[OpenLayers-Commits] r11971 - in trunk/openlayers: . build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue May 17 11:29:45 EDT 2011
Author: tschaub
Date: 2011-05-17 08:29:44 -0700 (Tue, 17 May 2011)
New Revision: 11971
   trunk/openlayers/build/license.txt
   trunk/openlayers/license.txt
Switching to the 2-clause BSD license - aka the FreeBSD license.
Modified: trunk/openlayers/build/license.txt
--- trunk/openlayers/build/license.txt	2011-05-17 12:57:23 UTC (rev 11970)
+++ trunk/openlayers/build/license.txt	2011-05-17 15:29:44 UTC (rev 11971)
@@ -2,7 +2,7 @@
   OpenLayers.js -- OpenLayers Map Viewer Library
-  Copyright 2005-2011 OpenLayers Contributors, released under the Clear BSD
+  Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
   license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
   for the full text of the license.
Modified: trunk/openlayers/license.txt
--- trunk/openlayers/license.txt	2011-05-17 12:57:23 UTC (rev 11970)
+++ trunk/openlayers/license.txt	2011-05-17 15:29:44 UTC (rev 11971)
@@ -1,38 +1,31 @@
 This license applies to all code and content in the 'branches', 'trunk', and
 'project' directories of the Openlayers code repository at svn.openlayers.org,
 and applies to all release of OpenLayers later than 2.5.
-Copyright (c) 2005-2011 OpenLayers Contributors. See authors.txt for
-  full list.
-All rights reserved.
+Copyright 2005-2011 OpenLayers Contributors. All rights reserved. See
+authors.txt for full list.
-Redistribution and use in source and binary forms, with or without
-modification, are permitted (subject to the limitations in the
-disclaimer below) provided that the following conditions are met:
+Redistribution and use in source and binary forms, with or without modification,
+are permitted provided that the following conditions are met:
- * Redistributions of source code must retain the above copyright
-   notice, this list of conditions and the following disclaimer.
+ 1. Redistributions of source code must retain the above copyright notice, this
+list of conditions and the following disclaimer.
- * Redistributions in binary form must reproduce the above copyright
-   notice, this list of conditions and the following disclaimer in the
-   documentation and/or other materials provided with the
-   distribution.
+ 2. Redistributions in binary form must reproduce the above copyright notice,
+this list of conditions and the following disclaimer in the documentation and/or
+other materials provided with the distribution.
- * Neither the name of OpenLayers nor the names of its contributors
-   may be used to endorse or promote products derived from this
-   software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY OPENLAYERS CONTRIBUTORS ``AS IS'' AND ANY EXPRESS
+OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
+SHALL COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-NO EXPRESS OR IMPLIED LICENSES TO ANY PARTY'S PATENT RIGHTS ARE
-GRANTED BY THIS LICENSE.  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT
-HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED
-WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
-MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
-DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
-LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
-BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
-WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
-OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
-IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+The views and conclusions contained in the software and documentation are those
+of the authors and should not be interpreted as representing official policies,
+either expressed or implied, of OpenLayers Contributors.
\ No newline at end of file
More information about the Commits mailing list
