.length>0?this.indices[this.order[this.order.length-1]]:0}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0},exists:function(a){return this.indices[a.id]!=null},getZIndex:function(a){return a._style.graphicZIndex},determineZIndex:function(a){var b=
-a._style.graphicZIndex;if(b==null){b=this.maxZIndex;a._style.graphicZIndex=b}else if(b>this.maxZIndex)this.maxZIndex=b},getNextElement:function(a){a=a+1;if(a<this.order.length){var b=OpenLayers.Util.getElement(this.order[a]);if(b==undefined)b=this.getNextElement(a);return b}else return null},CLASS_NAME:"OpenLayers.ElementsIndexer"});
-OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(a,b,c){b=a.getZIndex(b);var d=0;if(c){a=a.getZIndex(c);d=b-a}return d},Z_ORDER_DRAWING_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);if(c&&a==0)a=1;return a},Z_ORDER_Y_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);if(c&&a===0){b=c._boundsBottom-b._boundsBottom;a=b===0?1:b}return a}};
-OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",initialize:function(a,b){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);
-this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(b&&(b.zIndexing||b.yOrdering))this.indexer=new OpenLayers.ElementsIndexer(b.yOrdering)},destroy:function(){this.clear();this.xmlns=this.root=this.rendererRoot=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments)},clear:function(){var a,b=this.vectorRoot;if(b)for(;a=b.firstChild;)b.removeChild(a);if(b=this.textRoot)for(;a=b.firstChild;)b.removeChild(a);this.indexer&&this.indexer.clear()},getNodeType:function(){},
-drawGeometry:function(a,b,c){var d=a.CLASS_NAME,e=true;if(d=="OpenLayers.Geometry.Collection"||d=="OpenLayers.Geometry.MultiPoint"||d=="OpenLayers.Geometry.MultiLineString"||d=="OpenLayers.Geometry.MultiPolygon"){d=0;for(var f=a.components.length;d<f;d++)e=this.drawGeometry(a.components[d],b,c)&&e;return e}d=e=false;if(b.display!="none"){if(b.backgroundGraphic)this.redrawBackgroundNode(a.id,a,b,c);else d=true;e=this.redrawNode(a.id,a,b,c)}if(e==false)if(b=document.getElementById(a.id)){if(b._style.backgroundGraphic)d=
-true;b.parentNode.removeChild(b)}if(d)(b=document.getElementById(a.id+this.BACKGROUND_ID_SUFFIX))&&b.parentNode.removeChild(b);return e},redrawNode:function(a,b,c,d){c=this.applyDefaultSymbolizer(c);a=this.nodeFactory(a,this.getNodeType(b,c));a._featureId=d;a._boundsBottom=b.getBounds().bottom;a._geometryClass=b.CLASS_NAME;a._style=c;b=this.drawGeometryNode(a,b,c);if(b===false)return false;a=b.node;if(this.indexer)(c=this.indexer.insert(a))?this.vectorRoot.insertBefore(a,c):this.vectorRoot.appendChild(a);
-else a.parentNode!==this.vectorRoot&&this.vectorRoot.appendChild(a);this.postDraw(a);return b.complete},redrawBackgroundNode:function(a,b,c){c=OpenLayers.Util.extend({},c);c.externalGraphic=c.backgroundGraphic;c.graphicXOffset=c.backgroundXOffset;c.graphicYOffset=c.backgroundYOffset;c.graphicZIndex=c.backgroundGraphicZIndex;c.graphicWidth=c.backgroundWidth||c.graphicWidth;c.graphicHeight=c.backgroundHeight||c.graphicHeight;c.backgroundGraphic=null;c.backgroundXOffset=null;c.backgroundYOffset=null;
-c.backgroundGraphicZIndex=null;return this.redrawNode(a+this.BACKGROUND_ID_SUFFIX,b,c,null)},drawGeometryNode:function(a,b,c){c=c||a._style;var d={isFilled:c.fill===undefined?true:c.fill,isStroked:c.stroke===undefined?!!c.strokeWidth:c.stroke},e;switch(b.CLASS_NAME){case "OpenLayers.Geometry.Point":if(c.graphic===false){d.isFilled=false;d.isStroked=false}e=this.drawPoint(a,b);break;case "OpenLayers.Geometry.LineString":d.isFilled=false;e=this.drawLineString(a,b);break;case "OpenLayers.Geometry.LinearRing":e=
-this.drawLinearRing(a,b);break;case "OpenLayers.Geometry.Polygon":e=this.drawPolygon(a,b);break;case "OpenLayers.Geometry.Surface":e=this.drawSurface(a,b);break;case "OpenLayers.Geometry.Rectangle":e=this.drawRectangle(a,b)}a._options=d;return e!=false?{node:this.setStyle(a,c,d,b),complete:e}:false},postDraw:function(){},drawPoint:function(){},drawLineString:function(){},drawLinearRing:function(){},drawPolygon:function(){},drawRectangle:function(){},drawCircle:function(){},drawSurface:function(){},
-removeText:function(a){(a=document.getElementById(a+this.LABEL_ID_SUFFIX))&&this.textRoot.removeChild(a)},getFeatureIdFromEvent:function(a){var b=a.target,c=b&&b.correspondingUseElement;return(c?c:b||a.srcElement)._featureId},eraseGeometry:function(a,b){if(a.CLASS_NAME=="OpenLayers.Geometry.MultiPoint"||a.CLASS_NAME=="OpenLayers.Geometry.MultiLineString"||a.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon"||a.CLASS_NAME=="OpenLayers.Geometry.Collection")for(var c=0,d=a.components.length;c<d;c++)this.eraseGeometry(a.components[c],
-b);else if((c=OpenLayers.Util.getElement(a.id))&&c.parentNode){if(c.geometry){c.geometry.destroy();c.geometry=null}c.parentNode.removeChild(c);this.indexer&&this.indexer.remove(c);if(c._style.backgroundGraphic)(c=OpenLayers.Util.getElement(a.id+this.BACKGROUND_ID_SUFFIX))&&c.parentNode&&c.parentNode.removeChild(c)}},nodeFactory:function(a,b){var c=OpenLayers.Util.getElement(a);if(c){if(!this.nodeTypeCompare(c,b)){c.parentNode.removeChild(c);c=this.nodeFactory(a,b)}}else c=this.createNode(b,a);return c},
-nodeTypeCompare:function(){},createNode:function(){},moveRoot:function(a){var b=this.root;if(a.root.parentNode==this.rendererRoot)b=a.root;b.parentNode.removeChild(b);a.rendererRoot.appendChild(b)},getRenderLayerId:function(){return this.root.parentNode.parentNode.id},isComplexSymbol:function(a){return a!="circle"&&!!a},CLASS_NAME:"OpenLayers.Renderer.Elements"});
-OpenLayers.Renderer.symbol={star:[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],cross:[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],x:[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],square:[0,0,0,1,1,1,1,0,0,0],triangle:[0,10,10,10,5,0,0,10]};
-OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(a){this.easing=a?a:OpenLayers.Easing.Expo.easeOut},start:function(a,b,c,d){this.playing=true;this.begin=a;this.finish=b;this.duration=c;this.callbacks=d.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null}this.callbacks&&this.callbacks.start&&this.callbacks.start.call(this,this.begin);this.interval=
-window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL)},stop:function(){if(this.playing){this.callbacks&&this.callbacks.done&&this.callbacks.done.call(this,this.finish);window.clearInterval(this.interval);this.interval=null;this.playing=false}},play:function(){var a={},b;for(b in this.begin){var c=this.begin[b],d=this.finish[b];if(c==null||d==null||isNaN(c)||isNaN(d))OpenLayers.Console.error("invalid value for Tween");a[b]=this.easing.apply(this,[this.time,c,d-c,this.duration])}this.time++;
-this.callbacks&&this.callbacks.eachStep&&this.callbacks.eachStep.call(this,a);this.time>this.duration&&this.stop()},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(a,b,c,d){return c*a/d+b},easeOut:function(a,b,c,d){return c*a/d+b},easeInOut:function(a,b,c,d){return c*a/d+b},CLASS_NAME:"OpenLayers.Easing.Linear"};
-OpenLayers.Easing.Expo={easeIn:function(a,b,c,d){return a==0?b:c*Math.pow(2,10*(a/d-1))+b},easeOut:function(a,b,c,d){return a==d?b+c:c*(-Math.pow(2,-10*a/d)+1)+b},easeInOut:function(a,b,c,d){if(a==0)return b;if(a==d)return b+c;if((a/=d/2)<1)return c/2*Math.pow(2,10*(a-1))+b;return c/2*(-Math.pow(2,-10*--a)+2)+b},CLASS_NAME:"OpenLayers.Easing.Expo"};
-OpenLayers.Easing.Quad={easeIn:function(a,b,c,d){return c*(a/=d)*a+b},easeOut:function(a,b,c,d){return-c*(a/=d)*(a-2)+b},easeInOut:function(a,b,c,d){if((a/=d/2)<1)return c/2*a*a+b;return-c/2*(--a*(a-2)-1)+b},CLASS_NAME:"OpenLayers.Easing.Quad"};
-OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.map.events.un({removelayer:this.updateAttribution,addlayer:this.updateAttribution,changelayer:this.updateAttribution,changebaselayer:this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({changebaselayer:this.updateAttribution,
-changelayer:this.updateAttribution,addlayer:this.updateAttribution,removelayer:this.updateAttribution,scope:this});this.updateAttribution();return this.div},updateAttribution:function(){var a=[];if(this.map&&this.map.layers){for(var b=0,c=this.map.layers.length;b<c;b++){var d=this.map.layers[b];d.attribution&&d.getVisibility()&&OpenLayers.Util.indexOf(a,d.attribution)===-1&&a.push(d.attribution)}this.div.innerHTML=a.join(this.separator)}},CLASS_NAME:"OpenLayers.Control.Attribution"});
-OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(a){return a.target||a.srcElement},isLeftClick:function(a){return a.which&&a.which==1||a.button&&a.button==1},isRightClick:function(a){return a.which&&a.which==3||a.button&&a.button==2},stop:function(a,b){if(!b)if(a.preventDefault)a.preventDefault();else a.returnValue=false;if(a.stopPropagation)a.stopPropagation();else a.cancelBubble=true},
-findElement:function(a,b){for(var c=OpenLayers.Event.element(a);c.parentNode&&(!c.tagName||c.tagName.toUpperCase()!=b.toUpperCase());)c=c.parentNode;return c},observe:function(a,b,c,d){a=OpenLayers.Util.getElement(a);d=d||false;if(b=="keypress"&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.attachEvent))b="keydown";if(!this.observers)this.observers={};if(!a._eventCacheID){var e="eventCacheID_";if(a.id)e=a.id+"_"+e;a._eventCacheID=OpenLayers.Util.createUniqueID(e)}e=a._eventCacheID;this.observers[e]||
-(this.observers[e]=[]);this.observers[e].push({element:a,name:b,observer:c,useCapture:d});if(a.addEventListener)a.addEventListener(b,c,d);else a.attachEvent&&a.attachEvent("on"+b,c)},stopObservingElement:function(a){a=OpenLayers.Util.getElement(a)._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[a])},_removeElementObservers:function(a){if(a)for(var b=a.length-1;b>=0;b--){var c=a[b];OpenLayers.Event.stopObserving.apply(this,[c.element,c.name,c.observer,c.useCapture])}},stopObserving:function(a,
-b,c,d){d=d||false;a=OpenLayers.Util.getElement(a);var e=a._eventCacheID;if(b=="keypress")if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.detachEvent)b="keydown";var f=false,g=OpenLayers.Event.observers[e];if(g)for(var h=0;!f&&h<g.length;){var i=g[h];if(i.name==b&&i.observer==c&&i.useCapture==d){g.splice(h,1);g.length==0&&delete OpenLayers.Event.observers[e];f=true;break}h++}if(f)if(a.removeEventListener)a.removeEventListener(b,c,d);else a&&a.detachEvent&&a.detachEvent("on"+b,c);return f},
-unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var a in OpenLayers.Event.observers)OpenLayers.Event._removeElementObservers.apply(this,[OpenLayers.Event.observers[a]]);OpenLayers.Event.observers=false}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,"unload",OpenLayers.Event.unloadCache,false);if(window.Event)OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);else Event=OpenLayers.Event;
-OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(a,b,c,d,e){OpenLayers.Util.extend(this,e);this.object=a;this.fallThrough=d;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,
-this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(c!=null){a=0;for(d=c.length;a<d;a++)this.addEventType(c[a])}b!=null&&this.attachToElement(b)},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);this.element.hasScrollEvent&&OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener)}this.eventHandler=this.fallThrough=this.eventTypes=this.object=this.listeners=this.element=null},addEventType:function(a){if(!this.listeners[a]){this.eventTypes.push(a);
-this.listeners[a]=[]}},attachToElement:function(a){this.element&&OpenLayers.Event.stopObservingElement(this.element);this.element=a;for(var b=0,c=this.BROWSER_EVENTS.length;b<c;b++){var d=this.BROWSER_EVENTS[b];this.addEventType(d);OpenLayers.Event.observe(a,d,this.eventHandler)}OpenLayers.Event.observe(a,"dragstart",OpenLayers.Event.stop)},on:function(a){for(var b in a)b!="scope"&&this.register(b,a.scope,a[b])},register:function(a,b,c){if(c!=null&&OpenLayers.Util.indexOf(this.eventTypes,a)!=-1){if(b==
-null)b=this.object;this.listeners[a].push({obj:b,func:c})}},registerPriority:function(a,b,c){if(c!=null){if(b==null)b=this.object;a=this.listeners[a];a!=null&&a.unshift({obj:b,func:c})}},un:function(a){for(var b in a)b!="scope"&&this.unregister(b,a.scope,a[b])},unregister:function(a,b,c){if(b==null)b=this.object;a=this.listeners[a];if(a!=null)for(var d=0,e=a.length;d<e;d++)if(a[d].obj==b&&a[d].func==c){a.splice(d,1);break}},remove:function(a){if(this.listeners[a]!=null)this.listeners[a]=[]},triggerEvent:function(a,
-b){var c=this.listeners[a];if(!(!c||c.length==0)){if(b==null)b={};b.object=this.object;b.element=this.element;if(!b.type)b.type=a;c=c.slice();for(var d,e=0,f=c.length;e<f;e++){d=c[e];d=d.func.apply(d.obj,[b]);if(d!=undefined&&d==false)break}this.fallThrough||OpenLayers.Event.stop(b,true);return d}},handleBrowserEvent:function(a){var b=a.type,c=this.listeners[b];if(!(!c||c.length==0)){if(this.includeXY)a.xy=this.getMousePosition(a);this.triggerEvent(b,a)}},clearMouseCache:function(){this.element.scrolls=
-null;this.element.lefttop=null;this.element.offsets=null},getMousePosition:function(a){if(this.includeXY){if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true}}else this.clearMouseCache();if(!this.element.scrolls){var b=OpenLayers.Util.getViewportElement();this.element.scrolls=[b.scrollLeft,b.scrollTop]}if(!this.element.lefttop)this.element.lefttop=[document.documentElement.clientLeft||0,document.documentElement.clientTop||
-0];if(!this.element.offsets)this.element.offsets=OpenLayers.Util.pagePosition(this.element);return new OpenLayers.Pixel(a.clientX+this.element.scrolls[0]-this.element.offsets[0]-this.element.lefttop[0],a.clientY+this.element.scrolls[1]-this.element.offsets[1]-this.element.lefttop[1])},CLASS_NAME:"OpenLayers.Events"});
-OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:false,initialize:function(a){OpenLayers.Util.extend(this,a);this.options=a},destroy:function(){},read:function(){OpenLayers.Console.userError(OpenLayers.i18n("readNotImplemented"))},write:function(){OpenLayers.Console.userError(OpenLayers.i18n("writeNotImplemented"))},CLASS_NAME:"OpenLayers.Format"});
-OpenLayers.Lang.en={unhandledRequest:"Unhandled request return ${statusText}",permalink:"Permalink",overlays:"Overlays",baseLayer:"Base Layer",sameProjection:"The overview map only works when it is in the same projection as the main map",readNotImplemented:"Read not implemented.",writeNotImplemented:"Write not implemented.",noFID:"Can't update a feature for which there is no FID.",errorLoadingGML:"Error in loading GML file ${url}",browserNotSupported:"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",
-componentShouldBe:"addFeatures : component should be an ${geomType}",getFeatureError:"getFeatureFromEvent called on layer with no renderer. This usually means you destroyed a layer, but not some handler which is associated with it.",minZoomLevelError:"The minZoomLevel property is only intended for use with the FixedZoomLevels-descendent layers. That this wfs layer checks for minZoomLevel is a relic of thepast. We cannot, however, remove it without possibly breaking OL based applications that may depend on it. Therefore we are deprecating it -- the minZoomLevel check below will be removed at 3.0. Please instead use min/max resolution setting as described here: http://trac.openlayers.org/wiki/SettingZoomLevels",
-commitSuccess:"WFS Transaction: SUCCESS ${response}",commitFailed:"WFS Transaction: FAILED ${response}",googleWarning:"The Google Layer was unable to load correctly.<br><br>To get rid of this message, select a new BaseLayer in the layer switcher in the upper-right corner.<br><br>Most likely, this is because the Google Maps library script was either not included, or does not contain the correct API key for your site.<br><br>Developers: For help getting this working correctly, <a href='http://trac.openlayers.org/wiki/Google' target='_blank'>click here</a>",
-getLayerWarning:"The ${layerType} Layer was unable to load correctly.<br><br>To get rid of this message, select a new BaseLayer in the layer switcher in the upper-right corner.<br><br>Most likely, this is because the ${layerLib} library script was not correctly included.<br><br>Developers: For help getting this working correctly, <a href='http://trac.openlayers.org/wiki/${layerLib}' target='_blank'>click here</a>",scale:"Scale = 1 : ${scaleDenom}",W:"W",E:"E",N:"N",S:"S",graticule:"Graticule",layerAlreadyAdded:"You tried to add the layer: ${layerName} to the map, but it has already been added",
-reprojectDeprecated:"You are using the 'reproject' option on the ${layerName} layer. This option is deprecated: its use was designed to support displaying data over commercial basemaps, but that functionality should now be achieved by using Spherical Mercator support. More information is available from http://trac.openlayers.org/wiki/SphericalMercator.",methodDeprecated:"This method has been deprecated and will be removed in 3.0. Please use ${newMethod} instead.",boundsAddError:"You must pass both x and y values to the add function.",
-lonlatAddError:"You must pass both lon and lat values to the add function.",pixelAddError:"You must pass both x and y values to the add function.",unsupportedGeometryType:"Unsupported geometry type: ${geomType}",pagePositionFailed:"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",filterEvaluateNotImplemented:"evaluate is not implemented for this filter type.",end:""};
-OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments)},draw:function(){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div},updateRelativePosition:function(){this.setRicoCorners()},
-setSize:function(){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners()},setBackgroundColor:function(a){if(a!=undefined)this.backgroundColor=a;if(this.div!=null)if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor)}},setOpacity:function(a){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,a);this.div!=null&&this.groupDiv!=null&&OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,
-this.opacity)},setBorder:function(){this.border=0},setRicoCorners:function(){var a={corners:this.getCornersToRound(this.relativePosition),color:this.backgroundColor,bgColor:"transparent",blend:false};if(this.rounded){OpenLayers.Rico.Corner.reRound(this.groupDiv,a);this.setBackgroundColor();this.setOpacity()}else{OpenLayers.Rico.Corner.round(this.div,a);this.rounded=true}},getCornersToRound:function(){var a=["tl","tr","bl","br"],b=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(a,
-b);return a.join(" ")},CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;
-OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.projCode=a;if(window.Proj4js)this.proj=new Proj4js.Proj(a)},getCode:function(){return this.proj?this.proj.srsCode:this.projCode},getUnits:function(){return this.proj?this.proj.units:null},toString:function(){return this.getCode()},equals:function(a){var b=false;if(a)if(window.Proj4js&&this.proj.defData&&a.proj.defData)b=this.proj.defData.replace(this.titleRegEx,
-"")==a.proj.defData.replace(this.titleRegEx,"");else if(a.getCode){b=this.getCode();a=a.getCode();b=b==a||!!OpenLayers.Projection.transforms[b]&&OpenLayers.Projection.transforms[b][a]===OpenLayers.Projection.nullTransform}return b},destroy:function(){delete this.proj;delete this.projCode},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};
-OpenLayers.Projection.addTransform=function(a,b,c){OpenLayers.Projection.transforms[a]||(OpenLayers.Projection.transforms[a]={});OpenLayers.Projection.transforms[a][b]=c};OpenLayers.Projection.transform=function(a,b,c){if(b.proj&&c.proj)a=Proj4js.transform(b.proj,c.proj,a);else b&&c&&OpenLayers.Projection.transforms[b.getCode()]&&OpenLayers.Projection.transforms[b.getCode()][c.getCode()]&&OpenLayers.Projection.transforms[b.getCode()][c.getCode()](a);return a};OpenLayers.Projection.nullTransform=function(a){return a};
-OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15E3,translationParameters:null,symbolMetrics:null,supportUse:null,initialize:function(){if(this.supported()){OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.supportUse=navigator.userAgent.toLowerCase().indexOf("applewebkit/5")==-1;this.symbolMetrics={}}},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,
-arguments)},supported:function(){return document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#SVG","1.1")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure","1.1"))},inValidRange:function(a,b,c){a=a+(c?0:this.translationParameters.x);b=b+(c?0:this.translationParameters.y);return a>=-this.MAX_PIXEL&&a<=this.MAX_PIXEL&&b>=-this.MAX_PIXEL&&b<=this.MAX_PIXEL},setExtent:function(a,
-b){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var c=this.getResolution(),d=-a.left/c;c=a.top/c;if(b){this.left=d;this.top=c;this.rendererRoot.setAttributeNS(null,"viewBox","0 0 "+this.size.w+" "+this.size.h);this.translate(0,0);return true}else{(d=this.translate(d-this.left,c-this.top))||this.setExtent(a,true);return d}},translate:function(a,b){if(this.inValidRange(a,b,true)){var c="";if(a||b)c="translate("+a+","+b+")";this.root.setAttributeNS(null,"transform",c);this.translationParameters=
-{x:a,y:b};return true}else return false},setSize:function(){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h)},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"image":this.isComplexSymbol(b.graphicName)?this.supportUse===false?"svg":"use":"circle";break;case "OpenLayers.Geometry.Rectangle":c="rect";break;case "OpenLayers.Geometry.LineString":c=
-"polyline";break;case "OpenLayers.Geometry.LinearRing":c="polygon";break;case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c="path"}return c},setStyle:function(a,b,c){b=b||a._style;c=c||a._options;var d=parseFloat(a.getAttributeNS(null,"r")),e=1,f;if(a._geometryClass=="OpenLayers.Geometry.Point"&&d){a.style.visibility="";if(b.graphic===false)a.style.visibility="hidden";else if(b.externalGraphic){f=this.getPosition(a);b.graphicTitle&&a.setAttributeNS(null,
-"title",b.graphicTitle);b.graphicWidth&&b.graphicHeight&&a.setAttributeNS(null,"preserveAspectRatio","none");d=b.graphicWidth||b.graphicHeight;var g=b.graphicHeight||b.graphicWidth;d=d?d:b.pointRadius*2;g=g?g:b.pointRadius*2;var h=b.graphicYOffset!=undefined?b.graphicYOffset:-(0.5*g),i=b.graphicOpacity||b.fillOpacity;a.setAttributeNS(null,"x",(f.x+(b.graphicXOffset!=undefined?b.graphicXOffset:-(0.5*d))).toFixed());a.setAttributeNS(null,"y",(f.y+h).toFixed());a.setAttributeNS(null,"width",d);a.setAttributeNS(null,
-"height",g);a.setAttributeNS(this.xlinkns,"href",b.externalGraphic);a.setAttributeNS(null,"style","opacity: "+i)}else if(this.isComplexSymbol(b.graphicName)){d=b.pointRadius*3;g=d*2;var j=this.importSymbol(b.graphicName);f=this.getPosition(a);e=this.symbolMetrics[j][0]*3/g;h=a.parentNode;i=a.nextSibling;h&&h.removeChild(a);if(this.supportUse===false){var k=document.getElementById(j);a.firstChild&&a.removeChild(a.firstChild);a.appendChild(k.firstChild.cloneNode(true));a.setAttributeNS(null,"viewBox",
-k.getAttributeNS(null,"viewBox"))}else a.setAttributeNS(this.xlinkns,"href","#"+j);a.setAttributeNS(null,"width",g);a.setAttributeNS(null,"height",g);a.setAttributeNS(null,"x",f.x-d);a.setAttributeNS(null,"y",f.y-d);if(i)h.insertBefore(a,i);else h&&h.appendChild(a)}else a.setAttributeNS(null,"r",b.pointRadius);d=b.rotation;if((d!==undefined||a._rotation!==undefined)&&f){a._rotation=d;d|=0;if(a.nodeName!=="svg")a.setAttributeNS(null,"transform","rotate("+d+" "+f.x+" "+f.y+")");else{f=this.symbolMetrics[j];
-a.firstChild.setAttributeNS(null,"transform","rotate("+b.rotation+" "+f[1]+" "+f[2]+")")}}}if(c.isFilled){a.setAttributeNS(null,"fill",b.fillColor);a.setAttributeNS(null,"fill-opacity",b.fillOpacity)}else a.setAttributeNS(null,"fill","none");if(c.isStroked){a.setAttributeNS(null,"stroke",b.strokeColor);a.setAttributeNS(null,"stroke-opacity",b.strokeOpacity);a.setAttributeNS(null,"stroke-width",b.strokeWidth*e);a.setAttributeNS(null,"stroke-linecap",b.strokeLinecap||"round");a.setAttributeNS(null,
-"stroke-linejoin","round");b.strokeDashstyle&&a.setAttributeNS(null,"stroke-dasharray",this.dashStyle(b,e))}else a.setAttributeNS(null,"stroke","none");b.pointerEvents&&a.setAttributeNS(null,"pointer-events",b.pointerEvents);b.cursor!=null&&a.setAttributeNS(null,"cursor",b.cursor);return a},dashStyle:function(a,b){var c=a.strokeWidth*b,d=a.strokeDashstyle;switch(d){case "solid":return"none";case "dot":return[1,4*c].join();case "dash":return[4*c,4*c].join();case "dashdot":return[4*c,4*c,1,4*c].join();
-case "longdash":return[8*c,4*c].join();case "longdashdot":return[8*c,4*c,1,4*c].join();default:return OpenLayers.String.trim(d).replace(/\s+/g,",")}},createNode:function(a,b){var c=document.createElementNS(this.xmlns,a);b&&c.setAttributeNS(null,"id",b);return c},nodeTypeCompare:function(a,b){return b==a.nodeName},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg")},createRoot:function(a){return this.nodeFactory(this.container.id+a,"g")},createDefs:function(){var a=
-this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(a);return a},drawPoint:function(a,b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){var d=this.getResolution(),e=b.x/d+this.left;b=this.top-b.y/d;if(this.inValidRange(e,b)){a.setAttributeNS(null,"cx",e);a.setAttributeNS(null,"cy",b);a.setAttributeNS(null,"r",c);return a}else return false},drawLineString:function(a,b){var c=this.getComponentsString(b.components);if(c.path){a.setAttributeNS(null,"points",c.path);
-return c.complete?a:null}else return false},drawLinearRing:function(a,b){var c=this.getComponentsString(b.components);if(c.path){a.setAttributeNS(null,"points",c.path);return c.complete?a:null}else return false},drawPolygon:function(a,b){for(var c="",d=true,e=true,f,g,h=0,i=b.components.length;h<i;h++){c+=" M";f=this.getComponentsString(b.components[h].components," ");if(g=f.path){c+=" "+g;e=f.complete&&e}else d=false}c+=" z";if(d){a.setAttributeNS(null,"d",c);a.setAttributeNS(null,"fill-rule","evenodd");
-return e?a:null}else return false},drawRectangle:function(a,b){var c=this.getResolution(),d=b.x/c+this.left,e=this.top-b.y/c;if(this.inValidRange(d,e)){a.setAttributeNS(null,"x",d);a.setAttributeNS(null,"y",e);a.setAttributeNS(null,"width",b.width/c);a.setAttributeNS(null,"height",b.height/c);return a}else return false},drawSurface:function(a,b){for(var c=null,d=true,e=0,f=b.components.length;e<f;e++)if(e%3==0&&e/3==0){var g=this.getShortString(b.components[e]);g||(d=false);c="M "+g}else if(e%3==
-1){(g=this.getShortString(b.components[e]))||(d=false);c+=" C "+g}else{(g=this.getShortString(b.components[e]))||(d=false);c+=" "+g}c+=" Z";if(d){a.setAttributeNS(null,"d",c);return a}else return false},drawText:function(a,b,c){var d=this.getResolution(),e=c.x/d+this.left,f=c.y/d-this.top;d=this.nodeFactory(a+this.LABEL_ID_SUFFIX,"text");var g=this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_tspan","tspan");d.setAttributeNS(null,"x",e);d.setAttributeNS(null,"y",-f);b.fontColor&&d.setAttributeNS(null,"fill",
-b.fontColor);b.fontOpacity&&d.setAttributeNS(null,"opacity",b.fontOpacity);b.fontFamily&&d.setAttributeNS(null,"font-family",b.fontFamily);b.fontSize&&d.setAttributeNS(null,"font-size",b.fontSize);b.fontWeight&&d.setAttributeNS(null,"font-weight",b.fontWeight);if(b.labelSelect===true){d.setAttributeNS(null,"pointer-events","visible");d._featureId=a;g._featureId=a;g._geometry=c;g._geometryClass=c.CLASS_NAME}else d.setAttributeNS(null,"pointer-events","none");a=b.labelAlign||"cm";d.setAttributeNS(null,
-"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[a[0]]||"middle");OpenLayers.IS_GECKO===true?d.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG.LABEL_ALIGN[a[1]]||"central"):g.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[a[1]]||"-35%");g.textContent=b.label;if(!d.parentNode){d.appendChild(g);this.textRoot.appendChild(d)}},getComponentsString:function(a,b){for(var c=[],d=true,e=a.length,f=[],g,h=0;h<e;h++){g=a[h];c.push(g);if(g=this.getShortString(g))f.push(g);
-else{h>0&&this.getShortString(a[h-1])&&f.push(this.clipLine(a[h],a[h-1]));h<e-1&&this.getShortString(a[h+1])&&f.push(this.clipLine(a[h],a[h+1]));d=false}}return{path:f.join(b||","),complete:d}},clipLine:function(a,b){if(b.equals(a))return"";var c=this.getResolution(),d=this.MAX_PIXEL-this.translationParameters.x,e=this.MAX_PIXEL-this.translationParameters.y,f=b.x/c+this.left,g=this.top-b.y/c,h=a.x/c+this.left;c=this.top-a.y/c;var i;if(h<-d||h>d){i=(c-g)/(h-f);h=h<0?-d:d;c=g+(h-f)*i}if(c<-e||c>e){i=
-(h-f)/(c-g);c=c<0?-e:e;h=f+(c-g)*i}return h+","+c},getShortString:function(a){var b=this.getResolution(),c=a.x/b+this.left;a=this.top-a.y/b;return this.inValidRange(c,a)?c+","+a:false},getPosition:function(a){return{x:parseFloat(a.getAttributeNS(null,"cx")),y:parseFloat(a.getAttributeNS(null,"cy"))}},importSymbol:function(a){if(!this.defs)this.defs=this.createDefs();var b=this.container.id+"-"+a;if(document.getElementById(b)!=null)return b;var c=OpenLayers.Renderer.symbol[a];if(!c)throw Error(a+" is not a valid symbol name");
-a=this.nodeFactory(b,"symbol");var d=this.nodeFactory(null,"polygon");a.appendChild(d);for(var e=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0),f=[],g,h,i=0;i<c.length;i+=2){g=c[i];h=c[i+1];e.left=Math.min(e.left,g);e.bottom=Math.min(e.bottom,h);e.right=Math.max(e.right,g);e.top=Math.max(e.top,h);f.push(g,",",h)}d.setAttributeNS(null,"points",f.join(" "));c=e.getWidth();d=e.getHeight();a.setAttributeNS(null,"viewBox",[e.left-c,e.bottom-d,c*3,d*3].join(" "));this.symbolMetrics[b]=[Math.max(c,
-d),e.getCenterLonLat().lon,e.getCenterLonLat().lat];this.defs.appendChild(a);return a.id},getFeatureIdFromEvent:function(a){var b=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(this.supportUse===false&&!b){b=a.target;b=b.parentNode&&b!=this.rendererRoot&&b.parentNode._featureId}return b},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={l:"start",r:"end",b:"bottom",t:"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={t:"-70%",b:"0"};
-OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(){if(this.supported()){if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);for(var a=document.createStyleSheet(),b=["shape","rect","oval","fill","stroke","imagedata","group","textbox"],c=0,d=b.length;c<d;c++)a.addRule("olv\\:"+b[c],"behavior: url(#default#VML); position: absolute; display: inline-block;")}OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
-arguments)}},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments)},supported:function(){return!!document.namespaces},setExtent:function(a,b){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var c=this.getResolution(),d=a.left/c|0;c=a.top/c-this.size.h|0;if(b||!this.offset){this.offset={x:d,y:c};c=d=0}else{d-=this.offset.x;c-=this.offset.y}this.root.coordorigin=d+" "+c;d=[this.root,this.vectorRoot,this.textRoot];for(var e=0,f=d.length;e<f;++e){c=
-d[e];c.coordsize=this.size.w+" "+this.size.h}this.root.style.flip="y";return true},setSize:function(){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);for(var a=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot],b=this.size.w+"px",c=this.size.h+"px",d,e=0,f=a.length;e<f;++e){d=a[e];d.style.width=b;d.style.height=c}},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"olv:rect":this.isComplexSymbol(b.graphicName)?"olv:shape":
-"olv:oval";break;case "OpenLayers.Geometry.Rectangle":c="olv:rect";break;case "OpenLayers.Geometry.LineString":case "OpenLayers.Geometry.LinearRing":case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":case "OpenLayers.Geometry.Surface":c="olv:shape"}return c},setStyle:function(a,b,c,d){b=b||a._style;c=c||a._options;var e=b.fillColor;if(a._geometryClass==="OpenLayers.Geometry.Point")if(b.externalGraphic){if(b.graphicTitle)a.title=b.graphicTitle;e=b.graphicWidth||b.graphicHeight;var f=
-b.graphicHeight||b.graphicWidth;e=e?e:b.pointRadius*2;f=f?f:b.pointRadius*2;var g=this.getResolution(),h=b.graphicXOffset!=undefined?b.graphicXOffset:-(0.5*e),i=b.graphicYOffset!=undefined?b.graphicYOffset:-(0.5*f);a.style.left=(d.x/g-this.offset.x+h|0)+"px";a.style.top=(d.y/g-this.offset.y-(i+f)|0)+"px";a.style.width=e+"px";a.style.height=f+"px";a.style.flip="y";e="none";c.isStroked=false}else if(this.isComplexSymbol(b.graphicName)){f=this.importSymbol(b.graphicName);a.path=f.path;a.coordorigin=
-f.left+","+f.bottom;f=f.size;a.coordsize=f+","+f;this.drawCircle(a,d,b.pointRadius);a.style.flip="y"}else this.drawCircle(a,d,b.pointRadius);if(c.isFilled)a.fillcolor=e;else a.filled="false";d=a.getElementsByTagName("fill");d=d.length==0?null:d[0];if(c.isFilled){d||(d=this.createNode("olv:fill",a.id+"_fill"));d.opacity=b.fillOpacity;if(a._geometryClass==="OpenLayers.Geometry.Point"&&b.externalGraphic){if(b.graphicOpacity)d.opacity=b.graphicOpacity;d.src=b.externalGraphic;d.type="frame";if(!(b.graphicWidth&&
-b.graphicHeight))d.aspect="atmost"}d.parentNode!=a&&a.appendChild(d)}else d&&a.removeChild(d);e=b.rotation;if(e!==undefined||a._rotation!==undefined){a._rotation=e;if(b.externalGraphic){this.graphicRotate(a,h,i,b);d.opacity=0}else if(a._geometryClass==="OpenLayers.Geometry.Point")a.style.rotation=e||0}h=a.getElementsByTagName("stroke");h=h.length==0?null:h[0];if(c.isStroked){if(!h){h=this.createNode("olv:stroke",a.id+"_stroke");a.appendChild(h)}h.on=true;h.color=b.strokeColor;h.weight=b.strokeWidth+
-"px";h.opacity=b.strokeOpacity;h.endcap=b.strokeLinecap=="butt"?"flat":b.strokeLinecap||"round";if(b.strokeDashstyle)h.dashstyle=this.dashStyle(b)}else{a.stroked=false;if(h)h.on=false}if(b.cursor!="inherit"&&b.cursor!=null)a.style.cursor=b.cursor;return a},graphicRotate:function(a,b,c,d){d=d||a._style;var e=d.rotation||0,f,g;if(d.graphicWidth&&d.graphicHeight){g=Math.max(d.graphicWidth,d.graphicHeight);f=d.graphicWidth/d.graphicHeight;var h=Math.round(d.graphicWidth||g*f),i=Math.round(d.graphicHeight||
-g);a.style.width=h+"px";a.style.height=i+"px";var j=document.getElementById(a.id+"_image");if(!j){j=this.createNode("olv:imagedata",a.id+"_image");a.appendChild(j)}j.style.width=h+"px";j.style.height=i+"px";j.src=d.externalGraphic;j.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='', sizingMethod='scale')";j=e*Math.PI/180;e=Math.sin(j);j=Math.cos(j);e="progid:DXImageTransform.Microsoft.Matrix(M11="+j+",M12="+-e+",M21="+e+",M22="+j+",SizingMethod='auto expand')\n";if((j=d.graphicOpacity||
-d.fillOpacity)&&j!=1)e+="progid:DXImageTransform.Microsoft.BasicImage(opacity="+j+")\n";a.style.filter=e;e=new OpenLayers.Geometry.Point(-b,-c);h=(new OpenLayers.Bounds(0,0,h,i)).toGeometry();h.rotate(d.rotation,e);h=h.getBounds();a.style.left=Math.round(parseInt(a.style.left)+h.left)+"px";a.style.top=Math.round(parseInt(a.style.top)-h.bottom)+"px"}else{var k=new Image;k.onreadystatechange=OpenLayers.Function.bind(function(){if(k.readyState=="complete"||k.readyState=="interactive"){f=k.width/k.height;
-g=Math.max(d.pointRadius*2,d.graphicWidth||0,d.graphicHeight||0);b*=f;d.graphicWidth=g*f;d.graphicHeight=g;this.graphicRotate(a,b,c,d)}},this);k.src=d.externalGraphic}},postDraw:function(a){a.style.visibility="visible";var b=a._style.fillColor,c=a._style.strokeColor;if(b=="none"&&a.fillcolor!=b)a.fillcolor=b;if(c=="none"&&a.strokecolor!=c)a.strokecolor=c},setNodeDimension:function(a,b){var c=b.getBounds();if(c){var d=this.getResolution();c=new OpenLayers.Bounds(c.left/d-this.offset.x|0,c.bottom/d-
-this.offset.y|0,c.right/d-this.offset.x|0,c.top/d-this.offset.y|0);a.style.left=c.left+"px";a.style.top=c.top+"px";a.style.width=c.getWidth()+"px";a.style.height=c.getHeight()+"px";a.coordorigin=c.left+" "+c.top;a.coordsize=c.getWidth()+" "+c.getHeight()}},dashStyle:function(a){a=a.strokeDashstyle;switch(a){case "solid":case "dot":case "dash":case "dashdot":case "longdash":case "longdashdot":return a;default:a=a.split(/[ ,]/);if(a.length==2){if(1*a[0]>=2*a[1])return"longdash";return a[0]==1||a[1]==
-1?"dot":"dash"}else if(a.length==4)return 1*a[0]>=2*a[1]?"longdashdot":"dashdot";return"solid"}},createNode:function(a,b){var c=document.createElement(a);if(b)c.id=b;c.unselectable="on";c.onselectstart=OpenLayers.Function.False;return c},nodeTypeCompare:function(a,b){var c=b,d=c.indexOf(":");if(d!=-1)c=c.substr(d+1);var e=a.nodeName;d=e.indexOf(":");if(d!=-1)e=e.substr(d+1);return c==e},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div")},createRoot:function(a){return this.nodeFactory(this.container.id+
-a,"olv:group")},drawPoint:function(a,b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){if(!isNaN(b.x)&&!isNaN(b.y)){var d=this.getResolution();a.style.left=(b.x/d-this.offset.x|0)-c+"px";a.style.top=(b.y/d-this.offset.y|0)-c+"px";b=c*2;a.style.width=b+"px";a.style.height=b+"px";return a}return false},drawLineString:function(a,b){return this.drawLine(a,b,false)},drawLinearRing:function(a,b){return this.drawLine(a,b,true)},drawLine:function(a,b,c){this.setNodeDimension(a,b);for(var d=this.getResolution(),
-e=b.components.length,f=Array(e),g,h,i=0;i<e;i++){g=b.components[i];h=g.x/d-this.offset.x|0;g=g.y/d-this.offset.y|0;f[i]=" "+h+","+g+" l "}b=c?" x e":" e";a.path="m"+f.join("")+b;return a},drawPolygon:function(a,b){this.setNodeDimension(a,b);var c=this.getResolution(),d=[],e,f,g,h,i,j,k,n,m,l;e=0;for(f=b.components.length;e<f;e++){d.push("m");g=b.components[e].components;h=e===0;j=i=null;k=0;for(n=g.length;k<n;k++){m=g[k];l=m.x/c-this.offset.x|0;m=m.y/c-this.offset.y|0;l=" "+l+","+m;d.push(l);k==
-0&&d.push(" l");if(!h)if(i){if(i!=l)if(j){if(j!=l)h=true}else j=l}else i=l}d.push(h?" x ":" ")}d.push("e");a.path=d.join("");return a},drawRectangle:function(a,b){var c=this.getResolution();a.style.left=(b.x/c-this.offset.x|0)+"px";a.style.top=(b.y/c-this.offset.y|0)+"px";a.style.width=(b.width/c|0)+"px";a.style.height=(b.height/c|0)+"px";return a},drawText:function(a,b,c){var d=this.nodeFactory(a+this.LABEL_ID_SUFFIX,"olv:rect"),e=this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox"),
-f=this.getResolution();d.style.left=(c.x/f-this.offset.x|0)+"px";d.style.top=(c.y/f-this.offset.y|0)+"px";d.style.flip="y";e.innerText=b.label;if(b.fontColor)e.style.color=b.fontColor;if(b.fontOpacity)e.style.filter="alpha(opacity="+b.fontOpacity*100+")";if(b.fontFamily)e.style.fontFamily=b.fontFamily;if(b.fontSize)e.style.fontSize=b.fontSize;if(b.fontWeight)e.style.fontWeight=b.fontWeight;if(b.labelSelect===true){d._featureId=a;e._featureId=a;e._geometry=c;e._geometryClass=c.CLASS_NAME}e.style.whiteSpace=
-"nowrap";e.inset="1px,0px,0px,0px";if(!d.parentNode){d.appendChild(e);this.textRoot.appendChild(d)}b=b.labelAlign||"cm";if(b.length==1)b+="m";a=e.clientWidth*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(0,1)];e=e.clientHeight*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(1,1)];d.style.left=parseInt(d.style.left)-a-1+"px";d.style.top=parseInt(d.style.top)+e+"px"},drawSurface:function(a,b){this.setNodeDimension(a,b);for(var c=this.getResolution(),d=[],e,f,g=0,h=b.components.length;g<h;g++){e=b.components[g];
-f=e.x/c-this.offset.x|0;e=e.y/c-this.offset.y|0;if(g%3==0&&g/3==0)d.push("m");else g%3==1&&d.push(" c");d.push(" "+f+","+e)}d.push(" x e");a.path=d.join("");return a},moveRoot:function(a){var b=this.map.getLayer(a.container.id);if(b instanceof OpenLayers.Layer.Vector.RootContainer)b=this.map.getLayer(this.container.id);b&&b.renderer.clear();OpenLayers.Renderer.Elements.prototype.moveRoot.apply(this,arguments);b&&b.redraw()},importSymbol:function(a){var b=this.container.id+"-"+a,c=this.symbolCache[b];
-if(c)return c;c=OpenLayers.Renderer.symbol[a];if(!c)throw Error(a+" is not a valid symbol name");a=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);for(var d=["m"],e=0;e<c.length;e+=2){var f=c[e],g=c[e+1];a.left=Math.min(a.left,f);a.bottom=Math.min(a.bottom,g);a.right=Math.max(a.right,f);a.top=Math.max(a.top,g);d.push(f);d.push(g);e==0&&d.push("l")}d.push("x e");c=d.join(" ");d=(a.getWidth()-a.getHeight())/2;if(d>0){a.bottom-=d;a.top+=d}else{a.left+=d;a.right-=d}c={path:c,size:a.getWidth(),
-left:a.left,bottom:a.bottom};return this.symbolCache[b]=c},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Renderer.VML.LABEL_SHIFT={l:0,c:0.5,r:1,t:0,m:0.5,b:1};
-OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(a,b,c,d,e,f){this.layer=a;this.position=b.clone();this.bounds=c.clone();this.url=d;this.size=e.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,f)},unload:function(){if(this.isLoading){this.isLoading=false;
-this.events.triggerEvent("unload")}},destroy:function(){this.position=this.size=this.bounds=this.layer=null;this.events.destroy();this.events=null},clone:function(a){if(a==null)a=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);OpenLayers.Util.applyDefaults(a,this);return a},draw:function(){var a=this.layer.maxExtent;this.shouldDraw=a&&this.bounds.intersectsBounds(a,false)||this.layer.displayOutsideMaxExtent;this.clear();return this.shouldDraw},moveTo:function(a,b,c){if(c==
-null)c=true;this.bounds=a.clone();this.position=b.clone();c&&this.draw()},clear:function(){},getBoundsFromBaseLayer:function(a){var b=OpenLayers.i18n("reprojectDeprecated",{layerName:this.layer.name});OpenLayers.Console.warn(b);b=this.layer.map.getLonLatFromLayerPx(a);a=a.clone();a.x+=this.size.w;a.y+=this.size.h;a=this.layer.map.getLonLatFromLayerPx(a);if(b.lon>a.lon)if(b.lon<0)b.lon=-180-(b.lon+180);else a.lon=180+a.lon+180;return new OpenLayers.Bounds(b.lon,a.lat,a.lon,b.lat)},showTile:function(){this.shouldDraw&&
-this.show()},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Format.CSWGetDomain=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetDomain.DEFAULTS);var b=OpenLayers.Format.CSWGetDomain["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetDomain version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetDomain.DEFAULTS={version:"2.0.2"};
-OpenLayers.Format.CSWGetRecords=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetRecords.DEFAULTS);var b=OpenLayers.Format.CSWGetRecords["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetRecords version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetRecords.DEFAULTS={version:"2.0.2"};
-OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(a){if(window.ActiveXObject)this.xmldom=new ActiveXObject("Microsoft.XMLDOM");OpenLayers.Format.prototype.initialize.apply(this,[a]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var b in this.namespaces)this.namespaceAlias[this.namespaces[b]]=b},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,
-arguments)},setNamespace:function(a,b){this.namespaces[a]=b;this.namespaceAlias[b]=a},read:function(a){var b=a.indexOf("<");if(b>0)a=a.substring(b);b=OpenLayers.Util.Try(OpenLayers.Function.bind(function(){var c;c=window.ActiveXObject&&!this.xmldom?new ActiveXObject("Microsoft.XMLDOM"):this.xmldom;c.loadXML(a);return c},this),function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var c=new XMLHttpRequest;c.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),false);
-c.overrideMimeType&&c.overrideMimeType("text/xml");c.send(null);return c.responseXML});if(this.keepData)this.data=b;return b},write:function(a){if(this.xmldom)a=a.xml;else{var b=new XMLSerializer;if(a.nodeType==1){var c=document.implementation.createDocument("","",null);if(c.importNode)a=c.importNode(a,true);c.appendChild(a);a=b.serializeToString(c)}else a=b.serializeToString(a)}return a},createElementNS:function(a,b){return this.xmldom?typeof a=="string"?this.xmldom.createNode(1,b,a):this.xmldom.createNode(1,
-b,""):document.createElementNS(a,b)},createTextNode:function(a){if(typeof a!=="string")a=String(a);return this.xmldom?this.xmldom.createTextNode(a):document.createTextNode(a)},getElementsByTagNameNS:function(a,b,c){var d=[];if(a.getElementsByTagNameNS)d=a.getElementsByTagNameNS(b,c);else{a=a.getElementsByTagName("*");for(var e,f,g=0,h=a.length;g<h;++g){e=a[g];f=e.prefix?e.prefix+":"+c:c;if(c=="*"||f==e.nodeName)if(b=="*"||b==e.namespaceURI)d.push(e)}}return d},getAttributeNodeNS:function(a,b,c){var d=
-null;if(a.getAttributeNodeNS)d=a.getAttributeNodeNS(b,c);else{a=a.attributes;for(var e,f,g=0,h=a.length;g<h;++g){e=a[g];if(e.namespaceURI==b){f=e.prefix?e.prefix+":"+c:c;if(f==e.nodeName){d=e;break}}}}return d},getAttributeNS:function(a,b,c){var d="";if(a.getAttributeNS)d=a.getAttributeNS(b,c)||"";else if(a=this.getAttributeNodeNS(a,b,c))d=a.nodeValue;return d},getChildValue:function(a,b){var c=b||"";if(a)for(var d=a.firstChild;d;d=d.nextSibling)switch(d.nodeType){case 3:case 4:c+=d.nodeValue}return c},
-concatChildValues:function(a,b){for(var c="",d=a.firstChild,e;d;){if(e=d.nodeValue)c+=e;d=d.nextSibling}if(c==""&&b!=undefined)c=b;return c},isSimpleContent:function(a){var b=true;for(a=a.firstChild;a;a=a.nextSibling)if(a.nodeType===1){b=false;break}return b},contentType:function(a){var b=false,c=false,d=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY;for(a=a.firstChild;a;a=a.nextSibling){switch(a.nodeType){case 1:c=true;break;case 8:break;default:b=true}if(c&&b)break}if(c&&b)d=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;
-else if(c)return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;else if(b)return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE;return d},hasAttributeNS:function(a,b,c){var d=false;return d=a.hasAttributeNS?a.hasAttributeNS(b,c):!!this.getAttributeNodeNS(a,b,c)},setAttributeNS:function(a,b,c,d){if(a.setAttributeNS)a.setAttributeNS(b,c,d);else if(this.xmldom)if(b){b=a.ownerDocument.createNode(2,c,b);b.nodeValue=d;a.setAttributeNode(b)}else a.setAttribute(c,d);else throw"setAttributeNS not implemented";},createElementNSPlus:function(a,
-b){b=b||{};var c=b.uri||this.namespaces[b.prefix];if(!c){c=a.indexOf(":");c=this.namespaces[a.substring(0,c)]}c||(c=this.namespaces[this.defaultPrefix]);c=this.createElementNS(c,a);b.attributes&&this.setAttributes(c,b.attributes);var d=b.value;d!=null&&c.appendChild(this.createTextNode(d));return c},setAttributes:function(a,b){var c,d,e;for(e in b)if(b[e]!=null&&b[e].toString){c=b[e].toString();d=this.namespaces[e.substring(0,e.indexOf(":"))]||null;this.setAttributeNS(a,d,e,c)}},readNode:function(a,
-b){b||(b={});var c=this.readers[a.namespaceURI?this.namespaceAlias[a.namespaceURI]:this.defaultPrefix];if(c){var d=a.localName||a.nodeName.split(":").pop();(c=c[d]||c["*"])&&c.apply(this,[a,b])}return b},readChildNodes:function(a,b){b||(b={});for(var c=a.childNodes,d,e=0,f=c.length;e<f;++e){d=c[e];d.nodeType==1&&this.readNode(d,b)}return b},writeNode:function(a,b,c){var d,e=a.indexOf(":");if(e>0){d=a.substring(0,e);a=a.substring(e+1)}else{d=c?this.namespaceAlias[c.namespaceURI]:this.defaultPrefix;
-a=a}b=this.writers[d][a].apply(this,[b]);c&&c.appendChild(b);return b},getChildEl:function(a,b,c){return a&&this.getThisOrNextEl(a.firstChild,b,c)},getNextEl:function(a,b,c){return a&&this.getThisOrNextEl(a.nextSibling,b,c)},getThisOrNextEl:function(a,b,c){a=a;a:for(;a;a=a.nextSibling)switch(a.nodeType){case 1:if((!b||b===(a.localName||a.nodeName.split(":").pop()))&&(!c||c===a.namespaceURI))break a;a=null;break a;case 3:if(/^\s*$/.test(a.nodeValue))break;case 4:case 6:case 12:case 10:case 11:a=null;
-break a}return a||null},lookupNamespaceURI:function(a,b){var c=null;if(a)if(a.lookupNamespaceURI)c=a.lookupNamespaceURI(b);else a:switch(a.nodeType){case 1:if(a.namespaceURI!==null&&a.prefix===b){c=a.namespaceURI;break a}if(c=a.attributes.length)for(var d,e=0;e<c;++e){d=a.attributes[e];if(d.prefix==="xmlns"&&d.name==="xmlns:"+b){c=d.value||null;break a}else if(d.name==="xmlns"&&b===null){c=d.value||null;break a}}c=this.lookupNamespaceURI(a.parentNode,b);break a;case 2:c=this.lookupNamespaceURI(a.ownerElement,
-b);break a;case 9:c=this.lookupNamespaceURI(a.documentElement,b);break a;case 6:case 12:case 10:case 11:break a;default:c=this.lookupNamespaceURI(a.parentNode,b)}return c},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);
-OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(a,b,c){OpenLayers.Util.extend(this,c);this.control=a;this.callbacks=b;(a=this.map||a.map)&&this.setMap(a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},setMap:function(a){this.map=a},checkModifiers:function(a){if(this.keyMask==null)return true;return((a.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(a.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(a.altKey?OpenLayers.Handler.MOD_ALT:
-0))==this.keyMask},activate:function(){if(this.active)return false;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.register(a[b],this[a[b]]);return this.active=true},deactivate:function(){if(!this.active)return false;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]]);this.active=false;return true},callback:function(a,b){a&&this.callbacks[a]&&this.callbacks[a].apply(this.control,b)},register:function(a,
-b){this.map.events.registerPriority(a,this,b);this.map.events.registerPriority(a,this,this.setEvent)},unregister:function(a,b){this.map.events.unregister(a,this,b);this.map.events.unregister(a,this,this.setEvent)},setEvent:function(a){this.evt=a;return true},destroy:function(){this.deactivate();this.control=this.map=null},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;
-OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1E3},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,
-layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:"degrees",resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(a,
-b){if(arguments.length===1&&typeof a==="object")a=(b=a)&&b.div;this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+"theme/default/style.css";OpenLayers.Util.extend(this,b);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(a);if(!this.div){this.div=document.createElement("div");
-this.div.style.height="1px";this.div.style.width="1px"}OpenLayers.Element.addClass(this.div,"olMap");var c=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(c,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);c=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(c);this.layerContainerDiv.style.zIndex=
-this.Z_INDEX_BASE.Popup-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});this.updateSize();this.eventListeners instanceof Object&&this.events.on(this.eventListeners);this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft"))this.events.register("resize",this,this.updateSize);else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,
-this);OpenLayers.Event.observe(window,"resize",this.updateSizeDestroy)}if(this.theme){c=true;for(var d=document.getElementsByTagName("link"),e=0,f=d.length;e<f;++e)if(OpenLayers.Util.isEquivalentUrl(d.item(e).href,this.theme)){c=false;break}if(c){c=document.createElement("link");c.setAttribute("rel","stylesheet");c.setAttribute("type","text/css");c.setAttribute("href",this.theme);document.getElementsByTagName("head")[0].appendChild(c)}}if(this.controls==null)this.controls=OpenLayers.Control!=null?
-[new OpenLayers.Control.Navigation,new OpenLayers.Control.PanZoom,new OpenLayers.Control.ArgParser,new OpenLayers.Control.Attribution]:[];e=0;for(f=this.controls.length;e<f;e++)this.addControlToMap(this.controls[e]);this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,"unload",this.unloadDestroy);if(b&&b.layers){this.addLayers(b.layers);b.center&&this.setCenter(b.center,b.zoom)}},render:function(a){this.div=OpenLayers.Util.getElement(a);OpenLayers.Element.addClass(this.div,
-"olMap");this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize()},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy)return false;if(this.panTween){this.panTween.stop();this.panTween=null}OpenLayers.Event.stopObserving(window,"unload",this.unloadDestroy);this.unloadDestroy=null;this.updateSizeDestroy?OpenLayers.Event.stopObserving(window,"resize",this.updateSizeDestroy):this.events.unregister("resize",this,
-this.updateSize);this.paddingForPopups=null;if(this.controls!=null){for(var a=this.controls.length-1;a>=0;--a)this.controls[a].destroy();this.controls=null}if(this.layers!=null){for(a=this.layers.length-1;a>=0;--a)this.layers[a].destroy(false);this.layers=null}this.viewPortDiv&&this.div.removeChild(this.viewPortDiv);this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null}this.events.destroy();this.events=null},setOptions:function(a){OpenLayers.Util.extend(this,
-a)},getTileSize:function(){return this.tileSize},getBy:function(a,b,c){var d=typeof c.test=="function";return OpenLayers.Array.filter(this[a],function(e){return e[b]==c||d&&c.test(e[b])})},getLayersBy:function(a,b){return this.getBy("layers",a,b)},getLayersByName:function(a){return this.getLayersBy("name",a)},getLayersByClass:function(a){return this.getLayersBy("CLASS_NAME",a)},getControlsBy:function(a,b){return this.getBy("controls",a,b)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",
-a)},getLayer:function(a){for(var b=null,c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.id==a){b=e;break}}return b},setLayerZIndex:function(a,b){a.setZIndex(this.Z_INDEX_BASE[a.isBaseLayer?"BaseLayer":"Overlay"]+b*5)},resetLayersZIndex:function(){for(var a=0,b=this.layers.length;a<b;a++)this.setLayerZIndex(this.layers[a],a)},addLayer:function(a){for(var b=0,c=this.layers.length;b<c;b++)if(this.layers[b]==a){a=OpenLayers.i18n("layerAlreadyAdded",{layerName:a.name});OpenLayers.Console.warn(a);
-return false}if(this.allOverlays)a.isBaseLayer=false;if(this.events.triggerEvent("preaddlayer",{layer:a})!==false){a.div.className="olLayerDiv";a.div.style.overflow="";this.setLayerZIndex(a,this.layers.length);a.isFixed?this.viewPortDiv.appendChild(a.div):this.layerContainerDiv.appendChild(a.div);this.layers.push(a);a.setMap(this);if(a.isBaseLayer||this.allOverlays&&!this.baseLayer)this.baseLayer==null?this.setBaseLayer(a):a.setVisibility(false);else a.redraw();this.events.triggerEvent("addlayer",
-{layer:a});a.afterAdd()}},addLayers:function(a){for(var b=0,c=a.length;b<c;b++)this.addLayer(a[b])},removeLayer:function(a,b){if(b==null)b=true;a.isFixed?this.viewPortDiv.removeChild(a.div):this.layerContainerDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.layers,a);a.removeMap(this);a.map=null;if(this.baseLayer==a){this.baseLayer=null;if(b)for(var c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.isBaseLayer||this.allOverlays){this.setBaseLayer(e);break}}}this.resetLayersZIndex();
-this.events.triggerEvent("removelayer",{layer:a})},getNumLayers:function(){return this.layers.length},getLayerIndex:function(a){return OpenLayers.Util.indexOf(this.layers,a)},setLayerIndex:function(a,b){var c=this.getLayerIndex(a);if(b<0)b=0;else if(b>this.layers.length)b=this.layers.length;if(c!=b){this.layers.splice(c,1);this.layers.splice(b,0,a);c=0;for(var d=this.layers.length;c<d;c++)this.setLayerZIndex(this.layers[c],c);this.events.triggerEvent("changelayer",{layer:a,property:"order"});if(this.allOverlays)if(b===
-0)this.setBaseLayer(a);else this.baseLayer!==this.layers[0]&&this.setBaseLayer(this.layers[0])}},raiseLayer:function(a,b){var c=this.getLayerIndex(a)+b;this.setLayerIndex(a,c)},setBaseLayer:function(a){if(a!=this.baseLayer)if(OpenLayers.Util.indexOf(this.layers,a)!=-1){var b=this.getCenter(),c=OpenLayers.Util.getResolutionFromScale(this.getScale(),a.units);this.baseLayer!=null&&!this.allOverlays&&this.baseLayer.setVisibility(false);this.baseLayer=a;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility)this.baseLayer.setVisibility(true);
-if(b!=null){a=this.getZoomForResolution(c||this.resolution,true);this.setCenter(b,a,false,true)}this.events.triggerEvent("changebaselayer",{layer:this.baseLayer})}},addControl:function(a,b){this.controls.push(a);this.addControlToMap(a,b)},addControls:function(a,b){for(var c=arguments.length===1?[]:b,d=0,e=a.length;d<e;d++)this.addControl(a[d],c[d]?c[d]:null)},addControlToMap:function(a,b){a.outsideViewport=a.div!=null;if(this.displayProjection&&!a.displayProjection)a.displayProjection=this.displayProjection;
-a.setMap(this);var c=a.draw(b);if(c)if(!a.outsideViewport){c.style.zIndex=this.Z_INDEX_BASE.Control+this.controls.length;this.viewPortDiv.appendChild(c)}a.autoActivate&&a.activate()},getControl:function(a){for(var b=null,c=0,d=this.controls.length;c<d;c++){var e=this.controls[c];if(e.id==a){b=e;break}}return b},removeControl:function(a){if(a&&a==this.getControl(a.id)){a.div&&a.div.parentNode==this.viewPortDiv&&this.viewPortDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.controls,a)}},addPopup:function(a,
-b){if(b)for(var c=this.popups.length-1;c>=0;--c)this.removePopup(this.popups[c]);a.map=this;this.popups.push(a);if(c=a.draw()){c.style.zIndex=this.Z_INDEX_BASE.Popup+this.popups.length;this.layerContainerDiv.appendChild(c)}},removePopup:function(a){OpenLayers.Util.removeItem(this.popups,a);if(a.div)try{this.layerContainerDiv.removeChild(a.div)}catch(b){}a.map=null},getSize:function(){var a=null;if(this.size!=null)a=this.size.clone();return a},updateSize:function(){var a=this.getCurrentSize();if(a&&
-!isNaN(a.h)&&!isNaN(a.w)){this.events.clearMouseCache();var b=this.getSize();if(b==null)this.size=b=a;if(!a.equals(b)){this.size=a;a=0;for(b=this.layers.length;a<b;a++)this.layers[a].onMapResize();a=this.getCenter();if(this.baseLayer!=null&&a!=null){b=this.getZoom();this.zoom=null;this.setCenter(a,b)}}}},getCurrentSize:function(){var a=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(a.w==0&&a.h==0||isNaN(a.w)&&isNaN(a.h)){a.w=this.div.offsetWidth;a.h=this.div.offsetHeight}if(a.w==
-0&&a.h==0||isNaN(a.w)&&isNaN(a.h)){a.w=parseInt(this.div.style.width);a.h=parseInt(this.div.style.height)}return a},calculateBounds:function(a,b){var c=null;if(a==null)a=this.getCenter();if(b==null)b=this.getResolution();if(a!=null&&b!=null){var d=this.getSize();c=d.w*b;d=d.h*b;c=new OpenLayers.Bounds(a.lon-c/2,a.lat-d/2,a.lon+c/2,a.lat+d/2)}return c},getCenter:function(){var a=null;if(this.center)a=this.center.clone();return a},getZoom:function(){return this.zoom},pan:function(a,b,c){c=OpenLayers.Util.applyDefaults(c,
-{animate:true,dragging:false});var d=this.getViewPortPxFromLonLat(this.getCenter());a=d.add(a,b);if(!c.dragging||!a.equals(d)){d=this.getLonLatFromViewPortPx(a);c.animate?this.panTo(d):this.setCenter(d,null,c.dragging)}},panTo:function(a){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(a)){if(!this.panTween)this.panTween=new OpenLayers.Tween(this.panMethod);var b=this.getCenter();a.lon==b.lon&&a.lat==b.lat||this.panTween.start({lon:b.lon,lat:b.lat},{lon:a.lon,lat:a.lat},this.panDuration,
-{callbacks:{start:OpenLayers.Function.bind(function(){this.events.triggerEvent("movestart")},this),eachStep:OpenLayers.Function.bind(function(c){c=new OpenLayers.LonLat(c.lon,c.lat);this.moveTo(c,this.zoom,{dragging:true,noEvent:true})},this),done:OpenLayers.Function.bind(function(c){c=new OpenLayers.LonLat(c.lon,c.lat);this.moveTo(c,this.zoom,{noEvent:true});this.events.triggerEvent("moveend")},this)}})}else this.setCenter(a)},setCenter:function(a,b,c,d){this.moveTo(a,b,{dragging:c,forceZoomChange:d,
-caller:"setCenter"})},moveTo:function(a,b,c){c||(c={});if(b!=null){b=parseFloat(b);this.fractionalZoom||(b=Math.round(b))}var d=c.dragging,e=c.forceZoomChange,f=c.noEvent;this.panTween&&c.caller=="setCenter"&&this.panTween.stop();if(!this.center&&!this.isValidLonLat(a))a=this.maxExtent.getCenterLonLat();if(this.restrictedExtent!=null){if(a==null)a=this.getCenter();if(b==null)b=this.getZoom();c=this.getResolutionForZoom(b);c=this.calculateBounds(a,c);if(!this.restrictedExtent.containsBounds(c)){var g=
-this.restrictedExtent.getCenterLonLat();if(c.getWidth()>this.restrictedExtent.getWidth())a=new OpenLayers.LonLat(g.lon,a.lat);else if(c.left<this.restrictedExtent.left)a=a.add(this.restrictedExtent.left-c.left,0);else if(c.right>this.restrictedExtent.right)a=a.add(this.restrictedExtent.right-c.right,0);if(c.getHeight()>this.restrictedExtent.getHeight())a=new OpenLayers.LonLat(a.lon,g.lat);else if(c.bottom<this.restrictedExtent.bottom)a=a.add(0,this.restrictedExtent.bottom-c.bottom);else if(c.top>
-this.restrictedExtent.top)a=a.add(0,this.restrictedExtent.top-c.top)}}e=e||this.isValidZoomLevel(b)&&b!=this.getZoom();c=this.isValidLonLat(a)&&!a.equals(this.center);if(e||c||!d){!this.dragging&&!f&&this.events.triggerEvent("movestart");if(c){!e&&this.center&&this.centerLayerContainer(a);this.center=a.clone()}if(e||this.layerContainerOrigin==null){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px"}if(e){this.zoom=b;this.resolution=
-this.getResolutionForZoom(b);this.viewRequestID++}a=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(a,e,d);d?this.baseLayer.events.triggerEvent("move"):this.baseLayer.events.triggerEvent("moveend",{zoomChanged:e})}a=this.baseLayer.getExtent();b=0;for(c=this.layers.length;b<c;b++){g=this.layers[b];if(g!==this.baseLayer&&!g.isBaseLayer){var h=g.calculateInRange();if(g.inRange!=h){(g.inRange=h)||g.display(false);this.events.triggerEvent("changelayer",{layer:g,property:"visibility"})}if(h&&
-g.visibility){g.moveTo(a,e,d);d?g.events.triggerEvent("move"):g.events.triggerEvent("moveend",{zoomChanged:e})}}}if(e){b=0;for(c=this.popups.length;b<c;b++)this.popups[b].updatePosition()}this.events.triggerEvent("move");e&&this.events.triggerEvent("zoomend")}!d&&!f&&this.events.triggerEvent("moveend");this.dragging=!!d},centerLayerContainer:function(a){var b=this.getViewPortPxFromLonLat(this.layerContainerOrigin);a=this.getViewPortPxFromLonLat(a);if(b!=null&&a!=null){this.layerContainerDiv.style.left=
-Math.round(b.x-a.x)+"px";this.layerContainerDiv.style.top=Math.round(b.y-a.y)+"px"}},isValidZoomLevel:function(a){return a!=null&&a>=0&&a<this.getNumZoomLevels()},isValidLonLat:function(a){var b=false;if(a!=null)b=this.getMaxExtent().containsLonLat(a);return b},getProjection:function(){var a=this.getProjectionObject();return a?a.getCode():null},getProjectionObject:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.projection;return a},getMaxResolution:function(){var a=null;if(this.baseLayer!=
-null)a=this.baseLayer.maxResolution;return a},getMaxExtent:function(a){var b=null;if(a&&a.restricted&&this.restrictedExtent)b=this.restrictedExtent;else if(this.baseLayer!=null)b=this.baseLayer.maxExtent;return b},getNumZoomLevels:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.numZoomLevels;return a},getExtent:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.getExtent();return a},getResolution:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.getResolution();
-else if(this.allOverlays===true&&this.layers.length>0)a=this.layers[0].getResolution();return a},getUnits:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.units;return a},getScale:function(){var a=null;if(this.baseLayer!=null){a=this.getResolution();a=OpenLayers.Util.getScaleFromResolution(a,this.baseLayer.units)}return a},getZoomForExtent:function(a,b){var c=null;if(this.baseLayer!=null)c=this.baseLayer.getZoomForExtent(a,b);return c},getResolutionForZoom:function(a){var b=null;if(this.baseLayer)b=
-this.baseLayer.getResolutionForZoom(a);return b},getZoomForResolution:function(a,b){var c=null;if(this.baseLayer!=null)c=this.baseLayer.getZoomForResolution(a,b);return c},zoomTo:function(a){this.isValidZoomLevel(a)&&this.setCenter(null,a)},zoomIn:function(){this.zoomTo(this.getZoom()+1)},zoomOut:function(){this.zoomTo(this.getZoom()-1)},zoomToExtent:function(a,b){var c=a.getCenterLonLat();if(this.baseLayer.wrapDateLine){c=this.getMaxExtent();for(a=a.clone();a.right<a.left;)a.right+=c.getWidth();
-c=a.getCenterLonLat().wrapDateLine(c)}this.setCenter(c,this.getZoomForExtent(a,b))},zoomToMaxExtent:function(a){this.zoomToExtent(this.getMaxExtent({restricted:a?a.restricted:true}))},zoomToScale:function(a,b){var c=OpenLayers.Util.getResolutionFromScale(a,this.baseLayer.units),d=this.getSize(),e=d.w*c;c=d.h*c;d=this.getCenter();this.zoomToExtent(new OpenLayers.Bounds(d.lon-e/2,d.lat-c/2,d.lon+e/2,d.lat+c/2),b)},getLonLatFromViewPortPx:function(a){var b=null;if(this.baseLayer!=null)b=this.baseLayer.getLonLatFromViewPortPx(a);
-return b},getViewPortPxFromLonLat:function(a){var b=null;if(this.baseLayer!=null)b=this.baseLayer.getViewPortPxFromLonLat(a);return b},getLonLatFromPixel:function(a){return this.getLonLatFromViewPortPx(a)},getPixelFromLonLat:function(a){a=this.getViewPortPxFromLonLat(a);a.x=Math.round(a.x);a.y=Math.round(a.y);return a},getGeodesicPixelSize:function(a){var b=a?this.getLonLatFromPixel(a):this.getCenter()||new OpenLayers.LonLat(0,0),c=this.getResolution();a=b.add(-c/2,0);var d=b.add(c/2,0),e=b.add(0,
--c/2);b=b.add(0,c/2);c=new OpenLayers.Projection("EPSG:4326");var f=this.getProjectionObject()||c;if(!f.equals(c)){a.transform(f,c);d.transform(f,c);e.transform(f,c);b.transform(f,c)}return new OpenLayers.Size(OpenLayers.Util.distVincenty(a,d),OpenLayers.Util.distVincenty(e,b))},getViewPortPxFromLayerPx:function(a){var b=null;if(a!=null){b=parseInt(this.layerContainerDiv.style.left);var c=parseInt(this.layerContainerDiv.style.top);b=a.add(b,c)}return b},getLayerPxFromViewPortPx:function(a){var b=
-null;if(a!=null){b=-parseInt(this.layerContainerDiv.style.left);var c=-parseInt(this.layerContainerDiv.style.top);b=a.add(b,c);if(isNaN(b.x)||isNaN(b.y))b=null}return b},getLonLatFromLayerPx:function(a){a=this.getViewPortPxFromLayerPx(a);return this.getLonLatFromViewPortPx(a)},getLayerPxFromLonLat:function(a){return this.getLayerPxFromViewPortPx(this.getPixelFromLonLat(a))},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;
-OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(a,b){this.lonlat=a;var c=b?b:OpenLayers.Marker.defaultIcon();if(this.icon==null)this.icon=c;else{this.icon.url=c.url;this.icon.size=c.size;this.icon.offset=c.offset;this.icon.calculateOffset=c.calculateOffset}this.events=new OpenLayers.Events(this,this.icon.imageDiv,null)},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=
-null}},draw:function(a){return this.icon.draw(a)},erase:function(){this.icon!=null&&this.icon.erase()},moveTo:function(a){a!=null&&this.icon!=null&&this.icon.moveTo(a);this.lonlat=this.map.getLonLatFromLayerPx(a)},isDrawn:function(){return this.icon&&this.icon.isDrawn()},onScreen:function(){var a=false;if(this.map)a=this.map.getExtent().containsLonLat(this.lonlat);return a},inflate:function(a){this.icon&&this.icon.setSize(new OpenLayers.Size(this.icon.size.w*a,this.icon.size.h*a))},setOpacity:function(a){this.icon.setOpacity(a)},
-setUrl:function(a){this.icon.setUrl(a)},display:function(a){this.icon.display(a)},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var a=OpenLayers.Util.getImagesLocation()+"marker.png",b=new OpenLayers.Size(21,25);return new OpenLayers.Icon(a,b,null,function(c){return new OpenLayers.Pixel(-(c.w/2),-c.h)})};
-OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(a){var b=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});a=OpenLayers.Util.applyDefaults(a,b);var c=new OpenLayers.Request.XMLHttpRequest,d=a.url;if(a.params){b=
-OpenLayers.Util.getParameterString(a.params);if(b.length>0){var e=d.indexOf("?")>-1?"&":"?";d+=e+b}}if(a.proxy&&d.indexOf("http")==0)d=typeof a.proxy=="function"?a.proxy(d):a.proxy+encodeURIComponent(d);c.open(a.method,d,a.async,a.user,a.password);for(var f in a.headers)c.setRequestHeader(f,a.headers[f]);var g=this.events,h=this;c.onreadystatechange=function(){c.readyState==OpenLayers.Request.XMLHttpRequest.DONE&&g.triggerEvent("complete",{request:c,config:a,requestUrl:d})!==false&&h.runCallbacks({request:c,
-config:a,requestUrl:d})};a.async===false?c.send(a.data):window.setTimeout(function(){c._aborted!==true&&c.send(a.data)},0);return c},runCallbacks:function(a){var b=a.request,c=a.config,d=c.scope?OpenLayers.Function.bind(c.callback,c.scope):c.callback,e;if(c.success)e=c.scope?OpenLayers.Function.bind(c.success,c.scope):c.success;var f;if(c.failure)f=c.scope?OpenLayers.Function.bind(c.failure,c.scope):c.failure;d(b);if(!b.status||b.status>=200&&b.status<300){this.events.triggerEvent("success",a);e&&
-e(b)}if(b.status&&(b.status<200||b.status>=300)){this.events.triggerEvent("failure",a);f&&f(b)}},GET:function(a){a=OpenLayers.Util.extend(a,{method:"GET"});return OpenLayers.Request.issue(a)},POST:function(a){a=OpenLayers.Util.extend(a,{method:"POST"});a.headers=a.headers?a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");return OpenLayers.Request.issue(a)},PUT:function(a){a=OpenLayers.Util.extend(a,{method:"PUT"});a.headers=a.headers?
-a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");return OpenLayers.Request.issue(a)},DELETE:function(a){a=OpenLayers.Util.extend(a,{method:"DELETE"});return OpenLayers.Request.issue(a)},HEAD:function(a){a=OpenLayers.Util.extend(a,{method:"HEAD"});return OpenLayers.Request.issue(a)},OPTIONS:function(a){a=OpenLayers.Util.extend(a,{method:"OPTIONS"});return OpenLayers.Request.issue(a)}};
-OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(a,b,c,d){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.maxGetUrlLength!=null&&OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);this.url=d;this.frame=document.createElement("div");this.frame.style.overflow="hidden";this.frame.style.position="absolute";this.layerAlphaHack=
-this.layer.alpha&&OpenLayers.Util.alphaHack()},destroy:function(){this.imgDiv!=null&&this.removeImgDiv();this.imgDiv=null;this.frame!=null&&this.frame.parentNode==this.layer.div&&this.layer.div.removeChild(this.frame);this.frame=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null}this.layer.events.unregister("loadend",this,this.resetBackBuffer);OpenLayers.Tile.prototype.destroy.apply(this,arguments)},clone:function(a){if(a==null)a=new OpenLayers.Tile.Image(this.layer,
-this.position,this.bounds,this.url,this.size);a=OpenLayers.Tile.prototype.clone.apply(this,[a]);a.imgDiv=null;return a},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject)this.bounds=this.getBoundsFromBaseLayer(this.position);var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1||this.layer.singleTile)if(a){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();
-this.backBufferTile.isBackBuffer=true;this.events.register("loadend",this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer)}this.startTransition()}else this.backBufferTile&&this.backBufferTile.clear();else if(a&&this.isFirstDraw){this.events.register("loadend",this,this.showTile);this.isFirstDraw=false}if(!a)return false;if(this.isLoading)this.events.triggerEvent("reload");else{this.isLoading=true;this.events.triggerEvent("loadstart")}return this.renderTile()},
-resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var a=this.layer.maxExtent;if(a&&this.bounds.intersectsBounds(a,false)){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.getImageSize(this.bounds)||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();
-this.backBufferTile.renderTile()}this.backBufferTile.hide()}},renderTile:function(){if(this.layer.async){this.initImgDiv();this.layer.getURLasync(this.bounds,this,"url",this.positionImage)}else{this.url=this.layer.getURL(this.bounds);this.initImgDiv();this.positionImage()}return true},positionImage:function(){if(this.layer!==null){OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var a=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack)OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,
-null,null,a,this.url);else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,a);this.imgDiv.src=this.url}}},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile)this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif"}},initImgDiv:function(){if(this.imgDiv==null){var a=this.layer.imageOffset,b=this.layer.getImageSize(this.bounds);this.imgDiv=this.layerAlphaHack?OpenLayers.Util.createAlphaImageDiv(null,a,b,null,"relative",null,null,null,true):OpenLayers.Util.createImage(null,
-a,b,null,"relative",null,null,true);if(this.layer.url instanceof Array)this.imgDiv.urls=this.layer.url.slice();this.imgDiv.className="olTileImage";this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);this.layer.opacity!=null&&OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);this.imgDiv.map=this.layer.map;var c=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend")}};
-this.layerAlphaHack?OpenLayers.Event.observe(this.imgDiv.childNodes[0],"load",OpenLayers.Function.bind(c,this)):OpenLayers.Event.observe(this.imgDiv,"load",OpenLayers.Function.bind(c,this));OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(function(){this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS&&c.call(this)},this))}this.imgDiv.viewRequestID=this.layer.map.viewRequestID},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==
-this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null}this.imgDiv.urls=null;var a=this.imgDiv.firstChild;if(a){OpenLayers.Event.stopObservingElement(a);this.imgDiv.removeChild(a);delete a}else this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif"},checkImgURL:function(){if(this.layer)OpenLayers.Util.isEquivalentUrl(this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src,this.url)||this.hide()},startTransition:function(){if(this.backBufferTile&&this.backBufferTile.imgDiv){var a=
-1;if(this.backBufferTile.resolution)a=this.backBufferTile.resolution/this.layer.getResolution();if(a!=this.lastRatio){if(this.layer.transitionEffect=="resize"){var b=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top),c=new OpenLayers.Size(this.backBufferTile.size.w*a,this.backBufferTile.size.h*a);b=this.layer.map.getLayerPxFromLonLat(b);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,b,c);c=this.backBufferTile.imageSize;c=new OpenLayers.Size(c.w*
-a,c.h*a);if(b=this.backBufferTile.imageOffset)b=new OpenLayers.Pixel(b.x*a,b.y*a);OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,b,c);this.backBufferTile.show()}}else this.layer.singleTile?this.backBufferTile.show():this.backBufferTile.hide();this.lastRatio=a}},show:function(){this.frame.style.display="";if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1)if(OpenLayers.IS_GECKO===true)this.frame.scrollLeft=this.frame.scrollLeft},hide:function(){this.frame.style.display=
-"none"},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera";
-OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(a,b,c){this.layer=a;this.lonlat=b;this.data=c!=null?c:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.layer!=null&&this.layer.map!=null&&this.popup!=null&&this.layer.map.removePopup(this.popup);this.layer!=null&&this.marker!=null&&this.layer.removeMarker(this.marker);this.data=this.lonlat=this.id=
-this.layer=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null}if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null}},onScreen:function(){var a=false;if(this.layer!=null&&this.layer.map!=null)a=this.layer.map.getExtent().containsLonLat(this.lonlat);return a},createMarker:function(){if(this.lonlat!=null)this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);return this.marker},destroyMarker:function(){this.marker.destroy()},createPopup:function(a){if(this.lonlat!=
-null){var b=this.id+"_popup",c=this.marker?this.marker.icon:null;if(!this.popup)this.popup=new this.popupClass(b,this.lonlat,this.data.popupSize,this.data.popupContentHTML,c,a);if(this.data.overflow!=null)this.popup.contentDiv.style.overflow=this.data.overflow;this.popup.feature=this}return this.popup},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null}},CLASS_NAME:"OpenLayers.Feature"});
-OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a==
-"string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{csw:{GetDomainResponse:function(a,b){this.readChildNodes(a,b)},DomainValues:function(a,b){if(!(b.DomainValues instanceof Array))b.DomainValues=[];for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;this.readChildNodes(a,d);b.DomainValues.push(d)},PropertyName:function(a,b){b.PropertyName=this.getChildValue(a)},ParameterName:function(a,
-b){b.ParameterName=this.getChildValue(a)},ListOfValues:function(a,b){if(!(b.ListOfValues instanceof Array))b.ListOfValues=[];this.readChildNodes(a,b.ListOfValues)},Value:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.push({Value:d})},ConceptualScheme:function(a,b){b.ConceptualScheme={};this.readChildNodes(a,b.ConceptualScheme)},Name:function(a,b){b.Name=this.getChildValue(a)},Document:function(a,b){b.Document=this.getChildValue(a)},
-Authority:function(a,b){b.Authority=this.getChildValue(a)},RangeOfValues:function(a,b){b.RangeOfValues={};this.readChildNodes(a,b.RangeOfValues)},MinValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MinValue=d},MaxValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MaxValue=d}}},write:function(a){a=this.writeNode("csw:GetDomain",a);return OpenLayers.Format.XML.prototype.write.apply(this,
-[a])},writers:{csw:{GetDomain:function(a){var b=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(a.PropertyName||this.PropertyName)this.writeNode("csw:PropertyName",a.PropertyName||this.PropertyName,b);else if(a.ParameterName||this.ParameterName)this.writeNode("csw:ParameterName",a.ParameterName||this.ParameterName,b);this.readChildNodes(b,a);return b},PropertyName:function(a){return this.createElementNSPlus("csw:PropertyName",{value:a})},ParameterName:function(a){return this.createElementNSPlus("csw:ParameterName",
-{value:a})}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});if(!OpenLayers.Format.OWSCommon)OpenLayers.Format.OWSCommon={};
-OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},readers:{ows:{ServiceIdentification:function(a,b){b.serviceIdentification={};this.readChildNodes(a,b.serviceIdentification)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},Keywords:function(a,b){b.keywords={};this.readChildNodes(a,b.keywords)},Keyword:function(a,b){b[this.getChildValue(a)]=
-true},ServiceType:function(a,b){b.serviceType={codeSpace:a.getAttribute("codeSpace"),value:this.getChildValue(a)}},ServiceTypeVersion:function(a,b){b.serviceTypeVersion=this.getChildValue(a)},Fees:function(a,b){b.fees=this.getChildValue(a)},AccessConstraints:function(a,b){b.accessConstraints=this.getChildValue(a)},ServiceProvider:function(a,b){b.serviceProvider={};this.readChildNodes(a,b.serviceProvider)},ProviderName:function(a,b){b.providerName=this.getChildValue(a)},ProviderSite:function(a,b){b.providerSite=
-this.getAttributeNS(a,this.namespaces.xlink,"href")},ServiceContact:function(a,b){b.serviceContact={};this.readChildNodes(a,b.serviceContact)},IndividualName:function(a,b){b.individualName=this.getChildValue(a)},PositionName:function(a,b){b.positionName=this.getChildValue(a)},ContactInfo:function(a,b){b.contactInfo={};this.readChildNodes(a,b.contactInfo)},Phone:function(a,b){b.phone={};this.readChildNodes(a,b.phone)},Voice:function(a,b){b.voice=this.getChildValue(a)},Address:function(a,b){b.address=
-{};this.readChildNodes(a,b.address)},DeliveryPoint:function(a,b){b.deliveryPoint=this.getChildValue(a)},City:function(a,b){b.city=this.getChildValue(a)},AdministrativeArea:function(a,b){b.administrativeArea=this.getChildValue(a)},PostalCode:function(a,b){b.postalCode=this.getChildValue(a)},Country:function(a,b){b.country=this.getChildValue(a)},ElectronicMailAddress:function(a,b){b.electronicMailAddress=this.getChildValue(a)},Role:function(a,b){b.role=this.getChildValue(a)},OperationsMetadata:function(a,
-b){b.operationsMetadata={};this.readChildNodes(a,b.operationsMetadata)},Operation:function(a,b){var c=a.getAttribute("name");b[c]={};this.readChildNodes(a,b[c])},DCP:function(a,b){b.dcp={};this.readChildNodes(a,b.dcp)},HTTP:function(a,b){b.http={};this.readChildNodes(a,b.http)},Get:function(a,b){b.get=this.getAttributeNS(a,this.namespaces.xlink,"href")},Post:function(a,b){b.post=this.getAttributeNS(a,this.namespaces.xlink,"href")},Parameter:function(a,b){if(!b.parameters)b.parameters={};var c=a.getAttribute("name");
-b.parameters[c]={};this.readChildNodes(a,b.parameters[c])},Value:function(a,b){b[this.getChildValue(a)]=true},OutputFormat:function(a,b){b.formats.push({value:this.getChildValue(a)});this.readChildNodes(a,b)},WGS84BoundingBox:function(a,b){var c={};c.crs=a.getAttribute("crs");if(b.BoundingBox)b.BoundingBox.push(c);else{b.projection=c.crs;c=b}this.readChildNodes(a,c)},BoundingBox:function(a,b){this.readers.ows.WGS84BoundingBox.apply(this,[a,b])},LowerCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,
-"");c=c.replace(this.regExes.trimComma,",");c=c.split(this.regExes.splitSpace);b.left=c[0];b.bottom=c[1]},UpperCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"");c=c.replace(this.regExes.trimComma,",");c=c.split(this.regExes.splitSpace);b.right=c[0];b.top=c[1];b.bounds=new OpenLayers.Bounds(b.left,b.bottom,b.right,b.top);delete b.left;delete b.bottom;delete b.right;delete b.top}}},writers:{ows:{BoundingBox:function(a){var b=this.createElementNSPlus("ows:BoundingBox",
-{attributes:{crs:a.projection}});this.writeNode("ows:LowerCorner",a,b);this.writeNode("ows:UpperCorner",a,b);return b},LowerCorner:function(a){return this.createElementNSPlus("ows:LowerCorner",{value:a.bounds.left+" "+a.bounds.bottom})},UpperCorner:function(a){return this.createElementNSPlus("ows:UpperCorner",{value:a.bounds.right+" "+a.bounds.top})},Title:function(a){return this.createElementNSPlus("ows:Title",{value:a})},OutputFormat:function(a){return this.createElementNSPlus("ows:OutputFormat",
-{value:a})}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});
-OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments)},down:function(){},move:function(){},up:function(){},out:function(){},mousedown:function(a){var b=true;this.dragging=false;if(this.checkModifiers(a)&&OpenLayers.Event.isLeftClick(a)){this.started=true;this.last=
-this.start=a.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(a);this.callback("down",[a.xy]);OpenLayers.Event.stop(a);if(!this.oldOnselectstart)this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;document.onselectstart=OpenLayers.Function.False;b=!this.stopDown}else{this.started=false;this.last=this.start=null}return b},mousemove:function(a){if(this.started&&!this.timeoutId&&(a.xy.x!=this.last.x||a.xy.y!=this.last.y)){if(this.documentDrag===
-true&&this.documentEvents)if(a.element===document){this.adjustXY(a);this.setEvent(a)}else this.destroyDocumentEvents();if(this.interval>0)this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);this.dragging=true;this.move(a);this.callback("move",[a.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False}this.last=this.evt.xy}return true},removeTimeout:function(){this.timeoutId=null},mouseup:function(a){if(this.started){if(this.documentDrag===
-true&&this.documentEvents){this.adjustXY(a);this.destroyDocumentEvents()}var b=this.start!=this.last;this.dragging=this.started=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(a);this.callback("up",[a.xy]);b&&this.callback("done",[a.xy]);document.onselectstart=this.oldOnselectstart}return true},mouseout:function(a){if(this.started&&OpenLayers.Util.mouseLeft(a,this.map.div))if(this.documentDrag===true){this.documentEvents=new OpenLayers.Events(this,document,null,null,
-{includeXY:true});this.documentEvents.on({mousemove:this.mousemove,mouseup:this.mouseup});OpenLayers.Element.addClass(document.body,"olDragDown")}else{var b=this.start!=this.last;this.dragging=this.started=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(a);this.callback("out",[]);b&&this.callback("done",[a.xy]);if(document.onselectstart)document.onselectstart=this.oldOnselectstart}return true},click:function(){return this.start==this.last},activate:function(){var a=
-false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;a=true}return a},deactivate:function(){var a=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragging=this.started=false;this.last=this.start=null;a=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown")}return a},adjustXY:function(a){var b=OpenLayers.Util.pagePosition(this.map.viewPortDiv);a.xy.x-=b[0];a.xy.y-=b[1]},destroyDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,
-"olDragDown");this.documentEvents.destroy();this.documentEvents=null},CLASS_NAME:"OpenLayers.Handler.Drag"});
-OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this)},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null},onWheelEvent:function(a){if(this.map&&this.checkModifiers(a)){for(var b=false,c=false,d=false,
-e=OpenLayers.Event.element(a);e!=null&&!d&&!b;){if(!b)try{var f=e.currentStyle?e.currentStyle.overflow:document.defaultView.getComputedStyle(e,null).getPropertyValue("overflow");b=f&&f=="auto"||f=="scroll"}catch(g){}if(!c){d=0;for(var h=this.map.layers.length;d<h;d++)if(e==this.map.layers[d].div||e==this.map.layers[d].pane){c=true;break}}d=e==this.map.div;e=e.parentNode}if(!b&&d){if(c){b=0;if(!a)a=window.event;if(a.wheelDelta){b=a.wheelDelta/120;if(window.opera&&window.opera.version()<9.2)b=-b}else if(a.detail)b=
--a.detail/3;this.delta+=b;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(a)},this),this.interval)}else this.wheelZoom(a)}OpenLayers.Event.stop(a)}}},wheelZoom:function(a){var b=this.delta;this.delta=0;if(b){if(this.mousePosition)a.xy=this.mousePosition;if(!a.xy)a.xy=this.map.getPixelFromLonLat(this.map.getCenter());b<0?this.callback("down",[a,this.cumulative?b:-1]):this.callback("up",[a,this.cumulative?b:
-1])}},mousemove:function(a){this.mousePosition=a.xy},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var a=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",a);OpenLayers.Event.observe(window,"mousewheel",a);OpenLayers.Event.observe(document,"mousewheel",a);return true}else return false},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var a=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",
-a);OpenLayers.Event.stopObserving(window,"mousewheel",a);OpenLayers.Event.stopObserving(document,"mousewheel",a);return true}else return false},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});
-OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend"],RESOLUTION_PROPERTIES:["scales","resolutions","maxScale","minScale","maxResolution","minResolution","numZoomLevels","maxZoomLevel"],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,
-gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:["resize"],metadata:{},initialize:function(a,b){this.addOptions(b);this.name=a;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";
-this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);this.eventListeners instanceof Object&&this.events.on(this.eventListeners)}if(this.wrapDateLine)this.displayOutsideMaxExtent=true},destroy:function(a){if(a==null)a=true;this.map!=null&&this.map.removeLayer(this,a);this.options=this.div=this.name=this.map=this.projection=null;if(this.events){this.eventListeners&&this.events.un(this.eventListeners);this.events.destroy()}this.events=this.eventListeners=
-null},clone:function(a){if(a==null)a=new OpenLayers.Layer(this.name,this.getOptions());OpenLayers.Util.applyDefaults(a,this);a.map=null;return a},getOptions:function(){var a={},b;for(b in this.options)a[b]=this[b];return a},setName:function(a){if(a!=this.name){this.name=a;this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"name"})}},addOptions:function(a){if(this.options==null)this.options={};OpenLayers.Util.extend(this.options,a);OpenLayers.Util.extend(this,a);if(typeof this.projection==
-"string")this.projection=new OpenLayers.Projection(this.projection);if(this.projection&&this.projection.getUnits())this.units=this.projection.getUnits();if(this.map){var b=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]),c;for(c in a)if(a.hasOwnProperty(c)&&OpenLayers.Util.indexOf(b,c)>=0){this.initResolutions();break}}},onMapResize:function(){},redraw:function(){var a=false;if(this.map){this.inRange=this.calculateInRange();var b=this.getExtent();if(b&&this.inRange&&
-this.visibility){this.moveTo(b,true,false);this.events.triggerEvent("moveend",{zoomChanged:true});a=true}}return a},moveTo:function(){var a=this.visibility;this.isBaseLayer||(a=a&&this.inRange);this.display(a)},setMap:function(a){if(this.map==null){this.map=a;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string")this.projection=new OpenLayers.Projection(this.projection);
-this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();this.div.style.display=this.visibility&&this.inRange?"":"none"}this.setTileSize()}},afterAdd:function(){},removeMap:function(){},getImageSize:function(){return this.imageSize||this.tileSize},setTileSize:function(a){this.tileSize=a=a?a:this.tileSize?this.tileSize:this.map.getTileSize();if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,
--this.gutter);this.imageSize=new OpenLayers.Size(a.w+2*this.gutter,a.h+2*this.gutter)}},getVisibility:function(){return this.visibility},setVisibility:function(a){if(a!=this.visibility){this.visibility=a;this.display(a);this.redraw();this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});this.events.triggerEvent("visibilitychanged")}},display:function(a){if(a!=(this.div.style.display!="none"))this.div.style.display=a&&this.calculateInRange()?"block":"none"},
-calculateInRange:function(){var a=false;if(this.alwaysInRange)a=true;else if(this.map){a=this.map.getResolution();a=a>=this.minResolution&&a<=this.maxResolution}return a},setIsBaseLayer:function(a){if(a!=this.isBaseLayer){this.isBaseLayer=a;this.map!=null&&this.map.events.triggerEvent("changebaselayer",{layer:this})}},initResolutions:function(){var a,b,c={},d=true;a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++){var e=this.RESOLUTION_PROPERTIES[a];c[e]=this.options[e];if(d&&this.options[e])d=
-false}if(this.alwaysInRange==null)this.alwaysInRange=d;if(c.resolutions==null)c.resolutions=this.resolutionsFromScales(c.scales);if(c.resolutions==null)c.resolutions=this.calculateResolutions(c);if(c.resolutions==null){a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++){e=this.RESOLUTION_PROPERTIES[a];c[e]=this.options[e]!=null?this.options[e]:this.map[e]}if(c.resolutions==null)c.resolutions=this.resolutionsFromScales(c.scales);if(c.resolutions==null)c.resolutions=this.calculateResolutions(c)}var f;
-if(this.options.maxResolution&&this.options.maxResolution!=="auto")f=this.options.maxResolution;if(this.options.minScale)f=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);var g;if(this.options.minResolution&&this.options.minResolution!=="auto")g=this.options.minResolution;if(this.options.maxScale)g=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);if(c.resolutions){c.resolutions.sort(function(h,i){return i-h});f||(f=c.resolutions[0]);g||(g=c.resolutions[c.resolutions.length-
-1])}if(this.resolutions=c.resolutions){b=this.resolutions.length;this.scales=Array(b);for(a=0;a<b;a++)this.scales[a]=OpenLayers.Util.getScaleFromResolution(this.resolutions[a],this.units);this.numZoomLevels=b}if(this.minResolution=g)this.maxScale=OpenLayers.Util.getScaleFromResolution(g,this.units);if(this.maxResolution=f)this.minScale=OpenLayers.Util.getScaleFromResolution(f,this.units)},resolutionsFromScales:function(a){if(a!=null){var b,c,d;d=a.length;b=Array(d);for(c=0;c<d;c++)b[c]=OpenLayers.Util.getResolutionFromScale(a[c],
-this.units);return b}},calculateResolutions:function(a){var b=a.maxResolution;if(a.minScale!=null)b=OpenLayers.Util.getResolutionFromScale(a.minScale,this.units);else if(b=="auto"&&this.maxExtent!=null){var c=this.map.getSize(),d=this.maxExtent.getWidth()/c.w;c=this.maxExtent.getHeight()/c.h;b=Math.max(d,c)}d=a.minResolution;if(a.maxScale!=null)d=OpenLayers.Util.getResolutionFromScale(a.maxScale,this.units);else if(a.minResolution=="auto"&&this.minExtent!=null){c=this.map.getSize();d=this.minExtent.getWidth()/
-c.w;c=this.minExtent.getHeight()/c.h;d=Math.max(d,c)}c=a.maxZoomLevel;a=a.numZoomLevels;if(typeof d==="number"&&typeof b==="number"&&a===undefined)a=Math.floor(Math.log(b/d)/Math.log(2))+1;else if(a===undefined&&c!=null)a=c+1;if(!(typeof a!=="number"||a<=0||typeof b!=="number"&&typeof d!=="number")){c=Array(a);var e=2;if(typeof d=="number"&&typeof b=="number")e=Math.pow(b/d,1/(a-1));var f;if(typeof b==="number")for(f=0;f<a;f++)c[f]=b/Math.pow(e,f);else for(f=0;f<a;f++)c[a-1-f]=d*Math.pow(e,f);return c}},
-getResolution:function(){return this.getResolutionForZoom(this.map.getZoom())},getExtent:function(){return this.map.calculateBounds()},getZoomForExtent:function(a,b){var c=this.map.getSize();return this.getZoomForResolution(Math.max(a.getWidth()/c.w,a.getHeight()/c.h),b)},getDataExtent:function(){},getResolutionForZoom:function(a){a=Math.max(0,Math.min(a,this.resolutions.length-1));if(this.map.fractionalZoom){var b=Math.floor(a);a=this.resolutions[b]-(a-b)*(this.resolutions[b]-this.resolutions[Math.ceil(a)])}else a=
-this.resolutions[Math.round(a)];return a},getZoomForResolution:function(a,b){var c;if(this.map.fractionalZoom){var d=0,e=this.resolutions[d],f=this.resolutions[this.resolutions.length-1],g;c=0;for(var h=this.resolutions.length;c<h;++c){g=this.resolutions[c];if(g>=a){e=g;d=c}if(g<=a){f=g;break}}c=e-f;c=c>0?d+(e-a)/c:d}else{e=Number.POSITIVE_INFINITY;c=0;for(h=this.resolutions.length;c<h;c++)if(b){d=Math.abs(this.resolutions[c]-a);if(d>e)break;e=d}else if(this.resolutions[c]<a)break;c=Math.max(0,c-
-1)}return c},getLonLatFromViewPortPx:function(a){var b=null;if(a!=null){var c=this.map.getSize(),d=this.map.getCenter();if(d){b=this.map.getResolution();b=new OpenLayers.LonLat(d.lon+(a.x-c.w/2)*b,d.lat-(a.y-c.h/2)*b);if(this.wrapDateLine)b=b.wrapDateLine(this.maxExtent)}}return b},getViewPortPxFromLonLat:function(a){var b=null;if(a!=null){b=this.map.getResolution();var c=this.map.getExtent();b=new OpenLayers.Pixel(1/b*(a.lon-c.left),1/b*(c.top-a.lat))}return b},setOpacity:function(a){if(a!=this.opacity){this.opacity=
-a;for(var b=0,c=this.div.childNodes.length;b<c;++b)OpenLayers.Util.modifyDOMElement(this.div.childNodes[b].firstChild,null,null,null,null,null,null,a);this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"})}},getZIndex:function(){return this.div.style.zIndex},setZIndex:function(a){this.div.style.zIndex=a},adjustBounds:function(a){if(this.gutter){var b=this.gutter*this.map.getResolution();a=new OpenLayers.Bounds(a.left-b,a.bottom-b,a.right+b,a.top+b)}if(this.wrapDateLine){b=
-{rightTolerance:this.getResolution()};a=a.wrapDateLine(this.maxExtent,b)}return a},CLASS_NAME:"OpenLayers.Layer"});
-(function(){function a(){this._object=e&&!h?new e:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[]}function b(i){a.onreadystatechange&&a.onreadystatechange.apply(i);i.dispatchEvent({type:"readystatechange",bubbles:false,cancelable:false,timeStamp:new Date+0})}function c(i){try{i.responseText=i._object.responseText}catch(j){}try{var k;a:{var n=i._object,m=n.responseXML,l=n.responseText;if(g&&l&&m&&!m.documentElement&&n.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){m=
-new window.ActiveXObject("Microsoft.XMLDOM");m.async=false;m.validateOnParse=false;m.loadXML(l)}if(m)if(g&&m.parseError!=0||!m.documentElement||m.documentElement&&m.documentElement.tagName=="parsererror"){k=null;break a}k=m}i.responseXML=k}catch(o){}try{i.status=i._object.status}catch(p){}try{i.statusText=i._object.statusText}catch(r){}}function d(i){i._object.onreadystatechange=new window.Function}var e=window.XMLHttpRequest,f=!!window.controllers,g=window.document.all&&!window.opera,h=g&&window.navigator.userAgent.match(/MSIE ([\.0-9]+)/)&&
-RegExp.$1==7;if(f&&e.wrapped)a.wrapped=e.wrapped;a.UNSENT=0;a.OPENED=1;a.HEADERS_RECEIVED=2;a.LOADING=3;a.DONE=4;a.prototype.readyState=a.UNSENT;a.prototype.responseText="";a.prototype.responseXML=null;a.prototype.status=0;a.prototype.statusText="";a.prototype.onreadystatechange=null;a.onreadystatechange=null;a.onopen=null;a.onsend=null;a.onabort=null;a.prototype.open=function(i,j,k,n,m){delete this._headers;if(arguments.length<3)k=true;this._async=k;var l=this,o=this.readyState,p;if(g&&k){p=function(){if(o!=
-a.DONE){d(l);l.abort()}};window.attachEvent("onunload",p)}a.onopen&&a.onopen.apply(this,arguments);if(arguments.length>4)this._object.open(i,j,k,n,m);else arguments.length>3?this._object.open(i,j,k,n):this._object.open(i,j,k);if(!f&&!g){this.readyState=a.OPENED;b(this)}this._object.onreadystatechange=function(){if(!(f&&!k)){l.readyState=l._object.readyState;c(l);if(l._aborted)l.readyState=a.UNSENT;else{if(l.readyState==a.DONE){d(l);g&&k&&window.detachEvent("onunload",p)}o!=l.readyState&&b(l);o=l.readyState}}}};
-a.prototype.send=function(i){a.onsend&&a.onsend.apply(this,arguments);if(i&&i.nodeType){i=window.XMLSerializer?(new window.XMLSerializer).serializeToString(i):i.xml;this._headers["Content-Type"]||this._object.setRequestHeader("Content-Type","application/xml")}this._object.send(i);if(f&&!this._async){this.readyState=a.OPENED;for(c(this);this.readyState<a.DONE;){this.readyState++;b(this);if(this._aborted)break}}};a.prototype.abort=function(){a.onabort&&a.onabort.apply(this,arguments);if(this.readyState>
-a.UNSENT)this._aborted=true;this._object.abort();d(this)};a.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders()};a.prototype.getResponseHeader=function(i){return this._object.getResponseHeader(i)};a.prototype.setRequestHeader=function(i,j){if(!this._headers)this._headers={};this._headers[i]=j;return this._object.setRequestHeader(i,j)};a.prototype.addEventListener=function(i,j,k){for(var n=0,m;m=this._listeners[n];n++)if(m[0]==i&&m[1]==j&&m[2]==k)return;this._listeners.push([i,
-j,k])};a.prototype.removeEventListener=function(i,j,k){for(var n=0,m;m=this._listeners[n];n++)if(m[0]==i&&m[1]==j&&m[2]==k)break;m&&this._listeners.splice(n,1)};a.prototype.dispatchEvent=function(i){i={type:i.type,target:this,currentTarget:this,eventPhase:2,bubbles:i.bubbles,cancelable:i.cancelable,timeStamp:i.timeStamp,stopPropagation:function(){},preventDefault:function(){},initEvent:function(){}};if(i.type=="readystatechange"&&this.onreadystatechange)(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,
-[i]);for(var j=0,k;k=this._listeners[j];j++)if(k[0]==i.type&&!k[2])(k[1].handleEvent||k[1]).apply(this,[i])};a.prototype.toString=function(){return"[object XMLHttpRequest]"};a.toString=function(){return"[XMLHttpRequest]"};if(!window.Function.prototype.apply)window.Function.prototype.apply=function(i,j){j||(j=[]);i.__func=this;i.__func(j[0],j[1],j[2],j[3],j[4]);delete i.__func};OpenLayers.Request.XMLHttpRequest=a})();OpenLayers.ProxyHost="";
-OpenLayers.nullHandler=function(a){OpenLayers.Console.userError(OpenLayers.i18n("unhandledRequest",{statusText:a.statusText}))};OpenLayers.loadURL=function(a,b,c,d,e){if(typeof b=="string")b=OpenLayers.Util.getParameters(b);return OpenLayers.Request.GET({url:a,params:b,success:d?d:OpenLayers.nullHandler,failure:e?e:OpenLayers.nullHandler,scope:c})};
-OpenLayers.parseXMLString=function(a){var b=a.indexOf("<");if(b>0)a=a.substring(b);return OpenLayers.Util.Try(function(){var c=new ActiveXObject("Microsoft.XMLDOM");c.loadXML(a);return c},function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var c=new XMLHttpRequest;c.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),false);c.overrideMimeType&&c.overrideMimeType("text/xml");c.send(null);return c.responseXML})};
-OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest},function(){return new ActiveXObject("Msxml2.XMLHTTP")},function(){return new ActiveXObject("Microsoft.XMLHTTP")})||false},activeRequestCount:0};
-OpenLayers.Ajax.Responders={responders:[],register:function(a){for(var b=0;b<this.responders.length;b++)if(a==this.responders[b])return;this.responders.push(a)},unregister:function(a){OpenLayers.Util.removeItem(this.reponders,a)},dispatch:function(a,b,c){for(var d,e=0;e<this.responders.length;e++){d=this.responders[e];if(d[a]&&typeof d[a]=="function")try{d[a].apply(d,[b,c])}catch(f){}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++},onComplete:function(){OpenLayers.Ajax.activeRequestCount--}});
-OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(a){this.options={method:"post",asynchronous:true,contentType:"application/xml",parameters:""};OpenLayers.Util.extend(this.options,a||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=="string")this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters)}});
-OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(a,b){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[b]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(a,"http"))a=OpenLayers.ProxyHost+encodeURIComponent(a);this.transport=OpenLayers.Ajax.getTransport();this.request(a)},request:function(a){this.url=a;this.method=this.options.method;a=OpenLayers.Util.extend({},this.options.parameters);if(this.method!="get"&&this.method!="post"){a._method=
-this.method;this.method="post"}this.parameters=a;if(a=OpenLayers.Util.getParameterString(a))if(this.method=="get")this.url+=(this.url.indexOf("?")>-1?"&":"?")+a;else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent))a+="&_=";try{var b=new OpenLayers.Ajax.Response(this);this.options.onCreate&&this.options.onCreate(b);OpenLayers.Ajax.Responders.dispatch("onCreate",this,b);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);this.options.asynchronous&&window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,
-this,1),10);this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=="post"?this.options.postBody||a:null;this.transport.send(this.body);!this.options.asynchronous&&this.transport.overrideMimeType&&this.onStateChange()}catch(c){this.dispatchException(c)}},onStateChange:function(){var a=this.transport.readyState;a>1&&!(a==4&&this._complete)&&this.respondToReadyState(this.transport.readyState)},setRequestHeaders:function(){var a=
-{"X-Requested-With":"XMLHttpRequest",Accept:"text/javascript, text/html, application/xml, text/xml, */*",OpenLayers:true};if(this.method=="post"){a["Content-type"]=this.options.contentType+(this.options.encoding?"; charset="+this.options.encoding:"");if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005)a.Connection="close"}if(typeof this.options.requestHeaders=="object"){var b=this.options.requestHeaders;if(typeof b.push=="function")for(var c=0,d=b.length;c<
-d;c+=2)a[b[c]]=b[c+1];else for(c in b)a[c]=b[c]}for(var e in a)this.transport.setRequestHeader(e,a[e])},success:function(){var a=this.getStatus();return!a||a>=200&&a<300},getStatus:function(){try{return this.transport.status||0}catch(a){return 0}},respondToReadyState:function(a){a=OpenLayers.Ajax.Request.Events[a];var b=new OpenLayers.Ajax.Response(this);if(a=="Complete"){try{this._complete=true;(this.options["on"+b.status]||this.options["on"+(this.success()?"Success":"Failure")]||OpenLayers.Ajax.emptyFunction)(b)}catch(c){this.dispatchException(c)}b.getHeader("Content-type")}try{(this.options["on"+
-a]||OpenLayers.Ajax.emptyFunction)(b);OpenLayers.Ajax.Responders.dispatch("on"+a,this,b)}catch(d){this.dispatchException(d)}if(a=="Complete")this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction},getHeader:function(a){try{return this.transport.getResponseHeader(a)}catch(b){return null}},dispatchException:function(a){var b=this.options.onException;if(b){b(this,a);OpenLayers.Ajax.Responders.dispatch("onException",this,a)}else{b=false;for(var c=OpenLayers.Ajax.Responders.responders,d=0;d<c.length;d++)if(c[d].onException){b=
-true;break}if(b)OpenLayers.Ajax.Responders.dispatch("onException",this,a);else throw a;}}});OpenLayers.Ajax.Request.Events=["Uninitialized","Loading","Loaded","Interactive","Complete"];
-OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:"",initialize:function(a){this.request=a;a=this.transport=a.transport;var b=this.readyState=a.readyState;if(b>2&&!(window.attachEvent&&!window.opera)||b==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=a.responseText==null?"":String(a.responseText)}if(b==4){a=a.responseXML;this.responseXML=a===undefined?null:a}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||
-""}catch(a){return""}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(a){return this.transport.getResponseHeader(a)}});OpenLayers.Ajax.getElementsByTagNameNS=function(a,b,c,d){var e=null;return e=a.getElementsByTagNameNS?a.getElementsByTagNameNS(b,d):a.getElementsByTagName(c+":"+d)};OpenLayers.Ajax.serializeXMLToString=function(a){return(new XMLSerializer).serializeToString(a)};
-OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{move:this.panMap,done:this.panMapDone},{interval:this.interval,documentDrag:this.documentDrag})},panMap:function(a){this.panned=true;this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:this.handler.dragging,animate:false})},panMapDone:function(a){if(this.panned){this.panMap(a);
-this.panned=false}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.State={UNKNOWN:"Unknown",INSERT:"Insert",UPDATE:"Update",DELETE:"Delete"};
-OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",initialize:function(a,b,c){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,b]);this.lonlat=null;this.geometry=a?a:null;this.state=null;this.attributes={};if(b)this.attributes=OpenLayers.Util.extend(this.attributes,b);this.style=c?c:null},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null}this.geometry=
-null;OpenLayers.Feature.prototype.destroy.apply(this,arguments)},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style)},onScreen:function(a){var b=false;if(this.layer&&this.layer.map){b=this.layer.map.getExtent();if(a){a=this.geometry.getBounds();b=b.intersectsBounds(a)}else b=b.toGeometry().intersects(this.geometry)}return b},getVisibility:function(){return!(this.style&&this.style.display=="none"||!this.layer||this.layer&&this.layer.styleMap&&
-this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=="none"||this.layer&&!this.layer.getVisibility())},createMarker:function(){return null},destroyMarker:function(){},createPopup:function(){return null},atPoint:function(a,b,c){var d=false;if(this.geometry)d=this.geometry.atPoint(a,b,c);return d},destroyPopup:function(){},move:function(a){if(this.layer&&this.geometry.move){a=a.CLASS_NAME=="OpenLayers.LonLat"?this.layer.getViewPortPxFromLonLat(a):a;var b=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat()),
-c=this.layer.map.getResolution();this.geometry.move(c*(a.x-b.x),c*(b.y-a.y));this.layer.drawFeature(this);return b}},toState:function(a){if(a==OpenLayers.State.UPDATE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=a}else if(a==OpenLayers.State.INSERT)switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=a}else if(a==OpenLayers.State.DELETE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=a}else if(a==
-OpenLayers.State.UNKNOWN)this.state=a},CLASS_NAME:"OpenLayers.Feature.Vector"});
-OpenLayers.Feature.Vector.style={"default":{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},select:{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,
-strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},temporary:{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,
-hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},"delete":{display:"none"}};OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.0",xlink:"http://www.w3.org/1999/xlink"},readers:{ows:OpenLayers.Format.OWSCommon.v1.prototype.readers.ows},writers:{ows:OpenLayers.Format.OWSCommon.v1.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});
-OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:"olHandlerBoxZoomBox",boxCharacteristics:null,initialize:function(a,b){OpenLayers.Handler.prototype.initialize.apply(this,arguments);b={down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,b,{keyMask:this.keyMask})},destroy:function(){if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null}OpenLayers.Handler.prototype.destroy.apply(this,
-arguments)},setMap:function(a){OpenLayers.Handler.prototype.setMap.apply(this,arguments);this.dragHandler&&this.dragHandler.setMap(a)},startBox:function(){this.zoomBox=OpenLayers.Util.createDiv("zoomBox",this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox")},moveBox:function(a){var b=this.dragHandler.start.x,c=this.dragHandler.start.y,
-d=Math.abs(b-a.x),e=Math.abs(c-a.y);this.zoomBox.style.width=Math.max(1,d)+"px";this.zoomBox.style.height=Math.max(1,e)+"px";this.zoomBox.style.left=a.x<b?a.x+"px":b+"px";this.zoomBox.style.top=a.y<c?a.y+"px":c+"px";var f=this.getBoxCharacteristics();if(f.newBoxModel){if(a.x>b)this.zoomBox.style.width=Math.max(1,d-f.xOffset)+"px";if(a.y>c)this.zoomBox.style.height=Math.max(1,e-f.yOffset)+"px"}},endBox:function(a){if(Math.abs(this.dragHandler.start.x-a.x)>5||Math.abs(this.dragHandler.start.y-a.y)>
-5){var b=this.dragHandler.start;a=new OpenLayers.Bounds(Math.min(b.x,a.x),Math.max(b.y,a.y),Math.max(b.x,a.x),Math.min(b.y,a.y))}else a=this.dragHandler.start.clone();this.removeBox();this.callback("done",[a])},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.boxCharacteristics=this.zoomBox=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox")},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true}else return false},
-deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true}else return false},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var a=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1,b=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+
-1;this.boxCharacteristics={xOffset:a,yOffset:b,newBoxModel:OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompat":true}}return this.boxCharacteristics},CLASS_NAME:"OpenLayers.Handler.Box"});
-OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:"shiftKey",layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(a,b,c){if(!(c&&c.layerOptions&&c.layerOptions.styleMap))this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style["default"],{});OpenLayers.Handler.prototype.initialize.apply(this,[a,b,c]);this.options=c?c:{}},setOptions:function(a){OpenLayers.Util.extend(this.options,
-a);OpenLayers.Util.extend(this,a)},activate:function(){var a=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){a=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,a);this.map.addLayer(this.layer);a=true}return a},deactivate:function(){var a=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){this.dragging&&this.cancel();if(this.layer.map!=
-null){this.layer.destroy(false);this.feature&&this.feature.destroy()}this.feature=this.layer=null;a=true}return a},down:function(a){this.fixedRadius=!!this.radius;a=this.map.getLonLatFromPixel(a.xy);this.origin=new OpenLayers.Geometry.Point(a.lon,a.lat);if(!this.fixedRadius||this.irregular)this.radius=this.map.getResolution();this.persist&&this.clear();this.feature=new OpenLayers.Feature.Vector;this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],
-{silent:true});this.layer.drawFeature(this.feature,this.style)},move:function(a){var b=this.map.getLonLatFromPixel(a.xy);b=new OpenLayers.Geometry.Point(b.lon,b.lat);if(this.irregular){a=Math.sqrt(2)*Math.abs(b.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,a)}else if(this.fixedRadius)this.origin=b;else{this.calculateAngle(b,a);this.radius=Math.max(this.map.getResolution()/2,b.distanceTo(this.origin))}this.modifyGeometry();if(this.irregular){a=b.x-this.origin.x;b=b.y-this.origin.y;
-this.feature.geometry.resize(1,this.origin,b==0?a/(this.radius*Math.sqrt(2)):a/b);this.feature.geometry.move(a/2,b/2)}this.layer.drawFeature(this.feature,this.style)},up:function(a){this.finalize();this.start==this.last&&this.callback("done",[a.xy])},out:function(){this.finalize()},createGeometry:function(){this.angle=Math.PI*(1/this.sides-0.5);if(this.snapAngle)this.angle+=this.snapAngle*(Math.PI/180);this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,
-this.sides,this.snapAngle)},modifyGeometry:function(){var a,b,c=this.feature.geometry.components[0];if(c.components.length!=this.sides+1){this.createGeometry();c=this.feature.geometry.components[0]}for(var d=0;d<this.sides;++d){b=c.components[d];a=this.angle+d*2*Math.PI/this.sides;b.x=this.origin.x+this.radius*Math.cos(a);b.y=this.origin.y+this.radius*Math.sin(a);b.clearBounds()}},calculateAngle:function(a,b){var c=Math.atan2(a.y-this.origin.y,a.x-this.origin.x);if(this.snapAngle&&this.snapToggle&&
-!b[this.snapToggle]){var d=Math.PI/180*this.snapAngle;this.angle=Math.round(c/d)*d}else this.angle=c},cancel:function(){this.callback("cancel",null);this.finalize()},finalize:function(){this.origin=null;this.radius=this.options.radius},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures()}},callback:function(a){this.callbacks[a]&&this.callbacks[a].apply(this.control,[this.feature.geometry.clone()]);if(!this.persist&&(a=="done"||a=="cancel"))this.clear()},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});
-OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(a,b,c,d){var e=arguments;e=[a,d];OpenLayers.Layer.prototype.initialize.apply(this,e);this.url=b;this.params=OpenLayers.Util.extend({},c)},destroy:function(){this.params=this.url=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){if(a==null)a=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());
-return a=OpenLayers.Layer.prototype.clone.apply(this,[a])},setUrl:function(a){this.url=a},mergeNewParams:function(a){this.params=OpenLayers.Util.extend(this.params,a);a=this.redraw();this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});return a},redraw:function(a){return a?this.mergeNewParams({_olSalt:Math.random()}):OpenLayers.Layer.prototype.redraw.apply(this,[])},selectUrl:function(a,b){for(var c=1,d=0,e=a.length;d<e;d++){c*=a.charCodeAt(d)*this.URL_HASH_FACTOR;
-c-=Math.floor(c)}return b[Math.floor(c*b.length)]},getFullRequestString:function(a,b){var c=b||this.url,d=OpenLayers.Util.extend({},this.params);d=OpenLayers.Util.extend(d,a);var e=OpenLayers.Util.getParameterString(d);if(c instanceof Array)c=this.selectUrl(e,c);e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c));for(var f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);return OpenLayers.Util.urlAppend(c,e)},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});
-OpenLayers.Layer.SphericalMercator={getExtent:function(){var a=null;return a=this.sphericalMercator?this.map.calculateBounds():OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this)},getLonLatFromViewPortPx:function(){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments)},getViewPortPxFromLonLat:function(){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments)},initMercatorParameters:function(){this.RESOLUTIONS=[];for(var a=0;a<=this.MAX_ZOOM_LEVEL;++a)this.RESOLUTIONS[a]=
-156543.0339/Math.pow(2,a);this.units="m";this.projection=this.projection||"EPSG:900913"},forwardMercator:function(a,b){var c=a*2.003750834E7/180,d=Math.log(Math.tan((90+b)*Math.PI/360))/(Math.PI/180);d=d*2.003750834E7/180;return new OpenLayers.LonLat(c,d)},inverseMercator:function(a,b){var c=a/2.003750834E7*180,d=b/2.003750834E7*180;d=180/Math.PI*(2*Math.atan(Math.exp(d*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(c,d)},projectForward:function(a){var b=OpenLayers.Layer.SphericalMercator.forwardMercator(a.x,
-a.y);a.x=b.lon;a.y=b.lat;return a},projectInverse:function(a){var b=OpenLayers.Layer.SphericalMercator.inverseMercator(a.x,a.y);a.x=b.lon;a.y=b.lat;return a}};(function(){var a=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"],b=OpenLayers.Projection.addTransform,c=OpenLayers.Layer.SphericalMercator,d=OpenLayers.Projection.nullTransform,e,f,g,h,i;e=0;for(f=a.length;e<f;++e){g=a[e];b("EPSG:4326",g,c.projectForward);b(g,"EPSG:4326",c.projectInverse);for(i=e+1;i<f;++i){h=a[i];b(g,h,d);b(h,g,d)}}})();
-OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"],multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(a,b,c){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[c]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(d,e){this.layer.events.triggerEvent("sketchmodified",
-{vertex:d,feature:e})},create:function(d,e){this.layer.events.triggerEvent("sketchstarted",{vertex:d,feature:e})}},this.callbacks);this.layer=a;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions))this.handlerOptions.multi=this.multi;if(a=this.layer.styleMap&&this.layer.styleMap.styles.temporary)this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":a})});this.handler=new b(this,this.callbacks,
-this.handlerOptions)},drawFeature:function(a){a=new OpenLayers.Feature.Vector(a);if(this.layer.events.triggerEvent("sketchcomplete",{feature:a})!==false){a.state=OpenLayers.State.INSERT;this.layer.addFeatures([a]);this.featureAdded(a);this.events.triggerEvent("featureadded",{feature:a})}},CLASS_NAME:"OpenLayers.Control.DrawFeature"});
-OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask})},zoomBox:function(a){if(a instanceof OpenLayers.Bounds){var b;if(this.out){b=Math.min(this.map.size.h/Math.abs(a.top-a.bottom),this.map.size.w/Math.abs(a.right-a.left));var c=this.map.getExtent(),d=this.map.getLonLatFromPixel(a.getCenterPixel());a=d.lon-c.getWidth()/2*b;
-var e=d.lon+c.getWidth()/2*b,f=d.lat-c.getHeight()/2*b;b=d.lat+c.getHeight()/2*b;b=new OpenLayers.Bounds(a,f,e,b)}else{b=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.left,a.bottom));c=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.right,a.top));b=new OpenLayers.Bounds(b.lon,b.lat,c.lon,c.lat)}c=this.map.getZoom();this.map.zoomToExtent(b);if(c==this.map.getZoom()&&this.alwaysZoom==true)this.map.zoomTo(c+(this.out?-1:1))}else this.out?this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()-
-1):this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()+1)},CLASS_NAME:"OpenLayers.Control.ZoomBox"});
-OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(a){this.regExes={typeStr:/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,spaces:/\s+/,parenComma:/\)\s*,\s*\(/,doubleParenComma:/\)\s*\)\s*,\s*\(\s*\(/,trimParens:/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){var b,c;if(c=this.regExes.typeStr.exec(a)){a=c[1].toLowerCase();c=c[2];if(this.parse[a])b=this.parse[a].apply(this,[c]);if(this.internalProjection&&this.externalProjection)if(b&&b.CLASS_NAME==
-"OpenLayers.Feature.Vector")b.geometry.transform(this.externalProjection,this.internalProjection);else if(b&&a!="geometrycollection"&&typeof b=="object"){a=0;for(c=b.length;a<c;a++)b[a].geometry.transform(this.externalProjection,this.internalProjection)}}return b},write:function(a){var b,c,d;if(a.constructor==Array){a=a;d=true}else{a=[a];d=false}var e=[];d&&e.push("GEOMETRYCOLLECTION(");for(var f=0,g=a.length;f<g;++f){d&&f>0&&e.push(",");b=a[f].geometry;c=b.CLASS_NAME.split(".")[2].toLowerCase();
-if(!this.extract[c])return null;if(this.internalProjection&&this.externalProjection){b=b.clone();b.transform(this.internalProjection,this.externalProjection)}b=this.extract[c].apply(this,[b]);e.push(c.toUpperCase()+"("+b+")")}d&&e.push(")");return e.join("")},extract:{point:function(a){return a.x+" "+a.y},multipoint:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.point.apply(this,[a.components[c]])+")");return b.join(",")},linestring:function(a){for(var b=[],c=0,
-d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b.join(",")},multilinestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},polygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},multipolygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+
-this.extract.polygon.apply(this,[a.components[c]])+")");return b.join(",")}},parse:{point:function(a){a=OpenLayers.String.trim(a).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(a[0],a[1]))},multipoint:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.parenComma),c=[],d=0,e=b.length;d<e;++d){a=b[d].replace(this.regExes.trimParens,"$1");c.push(this.parse.point.apply(this,[a]).geometry)}return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(c))},
-linestring:function(a){a=OpenLayers.String.trim(a).split(",");for(var b=[],c=0,d=a.length;c<d;++c)b.push(this.parse.point.apply(this,[a[c]]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(b))},multilinestring:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.parenComma),c=[],d=0,e=b.length;d<e;++d){a=b[d].replace(this.regExes.trimParens,"$1");c.push(this.parse.linestring.apply(this,[a]).geometry)}return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(c))},
-polygon:function(a){var b;a=OpenLayers.String.trim(a).split(this.regExes.parenComma);for(var c=[],d=0,e=a.length;d<e;++d){b=a[d].replace(this.regExes.trimParens,"$1");b=this.parse.linestring.apply(this,[b]).geometry;b=new OpenLayers.Geometry.LinearRing(b.components);c.push(b)}return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(c))},multipolygon:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.doubleParenComma),c=[],d=0,e=b.length;d<e;++d){a=b[d].replace(this.regExes.trimParens,
-"$1");c.push(this.parse.polygon.apply(this,[a]).geometry)}return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(c))},geometrycollection:function(a){a=a.replace(/,\s*([A-Za-z])/g,"|$1");a=OpenLayers.String.trim(a).split("|");for(var b=[],c=0,d=a.length;c<d;++c)b.push(OpenLayers.Format.WKT.prototype.read.apply(this,[a[c]]));return b}},CLASS_NAME:"OpenLayers.Format.WKT"});
-OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[]},destroy:function(){this.clearGrid();this.tileSize=this.grid=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments)},clearGrid:function(){if(this.grid){for(var a=0,b=this.grid.length;a<
-b;a++)for(var c=this.grid[a],d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}this.grid=[]}},clone:function(a){if(a==null)a=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());a=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[a]);if(this.tileSize!=null)a.tileSize=this.tileSize.clone();a.grid=[];return a},moveTo:function(a,b,c){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);a=a||this.map.getExtent();if(a!=null){var d=
-!this.grid.length||b,e=this.getTilesBounds();if(this.singleTile){if(d||!c&&!e.containsBounds(a))this.initSingleTile(a)}else d||!e.containsBounds(a,true)?this.initGriddedTiles(a):this.moveGriddedTiles(a)}},setTileSize:function(a){if(this.singleTile){a=this.map.getSize();a.h=parseInt(a.h*this.ratio);a.w=parseInt(a.w*this.ratio)}OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[a])},getGridBounds:function(){OpenLayers.Console.warn("The getGridBounds() function is deprecated. It will be removed in 3.0. Please use getTilesBounds() instead.");
-return this.getTilesBounds()},getTilesBounds:function(){var a=null;if(this.grid.length){a=this.grid[this.grid.length-1][0];var b=this.grid[0][this.grid[0].length-1];a=new OpenLayers.Bounds(a.bounds.left,a.bounds.bottom,b.bounds.right,b.bounds.top)}return a},initSingleTile:function(a){var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio;a=a.getHeight()*this.ratio;b=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2);c=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(b.left,b.top));this.grid.length||
-(this.grid[0]=[]);if(a=this.grid[0][0])a.moveTo(b,c);else{a=this.addTile(b,c);this.addTileMonitoringHooks(a);a.draw();this.grid[0][0]=a}this.removeExcessTiles(1,1)},calculateGridLayout:function(a,b,c){var d=c*this.tileSize.w;c=c*this.tileSize.h;var e=a.left-b.left,f=Math.floor(e/d)-this.buffer;a=a.top-(b.bottom+c);var g=Math.ceil(a/c)+this.buffer;return{tilelon:d,tilelat:c,tileoffsetlon:b.left+f*d,tileoffsetlat:b.bottom+g*c,tileoffsetx:-(e/d-f)*this.tileSize.w,tileoffsety:-(g-a/c)*this.tileSize.h}},
-initGriddedTiles:function(a){var b=this.map.getSize(),c=Math.ceil(b.h/this.tileSize.h)+Math.max(1,2*this.buffer);b=Math.ceil(b.w/this.tileSize.w)+Math.max(1,2*this.buffer);var d=this.getMaxExtent(),e=this.map.getResolution(),f=this.calculateGridLayout(a,d,e);d=Math.round(f.tileoffsetx);e=Math.round(f.tileoffsety);var g=f.tileoffsetlon,h=f.tileoffsetlat,i=f.tilelon;f=f.tilelat;this.origin=new OpenLayers.Pixel(d,e);var j=d,k=g,n=0,m=parseInt(this.map.layerContainerDiv.style.left),l=parseInt(this.map.layerContainerDiv.style.top);
-do{var o=this.grid[n++];if(!o){o=[];this.grid.push(o)}g=k;d=j;var p=0;do{var r=new OpenLayers.Bounds(g,h,g+i,h+f),q=d;q-=m;var s=e;s-=l;q=new OpenLayers.Pixel(q,s);if(s=o[p++])s.moveTo(r,q,false);else{s=this.addTile(r,q);this.addTileMonitoringHooks(s);o.push(s)}g+=i;d+=this.tileSize.w}while(g<=a.right+i*this.buffer||p<b);h-=f;e+=this.tileSize.h}while(h>=a.bottom-f*this.buffer||n<c);this.removeExcessTiles(n,p);this.spiralTileLoad()},getMaxExtent:function(){return this.maxExtent},spiralTileLoad:function(){for(var a=
-[],b=["right","down","left","up"],c=0,d=-1,e=OpenLayers.Util.indexOf(b,"right"),f=0;f<b.length;){var g=c,h=d;switch(b[e]){case "right":h++;break;case "down":g++;break;case "left":h--;break;case "up":g--}var i=null;if(g<this.grid.length&&g>=0&&h<this.grid[0].length&&h>=0)i=this.grid[g][h];if(i!=null&&!i.queued){a.unshift(i);i.queued=true;f=0;c=g;d=h}else{e=(e+1)%4;f++}}b=0;for(c=a.length;b<c;b++){i=a[b];i.draw();i.queued=false}},addTile:function(){},addTileMonitoringHooks:function(a){a.onLoadStart=
-function(){this.numLoadingTiles==0&&this.events.triggerEvent("loadstart");this.numLoadingTiles++};a.events.register("loadstart",this,a.onLoadStart);a.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");this.numLoadingTiles==0&&this.events.triggerEvent("loadend")};a.events.register("loadend",this,a.onLoadEnd);a.events.register("unload",this,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,
-scope:this})},moveGriddedTiles:function(){for(var a=this.buffer||1;;){var b=this.map.getViewPortPxFromLayerPx(this.grid[0][0].position);if(b.x>-this.tileSize.w*(a-1))this.shiftColumn(true);else if(b.x<-this.tileSize.w*a)this.shiftColumn(false);else if(b.y>-this.tileSize.h*(a-1))this.shiftRow(true);else if(b.y<-this.tileSize.h*a)this.shiftRow(false);else break}},shiftRow:function(a){var b=this.grid,c=b[a?0:this.grid.length-1],d=this.map.getResolution(),e=a?-this.tileSize.h:this.tileSize.h;d=d*-e;for(var f=
-a?b.pop():b.shift(),g=0,h=c.length;g<h;g++){var i=c[g],j=i.bounds.clone();i=i.position.clone();j.bottom+=d;j.top+=d;i.y+=e;f[g].moveTo(j,i)}a?b.unshift(f):b.push(f)},shiftColumn:function(a){for(var b=a?-this.tileSize.w:this.tileSize.w,c=this.map.getResolution()*b,d=0,e=this.grid.length;d<e;d++){var f=this.grid[d],g=f[a?0:f.length-1],h=g.bounds.clone();g=g.position.clone();h.left+=c;h.right+=c;g.x+=b;var i=a?this.grid[d].pop():this.grid[d].shift();i.moveTo(h,g);a?f.unshift(i):f.push(i)}},removeExcessTiles:function(a,
-b){for(;this.grid.length>a;)for(var c=this.grid.pop(),d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}for(;this.grid[0].length>b;){d=0;for(e=this.grid.length;d<e;d++){c=this.grid[d];f=c.pop();this.removeTileMonitoringHooks(f);f.destroy()}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize()}},getTileBounds:function(a){var b=this.maxExtent,c=this.getResolution(),d=c*this.tileSize.w;c=c*this.tileSize.h;var e=this.getLonLatFromViewPortPx(a);
-a=b.left+d*Math.floor((e.lon-b.left)/d);b=b.bottom+c*Math.floor((e.lat-b.bottom)/c);return new OpenLayers.Bounds(a,b,a+d,b+c)},CLASS_NAME:"OpenLayers.Layer.Grid"});
-OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.rules=[];b&&b.rules&&this.addRules(b.rules);this.setDefaultStyle(a||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a=0,b=this.rules.length;a<b;a++){this.rules[a].destroy();
-this.rules[a]=null}this.defaultStyle=this.rules=null},createSymbolizer:function(a){for(var b=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),a),c=this.rules,d,e=[],f=false,g=0,h=c.length;g<h;g++){d=c[g];if(d.evaluate(a))if(d instanceof OpenLayers.Rule&&d.elseFilter)e.push(d);else{f=true;this.applySymbolizer(d,b,a)}}if(f==false&&e.length>0){f=true;g=0;for(h=e.length;g<h;g++)this.applySymbolizer(e[g],b,a)}if(c.length>0&&f==false)b.display="none";return b},
-applySymbolizer:function(a,b,c){var d=c.geometry?this.getSymbolizerPrefix(c.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];a=a.symbolizer[d]||a.symbolizer;if(this.defaultsPerSymbolizer===true){d=this.defaultStyle;OpenLayers.Util.applyDefaults(a,{pointRadius:d.pointRadius});if(a.stroke===true||a.graphic===true)OpenLayers.Util.applyDefaults(a,{strokeWidth:d.strokeWidth,strokeColor:d.strokeColor,strokeOpacity:d.strokeOpacity,strokeDashstyle:d.strokeDashstyle,strokeLinecap:d.strokeLinecap});if(a.fill===
-true||a.graphic===true)OpenLayers.Util.applyDefaults(a,{fillColor:d.fillColor,fillOpacity:d.fillOpacity});a.graphic===true&&OpenLayers.Util.applyDefaults(a,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset})}return this.createLiterals(OpenLayers.Util.extend(b,
-a),c)},createLiterals:function(a,b){var c=OpenLayers.Util.extend({},b.attributes||b.data);OpenLayers.Util.extend(c,this.context);for(var d in this.propertyStyles)a[d]=OpenLayers.Style.createLiteral(a[d],c,b,d);return a},findPropertyStyles:function(){var a={};this.addPropertyStyles(a,this.defaultStyle);for(var b=this.rules,c,d,e=0,f=b.length;e<f;e++){c=b[e].symbolizer;for(var g in c){d=c[g];if(typeof d=="object")this.addPropertyStyles(a,d);else{this.addPropertyStyles(a,c);break}}}return a},addPropertyStyles:function(a,
-b){var c,d;for(d in b){c=b[d];if(typeof c=="string"&&c.match(/\$\{\w+\}/))a[d]=true}return a},addRules:function(a){Array.prototype.push.apply(this.rules,a);this.propertyStyles=this.findPropertyStyles()},setDefaultStyle:function(a){this.defaultStyle=a;this.propertyStyles=this.findPropertyStyles()},getSymbolizerPrefix:function(a){for(var b=OpenLayers.Style.SYMBOLIZER_PREFIXES,c=0,d=b.length;c<d;c++)if(a.CLASS_NAME.indexOf(b[c])!=-1)return b[c]},clone:function(){var a=OpenLayers.Util.extend({},this);
-if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}a.context=this.context&&OpenLayers.Util.extend({},this.context);b=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(b,a)},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(a,b,c,d){if(typeof a=="string"&&a.indexOf("${")!=-1){a=OpenLayers.String.format(a,b,[c,d]);a=isNaN(a)||!a?a:parseFloat(a)}return a};
-OpenLayers.Style.SYMBOLIZER_PREFIXES=["Point","Line","Polygon","Text","Raster"];OpenLayers.Filter=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},destroy:function(){},evaluate:function(){return true},clone:function(){return null},CLASS_NAME:"OpenLayers.Filter"});
-OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.bounds=this.id=null},clone:function(){return new OpenLayers.Geometry},setBounds:function(a){if(a)this.bounds=a.clone()},clearBounds:function(){this.bounds=null;this.parent&&this.parent.clearBounds()},extendBounds:function(a){this.getBounds()?this.bounds.extend(a):this.setBounds(a)},getBounds:function(){this.bounds==null&&this.calculateBounds();
-return this.bounds},calculateBounds:function(){},distanceTo:function(){},getVertices:function(){},atPoint:function(a,b,c){var d=false;if(this.getBounds()!=null&&a!=null){b=b!=null?b:0;c=c!=null?c:0;d=(new OpenLayers.Bounds(this.bounds.left-b,this.bounds.bottom-c,this.bounds.right+b,this.bounds.top+c)).containsLonLat(a)}return d},getLength:function(){return 0},getArea:function(){return 0},getCentroid:function(){return null},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this))},
-CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(a){var b=arguments.callee.format;if(!b){b=new OpenLayers.Format.WKT;arguments.callee.format=b}var c;b=b.read(a);if(b instanceof OpenLayers.Feature.Vector)c=b.geometry;else if(b instanceof Array){c=b.length;for(var d=Array(c),e=0;e<c;++e)d[e]=b[e].geometry;c=new OpenLayers.Geometry.Collection(d)}return c};
-OpenLayers.Geometry.segmentsIntersect=function(a,b,c){var d=c&&c.point;c=c&&c.tolerance;var e=false,f=a.x1-b.x1,g=a.y1-b.y1,h=a.x2-a.x1,i=a.y2-a.y1,j=b.y2-b.y1,k=b.x2-b.x1,n=j*h-k*i;j=k*g-j*f;g=h*g-i*f;if(n==0){if(j==0&&g==0)e=true}else{f=j/n;n=g/n;if(f>=0&&f<=1&&n>=0&&n<=1)if(d){h=a.x1+f*h;n=a.y1+f*i;e=new OpenLayers.Geometry.Point(h,n)}else e=true}if(c)if(e){if(d){a=[a,b];b=0;a:for(;b<2;++b){f=a[b];for(i=1;i<3;++i){h=f["x"+i];n=f["y"+i];d=Math.sqrt(Math.pow(h-e.x,2)+Math.pow(n-e.y,2));if(d<c){e.x=
-h;e.y=n;break a}}}}}else{a=[a,b];b=0;a:for(;b<2;++b){h=a[b];n=a[(b+1)%2];for(i=1;i<3;++i){f={x:h["x"+i],y:h["y"+i]};g=OpenLayers.Geometry.distanceToSegment(f,n);if(g.distance<c){e=d?new OpenLayers.Geometry.Point(f.x,f.y):true;break a}}}}return e};
-OpenLayers.Geometry.distanceToSegment=function(a,b){var c=a.x,d=a.y,e=b.x1,f=b.y1,g=b.x2,h=b.y2,i=g-e,j=h-f,k=(i*(c-e)+j*(d-f))/(Math.pow(i,2)+Math.pow(j,2));if(k<=0){e=e;f=f}else if(k>=1){e=g;f=h}else{e=e+k*i;f=f+k*j}return{distance:Math.sqrt(Math.pow(e-c,2)+Math.pow(f-d,2)),x:e,y:f}};
-OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(a,b,c){if(c&&c.sphericalMercator||this.sphericalMercator)c=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-2.00375083392E7,-2.00375083392E7,2.00375083392E7,2.00375083392E7),maxResolution:156543.0339,numZoomLevels:19,units:"m",projection:"EPSG:900913"},c);b=b||this.url;a=a||this.name;OpenLayers.Layer.Grid.prototype.initialize.apply(this,
-[a,b,{},c])},clone:function(a){if(a==null)a=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var b=this.map.getResolution(),c=Math.round((a.left-this.maxExtent.left)/(b*this.tileSize.w));a=Math.round((this.maxExtent.top-a.top)/(b*this.tileSize.h));b=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,b):this.map.getZoom()+this.zoomOffset;var d=this.url,e=""+c+a+b;if(d instanceof
-Array)d=this.selectUrl(e,d);return OpenLayers.String.format(d,{x:c,y:a,z:b})},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize)},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin)this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom)},CLASS_NAME:"OpenLayers.Layer.XYZ"});
-OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:"http://tile.openstreetmap.org/${z}/${x}/${y}.png",clone:function(a){if(a==null)a=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.OSM"});
-OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(a,b){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),select:new OpenLayers.Style(OpenLayers.Feature.Vector.style.select),temporary:new OpenLayers.Style(OpenLayers.Feature.Vector.style.temporary),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(a instanceof OpenLayers.Style){this.styles["default"]=a;this.styles.select=a;this.styles.temporary=a;
-this.styles["delete"]=a}else if(typeof a=="object")for(var c in a)if(a[c]instanceof OpenLayers.Style)this.styles[c]=a[c];else if(typeof a[c]=="object")this.styles[c]=new OpenLayers.Style(a[c]);else{this.styles["default"]=new OpenLayers.Style(a);this.styles.select=new OpenLayers.Style(a);this.styles.temporary=new OpenLayers.Style(a);this.styles["delete"]=new OpenLayers.Style(a);break}OpenLayers.Util.extend(this,b)},destroy:function(){for(var a in this.styles)this.styles[a].destroy();this.styles=null},
-createSymbolizer:function(a,b){a||(a=new OpenLayers.Feature.Vector);this.styles[b]||(b="default");a.renderIntent=b;var c={};if(this.extendDefault&&b!="default")c=this.styles["default"].createSymbolizer(a);return OpenLayers.Util.extend(c,this.styles[b].createSymbolizer(a))},addUniqueValueRules:function(a,b,c,d){var e=[],f;for(f in c)e.push(new OpenLayers.Rule({symbolizer:c[f],context:d,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:b,value:f})}));this.styles[a].addRules(e)},
-CLASS_NAME:"OpenLayers.StyleMap"});
-OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(a){OpenLayers.Filter.prototype.initialize.apply(this,[a])},evaluate:function(a){if(a instanceof OpenLayers.Feature.Vector)a=a.attributes;var b=false;a=a[this.property];switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:b=this.value;b=!this.matchCase&&typeof a=="string"&&typeof b=="string"?a.toUpperCase()==b.toUpperCase():
-a==b;break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:b=this.value;b=!this.matchCase&&typeof a=="string"&&typeof b=="string"?a.toUpperCase()!=b.toUpperCase():a!=b;break;case OpenLayers.Filter.Comparison.LESS_THAN:b=a<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:b=a>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:b=a<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:b=a>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:b=
-a>=this.lowerBoundary&&a<=this.upperBoundary;break;case OpenLayers.Filter.Comparison.LIKE:b=RegExp(this.value,"gi").test(a)}return b},value2regex:function(a,b,c){if(a=="."){OpenLayers.Console.error("'.' is an unsupported wildCard character for OpenLayers.Filter.Comparison");return null}a=a?a:"*";b=b?b:".";c=c?c:"!";this.value=this.value.replace(RegExp("\\"+c+"(.|$)","g"),"\\$1");this.value=this.value.replace(RegExp("\\"+b,"g"),".");this.value=this.value.replace(RegExp("\\"+a,"g"),".*");this.value=
-this.value.replace(RegExp("\\\\.\\*","g"),"\\"+a);return this.value=this.value.replace(RegExp("\\\\\\.","g"),"\\"+b)},regex2value:function(){var a=this.value;a=a.replace(/!/g,"!!");a=a.replace(/(\\)?\\\./g,function(b,c){return c?b:"!."});a=a.replace(/(\\)?\\\*/g,function(b,c){return c?b:"!*"});a=a.replace(/\\\\/g,"\\");return a=a.replace(/\.\*/g,"*")},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison,this)},CLASS_NAME:"OpenLayers.Filter.Comparison"});
-OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";
-OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(a){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},evaluate:function(a){for(var b=0,c=this.fids.length;b<c;b++)if((a.fid||a.id)==this.fids[b])return true;return false},clone:function(){var a=new OpenLayers.Filter.FeatureId;OpenLayers.Util.extend(a,this);a.fids=this.fids.slice();return a},CLASS_NAME:"OpenLayers.Filter.FeatureId"});
-OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(a){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this)},evaluate:function(a){switch(this.type){case OpenLayers.Filter.Logical.AND:for(var b=0,c=this.filters.length;b<c;b++)if(this.filters[b].evaluate(a)==false)return false;return true;case OpenLayers.Filter.Logical.OR:b=0;for(c=this.filters.length;b<
-c;b++)if(this.filters[b].evaluate(a)==true)return true;return false;case OpenLayers.Filter.Logical.NOT:return!this.filters[0].evaluate(a)}},clone:function(){for(var a=[],b=0,c=this.filters.length;b<c;++b)a.push(this.filters[b].clone());return new OpenLayers.Filter.Logical({type:this.type,filters:a})},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";
-OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(a){OpenLayers.Filter.prototype.initialize.apply(this,[a])},evaluate:function(a){var b=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(a.geometry){var c=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds")c=this.value.toGeometry();if(a.geometry.intersects(c))b=true}break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"))}return b},
-clone:function(){var a=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(a)},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";
-OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(a){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];a!=null&&this.addComponents(a)},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments)},clone:function(){for(var a=eval("new "+this.CLASS_NAME+"()"),b=0,c=this.components.length;b<c;b++)a.addComponent(this.components[b].clone());
-OpenLayers.Util.applyDefaults(a,this);return a},getComponentsString:function(){for(var a=[],b=0,c=this.components.length;b<c;b++)a.push(this.components[b].toShortString());return a.join(",")},calculateBounds:function(){this.bounds=null;if(this.components&&this.components.length>0){this.setBounds(this.components[0].getBounds());for(var a=1,b=this.components.length;a<b;a++)this.extendBounds(this.components[a].getBounds())}},addComponents:function(a){a instanceof Array||(a=[a]);for(var b=0,c=a.length;b<
-c;b++)this.addComponent(a[b])},addComponent:function(a,b){var c=false;if(a)if(this.componentTypes==null||OpenLayers.Util.indexOf(this.componentTypes,a.CLASS_NAME)>-1){if(b!=null&&b<this.components.length){c=this.components.slice(0,b);var d=this.components.slice(b,this.components.length);c.push(a);this.components=c.concat(d)}else this.components.push(a);a.parent=this;this.clearBounds();c=true}return c},removeComponents:function(a){a instanceof Array||(a=[a]);for(var b=a.length-1;b>=0;--b)this.removeComponent(a[b])},
-removeComponent:function(a){OpenLayers.Util.removeItem(this.components,a);this.clearBounds()},getLength:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getLength();return a},getArea:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getArea();return a},getGeodesicArea:function(a){for(var b=0,c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicArea(a);return b},getCentroid:function(a){if(!a)return this.components.length&&
-this.components[0].getCentroid();a=this.components.length;if(!a)return false;for(var b=[],c=[],d=0,e=Number.MAX_VALUE,f,g=0;g<a;++g){f=this.components[g];var h=f.getArea();f=f.getCentroid(true);if(!(isNaN(h)||isNaN(f.x)||isNaN(f.y))){b.push(h);d+=h;e=h<e&&h>0?h:e;c.push(f)}}a=b.length;if(d===0){for(g=0;g<a;++g)b[g]=1;d=b.length}else{for(g=0;g<a;++g)b[g]/=e;d/=e}var i=e=0;for(g=0;g<a;++g){f=c[g];h=b[g];e+=f.x*h;i+=f.y*h}return new OpenLayers.Geometry.Point(e/d,i/d)},getGeodesicLength:function(a){for(var b=
-0,c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicLength(a);return b},move:function(a,b){for(var c=0,d=this.components.length;c<d;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0;d<this.components.length;++d)this.components[d].resize(a,b,c);return this},distanceTo:function(a,b){for(var c=!(b&&b.edge===false)&&b&&b.details,d,e,f,g=Number.POSITIVE_INFINITY,h=0,
-i=this.components.length;h<i;++h){d=this.components[h].distanceTo(a,b);f=c?d.distance:d;if(f<g){g=f;e=d;if(g==0)break}}return e},equals:function(a){var b=true;if(!a||!a.CLASS_NAME||this.CLASS_NAME!=a.CLASS_NAME)b=false;else if(!(a.components instanceof Array)||a.components.length!=this.components.length)b=false;else for(var c=0,d=this.components.length;c<d;++c)if(!this.components[c].equals(a.components[c])){b=false;break}return b},transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<
-d;c++)this.components[c].transform(a,b);this.bounds=null}return this},intersects:function(a){for(var b=false,c=0,d=this.components.length;c<d;++c)if(b=a.intersects(this.components[c]))break;return b},getVertices:function(a){for(var b=[],c=0,d=this.components.length;c<d;++c)Array.prototype.push.apply(b,this.components[c].getVertices(a));return b},CLASS_NAME:"OpenLayers.Geometry.Collection"});
-OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(a,b){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(a);this.y=parseFloat(b)},clone:function(a){if(a==null)a=new OpenLayers.Geometry.Point(this.x,this.y);OpenLayers.Util.applyDefaults(a,this);return a},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y)},distanceTo:function(a,b){var c=!(b&&b.edge===false)&&b&&b.details,d,e,f,g,h;if(a instanceof
-OpenLayers.Geometry.Point){e=this.x;f=this.y;g=a.x;h=a.y;d=Math.sqrt(Math.pow(e-g,2)+Math.pow(f-h,2));d=!c?d:{x0:e,y0:f,x1:g,y1:h,distance:d}}else{d=a.distanceTo(this,b);if(c)d={x0:d.x1,y0:d.y1,x1:d.x0,y1:d.y0,distance:d.distance}}return d},equals:function(a){var b=false;if(a!=null)b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y);return b},toShortString:function(){return this.x+", "+this.y},move:function(a,b){this.x+=a;this.y+=b;this.clearBounds()},rotate:function(a,
-b){a*=Math.PI/180;var c=this.distanceTo(b),d=a+Math.atan2(this.y-b.y,this.x-b.x);this.x=b.x+c*Math.cos(d);this.y=b.y+c*Math.sin(d);this.clearBounds()},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y)},resize:function(a,b,c){c=c==undefined?1:c;this.x=b.x+a*c*(this.x-b.x);this.y=b.y+a*(this.y-b.y);this.clearBounds();return this},intersects:function(a){var b=false;return b=a.CLASS_NAME=="OpenLayers.Geometry.Point"?this.equals(a):a.intersects(this)},transform:function(a,b){if(a&&
-b){OpenLayers.Projection.transform(this,a,b);this.bounds=null}return this},getVertices:function(){return[this]},CLASS_NAME:"OpenLayers.Geometry.Point"});
-OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,
-unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:["SVG","VML","Canvas"],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported())this.assignRenderer();if(!this.renderer||!this.renderer.supported()){this.renderer=
-null;this.displayError()}if(!this.styleMap)this.styleMap=new OpenLayers.StyleMap;this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies)for(var a=0,b=this.strategies.length;a<b;a++)this.strategies[a].setLayer(this)},destroy:function(){if(this.strategies){var a,b,c;b=0;for(c=this.strategies.length;b<c;b++){a=this.strategies[b];a.autoDestroy&&a.destroy()}this.strategies=null}if(this.protocol){this.protocol.autoDestroy&&this.protocol.destroy();this.protocol=null}this.destroyFeatures();
-this.unrenderedFeatures=this.selectedFeatures=this.features=null;this.renderer&&this.renderer.destroy();this.drawn=this.geometryType=this.renderer=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){if(a==null)a=new OpenLayers.Layer.Vector(this.name,this.getOptions());a=OpenLayers.Layer.prototype.clone.apply(this,[a]);for(var b=this.features,c=b.length,d=Array(c),e=0;e<c;++e)d[e]=b[e].clone();a.features=d;return a},refresh:function(a){this.calculateInRange()&&this.visibility&&
-this.events.triggerEvent("refresh",a)},assignRenderer:function(){for(var a=0,b=this.renderers.length;a<b;a++){var c=this.renderers[a];if((c=typeof c=="function"?c:OpenLayers.Renderer[c])&&c.prototype.supported()){this.renderer=new c(this.div,this.rendererOptions);break}}},displayError:function(){this.reportError&&OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{renderers:this.renderers.join("\n")}))},setMap:function(){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(this.renderer){this.renderer.map=
-this.map;this.renderer.setSize(this.map.getSize())}else this.map.removeLayer(this)},afterAdd:function(){if(this.strategies){var a,b,c;b=0;for(c=this.strategies.length;b<c;b++){a=this.strategies[b];a.autoActivate&&a.activate()}}},removeMap:function(){this.drawn=false;if(this.strategies){var a,b,c;b=0;for(c=this.strategies.length;b<c;b++){a=this.strategies[b];a.autoActivate&&a.deactivate()}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize())},
-moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var d=true;if(!c){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";d=this.renderer.setExtent(this.map.getExtent(),b);this.renderer.root.style.visibility="visible";if(OpenLayers.IS_GECKO===true)this.div.scrollLeft=this.div.scrollLeft;if(!b&&d)for(var e in this.unrenderedFeatures){var f=
-this.unrenderedFeatures[e];this.drawFeature(f)}}if(!this.drawn||b||!d){this.drawn=true;e=0;for(d=this.features.length;e<d;e++){this.renderer.locked=e!==d-1;f=this.features[e];this.drawFeature(f)}}},display:function(){OpenLayers.Layer.prototype.display.apply(this,arguments);var a=this.div.style.display;if(a!=this.renderer.root.style.display)this.renderer.root.style.display=a},addFeatures:function(a,b){a instanceof Array||(a=[a]);var c=!b||!b.silent;if(c){var d={features:a};if(this.events.triggerEvent("beforefeaturesadded",
-d)===false)return;a=d.features}d=[];for(var e=0,f=a.length;e<f;e++){this.renderer.locked=e!=a.length-1?true:false;var g=a[e];if(this.geometryType&&!(g.geometry instanceof this.geometryType))throw OpenLayers.i18n("componentShouldBe",{geomType:this.geometryType.prototype.CLASS_NAME});g.layer=this;if(!g.style&&this.style)g.style=OpenLayers.Util.extend({},this.style);if(c){if(this.events.triggerEvent("beforefeatureadded",{feature:g})===false)continue;this.preFeatureInsert(g)}d.push(g);this.features.push(g);
-this.drawFeature(g);if(c){this.events.triggerEvent("featureadded",{feature:g});this.onFeatureInsert(g)}}c&&this.events.triggerEvent("featuresadded",{features:d})},removeFeatures:function(a,b){if(!(!a||a.length===0)){if(a===this.features)return this.removeAllFeatures(b);a instanceof Array||(a=[a]);if(a===this.selectedFeatures)a=a.slice();var c=!b||!b.silent;c&&this.events.triggerEvent("beforefeaturesremoved",{features:a});for(var d=a.length-1;d>=0;d--){this.renderer.locked=d!=0&&a[d-1].geometry?true:
-false;var e=a[d];delete this.unrenderedFeatures[e.id];c&&this.events.triggerEvent("beforefeatureremoved",{feature:e});this.features=OpenLayers.Util.removeItem(this.features,e);e.layer=null;e.geometry&&this.renderer.eraseFeatures(e);OpenLayers.Util.indexOf(this.selectedFeatures,e)!=-1&&OpenLayers.Util.removeItem(this.selectedFeatures,e);c&&this.events.triggerEvent("featureremoved",{feature:e})}c&&this.events.triggerEvent("featuresremoved",{features:a})}},removeAllFeatures:function(a){a=!a||!a.silent;
-var b=this.features;a&&this.events.triggerEvent("beforefeaturesremoved",{features:b});for(var c,d=b.length-1;d>=0;d--){c=b[d];a&&this.events.triggerEvent("beforefeatureremoved",{feature:c});c.layer=null;a&&this.events.triggerEvent("featureremoved",{feature:c})}this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];a&&this.events.triggerEvent("featuresremoved",{features:b})},destroyFeatures:function(a,b){if(a==undefined)a=this.features;if(a){this.removeFeatures(a,
-b);for(var c=a.length-1;c>=0;c--)a[c].destroy()}},drawFeature:function(a,b){if(this.drawn){if(typeof b!="object"){if(!b&&a.state===OpenLayers.State.DELETE)b="delete";var c=b||a.renderIntent;(b=a.style||this.style)||(b=this.styleMap.createSymbolizer(a,c))}if(this.renderer.drawFeature(a,b))delete this.unrenderedFeatures[a.id];else this.unrenderedFeatures[a.id]=a}},eraseFeatures:function(a){this.renderer.eraseFeatures(a)},getFeatureFromEvent:function(a){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));
-return null}return this.getFeatureById(this.renderer.getFeatureIdFromEvent(a))},getFeatureBy:function(a,b){for(var c=null,d=0,e=this.features.length;d<e;++d)if(this.features[d][a]==b){c=this.features[d];break}return c},getFeatureById:function(a){return this.getFeatureBy("id",a)},getFeatureByFid:function(a){return this.getFeatureBy("fid",a)},onFeatureInsert:function(){},preFeatureInsert:function(){},getDataExtent:function(){var a=null,b=this.features;if(b&&b.length>0){a=new OpenLayers.Bounds;for(var c=
-null,d=0,e=b.length;d<e;d++)(c=b[d].geometry)&&a.extend(c.getBounds())}return a},CLASS_NAME:"OpenLayers.Layer.Vector"});
-OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},write:function(a,b){var c=b&&b.version||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=c){var d=OpenLayers.Format.Filter["v"+c.replace(/\./g,"_")];if(!d)throw"Can't find a Filter parser for version "+c;this.parser=new d(this.options)}return this.parser.write(a)},read:function(a){if(typeof a==
-"string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);var b=this.version;if(!b)b=this.defaultVersion;if(!this.parser||this.parser.VERSION!=b){var c=OpenLayers.Format.Filter["v"+b.replace(/\./g,"_")];if(!c)throw"Can't find a Filter parser for version "+b;this.parser=new c(this.options)}return this.parser.read(a)},CLASS_NAME:"OpenLayers.Format.Filter"});
-OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments)},addPoint:function(a,b){this.addComponent(a,b)},removePoint:function(a){this.removeComponent(a)},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});
-OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){var b={};this.readers.ogc.Filter.apply(this,[a,b]);return b.filter},readers:{ogc:{Filter:function(a,b){var c={fids:[],filters:[]};
-this.readChildNodes(a,c);if(c.fids.length>0)b.filter=new OpenLayers.Filter.FeatureId({fids:c.fids});else if(c.filters.length>0)b.filter=c.filters[0]},FeatureId:function(a,b){var c=a.getAttribute("fid");c&&b.fids.push(c)},And:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(a,c);b.filters.push(c)},Or:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(a,c);b.filters.push(c)},Not:function(a,
-b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThan:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThan:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThanOrEqualTo:function(a,b){var c=
-new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThanOrEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsBetween:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(a,c);b.filters.push(c)},Literal:function(a,
-b){b.value=OpenLayers.String.numericIf(this.getChildValue(a))},PropertyName:function(a,b){b.property=this.getChildValue(a)},LowerBoundary:function(a,b){b.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(a))},UpperBoundary:function(a,b){b.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(a))},Intersects:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.INTERSECTS)},Within:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.WITHIN)},Contains:function(a,
-b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.CONTAINS)},DWithin:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.DWITHIN)},Distance:function(a,b){b.distance=parseInt(this.getChildValue(a));b.distanceUnits=a.getAttribute("units")}}},readSpatial:function(a,b,c){c=new OpenLayers.Filter.Spatial({type:c});this.readChildNodes(a,c);c.value=c.components[0];delete c.components;b.filters.push(c)},readOgcExpression:function(a){var b={};this.readChildNodes(a,b);b=b.value;if(b===undefined)b=this.getChildValue(a);
-return b},write:function(a){return this.writers.ogc.Filter.apply(this,[a])},writers:{ogc:{Filter:function(a){var b=this.createElementNSPlus("ogc:Filter");if(a.CLASS_NAME.split(".").pop()=="FeatureId")for(var c=0;c<a.fids.length;++c)this.writeNode("FeatureId",a.fids[c],b);else this.writeNode(this.getFilterType(a),a,b);return b},FeatureId:function(a){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:a}})},And:function(a){for(var b=this.createElementNSPlus("ogc:And"),c,d=0;d<a.filters.length;++d){c=
-a.filters[d];this.writeNode(this.getFilterType(c),c,b)}return b},Or:function(a){for(var b=this.createElementNSPlus("ogc:Or"),c,d=0;d<a.filters.length;++d){c=a.filters[d];this.writeNode(this.getFilterType(c),c,b)}return b},Not:function(a){var b=this.createElementNSPlus("ogc:Not");a=a.filters[0];this.writeNode(this.getFilterType(a),a,b);return b},PropertyIsLessThan:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,
-b);return b},PropertyIsGreaterThan:function(a){var b=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsLessThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsGreaterThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",
-a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsBetween:function(a){var b=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",a,b);this.writeNode("LowerBoundary",a,b);this.writeNode("UpperBoundary",a,b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",{value:a.property})},Literal:function(a){return this.createElementNSPlus("ogc:Literal",{value:a})},LowerBoundary:function(a){var b=this.createElementNSPlus("ogc:LowerBoundary");
-this.writeNode("Literal",a.lowerBoundary,b);return b},UpperBoundary:function(a){var b=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",a.upperBoundary,b);return b},INTERSECTS:function(a){return this.writeSpatial(a,"Intersects")},WITHIN:function(a){return this.writeSpatial(a,"Within")},CONTAINS:function(a){return this.writeSpatial(a,"Contains")},DWITHIN:function(a){var b=this.writeSpatial(a,"DWithin");this.writeNode("Distance",a,b);return b},Distance:function(a){return this.createElementNSPlus("ogc:Distance",
-{attributes:{units:a.distanceUnits},value:a.distance})}}},getFilterType:function(a){var b=this.filterMap[a.type];if(!b)throw"Filter writing not supported for rule type: "+a.type;return b},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike",BBOX:"BBOX",DWITHIN:"DWITHIN",WITHIN:"WITHIN",
-CONTAINS:"CONTAINS",INTERSECTS:"INTERSECTS"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});
-OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments)},getLength:function(){var a=0;if(this.components&&this.components.length>1)for(var b=1,c=this.components.length;b<c;b++)a+=this.components[b-1].distanceTo(this.components[b]);return a},getGeodesicLength:function(a){var b=this;if(a){var c=new OpenLayers.Projection("EPSG:4326");c.equals(a)||
-(b=this.clone().transform(a,c))}a=0;if(b.components&&b.components.length>1)for(var d,e=1,f=b.components.length;e<f;e++){c=b.components[e-1];d=b.components[e];a+=OpenLayers.Util.distVincenty({lon:c.x,lat:c.y},{lon:d.x,lat:d.y})}return a*1E3},CLASS_NAME:"OpenLayers.Geometry.Curve"});
-OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments)},removeComponent:function(){this.components&&this.components.length>2&&OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments)},intersects:function(a){var b=false,c=a.CLASS_NAME;if(c=="OpenLayers.Geometry.LineString"||c=="OpenLayers.Geometry.LinearRing"||c=="OpenLayers.Geometry.Point"){var d=this.getSortedSegments();
-a=c=="OpenLayers.Geometry.Point"?[{x1:a.x,y1:a.y,x2:a.x,y2:a.y}]:a.getSortedSegments();var e,f,g,h,i,j,k,n=0,m=d.length;a:for(;n<m;++n){c=d[n];e=c.x1;f=c.x2;g=c.y1;h=c.y2;var l=0,o=a.length;for(;l<o;++l){i=a[l];if(i.x1>f)break;if(!(i.x2<e)){j=i.y1;k=i.y2;if(!(Math.min(j,k)>Math.max(g,h)))if(!(Math.max(j,k)<Math.min(g,h)))if(OpenLayers.Geometry.segmentsIntersect(c,i)){b=true;break a}}}}}else b=a.intersects(this);return b},getSortedSegments:function(){for(var a=this.components.length-1,b=Array(a),c,
-d,e=0;e<a;++e){c=this.components[e];d=this.components[e+1];b[e]=c.x<d.x?{x1:c.x,y1:c.y,x2:d.x,y2:d.y}:{x1:d.x,y1:d.y,x2:c.x,y2:c.y}}return b.sort(function(f,g){return f.x1-g.x1})},splitWithSegment:function(a,b){for(var c=!(b&&b.edge===false),d=b&&b.tolerance,e=[],f=this.getVertices(),g=[],h=[],i=false,j,k,n,m={point:true,tolerance:d},l=null,o=0,p=f.length-2;o<=p;++o){d=f[o];g.push(d.clone());j=f[o+1];k={x1:d.x,y1:d.y,x2:j.x,y2:j.y};k=OpenLayers.Geometry.segmentsIntersect(a,k,m);if(k instanceof OpenLayers.Geometry.Point)if((n=
-k.x===a.x1&&k.y===a.y1||k.x===a.x2&&k.y===a.y2||k.equals(d)||k.equals(j)?true:false)||c){k.equals(h[h.length-1])||h.push(k.clone());if(o===0)if(k.equals(d))continue;if(!k.equals(j)){i=true;k.equals(d)||g.push(k);e.push(new OpenLayers.Geometry.LineString(g));g=[k.clone()]}}}if(i){g.push(j.clone());e.push(new OpenLayers.Geometry.LineString(g))}if(h.length>0){var r=a.x1<a.x2?1:-1,q=a.y1<a.y2?1:-1;l={lines:e,points:h.sort(function(s,t){return r*s.x-r*t.x||q*s.y-q*t.y})}}return l},split:function(a,b){var c=
-null,d=b&&b.mutual,e,f,g,h;if(a instanceof OpenLayers.Geometry.LineString){var i=this.getVertices(),j,k,n,m,l,o=[];g=[];for(var p=0,r=i.length-2;p<=r;++p){j=i[p];k=i[p+1];n={x1:j.x,y1:j.y,x2:k.x,y2:k.y};h=h||[a];d&&o.push(j.clone());for(var q=0;q<h.length;++q)if(m=h[q].splitWithSegment(n,b)){l=m.lines;if(l.length>0){l.unshift(q,1);Array.prototype.splice.apply(h,l);q+=l.length-2}if(d)for(var s=0,t=m.points.length;s<t;++s){l=m.points[s];if(!l.equals(j)){o.push(l);g.push(new OpenLayers.Geometry.LineString(o));
-o=l.equals(k)?[]:[l.clone()]}}}}if(d&&g.length>0&&o.length>0){o.push(k.clone());g.push(new OpenLayers.Geometry.LineString(o))}}else c=a.splitWith(this,b);if(h&&h.length>1)f=true;else h=[];if(g&&g.length>1)e=true;else g=[];if(f||e)c=d?[g,h]:h;return c},splitWith:function(a,b){return a.split(this,b)},getVertices:function(a){return a===true?[this.components[0],this.components[this.components.length-1]]:a===false?this.components.slice(1,this.components.length-1):this.components.slice()},distanceTo:function(a,
-b){var c=!(b&&b.edge===false)&&b&&b.details,d,e={},f=Number.POSITIVE_INFINITY;if(a instanceof OpenLayers.Geometry.Point){for(var g=this.getSortedSegments(),h=a.x,i=a.y,j,k=0,n=g.length;k<n;++k){j=g[k];d=OpenLayers.Geometry.distanceToSegment(a,j);if(d.distance<f){f=d.distance;e=d;if(f===0)break}else if(j.x2>h&&(i>j.y1&&i<j.y2||i<j.y1&&i>j.y2))break}e=c?{distance:e.distance,x0:e.x,y0:e.y,x1:h,y1:i}:e.distance}else if(a instanceof OpenLayers.Geometry.LineString){g=this.getSortedSegments();h=a.getSortedSegments();
-var m,l,o=h.length,p={point:true};k=0;n=g.length;a:for(;k<n;++k){i=g[k];j=i.x1;l=i.y1;for(var r=0;r<o;++r){d=h[r];if(m=OpenLayers.Geometry.segmentsIntersect(i,d,p)){f=0;e={distance:0,x0:m.x,y0:m.y,x1:m.x,y1:m.y};break a}else{d=OpenLayers.Geometry.distanceToSegment({x:j,y:l},d);if(d.distance<f){f=d.distance;e={distance:f,x0:j,y0:l,x1:d.x,y1:d.y}}}}}if(!c)e=e.distance;if(f!==0)if(i){d=a.distanceTo(new OpenLayers.Geometry.Point(i.x2,i.y2),b);k=c?d.distance:d;if(k<f)e=c?{distance:f,x0:d.x1,y0:d.y1,x1:d.x0,
-y1:d.y0}:k}}else{e=a.distanceTo(this,b);if(c)e={distance:e.distance,x0:e.x1,y0:e.y1,x1:e.x0,y1:e.y0}}return e},CLASS_NAME:"OpenLayers.Geometry.LineString"});
-OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments)},addComponent:function(a,b){var c=false,d=this.components.pop();if(b!=null||!a.equals(d))c=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]]);return c},removeComponent:function(){if(this.components.length>
-4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]])}},move:function(a,b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d-1;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0,e=this.components.length;d<e-1;++d)this.components[d].resize(a,b,c);return this},
-transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].transform(a,b);this.bounds=null}return this},getCentroid:function(){if(this.components&&this.components.length>2){for(var a=0,b=0,c=0;c<this.components.length-1;c++){var d=this.components[c],e=this.components[c+1];a+=(d.x+e.x)*(d.x*e.y-e.x*d.y);b+=(d.y+e.y)*(d.x*e.y-e.x*d.y)}c=-1*this.getArea();return new OpenLayers.Geometry.Point(a/(6*c),b/(6*c))}else return null},getArea:function(){var a=0;if(this.components&&
-this.components.length>2){for(var b=a=0,c=this.components.length;b<c-1;b++){var d=this.components[b],e=this.components[b+1];a+=(d.x+e.x)*(e.y-d.y)}a=-a/2}return a},getGeodesicArea:function(a){var b=this;if(a){var c=new OpenLayers.Projection("EPSG:4326");c.equals(a)||(b=this.clone().transform(a,c))}a=0;c=b.components&&b.components.length;if(c>2){for(var d,e,f=0;f<c-1;f++){d=b.components[f];e=b.components[f+1];a+=OpenLayers.Util.rad(e.x-d.x)*(2+Math.sin(OpenLayers.Util.rad(d.y))+Math.sin(OpenLayers.Util.rad(e.y)))}a=
-a*6378137*6378137/2}return a},containsPoint:function(a){var b=OpenLayers.Number.limitSigDigs,c=b(a.x,14);a=b(a.y,14);for(var d=this.components.length-1,e,f,g,h,i,j=0,k=0;k<d;++k){e=this.components[k];g=b(e.x,14);e=b(e.y,14);f=this.components[k+1];h=b(f.x,14);f=b(f.y,14);if(e==f){if(a==e)if(g<=h&&c>=g&&c<=h||g>=h&&c<=g&&c>=h){j=-1;break}}else{i=b(((g-h)*a+(h*e-g*f))/(e-f),14);if(i==c)if(e<f&&a>=e&&a<=f||e>f&&a<=e&&a>=f){j=-1;break}if(!(i<=c))if(!(g!=h&&(i<Math.min(g,h)||i>Math.max(g,h))))if(e<f&&a>=
-e&&a<f||e>f&&a<e&&a>=f)++j}}return j==-1?1:!!(j&1)},intersects:function(a){var b=false;if(a.CLASS_NAME=="OpenLayers.Geometry.Point")b=this.containsPoint(a);else if(a.CLASS_NAME=="OpenLayers.Geometry.LineString")b=a.intersects(this);else if(a.CLASS_NAME=="OpenLayers.Geometry.LinearRing")b=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[a]);else for(var c=0,d=a.components.length;c<d;++c)if(b=a.components[c].intersects(this))break;return b},getVertices:function(a){return a===true?[]:
-this.components.slice(0,this.components.length-1)},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});
-OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments)},split:function(a,b){for(var c=null,d=b&&b.mutual,e,f,g,h,i=[],j=[a],k=0,n=this.components.length;k<n;++k){f=this.components[k];g=false;for(var m=0;m<j.length;++m)if(e=f.split(j[m],b)){if(d){g=e[0];for(var l=0,o=g.length;l<o;++l)l===0&&i.length?i[i.length-1].addComponent(g[l]):
-i.push(new OpenLayers.Geometry.MultiLineString([g[l]]));g=true;e=e[1]}if(e.length){e.unshift(m,1);Array.prototype.splice.apply(j,e);break}}if(!g)if(i.length)i[i.length-1].addComponent(f.clone());else i=[new OpenLayers.Geometry.MultiLineString(f.clone())]}if(i&&i.length>1)g=true;else i=[];if(j&&j.length>1)h=true;else j=[];if(g||h)c=d?[i,j]:j;return c},splitWith:function(a,b){var c=null,d=b&&b.mutual,e,f,g,h,i,j;if(a instanceof OpenLayers.Geometry.LineString){j=[];i=[a];for(var k=0,n=this.components.length;k<
-n;++k){g=false;f=this.components[k];for(var m=0;m<i.length;++m)if(e=i[m].split(f,b)){if(d){g=e[0];if(g.length){g.unshift(m,1);Array.prototype.splice.apply(i,g);m+=g.length-2}e=e[1];if(e.length===0)e=[f.clone()]}g=0;for(var l=e.length;g<l;++g)g===0&&j.length?j[j.length-1].addComponent(e[g]):j.push(new OpenLayers.Geometry.MultiLineString([e[g]]));g=true}if(!g)if(j.length)j[j.length-1].addComponent(f.clone());else j=[new OpenLayers.Geometry.MultiLineString([f.clone()])]}}else c=a.split(this);if(i&&i.length>
-1)h=true;else i=[];if(j&&j.length>1)g=true;else j=[];if(h||g)c=d?[i,j]:j;return c},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});
-OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments)},getArea:function(){var a=0;if(this.components&&this.components.length>0){a+=Math.abs(this.components[0].getArea());for(var b=1,c=this.components.length;b<c;b++)a-=Math.abs(this.components[b].getArea())}return a},getGeodesicArea:function(a){var b=0;if(this.components&&this.components.length>
-0){b+=Math.abs(this.components[0].getGeodesicArea(a));for(var c=1,d=this.components.length;c<d;c++)b-=Math.abs(this.components[c].getGeodesicArea(a))}return b},containsPoint:function(a){var b=this.components.length,c=false;if(b>0){c=this.components[0].containsPoint(a);if(c!==1)if(c&&b>1)for(var d,e=1;e<b;++e)if(d=this.components[e].containsPoint(a)){c=d===1?1:false;break}}return c},intersects:function(a){var b=false,c,d;if(a.CLASS_NAME=="OpenLayers.Geometry.Point")b=this.containsPoint(a);else if(a.CLASS_NAME==
-"OpenLayers.Geometry.LineString"||a.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){c=0;for(d=this.components.length;c<d;++c)if(b=a.intersects(this.components[c]))break;if(!b){c=0;for(d=a.components.length;c<d;++c)if(b=this.containsPoint(a.components[c]))break}}else{c=0;for(d=a.components.length;c<d;++c)if(b=this.intersects(a.components[c]))break}if(!b&&a.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var e=this.components[0];c=0;for(d=e.components.length;c<d;++c)if(b=a.containsPoint(e.components[c]))break}return b},
-distanceTo:function(a,b){return b&&b.edge===false&&this.intersects(a)?0:OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[a,b])},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(a,b,c,d){var e=Math.PI*(1/c-0.5);if(d)e+=d/180*Math.PI;for(var f,g=[],h=0;h<c;++h){f=e+h*2*Math.PI/c;d=a.x+b*Math.cos(f);f=a.y+b*Math.sin(f);g.push(new OpenLayers.Geometry.Point(d,f))}a=new OpenLayers.Geometry.LinearRing(g);return new OpenLayers.Geometry.Polygon([a])};
-OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});
-OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(a){this.regExes={trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g};OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a==
-"string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);a=this.getElementsByTagNameNS(a.documentElement,this.gmlns,this.featureName);for(var b=[],c=0;c<a.length;c++){var d=this.parseFeature(a[c]);d&&b.push(d)}return b},parseFeature:function(a){var b=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"],c,d,e,f;for(f=0;f<b.length;++f){c=b[f];d=this.getElementsByTagNameNS(a,this.gmlns,c);if(d.length>0){if(f=this.parseGeometry[c.toLowerCase()]){e=f.apply(this,
-[d[0]]);this.internalProjection&&this.externalProjection&&e.transform(this.externalProjection,this.internalProjection)}else OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{geomType:c}));break}}var g;c=this.getElementsByTagNameNS(a,this.gmlns,"Box");for(f=0;f<c.length;++f){b=c[f];d=this.parseGeometry.box.apply(this,[b]);b=b.parentNode;if((b.localName||b.nodeName.split(":").pop())==="boundedBy")g=d;else e=d.toGeometry()}var h;if(this.extractAttributes)h=this.parseAttributes(a);e=
-new OpenLayers.Feature.Vector(e,h);e.bounds=g;e.gml={featureType:a.firstChild.nodeName.split(":")[1],featureNS:a.firstChild.namespaceURI,featureNSPrefix:a.firstChild.prefix};a=a.firstChild;for(var i;a;){if(a.nodeType==1)if(i=a.getAttribute("fid")||a.getAttribute("id"))break;a=a.nextSibling}e.fid=i;return e},parseGeometry:{point:function(a){var b,c;c=[];b=this.getElementsByTagNameNS(a,this.gmlns,"pos");if(b.length>0){c=b[0].firstChild.nodeValue;c=c.replace(this.regExes.trimSpace,"");c=c.split(this.regExes.splitSpace)}if(c.length==
-0){b=this.getElementsByTagNameNS(a,this.gmlns,"coordinates");if(b.length>0){c=b[0].firstChild.nodeValue;c=c.replace(this.regExes.removeSpace,"");c=c.split(",")}}if(c.length==0){b=this.getElementsByTagNameNS(a,this.gmlns,"coord");if(b.length>0){a=this.getElementsByTagNameNS(b[0],this.gmlns,"X");b=this.getElementsByTagNameNS(b[0],this.gmlns,"Y");if(a.length>0&&b.length>0)c=[a[0].firstChild.nodeValue,b[0].firstChild.nodeValue]}}if(c.length==2)c[2]=null;return this.xy?new OpenLayers.Geometry.Point(c[0],
-c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])},multipoint:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"Point");var b=[];if(a.length>0)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.point.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPoint(b)},linestring:function(a,b){var c,d;d=[];var e=[];c=this.getElementsByTagNameNS(a,this.gmlns,"posList");if(c.length>0){d=this.getChildValue(c[0]);d=d.replace(this.regExes.trimSpace,"");d=d.split(this.regExes.splitSpace);
-var f=parseInt(c[0].getAttribute("dimension")),g,h,i;for(c=0;c<d.length/f;++c){g=c*f;h=d[g];i=d[g+1];g=f==2?null:d[g+2];this.xy?e.push(new OpenLayers.Geometry.Point(h,i,g)):e.push(new OpenLayers.Geometry.Point(i,h,g))}}if(d.length==0){c=this.getElementsByTagNameNS(a,this.gmlns,"coordinates");if(c.length>0){d=this.getChildValue(c[0]);d=d.replace(this.regExes.trimSpace,"");d=d.replace(this.regExes.trimComma,",");f=d.split(this.regExes.splitSpace);for(c=0;c<f.length;++c){d=f[c].split(",");if(d.length==
-2)d[2]=null;this.xy?e.push(new OpenLayers.Geometry.Point(d[0],d[1],d[2])):e.push(new OpenLayers.Geometry.Point(d[1],d[0],d[2]))}}}d=null;if(e.length!=0)d=b?new OpenLayers.Geometry.LinearRing(e):new OpenLayers.Geometry.LineString(e);return d},multilinestring:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"LineString");var b=[];if(a.length>0)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiLineString(b)},polygon:function(a){a=
-this.getElementsByTagNameNS(a,this.gmlns,"LinearRing");var b=[];if(a.length>0)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d],true]))&&b.push(c);return new OpenLayers.Geometry.Polygon(b)},multipolygon:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"Polygon");var b=[];if(a.length>0)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.polygon.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPolygon(b)},envelope:function(a){var b=[],c,d,e=this.getElementsByTagNameNS(a,
-this.gmlns,"lowerCorner");if(e.length>0){c=[];if(e.length>0){c=e[0].firstChild.nodeValue;c=c.replace(this.regExes.trimSpace,"");c=c.split(this.regExes.splitSpace)}if(c.length==2)c[2]=null;var f=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}a=this.getElementsByTagNameNS(a,this.gmlns,"upperCorner");if(a.length>0){c=[];if(a.length>0){c=a[0].firstChild.nodeValue;c=c.replace(this.regExes.trimSpace,"");c=c.split(this.regExes.splitSpace)}if(c.length==
-2)c[2]=null;var g=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}if(f&&g){b.push(new OpenLayers.Geometry.Point(f.x,f.y));b.push(new OpenLayers.Geometry.Point(g.x,f.y));b.push(new OpenLayers.Geometry.Point(g.x,g.y));b.push(new OpenLayers.Geometry.Point(f.x,g.y));b.push(new OpenLayers.Geometry.Point(f.x,f.y));b=new OpenLayers.Geometry.LinearRing(b);d=new OpenLayers.Geometry.Polygon([b])}return d},box:function(a){var b=this.getElementsByTagNameNS(a,
-this.gmlns,"coordinates");var c=a=null;if(b.length>0){b=b[0].firstChild.nodeValue;b=b.split(" ");if(b.length==2){a=b[0].split(",");c=b[1].split(",")}}if(a!==null&&c!==null)return new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(c[0]),parseFloat(c[1]))}},parseAttributes:function(a){var b={};a=a.firstChild;for(var c,d,e;a;){if(a.nodeType==1){a=a.childNodes;for(c=0;c<a.length;++c){d=a[c];if(d.nodeType==1){e=d.childNodes;if(e.length==1){e=e[0];if(e.nodeType==3||e.nodeType==4){d=d.prefix?
-d.nodeName.split(":")[1]:d.nodeName;e=e.nodeValue.replace(this.regExes.trimSpace,"");b[d]=e}}else b[d.nodeName.split(":").pop()]=null}}break}a=a.nextSibling}return b},write:function(a){a instanceof Array||(a=[a]);for(var b=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName),c=0;c<a.length;c++)b.appendChild(this.createFeatureXML(a[c]));return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.featureNS,
-this.featurePrefix+":"+this.geometryName);c.appendChild(b);b=this.createElementNS(this.gmlns,"gml:"+this.featureName);var d=this.createElementNS(this.featureNS,this.featurePrefix+":"+this.layerName);d.setAttribute("fid",a.fid||a.id);d.appendChild(c);for(var e in a.attributes){c=this.createTextNode(a.attributes[e]);var f=this.createElementNS(this.featureNS,this.featurePrefix+":"+e.substring(e.lastIndexOf(":")+1));f.appendChild(c);d.appendChild(f)}b.appendChild(d);return b},buildGeometryNode:function(a){if(this.externalProjection&&
-this.internalProjection){a=a.clone();a.transform(this.internalProjection,this.externalProjection)}var b=a.CLASS_NAME;return this.buildGeometry[b.substring(b.lastIndexOf(".")+1).toLowerCase()].apply(this,[a])},buildGeometry:{point:function(a){var b=this.createElementNS(this.gmlns,"gml:Point");b.appendChild(this.buildCoordinatesNode(a));return b},multipoint:function(a){var b=this.createElementNS(this.gmlns,"gml:MultiPoint");a=a.components;for(var c,d,e=0;e<a.length;e++){c=this.createElementNS(this.gmlns,
-"gml:pointMember");d=this.buildGeometry.point.apply(this,[a[e]]);c.appendChild(d);b.appendChild(c)}return b},linestring:function(a){var b=this.createElementNS(this.gmlns,"gml:LineString");b.appendChild(this.buildCoordinatesNode(a));return b},multilinestring:function(a){var b=this.createElementNS(this.gmlns,"gml:MultiLineString");a=a.components;for(var c,d,e=0;e<a.length;++e){c=this.createElementNS(this.gmlns,"gml:lineStringMember");d=this.buildGeometry.linestring.apply(this,[a[e]]);c.appendChild(d);
-b.appendChild(c)}return b},linearring:function(a){var b=this.createElementNS(this.gmlns,"gml:LinearRing");b.appendChild(this.buildCoordinatesNode(a));return b},polygon:function(a){var b=this.createElementNS(this.gmlns,"gml:Polygon");a=a.components;for(var c,d,e=0;e<a.length;++e){c=e==0?"outerBoundaryIs":"innerBoundaryIs";c=this.createElementNS(this.gmlns,"gml:"+c);d=this.buildGeometry.linearring.apply(this,[a[e]]);c.appendChild(d);b.appendChild(c)}return b},multipolygon:function(a){var b=this.createElementNS(this.gmlns,
-"gml:MultiPolygon");a=a.components;for(var c,d,e=0;e<a.length;++e){c=this.createElementNS(this.gmlns,"gml:polygonMember");d=this.buildGeometry.polygon.apply(this,[a[e]]);c.appendChild(d);b.appendChild(c)}return b},bounds:function(a){var b=this.createElementNS(this.gmlns,"gml:Box");b.appendChild(this.buildCoordinatesNode(a));return b}},buildCoordinatesNode:function(a){var b=this.createElementNS(this.gmlns,"gml:coordinates");b.setAttribute("decimal",".");b.setAttribute("cs",",");b.setAttribute("ts",
-" ");var c=[];if(a instanceof OpenLayers.Bounds){c.push(a.left+","+a.bottom);c.push(a.right+","+a.top)}else{a=a.components?a.components:[a];for(var d=0;d<a.length;d++)c.push(a[d].x+","+a[d].y)}c=this.createTextNode(c.join(" "));b.appendChild(c);return b},CLASS_NAME:"OpenLayers.Format.GML"});if(!OpenLayers.Format.GML)OpenLayers.Format.GML={};
-OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:true,srsName:null,xy:true,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},
-initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.setGeometryTypes();a&&a.featureNS&&this.setNamespace("feature",a.featureNS);this.singleFeatureType=!a||typeof a.featureType==="string"},read:function(a){if(typeof a=="string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b=[];this.readNode(a,{features:b});if(b.length==0){var c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMember");if(c.length){a=0;
-for(var d=c.length;a<d;++a)this.readNode(c[a],{features:b})}else{c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMembers");c.length&&this.readNode(c[0],{features:b})}}return b},readers:{gml:{featureMember:function(a,b){this.readChildNodes(a,b)},featureMembers:function(a,b){this.readChildNodes(a,b)},name:function(a,b){b.name=this.getChildValue(a)},boundedBy:function(a,b){var c={};this.readChildNodes(a,c);if(c.components&&c.components.length>0)b.bounds=c.components[0]},Point:function(a,
-b){var c={points:[]};this.readChildNodes(a,c);if(!b.components)b.components=[];b.components.push(c.points[0])},coordinates:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"");c=c.replace(this.regExes.trimComma,",");c=c.split(this.regExes.splitSpace);for(var d,e=c.length,f=Array(e),g=0;g<e;++g){d=c[g].split(",");f[g]=this.xy?new OpenLayers.Geometry.Point(d[0],d[1],d[2]):new OpenLayers.Geometry.Point(d[1],d[0],d[2])}b.points=f},coord:function(a,b){var c={};this.readChildNodes(a,
-c);if(!b.points)b.points=[];b.points.push(new OpenLayers.Geometry.Point(c.x,c.y,c.z))},X:function(a,b){b.x=this.getChildValue(a)},Y:function(a,b){b.y=this.getChildValue(a)},Z:function(a,b){b.z=this.getChildValue(a)},MultiPoint:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPoint(c.components)]},pointMember:function(a,b){this.readChildNodes(a,b)},LineString:function(a,b){var c={};this.readChildNodes(a,c);if(!b.components)b.components=[];b.components.push(new OpenLayers.Geometry.LineString(c.points))},
-MultiLineString:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiLineString(c.components)]},lineStringMember:function(a,b){this.readChildNodes(a,b)},Polygon:function(a,b){var c={outer:null,inner:[]};this.readChildNodes(a,c);c.inner.unshift(c.outer);if(!b.components)b.components=[];b.components.push(new OpenLayers.Geometry.Polygon(c.inner))},LinearRing:function(a,b){var c={};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.LinearRing(c.points)]},
-MultiPolygon:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)]},polygonMember:function(a,b){this.readChildNodes(a,b)},GeometryCollection:function(a,b){var c={components:[]};this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.Collection(c.components)]},geometryMember:function(a,b){this.readChildNodes(a,b)}},feature:{"*":function(a,b){var c,d=a.localName||a.nodeName.split(":").pop();if(b.features)if(!this.singleFeatureType&&
-OpenLayers.Util.indexOf(this.featureType,d)!==-1)c="_typeName";else{if(d===this.featureType)c="_typeName"}else if(a.childNodes.length==0||a.childNodes.length==1&&a.firstChild.nodeType==3){if(this.extractAttributes)c="_attribute"}else c="_geometry";c&&this.readers.feature[c].apply(this,[a,b])},_typeName:function(a,b){var c={components:[],attributes:{}};this.readChildNodes(a,c);if(c.name)c.attributes.name=c.name;var d=new OpenLayers.Feature.Vector(c.components[0],c.attributes);if(!this.singleFeatureType){d.type=
-a.nodeName.split(":").pop();d.namespace=a.namespaceURI}var e=a.getAttribute("fid")||this.getAttributeNS(a,this.namespaces.gml,"id");if(e)d.fid=e;this.internalProjection&&this.externalProjection&&d.geometry&&d.geometry.transform(this.externalProjection,this.internalProjection);if(c.bounds)d.bounds=c.bounds;b.features.push(d)},_geometry:function(a,b){this.readChildNodes(a,b)},_attribute:function(a,b){var c=a.localName||a.nodeName.split(":").pop(),d=this.getChildValue(a);b.attributes[c]=d}},wfs:{FeatureCollection:function(a,
-b){this.readChildNodes(a,b)}}},write:function(a){a=this.writeNode("gml:"+(a instanceof Array?"featureMembers":"featureMember"),a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:{featureMember:function(a){var b=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",a,b);return b},MultiPoint:function(a){for(var b=this.createElementNSPlus("gml:MultiPoint"),c=0;c<a.components.length;++c)this.writeNode("pointMember",
-a.components[c],b);return b},pointMember:function(a){var b=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",a,b);return b},MultiLineString:function(a){for(var b=this.createElementNSPlus("gml:MultiLineString"),c=0;c<a.components.length;++c)this.writeNode("lineStringMember",a.components[c],b);return b},lineStringMember:function(a){var b=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",a,b);return b},MultiPolygon:function(a){for(var b=this.createElementNSPlus("gml:MultiPolygon"),
-c=0;c<a.components.length;++c)this.writeNode("polygonMember",a.components[c],b);return b},polygonMember:function(a){var b=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",a,b);return b},GeometryCollection:function(a){for(var b=this.createElementNSPlus("gml:GeometryCollection"),c=0,d=a.components.length;c<d;++c)this.writeNode("geometryMember",a.components[c],b);return b},geometryMember:function(a){var b=this.createElementNSPlus("gml:geometryMember");a=this.writeNode("feature:_geometry",
-a);b.appendChild(a.firstChild);return b}},feature:{_typeName:function(a){var b=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:a.fid}});a.geometry&&this.writeNode("feature:_geometry",a.geometry,b);for(var c in a.attributes){var d=a.attributes[c];d!=null&&this.writeNode("feature:_attribute",{name:c,value:d},b)}return b},_geometry:function(a){if(this.externalProjection&&this.internalProjection)a=a.clone().transform(this.internalProjection,this.externalProjection);var b=this.createElementNSPlus("feature:"+
-this.geometryName);a=this.writeNode("gml:"+this.geometryTypes[a.CLASS_NAME],a,b);this.srsName&&a.setAttribute("srsName",this.srsName);return b},_attribute:function(a){return this.createElementNSPlus("feature:"+a.name,{value:a.value})}},wfs:{FeatureCollection:function(a){for(var b=this.createElementNSPlus("wfs:FeatureCollection"),c=0,d=a.length;c<d;++c)this.writeNode("gml:featureMember",a[c],b);return b}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint",
-"OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.Base"});
-OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({outerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.outer=c.components[0]},innerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},Box:function(a,b){var c=
-{};this.readChildNodes(a,c);if(!b.components)b.components=[];var d=c.points[0];c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){a=this.writeNode(a instanceof Array?"wfs:FeatureCollection":"gml:featureMember",a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);
-return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[a],b);return b},coordinates:function(a){for(var b=a.length,c=Array(b),d,e=0;e<b;++e){d=a[e];c[e]=this.xy?d.x+","+d.y:d.y+","+d.x;if(d.z!=undefined)c[e]+=","+d.z}return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:b==1?c[0]:c.join(" ")})},LineString:function(a){var b=
-this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",a.components,b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",a.components[0],b);for(var c=1;c<a.components.length;++c)this.writeNode("innerBoundaryIs",a.components[c],b);return b},outerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",a,b);return b},innerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:innerBoundaryIs");
-this.writeNode("LinearRing",a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",a.components,b);return b},Box:function(a){var b=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:a.left,y:a.bottom},{x:a.right,y:a.top}],b);this.srsName&&b.setAttribute("srsName",this.srsName);return b}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},
-CLASS_NAME:"OpenLayers.Format.GML.v2"});
-OpenLayers.Format.GML.v3=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/1.0.0/gmlsf.xsd",curve:false,multiCurve:true,surface:false,multiSurface:true,initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({featureMembers:function(a,b){this.readChildNodes(a,b)},Curve:function(a,b){var c={points:[]};this.readChildNodes(a,c);if(!b.components)b.components=
-[];b.components.push(new OpenLayers.Geometry.LineString(c.points))},segments:function(a,b){this.readChildNodes(a,b)},LineStringSegment:function(a,b){var c={};this.readChildNodes(a,c);c.points&&Array.prototype.push.apply(b.points,c.points)},pos:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(this.regExes.splitSpace);c=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2]);b.points=[c]},posList:function(a,b){for(var c=this.getChildValue(a).replace(this.regExes.trimSpace,
-"").split(this.regExes.splitSpace),d=parseInt(a.getAttribute("dimension"))||2,e,f,g,h=Array(c.length/d),i=0,j=c.length;i<j;i+=d){e=c[i];f=c[i+1];g=d==2?undefined:c[i+2];h[i/d]=this.xy?new OpenLayers.Geometry.Point(e,f,g):new OpenLayers.Geometry.Point(f,e,g)}b.points=h},Surface:function(a,b){this.readChildNodes(a,b)},patches:function(a,b){this.readChildNodes(a,b)},PolygonPatch:function(a,b){this.readers.gml.Polygon.apply(this,[a,b])},exterior:function(a,b){var c={};this.readChildNodes(a,c);b.outer=
-c.components[0]},interior:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},MultiCurve:function(a,b){var c={components:[]};this.readChildNodes(a,c);if(c.components.length>0)b.components=[new OpenLayers.Geometry.MultiLineString(c.components)]},curveMember:function(a,b){this.readChildNodes(a,b)},MultiSurface:function(a,b){var c={components:[]};this.readChildNodes(a,c);if(c.components.length>0)b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)]},surfaceMember:function(a,
-b){this.readChildNodes(a,b)},surfaceMembers:function(a,b){this.readChildNodes(a,b)},pointMembers:function(a,b){this.readChildNodes(a,b)},lineStringMembers:function(a,b){this.readChildNodes(a,b)},polygonMembers:function(a,b){this.readChildNodes(a,b)},geometryMembers:function(a,b){this.readChildNodes(a,b)},Envelope:function(a,b){var c={points:Array(2)};this.readChildNodes(a,c);if(!b.components)b.components=[];var d=c.points[0];c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))},
-lowerCorner:function(a,b){var c={};this.readers.gml.pos.apply(this,[a,c]);b.points[0]=c.points[0]},upperCorner:function(a,b){var c={};this.readers.gml.pos.apply(this,[a,c]);b.points[1]=c.points[0]}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){a=this.writeNode("gml:"+(a instanceof Array?"featureMembers":"featureMember"),a);this.setAttributeNS(a,this.namespaces.xsi,
-"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({featureMembers:function(a){for(var b=this.createElementNSPlus("gml:featureMembers"),c=0,d=a.length;c<d;++c)this.writeNode("feature:_typeName",a[c],b);return b},Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("pos",a,b);return b},pos:function(a){return this.createElementNSPlus("gml:pos",{value:this.xy?a.x+" "+a.y:a.y+" "+a.x})},
-LineString:function(a){var b=this.createElementNSPlus("gml:LineString");this.writeNode("posList",a.components,b);return b},Curve:function(a){var b=this.createElementNSPlus("gml:Curve");this.writeNode("segments",a,b);return b},segments:function(a){var b=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",a,b);return b},LineStringSegment:function(a){var b=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",a.components,b);return b},posList:function(a){for(var b=
-a.length,c=Array(b),d,e=0;e<b;++e){d=a[e];c[e]=this.xy?d.x+" "+d.y:d.y+" "+d.x}return this.createElementNSPlus("gml:posList",{value:c.join(" ")})},Surface:function(a){var b=this.createElementNSPlus("gml:Surface");this.writeNode("patches",a,b);return b},patches:function(a){var b=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",a,b);return b},PolygonPatch:function(a){var b=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",
-a.components[0],b);for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",a.components[0],b);for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},exterior:function(a){var b=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",a,b);return b},interior:function(a){var b=this.createElementNSPlus("gml:interior");
-this.writeNode("LinearRing",a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",a.components,b);return b},MultiCurve:function(a){for(var b=this.createElementNSPlus("gml:MultiCurve"),c=0,d=a.components.length;c<d;++c)this.writeNode("curveMember",a.components[c],b);return b},curveMember:function(a){var b=this.createElementNSPlus("gml:curveMember");this.curve?this.writeNode("Curve",a,b):this.writeNode("LineString",a,b);return b},MultiSurface:function(a){for(var b=
-this.createElementNSPlus("gml:MultiSurface"),c=0,d=a.components.length;c<d;++c)this.writeNode("surfaceMember",a.components[c],b);return b},surfaceMember:function(a){var b=this.createElementNSPlus("gml:surfaceMember");this.surface?this.writeNode("Surface",a,b):this.writeNode("Polygon",a,b);return b},Envelope:function(a){var b=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",a,b);this.writeNode("upperCorner",a,b);this.srsName&&b.setAttribute("srsName",this.srsName);return b},lowerCorner:function(a){return this.createElementNSPlus("gml:lowerCorner",
-{value:this.xy?a.left+" "+a.bottom:a.bottom+" "+a.left})},upperCorner:function(a){return this.createElementNSPlus("gml:upperCorner",{value:this.xy?a.right+" "+a.top:a.top+" "+a.right})}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":this.curve===
-true?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":this.multiCurve===false?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":this.surface===true?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":this.multiSurface===false?"MultiPolygon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.v3"});
-OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,
-b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escape");c.value2regex(d,e,f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,
-feature:OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",
-{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Box",a.value,b);a.projection&&c.setAttribute("srsName",a.projection);return b}},OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Format.GML.v2.prototype.writers.feature},
-writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Box",a.value);a.projection&&d.setAttribute("srsName",a.projection);c.appendChild(d);return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});
-OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=a.getAttribute("matchCase");c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!(c==="false"||c==="0")});this.readChildNodes(a,
-c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,b){var c=a.getAttribute("matchCase");c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!(c==="false"||c==="0")});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escapeChar");c.value2regex(d,e,
-f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v3.prototype.readers.gml,feature:OpenLayers.Format.GML.v3.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",
-{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Envelope",a.value);a.projection&&c.setAttribute("srsName",
-a.projection);b.appendChild(c);return b}},OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature},writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Envelope",a.value);a.projection&&d.setAttribute("srsName",a.projection);
-c.appendChild(d);return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});
-OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",gco:"http://www.isotc211.org/2005/gco",geonet:"http://www.fao.org/geonetwork",gmd:"http://www.isotc211.org/2005/gmd",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},
-defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){if(typeof a==
-"string")a=OpenLayers.Format.XML.prototype.read.apply(this,[a]);if(a&&a.nodeType==9)a=a.documentElement;var b={};this.readNode(a,b);return b},readers:{csw:{GetRecordsResponse:function(a,b){b.records=[];this.readChildNodes(a,b);var c=this.getAttributeNS(a,"","version");if(c!="")b.version=c},RequestId:function(a,b){b.RequestId=this.getChildValue(a)},SearchStatus:function(a,b){b.SearchStatus={};var c=this.getAttributeNS(a,"","timestamp");if(c!="")b.SearchStatus.timestamp=c},SearchResults:function(a,
-b){this.readChildNodes(a,b);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].name=="numberOfRecordsMatched"||c[e].name=="numberOfRecordsReturned"||c[e].name=="nextRecord"?parseInt(c[e].nodeValue):c[e].nodeValue;b.SearchResults=d},SummaryRecord:function(a,b){var c={type:"SummaryRecord"};this.readChildNodes(a,c);b.records.push(c)},BriefRecord:function(a,b){var c={type:"BriefRecord"};this.readChildNodes(a,c);b.records.push(c)},DCMIRecord:function(a,b){var c={type:"DCMIRecord"};this.readChildNodes(a,
-c);b.records.push(c)},Record:function(a,b){var c={type:"Record"};this.readChildNodes(a,c);b.records.push(c)},"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]=this.getChildValue(a)}},gco:{Measure:function(a,b){b.Measure={value:this.getChildValue(a)};for(var c=a.attributes,d=0,e=c.length;d<e;++d)b.Measure[c[d].name]=c[d].nodeValue},"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]={value:this.getChildValue(a)}}},geonet:{info:function(a,b){var c={};this.readChildNodes(a,
-c);b.gninfo=c}},gmd:{MD_Metadata:function(a,b){var c={type:"MD_Metadata"};this.readChildNodes(a,c);b.records.push(c)},MD_TopicCategoryCode:function(a,b){b.topicCategoryCode=this.getChildValue(a)},URL:function(a,b){b.URL=this.getChildValue(a)},extent:function(a,b){if(a.parentNode.localName=="MD_DataIdentification"||a.parentNode.nodeName.split(":").pop()=="MD_DataIdentification"){if(!(b.extent instanceof Array))b.extent=[];b.extent.push(this.readChildNodes(a))}else b.extent=this.readChildNodes(a)},
-"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();if(c in this.readers.gmd._createOneChild)b[c]=this.readChildNodes(a);else if(c in this.readers.gmd._createManyChildren){b[c]instanceof Array||(b[c]=[]);b[c].push(this.readChildNodes(a))}else if(c in this.readers.gmd._pass)this.readChildNodes(a,b);else if(c in this.readers.gmd._readAttributes){c=a.attributes;for(var d=0,e=c.length;d<e;++d)b[c[d].name]=c[d].nodeValue}},_readAttributes:{CI_RoleCode:null,MD_ProgressCode:null,MD_KeywordTypeCode:null,
-MD_RestrictionCode:null,MD_SpatialRepresentationTypeCode:null,MD_CharacterSetCode:null,CI_DateTypeCode:null,MD_TopologyLevelCode:null,MD_GeometricObjectTypeCode:null,MD_DimensionNameTypeCode:null,MD_CellGeometryCode:null,MD_MaintenanceFrequencyCode:null,MD_ScopeCode:null},_pass:{CI_ResponsibleParty:null,CI_Contact:null,CI_Telephone:null,CI_Address:null,MD_DataIdentification:null,MD_Keywords:null,MD_LegalConstraints:null,MD_Resolution:null,MD_RepresentativeFraction:null,EX_Extent:null,EX_GeographicBoundingBox:null,
-EX_TemporalExtent:null,MD_Distribution:null,MD_Distributor:null,MD_DigitalTransferOptions:null,MD_Format:null,MD_Medium:null,CI_OnlineResource:null,MD_ReferenceSystem:null,RS_Identifier:null,CI_Citation:null,CI_Date:null,MD_GridSpatialRepresentation:null,MD_VectorSpatialRepresentation:null,MD_GeometricObjects:null,MD_Dimension:null,MD_MaintenanceInformation:null,MD_ScopeDescription:null,MD_BrowseGraphic:null,DQ_DataQuality:null,DQ_Scope:null,DQ_Element:null,LI_Lineage:null,LI_Source:null,LI_ProcessStep:null,
-MD_ReferenceSystem:null},_createManyChildren:{contact:null,voice:null,facsimile:null,deliveryPoint:null,electronicMailAddress:null,identificationInfo:null,pointOfContact:null,status:null,descriptiveKeywords:null,keyword:null,resourceConstraints:null,useLimitation:null,accessConstraints:null,useConstraints:null,otherConstraints:null,spatialResolution:null,spatialRepresentationType:null,language:null,characterSet:null,topicCategory:null,geographicElement:null,temporalElement:null,distributor:null,transferOptions:null,
-distributionFormat:null,distributionOrderProcess:null,distributorFormat:null,formatDistributor:null,distributorTransferOptions:null,onLine:null,referenceSystemInfo:null,alternateTitle:null,date:null,identifier:null,citedResponsibleParty:null,presentationForm:null,spatialRepresentationInfo:null,geometricObjects:null,axisDimensionProperties:null,resourceMaintenance:null,updateScope:null,updateScopeDescription:null,maintenanceNote:null,attributes:null,features:null,featureInstances:null,attributeInstances:null,
-graphicOverview:null,dataQualityInfo:null,report:null,levelDescription:null,processStep:null,source:null,sourceExtent:null,sourceStep:null,processor:null},_createOneChild:{dateTime:null,rationale:null,description:null,statement:null,scaleDenominator:null,sourceReferenceSystem:null,sourceCitation:null,level:null,scope:null,lineage:null,fileName:null,fileDescription:null,fileType:null,other:null,maintenanceAndUpdateFrequency:null,userDefinedMaintenanceFrequency:null,dataset:null,citation:null,dateOfNextUpdate:null,
-dimensionName:null,dimensionSize:null,resolution:null,numberOfDimensions:null,cellGeometry:null,transformationParameterAvailability:null,geometricObjectType:null,geometricObjectCount:null,topologyLevel:null,dateType:null,title:null,edition:null,editionDate:null,series:null,otherCitationDetails:null,collectiveTitle:null,ISBN:null,ISSN:null,authority:null,code:null,referenceSystemIdentifier:null,linkage:null,protocol:null,unitsOfDistribution:null,transferSize:null,offLine:null,name:null,version:null,
-amendmentNumber:null,specification:null,fileDecompressionTechnique:null,distributorContact:null,distributionInfo:null,westBoundLongitude:null,eastBoundLongitude:null,southBoundLatitude:null,northBoundLatitude:null,supplementalInformation:null,denominator:null,equivalentScale:null,type:null,purpose:null,"abstract":null,city:null,administrativeArea:null,postalCode:null,country:null,address:null,phone:null,contactInfo:null,role:null,fileIdentifier:null,language:null,dateStamp:null,metadataStandardName:null,
-metadataStandardVersion:null,individualName:null,organisationName:null,positionName:null}},gml:{TimePeriod:function(a,b){b.TimePeriod={};this.readChildNodes(a,b.TimePeriod)},beginPosition:function(a,b){b.beginPosition=this.getChildValue(a)},endPosition:function(a,b){b.endPosition=this.getChildValue(a)}},dc:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]instanceof Array||(b[c]=[]);for(var d={},e=a.attributes,f=0,g=e.length;f<g;++f)d[e[f].name]=e[f].nodeValue;d.value=this.getChildValue(a);
-b[c].push(d)}},dct:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();b[c]instanceof Array||(b[c]=[]);b[c].push(this.getChildValue(a))}},ows:OpenLayers.Util.applyDefaults({BoundingBox:function(a,b){if(b.bounds){b.BoundingBox=[{crs:b.projection,value:[b.bounds.left,b.bounds.bottom,b.bounds.right,b.bounds.top]}];delete b.projection;delete b.bounds}OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows.BoundingBox.apply(this,arguments)}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows)},
-write:function(a){a=this.writeNode("csw:GetRecords",a);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{ogc:{SortBy:function(a){var b=this.createElementNSPlus("ogc:SortBy");a.SortProperty&&this.writeNode("ogc:SortProperty",a.SortProperty,b);return b},SortProperty:function(a){var b=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",a.PropertyName,b);this.writeNode("ogc:SortOrder",a.SortOrder?a.SortOrder:"ASC",b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",
-{value:a})},SortOrder:function(a){return this.createElementNSPlus("ogc:SortOrder",{value:a})}},csw:{GetRecords:function(a){a||(a={});var b=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:a.requestId||this.requestId,resultType:a.resultType||this.resultType,outputFormat:a.outputFormat||this.outputFormat,outputSchema:a.outputSchema||this.outputSchema,startPosition:a.startPosition||this.startPosition,maxRecords:a.maxRecords||this.maxRecords}});if(a.DistributedSearch||
-this.DistributedSearch)this.writeNode("csw:DistributedSearch",a.DistributedSearch||this.DistributedSearch,b);var c=a.ResponseHandler||this.ResponseHandler;if(c instanceof Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ResponseHandler",c[d],b);this.writeNode("Query",a.Query||this.Query,b);return b},DistributedSearch:function(a){return this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:a.hopCount}})},ResponseHandler:function(a){return this.createElementNSPlus("csw:ResponseHandler",
-{value:a.value})},Query:function(a){a||(a={});var b=this.createElementNSPlus("csw:Query",{attributes:{typeNames:a.typeNames||"csw:Record"}}),c=a.ElementName;if(c instanceof Array&&c.length>0)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ElementName",c[d],b);else this.writeNode("csw:ElementSetName",a.ElementSetName||{value:"summary"},b);a.Constraint&&this.writeNode("csw:Constraint",a.Constraint,b);a.SortBy&&this.writeNode("ogc:SortBy",a.SortBy,b);return b},ElementName:function(a){return this.createElementNSPlus("csw:ElementName",
-{value:a.value})},ElementSetName:function(a){return this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:a.typeNames},value:a.value})},Constraint:function(a){var b=this.createElementNSPlus("csw:Constraint",{attributes:{version:a.version}});if(a.Filter){var c=new OpenLayers.Format.Filter({version:a.version});b.appendChild(c.write(a.Filter))}else if(a.CqlText){a=this.createElementNSPlus("CqlText",{value:a.CqlText.value});b.appendChild(a)}return b}}},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});
Modified: sandbox/camptocamp/ifremer/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js
--- sandbox/camptocamp/ifremer/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js 2011-05-16 07:12:03 UTC (rev 11969)
+++ sandbox/camptocamp/ifremer/openlayers/lib/OpenLayers/Format/CSWGetRecords/v2_0_2.js 2011-05-17 12:57:23 UTC (rev 11970)
@@ -193,6 +193,10 @@
obj.version = version;
+ "GetRecordByIdResponse": function(node, obj) {
+ obj.records = [];
+ this.readChildNodes(node, obj);
"RequestId": function(node, obj) {
obj.RequestId = this.getChildValue(node);
More information about the Commits
