[OpenLayers-Commits] r12012 - sandbox/elemoine/slim/build
commits-20090109 at openlayers.org
Wed May 25 16:51:53 EDT 2011
Author: erilem
Date: 2011-05-25 13:51:53 -0700 (Wed, 25 May 2011)
New Revision: 12012
Added:
sandbox/elemoine/slim/build/OpenLayers.mobile.js
add a mobile-specific build
Added: sandbox/elemoine/slim/build/OpenLayers.mobile.js
--- sandbox/elemoine/slim/build/OpenLayers.mobile.js (rev 0)
+++ sandbox/elemoine/slim/build/OpenLayers.mobile.js 2011-05-25 20:51:53 UTC (rev 12012)
@@ -0,0 +1,360 @@
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
+ license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+ for the full text of the license.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used please see the
+ OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ * (c) 2005 Sam Stephenson <sam at conio.net>
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+* Contains portions of Rico <http://openrico.org/>
+* Copyright 2005 Sabre Airline Solutions
+* Licensed under the Apache License, Version 2.0 (the "License"); you
+* may not use this file except in compliance with the License. You
+* may obtain a copy of the License at
+* http://www.apache.org/licenses/LICENSE-2.0
+* Unless required by applicable law or agreed to in writing, software
+* distributed under the License is distributed on an "AS IS" BASIS,
+* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+* implied. See the License for the specific language governing
+* permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * 3. Neither the name of Google Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ * specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */var OpenLayers={VERSION_NUMBER:"$Revision$",singleFile:!0,_getScriptLocation:function(){for(var a=/(^|(.*?\/))(OpenLayers.js)(\?|$)/,b=document.getElementsByTagName("script"),c,d="",e=0,f=b.length;e<f;e++)if(c=b[e].getAttribute("src"))if(c=c.match(a)){d=c[1];break}return function(){return d}}()};
+OpenLayers.Class=function(){var a=arguments.length,b=arguments[0],c=arguments[a-1],d=typeof c.initialize=="function"?c.initialize:function(){b.apply(this,arguments)};a>1?(a=[d,b].concat(Array.prototype.slice.call(arguments).slice(1,a-1),c),OpenLayers.inherit.apply(null,a)):d.prototype=c;return d};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){arguments&&arguments[0]!=OpenLayers.Class.isPrototype&&this.initialize.apply(this,arguments)}};
+OpenLayers.Class.inherit=function(a){var b=function(){a.call(this)},c=[b].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,c);return b.prototype};OpenLayers.inherit=function(a,b){var c=function(){};c.prototype=b.prototype;a.prototype=new c;var d,e,c=2;for(d=arguments.length;c<d;c++){e=arguments[c];if(typeof e==="function")e=e.prototype;OpenLayers.Util.extend(a.prototype,e)}};OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.extend=function(a,b){a=a||{};if(b){for(var c in b){var d=b[c];d!==void 0&&(a[c]=d)}if(!(typeof window.Event=="function"&&b instanceof window.Event)&&b.hasOwnProperty&&b.hasOwnProperty("toString"))a.toString=b.toString}return a};
+OpenLayers.String={startsWith:function(a,b){return a.indexOf(b)==0},contains:function(a,b){return a.indexOf(b)!=-1},trim:function(a){return a.replace(/^\s\s*/,"").replace(/\s\s*$/,"")},camelize:function(a){for(var a=a.split("-"),b=a[0],c=1,d=a.length;c<d;c++){var e=a[c];b+=e.charAt(0).toUpperCase()+e.substring(1)}return b},format:function(a,b,c){b||(b=window);return a.replace(OpenLayers.String.tokenRegEx,function(a,e){for(var f,g=e.split(/\.+/),h=0;h<g.length;h++)h==0&&(f=b),f=f[g[h]];typeof f=="function"&&
+(f=c?f.apply(null,c):f());return typeof f=="undefined"?"undefined":f})},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(a){return OpenLayers.String.numberRegEx.test(a)},numericIf:function(a){return OpenLayers.String.isNumeric(a)?parseFloat(a):a}};
+if(!String.prototype.startsWith)String.prototype.startsWith=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.startsWith"}));return OpenLayers.String.startsWith(this,a)};if(!String.prototype.contains)String.prototype.contains=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.contains"}));return OpenLayers.String.contains(this,a)};
+if(!String.prototype.trim)String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.trim"}));return OpenLayers.String.trim(this)};if(!String.prototype.camelize)String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.camelize"}));return OpenLayers.String.camelize(this)};
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(a,b){var c=0;b>0&&(c=parseFloat(a.toPrecision(b)));return c},format:function(a,b,c,d){b=typeof b!="undefined"?b:0;c=typeof c!="undefined"?c:OpenLayers.Number.thousandsSeparator;d=typeof d!="undefined"?d:OpenLayers.Number.decimalSeparator;b!=null&&(a=parseFloat(a.toFixed(b)));var e=a.toString().split(".");e.length==1&&b==null&&(b=0);a=e[0];if(c)for(var f=/(-?[0-9]+)([0-9]{3})/;f.test(a);)a=a.replace(f,"$1"+c+"$2");
+b==0?b=a:(c=e.length>1?e[1]:"0",b!=null&&(c+=Array(b-c.length+1).join("0")),b=a+d+c);return b}};if(!Number.prototype.limitSigDigs)Number.prototype.limitSigDigs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Number.limitSigDigs"}));return OpenLayers.Number.limitSigDigs(this,a)};
+OpenLayers.Function={bind:function(a,b){var c=Array.prototype.slice.apply(arguments,[2]);return function(){var d=c.concat(Array.prototype.slice.apply(arguments,[0]));return a.apply(b,d)}},bindAsEventListener:function(a,b){return function(c){return a.call(b,c||window.event)}},False:function(){return!1},True:function(){return!0},Void:function(){}};
+if(!Function.prototype.bind)Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bind"}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments)};
+if(!Function.prototype.bindAsEventListener)Function.prototype.bindAsEventListener=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bindAsEventListener"}));return OpenLayers.Function.bindAsEventListener(this,a)};OpenLayers.Array={filter:function(a,b,c){var d=[];if(Array.prototype.filter)d=a.filter(b,c);else{var e=a.length;if(typeof b!="function")throw new TypeError;for(var f=0;f<e;f++)if(f in a){var g=a[f];b.call(c,g,f,a)&&d.push(g)}}return d}};
+OpenLayers.Date={toISOString:function(){if("toISOString"in Date.prototype)return function(a){return a.toISOString()};else{var a=function(a,c){for(var d=a+"";d.length<c;)d="0"+d;return d};return function(b){return isNaN(b.getTime())?"Invalid Date":b.getUTCFullYear()+"-"+a(b.getUTCMonth()+1,2)+"-"+a(b.getUTCDate(),2)+"T"+a(b.getUTCHours(),2)+":"+a(b.getUTCMinutes(),2)+":"+a(b.getUTCSeconds(),2)+"."+a(b.getUTCMilliseconds(),3)+"Z"}}}(),parse:function(a){var b;if((a=a.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/))&&
+(a[1]||a[7])){b=parseInt(a[1],10)||0;var c=parseInt(a[2],10)-1||0,d=parseInt(a[3],10)||1;b=new Date(Date.UTC(b,c,d));if(c=a[7]){var d=parseInt(a[4],10),e=parseInt(a[5],10),f=parseFloat(a[6]),g=f|0;b.setUTCHours(d,e,g,Math.round(1E3*(f-g)));c!=="Z"&&(c=parseInt(c,10),a=parseInt(a[8],10)||0,b=new Date(b.getTime()+-1E3*(60*c*60+a*60)))}}else b=new Date("invalid");return b}};
+OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(a,b,c,d){if(a!=null)this.left=OpenLayers.Util.toFloat(a);if(b!=null)this.bottom=OpenLayers.Util.toFloat(b);if(c!=null)this.right=OpenLayers.Util.toFloat(c);if(d!=null)this.top=OpenLayers.Util.toFloat(d)},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top)},equals:function(a){var b=!1;a!=null&&(b=this.left==a.left&&this.right==a.right&&this.top==a.top&&
+this.bottom==a.bottom);return b},toString:function(){return[this.left,this.bottom,this.right,this.top].join(",")},toArray:function(a){return a===!0?[this.bottom,this.left,this.top,this.right]:[this.left,this.bottom,this.right,this.top]},toBBOX:function(a,b){a==null&&(a=6);var c=Math.pow(10,a),d=Math.round(this.left*c)/c,e=Math.round(this.bottom*c)/c,f=Math.round(this.right*c)/c,c=Math.round(this.top*c)/c;return b===!0?e+","+d+","+c+","+f:d+","+e+","+f+","+c},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,
+this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])])},getWidth:function(){return this.right-this.left},getHeight:function(){return this.top-this.bottom},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight())},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2)},getCenterLonLat:function(){if(!this.centerLonLat)this.centerLonLat=
+new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);return this.centerLonLat},scale:function(a,b){b==null&&(b=this.getCenterLonLat());var c,d;b.CLASS_NAME=="OpenLayers.LonLat"?(c=b.lon,d=b.lat):(c=b.x,d=b.y);return new OpenLayers.Bounds((this.left-c)*a+c,(this.bottom-d)*a+d,(this.right-c)*a+c,(this.top-d)*a+d)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(c);return null}return new OpenLayers.Bounds(this.left+a,this.bottom+
+b,this.right+a,this.top+b)},extend:function(a){var b=null;if(a){switch(a.CLASS_NAME){case "OpenLayers.LonLat":b=new OpenLayers.Bounds(a.lon,a.lat,a.lon,a.lat);break;case "OpenLayers.Geometry.Point":b=new OpenLayers.Bounds(a.x,a.y,a.x,a.y);break;case "OpenLayers.Bounds":b=a}if(b){this.centerLonLat=null;if(this.left==null||b.left<this.left)this.left=b.left;if(this.bottom==null||b.bottom<this.bottom)this.bottom=b.bottom;if(this.right==null||b.right>this.right)this.right=b.right;if(this.top==null||b.top>
+this.top)this.top=b.top}}},containsLonLat:function(a,b){return this.contains(a.lon,a.lat,b)},containsPixel:function(a,b){return this.contains(a.x,a.y,b)},contains:function(a,b,c){c==null&&(c=!0);if(a==null||b==null)return!1;var a=OpenLayers.Util.toFloat(a),b=OpenLayers.Util.toFloat(b),d=!1;return d=c?a>=this.left&&a<=this.right&&b>=this.bottom&&b<=this.top:a>this.left&&a<this.right&&b>this.bottom&&b<this.top},intersectsBounds:function(a,b){b==null&&(b=!0);var c=!1,d=this.left==a.right||this.right==
+a.left||this.top==a.bottom||this.bottom==a.top;if(b||!d)var c=a.top>=this.bottom&&a.top<=this.top||this.top>a.bottom&&this.top<a.top,d=a.left>=this.left&&a.left<=this.right||this.left>=a.left&&this.left<=a.right,e=a.right>=this.left&&a.right<=this.right||this.right>=a.left&&this.right<=a.right,c=(a.bottom>=this.bottom&&a.bottom<=this.top||this.bottom>=a.bottom&&this.bottom<=a.top||c)&&(d||e);return c},containsBounds:function(a,b,c){b==null&&(b=!1);c==null&&(c=!0);var d=this.contains(a.left,a.bottom,
+c),e=this.contains(a.right,a.bottom,c),f=this.contains(a.left,a.top,c),a=this.contains(a.right,a.top,c);return b?d||e||f||a:d&&e&&f&&a},determineQuadrant:function(a){var b="",c=this.getCenterLonLat();b+=a.lat<c.lat?"b":"t";b+=a.lon<c.lon?"l":"r";return b},transform:function(a,b){this.centerLonLat=null;var c=OpenLayers.Projection.transform({x:this.left,y:this.bottom},a,b),d=OpenLayers.Projection.transform({x:this.right,y:this.bottom},a,b),e=OpenLayers.Projection.transform({x:this.left,y:this.top},
+a,b),f=OpenLayers.Projection.transform({x:this.right,y:this.top},a,b);this.left=Math.min(c.x,e.x);this.bottom=Math.min(c.y,d.y);this.right=Math.max(d.x,f.x);this.top=Math.max(e.y,f.y);return this},wrapDateLine:function(a,b){var b=b||{},c=b.leftTolerance||0,d=b.rightTolerance||0,e=this.clone();if(a){for(;e.left<a.left&&e.right-d<=a.left;)e=e.add(a.getWidth(),0);for(;e.left+c>=a.right&&e.right>a.right;)e=e.add(-a.getWidth(),0)}return e},CLASS_NAME:"OpenLayers.Bounds"});
+OpenLayers.Bounds.fromString=function(a,b){var c=a.split(",");return OpenLayers.Bounds.fromArray(c,b)};OpenLayers.Bounds.fromArray=function(a,b){return b===!0?new OpenLayers.Bounds(parseFloat(a[1]),parseFloat(a[0]),parseFloat(a[3]),parseFloat(a[2])):new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(a[2]),parseFloat(a[3]))};OpenLayers.Bounds.fromSize=function(a){return new OpenLayers.Bounds(0,a.h,a.w,0)};
+OpenLayers.Bounds.oppositeQuadrant=function(a){var b="";b+=a.charAt(0)=="t"?"b":"t";b+=a.charAt(1)=="l"?"r":"l";return b};
+OpenLayers.Element={visible:function(a){return OpenLayers.Util.getElement(a).style.display!="none"},toggle:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]),d=OpenLayers.Element.visible(c)?"hide":"show";OpenLayers.Element[d](c)}},hide:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = 'none';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=
+"none"}},show:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = '';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=""}},remove:function(a){a=OpenLayers.Util.getElement(a);a.parentNode.removeChild(a)},getHeight:function(a){a=OpenLayers.Util.getElement(a);return a.offsetHeight},getDimensions:function(a){a=OpenLayers.Util.getElement(a);if(OpenLayers.Element.getStyle(a,"display")!=
+"none")return{width:a.offsetWidth,height:a.offsetHeight};var b=a.style,c=b.visibility,d=b.position,e=b.display;b.visibility="hidden";b.position="absolute";b.display="";var f=a.clientWidth,a=a.clientHeight;b.display=e;b.position=d;b.visibility=c;return{width:f,height:a}},hasClass:function(a,b){var c=a.className;return!!c&&RegExp("(^|\\s)"+b+"(\\s|$)").test(c)},addClass:function(a,b){OpenLayers.Element.hasClass(a,b)||(a.className+=(a.className?" ":"")+b);return a},removeClass:function(a,b){var c=a.className;
+if(c)a.className=OpenLayers.String.trim(c.replace(RegExp("(^|\\s+)"+b+"(\\s+|$)")," "));return a},toggleClass:function(a,b){OpenLayers.Element.hasClass(a,b)?OpenLayers.Element.removeClass(a,b):OpenLayers.Element.addClass(a,b);return a},getStyle:function(a,b){var a=OpenLayers.Util.getElement(a),c=null;if(a&&a.style){c=a.style[OpenLayers.String.camelize(b)];c||(document.defaultView&&document.defaultView.getComputedStyle?c=(c=document.defaultView.getComputedStyle(a,null))?c.getPropertyValue(b):null:
+a.currentStyle&&(c=a.currentStyle[OpenLayers.String.camelize(b)]));var d=["left","top","right","bottom"];window.opera&&OpenLayers.Util.indexOf(d,b)!=-1&&OpenLayers.Element.getStyle(a,"position")=="static"&&(c="auto")}return c=="auto"?null:c}};
+OpenLayers.LonLat=OpenLayers.Class({lon:0,lat:0,initialize:function(a,b){this.lon=OpenLayers.Util.toFloat(a);this.lat=OpenLayers.Util.toFloat(b)},toString:function(){return"lon="+this.lon+",lat="+this.lat},toShortString:function(){return this.lon+", "+this.lat},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(c);return null}return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(a),
+this.lat+OpenLayers.Util.toFloat(b))},equals:function(a){var b=!1;a!=null&&(b=this.lon==a.lon&&this.lat==a.lat||isNaN(this.lon)&&isNaN(this.lat)&&isNaN(a.lon)&&isNaN(a.lat));return b},transform:function(a,b){var c=OpenLayers.Projection.transform({x:this.lon,y:this.lat},a,b);this.lon=c.x;this.lat=c.y;return this},wrapDateLine:function(a){var b=this.clone();if(a){for(;b.lon<a.left;)b.lon+=a.getWidth();for(;b.lon>a.right;)b.lon-=a.getWidth()}return b},CLASS_NAME:"OpenLayers.LonLat"});
+OpenLayers.LonLat.fromString=function(a){a=a.split(",");return new OpenLayers.LonLat(a[0],a[1])};
+OpenLayers.Pixel=OpenLayers.Class({x:0,y:0,initialize:function(a,b){this.x=parseFloat(a);this.y=parseFloat(b)},toString:function(){return"x="+this.x+",y="+this.y},clone:function(){return new OpenLayers.Pixel(this.x,this.y)},equals:function(a){var b=!1;a!=null&&(b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y));return b},distanceTo:function(a){return Math.sqrt(Math.pow(this.x-a.x,2)+Math.pow(this.y-a.y,2))},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("pixelAddError");
+OpenLayers.Console.error(c);return null}return new OpenLayers.Pixel(this.x+a,this.y+b)},offset:function(a){var b=this.clone();a&&(b=this.add(a.x,a.y));return b},CLASS_NAME:"OpenLayers.Pixel"});
+OpenLayers.Size=OpenLayers.Class({w:0,h:0,initialize:function(a,b){this.w=parseFloat(a);this.h=parseFloat(b)},toString:function(){return"w="+this.w+",h="+this.h},clone:function(){return new OpenLayers.Size(this.w,this.h)},equals:function(a){var b=!1;a!=null&&(b=this.w==a.w&&this.h==a.h||isNaN(this.w)&&isNaN(this.h)&&isNaN(a.w)&&isNaN(a.h));return b},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.getElement=function(){for(var a=[],b=0,c=arguments.length;b<c;b++){var d=arguments[b];typeof d=="string"&&(d=document.getElementById(d));if(arguments.length==1)return d;a.push(d)}return a};OpenLayers.Util.isElement=function(a){return!!(a&&a.nodeType===1)};if(typeof window.$==="undefined")window.$=OpenLayers.Util.getElement;OpenLayers.Util.removeItem=function(a,b){for(var c=a.length-1;c>=0;c--)a[c]==b&&a.splice(c,1);return a};
+OpenLayers.Util.clearArray=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"array = []"}));a.length=0};OpenLayers.Util.indexOf=function(a,b){if(typeof a.indexOf=="function")return a.indexOf(b);else{for(var c=0,d=a.length;c<d;c++)if(a[c]==b)return c;return-1}};
+OpenLayers.Util.modifyDOMElement=function(a,b,c,d,e,f,g,h){if(b)a.id=b;if(c)a.style.left=c.x+"px",a.style.top=c.y+"px";if(d)a.style.width=d.w+"px",a.style.height=d.h+"px";if(e)a.style.position=e;if(f)a.style.border=f;if(g)a.style.overflow=g;if(parseFloat(h)>=0&&parseFloat(h)<1)a.style.filter="alpha(opacity="+h*100+")",a.style.opacity=h;else if(parseFloat(h)==1)a.style.filter="",a.style.opacity=""};
+OpenLayers.Util.createDiv=function(a,b,c,d,e,f,g,h){var i=document.createElement("div");if(d)i.style.backgroundImage="url("+d+")";a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="absolute");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,g,h);return i};
+OpenLayers.Util.createImage=function(a,b,c,d,e,f,g,h){var i=document.createElement("img");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="relative");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,null,g);if(h)i.style.display="none",OpenLayers.Event.observe(i,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,i)),OpenLayers.Event.observe(i,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,i));i.style.alt=a;i.galleryImg="no";if(d)i.src=d;return i};
+OpenLayers.Util.setOpacity=function(a,b){OpenLayers.Util.modifyDOMElement(a,null,null,null,null,null,null,b)};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||this.map&&this.viewRequestID==this.map.viewRequestID)this.style.display="";OpenLayers.Element.removeClass(this,"olImageLoadError")};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;
+OpenLayers.Util.onImageLoadError=function(){this._attempts=this._attempts?this._attempts+1:1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var a=this.urls;if(a&&a instanceof Array&&a.length>1){var b=this.src.toString(),c,d;for(d=0;c=a[d];d++)if(b.indexOf(c)!=-1)break;var e=Math.floor(a.length*Math.random()),e=a[e];for(d=0;e==c&&d++<4;)e=Math.floor(a.length*Math.random()),e=a[e];this.src=b.replace(c,e)}else this.src=this.src}else OpenLayers.Element.addClass(this,"olImageLoadError");this.style.display=
+OpenLayers.Util.modifyAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){OpenLayers.Util.modifyDOMElement(a,b,c,d,f,null,null,i);b=a.childNodes[0];if(e)b.src=e;OpenLayers.Util.modifyDOMElement(b,a.id+"_innerImage",null,d,"relative",g);if(OpenLayers.Util.alphaHack()){if(a.style.display!="none")a.style.display="inline-block";h==null&&(h="scale");a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+b.src+"', sizingMethod='"+h+"')";parseFloat(a.style.opacity)>=0&&parseFloat(a.style.opacity)<1&&
+(a.style.filter+=" alpha(opacity="+a.style.opacity*100+")");b.style.filter="alpha(opacity=0)"}};
+OpenLayers.Util.createAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){var j=OpenLayers.Util.createDiv(),k=OpenLayers.Util.createImage(null,null,null,null,null,null,null,!1);j.appendChild(k);if(i)k.style.display="none",OpenLayers.Event.observe(k,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,j)),OpenLayers.Event.observe(k,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,j));OpenLayers.Util.modifyAlphaImageDiv(j,a,b,c,d,e,f,g,h);return j};
+OpenLayers.Util.upperCaseObject=function(a){var b={},c;for(c in a)b[c.toUpperCase()]=a[c];return b};OpenLayers.Util.applyDefaults=function(a,b){var a=a||{},c=typeof window.Event=="function"&&b instanceof window.Event,d;for(d in b)if(a[d]===void 0||!c&&b.hasOwnProperty&&b.hasOwnProperty(d)&&!a.hasOwnProperty(d))a[d]=b[d];if(!c&&b&&b.hasOwnProperty&&b.hasOwnProperty("toString")&&!a.hasOwnProperty("toString"))a.toString=b.toString;return a};
+OpenLayers.Util.getParameterString=function(a){var b=[],c;for(c in a){var d=a[c];if(d!=null&&typeof d!="function"){if(typeof d=="object"&&d.constructor==Array){for(var e=[],f,g=0,h=d.length;g<h;g++)f=d[g],e.push(encodeURIComponent(f===null||f===void 0?"":f));d=e.join(",")}else d=encodeURIComponent(d);b.push(encodeURIComponent(c)+"="+d)}}return b.join("&")};OpenLayers.Util.urlAppend=function(a,b){var c=a;if(b){var d=(a+" ").split(/[?&]/);c+=d.pop()===" "?b:d.length?"&"+b:"?"+b}return c};
+OpenLayers.ImgPath="";OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||OpenLayers._getScriptLocation()+"img/"};OpenLayers.Util.Try=function(){for(var a=null,b=0,c=arguments.length;b<c;b++){var d=arguments[b];try{a=d();break}catch(e){}}return a};OpenLayers.Util.getNodes=function(a,b){return OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(a.documentElement.childNodes,b)},function(){return OpenLayers.Util._getNodes(a.childNodes,b)})};
+OpenLayers.Util._getNodes=function(a,b){for(var c=[],d=0,e=a.length;d<e;d++)a[d].nodeName==b&&c.push(a[d]);return c};OpenLayers.Util.mouseLeft=function(a,b){for(var c=a.relatedTarget?a.relatedTarget:a.toElement;c!=b&&c!=null;)c=c.parentNode;return c!=b};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(a,b){if(b==null)b=OpenLayers.Util.DEFAULT_PRECISION;typeof a!=="number"&&(a=parseFloat(a));return b===0?a:parseFloat(a.toPrecision(b))};
+OpenLayers.Util.rad=function(a){return a*Math.PI/180};OpenLayers.Util.deg=function(a){return a*180/Math.PI};
+OpenLayers.Util.getParameters=function(a){var a=a||window.location.href,b="";if(OpenLayers.String.contains(a,"?"))var b=a.indexOf("?")+1,c=OpenLayers.String.contains(a,"#")?a.indexOf("#"):a.length,b=a.substring(b,c);for(var a={},b=b.split(/[&;]/),c=0,d=b.length;c<d;++c){var e=b[c].split("=");if(e[0]){var f=e[0];try{f=decodeURIComponent(f)}catch(g){f=unescape(f)}e=(e[1]||"").replace(/\+/g," ");try{e=decodeURIComponent(e)}catch(h){e=unescape(e)}e=e.split(",");e.length==1&&(e=e[0]);a[f]=e}}return a};
+OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(a){a==null&&(a="id_");OpenLayers.Util.lastSeqID+=1;return a+OpenLayers.Util.lastSeqID};OpenLayers.INCHES_PER_UNIT={inches:1,ft:12,mi:63360,m:39.3701,km:39370.1,dd:4374754,yd:36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT.degrees=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT.nmi=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.DOTS_PER_INCH=72;
+OpenLayers.Util.normalizeScale=function(a){return a>1?1/a:a};OpenLayers.Util.getResolutionFromScale=function(a,b){var c;a&&(b==null&&(b="degrees"),c=1/(OpenLayers.Util.normalizeScale(a)*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH));return c};OpenLayers.Util.getScaleFromResolution=function(a,b){b==null&&(b="degrees");return a*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH};
+OpenLayers.Util.pagePosition=function(a){var b=[0,0],c=OpenLayers.Util.getViewportElement();if(!a||a==window||a==c)return b;var d=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(a,"position")=="absolute"&&(a.style.top==""||a.style.left==""),e=null;if(a.getBoundingClientRect)a=a.getBoundingClientRect(),e=c.scrollTop,b[0]=a.left+c.scrollLeft,b[1]=a.top+e;else if(document.getBoxObjectFor&&!d)a=document.getBoxObjectFor(a),c=document.getBoxObjectFor(c),b[0]=a.screenX-c.screenX,
+b[1]=a.screenY-c.screenY;else{b[0]=a.offsetLeft;b[1]=a.offsetTop;e=a.offsetParent;if(e!=a)for(;e;)b[0]+=e.offsetLeft,b[1]+=e.offsetTop,e=e.offsetParent;c=OpenLayers.BROWSER_NAME;if(c=="opera"||c=="safari"&&OpenLayers.Element.getStyle(a,"position")=="absolute")b[1]-=document.body.offsetTop;for(e=a.offsetParent;e&&e!=document.body;){b[0]-=e.scrollLeft;if(c!="opera"||e.tagName!="TR")b[1]-=e.scrollTop;e=e.offsetParent}}return b};
+OpenLayers.Util.getViewportElement=function(){var a=arguments.callee.viewportElement;if(a==void 0)a=OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!="CSS1Compat"?document.body:document.documentElement,arguments.callee.viewportElement=a;return a};
+OpenLayers.Util.isEquivalentUrl=function(a,b,c){c=c||{};OpenLayers.Util.applyDefaults(c,{ignoreCase:!0,ignorePort80:!0,ignoreHash:!0});var a=OpenLayers.Util.createUrlObject(a,c),b=OpenLayers.Util.createUrlObject(b,c),d;for(d in a)if(d!=="args"&&a[d]!=b[d])return!1;for(d in a.args){if(a.args[d]!=b.args[d])return!1;delete b.args[d]}for(d in b.args)return!1;return!0};
+OpenLayers.Util.createUrlObject=function(a,b){b=b||{};if(!/^\w+:\/\//.test(a)){var c=window.location,d=c.port?":"+c.port:"",d=c.protocol+"//"+c.host.split(":").shift()+d;a.indexOf("/")===0?a=d+a:(c=c.pathname.split("/"),c.pop(),a=d+c.join("/")+"/"+a)}b.ignoreCase&&(a=a.toLowerCase());c=document.createElement("a");c.href=a;d={};d.host=c.host.split(":").shift();d.protocol=c.protocol;d.port=b.ignorePort80?c.port=="80"||c.port=="0"?"":c.port:c.port==""||c.port=="0"?"80":c.port;d.hash=b.ignoreHash||c.hash===
+"#"?"":c.hash;var e=c.search;e||(e=a.indexOf("?"),e=e!=-1?a.substr(e):"");d.args=OpenLayers.Util.getParameters(e);d.pathname=c.pathname.charAt(0)=="/"?c.pathname:"/"+c.pathname;return d};OpenLayers.Util.removeTail=function(a){var b=null,b=a.indexOf("?"),c=a.indexOf("#");return b=b==-1?c!=-1?a.substr(0,c):a:c!=-1?a.substr(0,Math.min(b,c)):a.substr(0,b)};OpenLayers.IS_GECKO=function(){var a=navigator.userAgent.toLowerCase();return a.indexOf("webkit")==-1&&a.indexOf("gecko")!=-1}();
+OpenLayers.BROWSER_NAME=function(){var a="",b=navigator.userAgent.toLowerCase();b.indexOf("opera")!=-1?a="opera":b.indexOf("msie")!=-1?a="msie":b.indexOf("safari")!=-1?a="safari":b.indexOf("mozilla")!=-1&&(a=b.indexOf("firefox")!=-1?"firefox":"mozilla");return a}();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME};
+OpenLayers.Util.getRenderedDimensions=function(a,b,c){var d,e,f=document.createElement("div");f.style.visibility="hidden";var g=c&&c.containerElement?c.containerElement:document.body;if(b)if(b.w)d=b.w,f.style.width=d+"px";else if(b.h)e=b.h,f.style.height=e+"px";if(c&&c.displayClass)f.className=c.displayClass;b=document.createElement("div");b.innerHTML=a;b.style.overflow="visible";if(b.childNodes){a=0;for(c=b.childNodes.length;a<c;a++)if(b.childNodes[a].style)b.childNodes[a].style.overflow="visible"}f.appendChild(b);
+g.appendChild(f);a=!1;for(c=f.parentNode;c&&c.tagName.toLowerCase()!="body";){var h=OpenLayers.Element.getStyle(c,"position");if(h=="absolute"){a=!0;break}else if(h&&h!="static")break;c=c.parentNode}if(!a)f.style.position="absolute";if(!d)d=parseInt(b.scrollWidth),f.style.width=d+"px";e||(e=parseInt(b.scrollHeight));f.removeChild(b);g.removeChild(f);return new OpenLayers.Size(d,e)};
+OpenLayers.Util.getScrollbarWidth=function(){var a=OpenLayers.Util._scrollbarWidth;if(a==null){var b=null,c=null,b=a=0,b=document.createElement("div");b.style.position="absolute";b.style.top="-1000px";b.style.left="-1000px";b.style.width="100px";b.style.height="50px";b.style.overflow="hidden";c=document.createElement("div");c.style.width="100%";c.style.height="200px";b.appendChild(c);document.body.appendChild(b);a=c.offsetWidth;b.style.overflow="scroll";b=c.offsetWidth;document.body.removeChild(document.body.lastChild);
+OpenLayers.Util._scrollbarWidth=a-b;a=OpenLayers.Util._scrollbarWidth}return a};
+OpenLayers.Event={observers:!1,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(a){return a.target||a.srcElement},isSingleTouch:function(a){return a.touches&&a.touches.length==1},isMultiTouch:function(a){return a.touches&&a.touches.length>1},isLeftClick:function(a){return a.which&&a.which==1||a.button&&a.button==1},isRightClick:function(a){return a.which&&a.which==3||a.button&&a.button==2},stop:function(a,b){if(!b)a.preventDefault?
+a.preventDefault():a.returnValue=!1;a.stopPropagation?a.stopPropagation():a.cancelBubble=!0},findElement:function(a,b){for(var c=OpenLayers.Event.element(a);c.parentNode&&(!c.tagName||c.tagName.toUpperCase()!=b.toUpperCase());)c=c.parentNode;return c},observe:function(a,b,c,d){a=OpenLayers.Util.getElement(a);d=d||!1;if(b=="keypress"&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.attachEvent))b="keydown";if(!this.observers)this.observers={};if(!a._eventCacheID){var e="eventCacheID_";a.id&&
+(e=a.id+"_"+e);a._eventCacheID=OpenLayers.Util.createUniqueID(e)}e=a._eventCacheID;this.observers[e]||(this.observers[e]=[]);this.observers[e].push({element:a,name:b,observer:c,useCapture:d});a.addEventListener?a.addEventListener(b,c,d):a.attachEvent&&a.attachEvent("on"+b,c)},stopObservingElement:function(a){a=OpenLayers.Util.getElement(a)._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[a])},_removeElementObservers:function(a){if(a)for(var b=a.length-1;b>=0;b--){var c=a[b];OpenLayers.Event.stopObserving.apply(this,
+[c.element,c.name,c.observer,c.useCapture])}},stopObserving:function(a,b,c,d){var d=d||!1,a=OpenLayers.Util.getElement(a),e=a._eventCacheID;if(b=="keypress"&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.detachEvent))b="keydown";var f=!1,g=OpenLayers.Event.observers[e];if(g)for(var h=0;!f&&h<g.length;){var i=g[h];if(i.name==b&&i.observer==c&&i.useCapture==d){g.splice(h,1);g.length==0&&delete OpenLayers.Event.observers[e];f=!0;break}h++}f&&(a.removeEventListener?a.removeEventListener(b,
+c,d):a&&a.detachEvent&&a.detachEvent("on"+b,c));return f},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var a in OpenLayers.Event.observers)OpenLayers.Event._removeElementObservers.apply(this,[OpenLayers.Event.observers[a]]);OpenLayers.Event.observers=!1}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,"unload",OpenLayers.Event.unloadCache,!1);if(window.Event)OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);else var Event=OpenLayers.Event;
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:!1,clearMouseListener:null,initialize:function(a,b,c,d,e){OpenLayers.Util.extend(this,e);this.object=a;this.fallThrough=d;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,
+this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(c!=null){a=0;for(d=c.length;a<d;a++)this.addEventType(c[a])}b!=null&&this.attachToElement(b)},destroy:function(){this.element&&(OpenLayers.Event.stopObservingElement(this.element),this.element.hasScrollEvent&&OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener));this.eventHandler=this.fallThrough=this.eventTypes=this.object=this.listeners=this.element=null},addEventType:function(a){this.listeners[a]||
+(this.eventTypes.push(a),this.listeners[a]=[])},attachToElement:function(a){this.element&&OpenLayers.Event.stopObservingElement(this.element);this.element=a;for(var b=0,c=this.BROWSER_EVENTS.length;b<c;b++){var d=this.BROWSER_EVENTS[b];this.addEventType(d);OpenLayers.Event.observe(a,d,this.eventHandler)}OpenLayers.Event.observe(a,"dragstart",OpenLayers.Event.stop)},on:function(a){for(var b in a)b!="scope"&&this.register(b,a.scope,a[b])},register:function(a,b,c){if(c!=null&&OpenLayers.Util.indexOf(this.eventTypes,
+a)!=-1){if(b==null)b=this.object;this.listeners[a].push({obj:b,func:c})}},registerPriority:function(a,b,c){if(c!=null){if(b==null)b=this.object;a=this.listeners[a];a!=null&&a.unshift({obj:b,func:c})}},un:function(a){for(var b in a)b!="scope"&&this.unregister(b,a.scope,a[b])},unregister:function(a,b,c){if(b==null)b=this.object;a=this.listeners[a];if(a!=null)for(var d=0,e=a.length;d<e;d++)if(a[d].obj==b&&a[d].func==c){a.splice(d,1);break}},remove:function(a){this.listeners[a]!=null&&(this.listeners[a]=
+[])},triggerEvent:function(a,b){var c=this.listeners[a];if(c&&c.length!=0){b==null&&(b={});b.object=this.object;b.element=this.element;if(!b.type)b.type=a;for(var c=c.slice(),d,e=0,f=c.length;e<f;e++)if(d=c[e],d=d.func.apply(d.obj,[b]),d!=void 0&&d==!1)break;this.fallThrough||OpenLayers.Event.stop(b,!0);return d}},handleBrowserEvent:function(a){var b=a.type,c=this.listeners[b];if(c&&c.length!=0){if((c=a.touches)&&c[0]){for(var d=0,e=0,f=c.length,g,h=0;h<f;++h)g=c[h],d+=g.clientX,e+=g.clientY;a.clientX=
+d/f;a.clientY=e/f}if(this.includeXY)a.xy=this.getMousePosition(a);this.triggerEvent(b,a)}},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;var a=document.body;if(a&&(!(a.scrollTop!=0||a.scrollLeft!=0)||!navigator.userAgent.match(/iPhone/i)))this.element.offsets=null},getMousePosition:function(a){if(this.includeXY){if(!this.element.hasScrollEvent)OpenLayers.Event.observe(window,"scroll",this.clearMouseListener),this.element.hasScrollEvent=!0}else this.clearMouseCache();
+if(!this.element.scrolls){var b=OpenLayers.Util.getViewportElement();this.element.scrolls=[b.scrollLeft,b.scrollTop]}if(!this.element.lefttop)this.element.lefttop=[document.documentElement.clientLeft||0,document.documentElement.clientTop||0];if(!this.element.offsets)this.element.offsets=OpenLayers.Util.pagePosition(this.element);return new OpenLayers.Pixel(a.clientX+this.element.scrolls[0]-this.element.offsets[0]-this.element.lefttop[0],a.clientY+this.element.scrolls[1]-this.element.offsets[1]-this.element.lefttop[1])},
+CLASS_NAME:"OpenLayers.Events"});
+OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1E3},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:!1,events:null,allOverlays:!1,div:null,dragging:!1,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,
+layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:"degrees",resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:!0,panTween:null,eventListeners:null,panMethod:null,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(a,
+b){arguments.length===1&&typeof a==="object"&&(a=(b=a)&&b.div);this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+"theme/default/style.css";OpenLayers.Util.extend(this,b);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(a);if(!this.div)this.div=document.createElement("div"),
+this.div.style.height="1px",this.div.style.width="1px";OpenLayers.Element.addClass(this.div,"olMap");var c=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(c,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);c=document.createElement("div");c.id=this.id+"_events";c.style.position="absolute";c.style.width="100%";c.style.height="100%";
+c.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(c);this.eventsDiv=c;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:!0});c=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(c);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE.Popup-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);this.events.register("movestart",
+this,this.updateSize);OpenLayers.String.contains(navigator.appName,"Microsoft")?this.events.register("resize",this,this.updateSize):(this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this),OpenLayers.Event.observe(window,"resize",this.updateSizeDestroy));if(this.theme){for(var c=!0,d=document.getElementsByTagName("link"),e=0,f=d.length;e<f;++e)if(OpenLayers.Util.isEquivalentUrl(d.item(e).href,this.theme)){c=!1;break}c&&(c=document.createElement("link"),c.setAttribute("rel","stylesheet"),
+c.setAttribute("type","text/css"),c.setAttribute("href",this.theme),document.getElementsByTagName("head")[0].appendChild(c))}if(this.controls==null)this.controls=OpenLayers.Control!=null?[new OpenLayers.Control.Navigation,new OpenLayers.Control.PanZoom,new OpenLayers.Control.ArgParser,new OpenLayers.Control.Attribution]:[];e=0;for(f=this.controls.length;e<f;e++)this.addControlToMap(this.controls[e]);this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,
+"unload",this.unloadDestroy);b&&b.layers&&(delete this.center,this.addLayers(b.layers),b.center&&this.setCenter(b.center,b.zoom))},render:function(a){this.div=OpenLayers.Util.getElement(a);OpenLayers.Element.addClass(this.div,"olMap");this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize()},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy)return!1;if(this.panTween)this.panTween.stop(),this.panTween=null;
+OpenLayers.Event.stopObserving(window,"unload",this.unloadDestroy);this.unloadDestroy=null;this.updateSizeDestroy?OpenLayers.Event.stopObserving(window,"resize",this.updateSizeDestroy):this.events.unregister("resize",this,this.updateSize);this.paddingForPopups=null;if(this.controls!=null){for(var a=this.controls.length-1;a>=0;--a)this.controls[a].destroy();this.controls=null}if(this.layers!=null){for(a=this.layers.length-1;a>=0;--a)this.layers[a].destroy(!1);this.layers=null}this.viewPortDiv&&this.div.removeChild(this.viewPortDiv);
+this.viewPortDiv=null;if(this.eventListeners)this.events.un(this.eventListeners),this.eventListeners=null;this.events.destroy();this.events=null},setOptions:function(a){var b=this.minPx&&a.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,a);b&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:!0})},getTileSize:function(){return this.tileSize},getBy:function(a,b,c){var d=typeof c.test=="function";return OpenLayers.Array.filter(this[a],function(a){return a[b]==c||d&&c.test(a[b])})},
+getLayersBy:function(a,b){return this.getBy("layers",a,b)},getLayersByName:function(a){return this.getLayersBy("name",a)},getLayersByClass:function(a){return this.getLayersBy("CLASS_NAME",a)},getControlsBy:function(a,b){return this.getBy("controls",a,b)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},getLayer:function(a){for(var b=null,c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.id==a){b=e;break}}return b},setLayerZIndex:function(a,b){a.setZIndex(this.Z_INDEX_BASE[a.isBaseLayer?
+"BaseLayer":"Overlay"]+b*5)},resetLayersZIndex:function(){for(var a=0,b=this.layers.length;a<b;a++)this.setLayerZIndex(this.layers[a],a)},addLayer:function(a){for(var b=0,c=this.layers.length;b<c;b++)if(this.layers[b]==a)return!1;if(this.allOverlays)a.isBaseLayer=!1;if(this.events.triggerEvent("preaddlayer",{layer:a})!==!1)a.div.className="olLayerDiv",a.div.style.overflow="",this.setLayerZIndex(a,this.layers.length),a.isFixed?this.viewPortDiv.appendChild(a.div):this.layerContainerDiv.appendChild(a.div),
+this.layers.push(a),a.setMap(this),a.isBaseLayer||this.allOverlays&&!this.baseLayer?this.baseLayer==null?this.setBaseLayer(a):a.setVisibility(!1):a.redraw(),this.events.triggerEvent("addlayer",{layer:a}),a.events.triggerEvent("added",{map:this,layer:a}),a.afterAdd()},addLayers:function(a){for(var b=0,c=a.length;b<c;b++)this.addLayer(a[b])},removeLayer:function(a,b){b==null&&(b=!0);a.isFixed?this.viewPortDiv.removeChild(a.div):this.layerContainerDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.layers,
+a);a.removeMap(this);a.map=null;if(this.baseLayer==a&&(this.baseLayer=null,b))for(var c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.isBaseLayer||this.allOverlays){this.setBaseLayer(e);break}}this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:a});a.events.triggerEvent("removed",{map:this,layer:a})},getNumLayers:function(){return this.layers.length},getLayerIndex:function(a){return OpenLayers.Util.indexOf(this.layers,a)},setLayerIndex:function(a,b){var c=this.getLayerIndex(a);
+if(b<0)b=0;else if(b>this.layers.length)b=this.layers.length;if(c!=b){this.layers.splice(c,1);this.layers.splice(b,0,a);for(var c=0,d=this.layers.length;c<d;c++)this.setLayerZIndex(this.layers[c],c);this.events.triggerEvent("changelayer",{layer:a,property:"order"});this.allOverlays&&(b===0?this.setBaseLayer(a):this.baseLayer!==this.layers[0]&&this.setBaseLayer(this.layers[0]))}},raiseLayer:function(a,b){var c=this.getLayerIndex(a)+b;this.setLayerIndex(a,c)},setBaseLayer:function(a){if(a!=this.baseLayer&&
+OpenLayers.Util.indexOf(this.layers,a)!=-1){var b=this.getCachedCenter(),c=OpenLayers.Util.getResolutionFromScale(this.getScale(),a.units);this.baseLayer!=null&&!this.allOverlays&&this.baseLayer.setVisibility(!1);this.baseLayer=a;this.viewRequestID++;(!this.allOverlays||this.baseLayer.visibility)&&this.baseLayer.setVisibility(!0);b!=null&&(a=this.getZoomForResolution(c||this.resolution,!0),this.setCenter(b,a,!1,!0));this.events.triggerEvent("changebaselayer",{layer:this.baseLayer})}},addControl:function(a,
+b){this.controls.push(a);this.addControlToMap(a,b)},addControls:function(a,b){for(var c=arguments.length===1?[]:b,d=0,e=a.length;d<e;d++)this.addControl(a[d],c[d]?c[d]:null)},addControlToMap:function(a,b){a.outsideViewport=a.div!=null;if(this.displayProjection&&!a.displayProjection)a.displayProjection=this.displayProjection;a.setMap(this);var c=a.draw(b);if(c&&!a.outsideViewport)c.style.zIndex=this.Z_INDEX_BASE.Control+this.controls.length,this.viewPortDiv.appendChild(c);a.autoActivate&&a.activate()},
+getControl:function(a){for(var b=null,c=0,d=this.controls.length;c<d;c++){var e=this.controls[c];if(e.id==a){b=e;break}}return b},removeControl:function(a){a&&a==this.getControl(a.id)&&(a.div&&a.div.parentNode==this.viewPortDiv&&this.viewPortDiv.removeChild(a.div),OpenLayers.Util.removeItem(this.controls,a))},addPopup:function(a,b){if(b)for(var c=this.popups.length-1;c>=0;--c)this.removePopup(this.popups[c]);a.map=this;this.popups.push(a);if(c=a.draw())c.style.zIndex=this.Z_INDEX_BASE.Popup+this.popups.length,
+this.layerContainerDiv.appendChild(c)},removePopup:function(a){OpenLayers.Util.removeItem(this.popups,a);if(a.div)try{this.layerContainerDiv.removeChild(a.div)}catch(b){}a.map=null},getSize:function(){var a=null;this.size!=null&&(a=this.size.clone());return a},updateSize:function(){var a=this.getCurrentSize();if(a&&!isNaN(a.h)&&!isNaN(a.w)){this.events.clearMouseCache();var b=this.getSize();if(b==null)this.size=b=a;if(!a.equals(b)){this.size=a;a=0;for(b=this.layers.length;a<b;a++)this.layers[a].onMapResize();
+a=this.getCachedCenter();if(this.baseLayer!=null&&a!=null)b=this.getZoom(),this.zoom=null,this.setCenter(a,b)}}},getCurrentSize:function(){var a=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(a.w==0&&a.h==0||isNaN(a.w)&&isNaN(a.h))a.w=this.div.offsetWidth,a.h=this.div.offsetHeight;if(a.w==0&&a.h==0||isNaN(a.w)&&isNaN(a.h))a.w=parseInt(this.div.style.width),a.h=parseInt(this.div.style.height);return a},calculateBounds:function(a,b){var c=null;a==null&&(a=this.getCachedCenter());
+b==null&&(b=this.getResolution());if(a!=null&&b!=null)var d=this.getSize(),c=d.w*b,d=d.h*b,c=new OpenLayers.Bounds(a.lon-c/2,a.lat-d/2,a.lon+c/2,a.lat+d/2);return c},getCenter:function(){var a=null,b=this.getCachedCenter();b&&(a=b.clone());return a},getCachedCenter:function(){if(!this.center&&this.size)this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));return this.center},getZoom:function(){return this.zoom},pan:function(a,b,c){c=OpenLayers.Util.applyDefaults(c,
+{animate:!0,dragging:!1});if(c.dragging)(a!=0||b!=0)&&this.moveByPx(a,b);else{var d=this.getViewPortPxFromLonLat(this.getCachedCenter()),a=d.add(a,b);if(this.dragging||!a.equals(d))d=this.getLonLatFromViewPortPx(a),c.animate?this.panTo(d):(this.moveTo(d),this.dragging=!1,this.events.triggerEvent("moveend"))}},panTo:function(a){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(a)){if(!this.panTween)this.panTween=new OpenLayers.Tween(this.panMethod);var b=this.getCachedCenter();
+if(!a.equals(b)){var b=this.getPixelFromLonLat(b),c=this.getPixelFromLonLat(a),d={x:0,y:0};this.panTween.start({x:0,y:0},{x:c.x-b.x,y:c.y-b.y},this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(a){this.moveByPx(a.x-d.x,a.y-d.y);d.x=Math.round(a.x);d.y=Math.round(a.y)},this),done:OpenLayers.Function.bind(function(){this.moveTo(a);this.dragging=!1;this.events.triggerEvent("moveend")},this)}})}}else this.setCenter(a)},setCenter:function(a,b,c,d){this.panTween&&this.panTween.stop();
+this.moveTo(a,b,{dragging:c,forceZoomChange:d})},moveByPx:function(a,b){var a=Math.round(a),b=Math.round(b),c=this.size.w/2,d=this.size.h/2,e=c+a,f=d+b,g=this.baseLayer.wrapDateLine,h=0,i=0;this.restrictedExtent&&(h=c,i=d,g=!1);c=f<=this.maxPx.y-i&&f>=this.minPx.y+i;d=this.minPx.x;f=this.maxPx.x;g||(c=c&&e<=this.maxPx.x-h&&e>=this.minPx.x+h);if(c){if(!this.dragging)this.dragging=!0,this.events.triggerEvent("movestart");this.center=null;if(a)this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-
+a+"px",this.minPx.x-=a,this.maxPx.x-=a,g&&(this.maxPx.x>f&&(this.maxPx.x-=f-d),this.minPx.x<d&&(this.minPx.x+=f-d));if(b)this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-b+"px",this.minPx.y-=b,this.maxPx.y-=b;g=0;for(h=this.layers.length;g<h;++g)e=this.layers[g],e.visibility&&(e.moveByPx(a,b),e.events.triggerEvent("move"));this.events.triggerEvent("move")}},moveTo:function(a,b,c){c||(c={});b!=null&&(b=parseFloat(b),this.fractionalZoom||(b=Math.round(b)));var d=c.dragging||
+this.dragging,e=c.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(a))a=this.maxExtent.getCenterLonLat(),this.center=a.clone();if(this.restrictedExtent!=null){if(a==null)a=this.center;b==null&&(b=this.getZoom());var f=this.getResolutionForZoom(b),f=this.calculateBounds(a,f);if(!this.restrictedExtent.containsBounds(f)){var g=this.restrictedExtent.getCenterLonLat();f.getWidth()>this.restrictedExtent.getWidth()?a=new OpenLayers.LonLat(g.lon,a.lat):f.left<this.restrictedExtent.left?a=a.add(this.restrictedExtent.left-
+f.left,0):f.right>this.restrictedExtent.right&&(a=a.add(this.restrictedExtent.right-f.right,0));f.getHeight()>this.restrictedExtent.getHeight()?a=new OpenLayers.LonLat(a.lon,g.lat):f.bottom<this.restrictedExtent.bottom?a=a.add(0,this.restrictedExtent.bottom-f.bottom):f.top>this.restrictedExtent.top&&(a=a.add(0,this.restrictedExtent.top-f.top))}}e=e||this.isValidZoomLevel(b)&&b!=this.getZoom();f=this.isValidLonLat(a)&&!a.equals(this.center);if(e||f||d){d||this.events.triggerEvent("movestart");if(f)!e&&
+this.center&&this.centerLayerContainer(a),this.center=a.clone();a=e?this.getResolutionForZoom(b):this.getResolution();if(e||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var h=this.getMaxExtent({restricted:!0}),f=h.getCenterLonLat(),g=this.center.lon-f.lon,i=f.lat-this.center.lat,f=Math.round(h.getWidth()/a),h=Math.round(h.getHeight()/a),g=(this.size.w-f)/2-g/a,i=(this.size.h-h)/2-i/
+a;this.minPx=new OpenLayers.Pixel(g,i);this.maxPx=new OpenLayers.Pixel(g+f,i+h)}if(e)this.zoom=b,this.resolution=a,this.viewRequestID++;a=this.getExtent();this.baseLayer.visibility&&(this.baseLayer.moveTo(a,e,c.dragging),c.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:e}));a=this.baseLayer.getExtent();for(b=this.layers.length-1;b>=0;--b)if(f=this.layers[b],f!==this.baseLayer&&!f.isBaseLayer){g=f.calculateInRange();if(f.inRange!=g)(f.inRange=g)||f.display(!1),this.events.triggerEvent("changelayer",
+{layer:f,property:"visibility"});g&&f.visibility&&(f.moveTo(a,e,c.dragging),c.dragging||f.events.triggerEvent("moveend",{zoomChanged:e}))}this.events.triggerEvent("move");d||this.events.triggerEvent("moveend");if(e){b=0;for(c=this.popups.length;b<c;b++)this.popups[b].updatePosition();this.events.triggerEvent("zoomend")}}},centerLayerContainer:function(a){var b=this.getViewPortPxFromLonLat(this.layerContainerOrigin),c=this.getViewPortPxFromLonLat(a);if(b!=null&&c!=null){var d=parseInt(this.layerContainerDiv.style.left),
+a=parseInt(this.layerContainerDiv.style.top),e=Math.round(b.x-c.x),b=Math.round(b.y-c.y);this.layerContainerDiv.style.left=e+"px";this.layerContainerDiv.style.top=b+"px";d-=e;a-=b;this.minPx.x-=d;this.maxPx.x-=d;this.minPx.y-=a;this.maxPx.y-=a}},isValidZoomLevel:function(a){return a!=null&&a>=this.getRestrictedMinZoom()&&a<this.getNumZoomLevels()},isValidLonLat:function(a){var b=!1;a!=null&&(b=this.getMaxExtent().containsLonLat(a));return b},getProjection:function(){var a=this.getProjectionObject();
+return a?a.getCode():null},getProjectionObject:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.projection;return a},getMaxResolution:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.maxResolution;return a},getMaxExtent:function(a){var b=null;if(a&&a.restricted&&this.restrictedExtent)b=this.restrictedExtent;else if(this.baseLayer!=null)b=this.baseLayer.maxExtent;return b},getRestrictedMinZoom:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.restrictedMinZoom;
+return a},getNumZoomLevels:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.numZoomLevels;return a},getExtent:function(){var a=null;this.baseLayer!=null&&(a=this.baseLayer.getExtent());return a},getResolution:function(){var a=null;this.baseLayer!=null?a=this.baseLayer.getResolution():this.allOverlays===!0&&this.layers.length>0&&(a=this.layers[0].getResolution());return a},getUnits:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.units;return a},getScale:function(){var a=
+null;this.baseLayer!=null&&(a=this.getResolution(),a=OpenLayers.Util.getScaleFromResolution(a,this.baseLayer.units));return a},getZoomForExtent:function(a,b){var c=null;this.baseLayer!=null&&(c=this.baseLayer.getZoomForExtent(a,b));return c},getResolutionForZoom:function(a){var b=null;this.baseLayer&&(b=this.baseLayer.getResolutionForZoom(a));return b},getZoomForResolution:function(a,b){var c=null;this.baseLayer!=null&&(c=this.baseLayer.getZoomForResolution(a,b));return c},zoomTo:function(a){this.isValidZoomLevel(a)&&
+this.setCenter(null,a)},zoomIn:function(){this.zoomTo(this.getZoom()+1)},zoomOut:function(){this.zoomTo(this.getZoom()-1)},zoomToExtent:function(a,b){var c=a.getCenterLonLat();if(this.baseLayer.wrapDateLine){c=this.getMaxExtent();for(a=a.clone();a.right<a.left;)a.right+=c.getWidth();c=a.getCenterLonLat().wrapDateLine(c)}this.setCenter(c,this.getZoomForExtent(a,b))},zoomToMaxExtent:function(a){this.zoomToExtent(this.getMaxExtent({restricted:a?a.restricted:!0}))},zoomToScale:function(a,b){var c=OpenLayers.Util.getResolutionFromScale(a,
+this.baseLayer.units),d=this.getSize(),e=d.w*c;c*=d.h;d=this.getCachedCenter();this.zoomToExtent(new OpenLayers.Bounds(d.lon-e/2,d.lat-c/2,d.lon+e/2,d.lat+c/2),b)},getLonLatFromViewPortPx:function(a){var b=null;this.baseLayer!=null&&(b=this.baseLayer.getLonLatFromViewPortPx(a));return b},getViewPortPxFromLonLat:function(a){var b=null;this.baseLayer!=null&&(b=this.baseLayer.getViewPortPxFromLonLat(a));return b},getLonLatFromPixel:function(a){return this.getLonLatFromViewPortPx(a)},getPixelFromLonLat:function(a){a=
+this.getViewPortPxFromLonLat(a);a.x=Math.round(a.x);a.y=Math.round(a.y);return a},getGeodesicPixelSize:function(a){var b=a?this.getLonLatFromPixel(a):this.getCachedCenter()||new OpenLayers.LonLat(0,0),c=this.getResolution(),a=b.add(-c/2,0),d=b.add(c/2,0),e=b.add(0,-c/2),b=b.add(0,c/2),c=new OpenLayers.Projection("EPSG:4326"),f=this.getProjectionObject()||c;f.equals(c)||(a.transform(f,c),d.transform(f,c),e.transform(f,c),b.transform(f,c));return new OpenLayers.Size(OpenLayers.Util.distVincenty(a,d),
+OpenLayers.Util.distVincenty(e,b))},getViewPortPxFromLayerPx:function(a){var b=null;if(a!=null)var b=parseInt(this.layerContainerDiv.style.left),c=parseInt(this.layerContainerDiv.style.top),b=a.add(b,c);return b},getLayerPxFromViewPortPx:function(a){var b=null;if(a!=null){var b=-parseInt(this.layerContainerDiv.style.left),c=-parseInt(this.layerContainerDiv.style.top),b=a.add(b,c);if(isNaN(b.x)||isNaN(b.y))b=null}return b},getLonLatFromLayerPx:function(a){a=this.getViewPortPxFromLayerPx(a);return this.getLonLatFromViewPortPx(a)},
+getLayerPxFromLonLat:function(a){return this.getLayerPxFromViewPortPx(this.getPixelFromLonLat(a))},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;
+OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.projCode=a;if(window.Proj4js)this.proj=new Proj4js.Proj(a)},getCode:function(){return this.proj?this.proj.srsCode:this.projCode},getUnits:function(){return this.proj?this.proj.units:null},toString:function(){return this.getCode()},equals:function(a){var b=!1;a&&(window.Proj4js&&this.proj.defData&&a.proj.defData?b=this.proj.defData.replace(this.titleRegEx,
+"")==a.proj.defData.replace(this.titleRegEx,""):a.getCode&&(b=this.getCode(),a=a.getCode(),b=b==a||!!OpenLayers.Projection.transforms[b]&&OpenLayers.Projection.transforms[b][a]===OpenLayers.Projection.nullTransform));return b},destroy:function(){delete this.proj;delete this.projCode},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};
+OpenLayers.Projection.addTransform=function(a,b,c){OpenLayers.Projection.transforms[a]||(OpenLayers.Projection.transforms[a]={});OpenLayers.Projection.transforms[a][b]=c};OpenLayers.Projection.transform=function(a,b,c){if(b.proj&&c.proj)a=Proj4js.transform(b.proj,c.proj,a);else if(b&&c&&OpenLayers.Projection.transforms[b.getCode()]&&OpenLayers.Projection.transforms[b.getCode()][c.getCode()])OpenLayers.Projection.transforms[b.getCode()][c.getCode()](a);return a};
+OpenLayers.Projection.nullTransform=function(a){return a};
+OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:["scales","resolutions","maxScale","minScale","maxResolution","minResolution","numZoomLevels","maxZoomLevel"],events:null,map:null,isBaseLayer:!1,alpha:!1,displayInLayerSwitcher:!0,visibility:!0,attribution:null,inRange:!1,imageSize:null,imageOffset:null,options:null,eventListeners:null,
+gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:!1,wrapDateLine:!1,transitionEffect:null,SUPPORTED_TRANSITIONS:["resize"],metadata:{},initialize:function(a,b){this.addOptions(b);this.name=a;if(this.id==null&&(this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_"),this.div=OpenLayers.Util.createDiv(this.id),this.div.style.width=
+"100%",this.div.style.height="100%",this.div.dir="ltr",this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES),this.eventListeners instanceof Object))this.events.on(this.eventListeners);if(this.wrapDateLine)this.displayOutsideMaxExtent=!0},destroy:function(a){a==null&&(a=!0);this.map!=null&&this.map.removeLayer(this,a);this.options=this.div=this.name=this.map=this.projection=null;this.events&&(this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy());this.events=this.eventListeners=
+null},clone:function(a){a==null&&(a=new OpenLayers.Layer(this.name,this.getOptions()));OpenLayers.Util.applyDefaults(a,this);a.map=null;return a},getOptions:function(){var a={},b;for(b in this.options)a[b]=this[b];return a},setName:function(a){if(a!=this.name)this.name=a,this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"name"})},addOptions:function(a){if(this.options==null)this.options={};OpenLayers.Util.extend(this.options,a);OpenLayers.Util.extend(this,a);if(typeof this.projection==
+"string")this.projection=new OpenLayers.Projection(this.projection);if(this.projection&&this.projection.getUnits())this.units=this.projection.getUnits();if(this.map){var b=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]),c;for(c in a)if(a.hasOwnProperty(c)&&OpenLayers.Util.indexOf(b,c)>=0){this.initResolutions();break}}},onMapResize:function(){},redraw:function(){var a=!1;if(this.map){this.inRange=this.calculateInRange();var b=this.getExtent();b&&this.inRange&&this.visibility&&
+(this.moveTo(b,!0,!1),this.events.triggerEvent("moveend",{zoomChanged:!0}),a=!0)}return a},moveTo:function(){var a=this.visibility;this.isBaseLayer||(a=a&&this.inRange);this.display(a)},moveByPx:function(){},setMap:function(a){if(this.map==null){this.map=a;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string")this.projection=new OpenLayers.Projection(this.projection);
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer)this.inRange=this.calculateInRange(),this.div.style.display=this.visibility&&this.inRange?"":"none";this.setTileSize()}},afterAdd:function(){},removeMap:function(){},getImageSize:function(){return this.imageSize||this.tileSize},setTileSize:function(a){this.tileSize=a=a?a:this.tileSize?this.tileSize:this.map.getTileSize();if(this.gutter)this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter),
+this.imageSize=new OpenLayers.Size(a.w+2*this.gutter,a.h+2*this.gutter)},getVisibility:function(){return this.visibility},setVisibility:function(a){if(a!=this.visibility)this.visibility=a,this.display(a),this.redraw(),this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"}),this.events.triggerEvent("visibilitychanged")},display:function(a){if(a!=(this.div.style.display!="none"))this.div.style.display=a&&this.calculateInRange()?"block":"none"},calculateInRange:function(){var a=
+!1;this.alwaysInRange?a=!0:this.map&&(a=this.map.getResolution(),a=this.map.getZoom()>=this.restrictedMinZoom&&a>=this.minResolution&&a<=this.maxResolution);return a},setIsBaseLayer:function(a){if(a!=this.isBaseLayer)this.isBaseLayer=a,this.map!=null&&this.map.events.triggerEvent("changebaselayer",{layer:this})},initResolutions:function(){var a,b,c,d={},e=!0;a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=this.options[c],e&&this.options[c]&&(e=!1);if(this.alwaysInRange==
+null)this.alwaysInRange=e;if(d.resolutions==null)d.resolutions=this.resolutionsFromScales(d.scales);if(d.resolutions==null)d.resolutions=this.calculateResolutions(d);if(d.resolutions==null){a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=this.options[c]!=null?this.options[c]:this.map[c];if(d.resolutions==null)d.resolutions=this.resolutionsFromScales(d.scales);if(d.resolutions==null)d.resolutions=this.calculateResolutions(d)}var f;if(this.options.maxResolution&&
+this.options.maxResolution!=="auto")f=this.options.maxResolution;this.options.minScale&&(f=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units));var g;if(this.options.minResolution&&this.options.minResolution!=="auto")g=this.options.minResolution;this.options.maxScale&&(g=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units));d.resolutions&&(d.resolutions.sort(function(a,b){return b-a}),f||(f=d.resolutions[0]),g||(g=d.resolutions[d.resolutions.length-1]));if(this.resolutions=
+d.resolutions){b=this.resolutions.length;this.scales=Array(b);for(a=0;a<b;a++)this.scales[a]=OpenLayers.Util.getScaleFromResolution(this.resolutions[a],this.units);this.numZoomLevels=b}if(this.minResolution=g)this.maxScale=OpenLayers.Util.getScaleFromResolution(g,this.units);if(this.maxResolution=f)this.minScale=OpenLayers.Util.getScaleFromResolution(f,this.units)},resolutionsFromScales:function(a){if(a!=null){var b,c,d;d=a.length;b=Array(d);for(c=0;c<d;c++)b[c]=OpenLayers.Util.getResolutionFromScale(a[c],
+this.units);return b}},calculateResolutions:function(a){var b,c,d=a.maxResolution;a.minScale!=null?d=OpenLayers.Util.getResolutionFromScale(a.minScale,this.units):d=="auto"&&this.maxExtent!=null&&(b=this.map.getSize(),c=this.maxExtent.getWidth()/b.w,b=this.maxExtent.getHeight()/b.h,d=Math.max(c,b));c=a.minResolution;a.maxScale!=null?c=OpenLayers.Util.getResolutionFromScale(a.maxScale,this.units):a.minResolution=="auto"&&this.minExtent!=null&&(b=this.map.getSize(),c=this.minExtent.getWidth()/b.w,b=
+this.minExtent.getHeight()/b.h,c=Math.max(c,b));b=a.maxZoomLevel;a=a.numZoomLevels;typeof c==="number"&&typeof d==="number"&&a===void 0?a=Math.floor(Math.log(d/c)/Math.log(2))+1:a===void 0&&b!=null&&(a=b+1);if(!(typeof a!=="number"||a<=0||typeof d!=="number"&&typeof c!=="number")){b=Array(a);var e=2;typeof c=="number"&&typeof d=="number"&&(e=Math.pow(d/c,1/(a-1)));var f;if(typeof d==="number")for(f=0;f<a;f++)b[f]=d/Math.pow(e,f);else for(f=0;f<a;f++)b[a-1-f]=c*Math.pow(e,f);return b}},getResolution:function(){return this.getResolutionForZoom(this.map.getZoom())},
+getExtent:function(){return this.map.calculateBounds()},getZoomForExtent:function(a,b){var c=this.map.getSize();return this.getZoomForResolution(Math.max(a.getWidth()/c.w,a.getHeight()/c.h),b)},getDataExtent:function(){},getResolutionForZoom:function(a){a=Math.max(0,Math.min(a,this.resolutions.length-1));if(this.map.fractionalZoom)var b=Math.floor(a),a=this.resolutions[b]-(a-b)*(this.resolutions[b]-this.resolutions[Math.ceil(a)]);else a=this.resolutions[Math.round(a)];return a},getZoomForResolution:function(a,
+b){var c,d;if(this.map.fractionalZoom){var e=0,f=this.resolutions[e],g=this.resolutions[this.resolutions.length-1],h;c=0;for(d=this.resolutions.length;c<d;++c)if(h=this.resolutions[c],h>=a&&(f=h,e=c),h<=a){g=h;break}c=f-g;c=c>0?e+(f-a)/c:e}else{f=Number.POSITIVE_INFINITY;c=0;for(d=this.resolutions.length;c<d;c++)if(b){e=Math.abs(this.resolutions[c]-a);if(e>f)break;f=e}else if(this.resolutions[c]<a)break;c=Math.max(0,c-1)}return Math.max(this.restrictedMinZoom,c)},getLonLatFromViewPortPx:function(a){var b=
+null,c=this.map;if(a!=null&&c.minPx){var b=c.getResolution(),d=c.getMaxExtent({restricted:!0}),b=new OpenLayers.LonLat((a.x-c.minPx.x)*b+d.left,(c.minPx.y-a.y)*b+d.top);this.wrapDateLine&&(b=b.wrapDateLine(this.maxExtent))}return b},getViewPortPxFromLonLat:function(a){var b=null;if(a!=null)var b=this.map.getResolution(),c=this.map.getExtent(),b=new OpenLayers.Pixel(1/b*(a.lon-c.left),1/b*(c.top-a.lat));return b},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;for(var b=0,c=this.div.childNodes.length;b<
+c;++b)OpenLayers.Util.modifyDOMElement(this.div.childNodes[b].firstChild,null,null,null,null,null,null,a);this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"})}},getZIndex:function(){return this.div.style.zIndex},setZIndex:function(a){this.div.style.zIndex=a},adjustBounds:function(a){if(this.gutter)var b=this.gutter*this.map.getResolution(),a=new OpenLayers.Bounds(a.left-b,a.bottom-b,a.right+b,a.top+b);this.wrapDateLine&&(b={rightTolerance:this.getResolution(),
+leftTolerance:this.getResolution()},a=a.wrapDateLine(this.maxExtent,b));return a},CLASS_NAME:"OpenLayers.Layer"});
+OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:!1,initialize:function(a,b,c,d){var e=arguments,e=[a,d];OpenLayers.Layer.prototype.initialize.apply(this,e);this.url=b;this.params=OpenLayers.Util.extend({},c)},destroy:function(){this.params=this.url=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){a==null&&(a=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions()));
+return a=OpenLayers.Layer.prototype.clone.apply(this,[a])},setUrl:function(a){this.url=a},mergeNewParams:function(a){this.params=OpenLayers.Util.extend(this.params,a);a=this.redraw();this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});return a},redraw:function(a){return a?this.mergeNewParams({_olSalt:Math.random()}):OpenLayers.Layer.prototype.redraw.apply(this,[])},selectUrl:function(a,b){for(var c=1,d=0,e=a.length;d<e;d++)c*=a.charCodeAt(d)*this.URL_HASH_FACTOR,
+c-=Math.floor(c);return b[Math.floor(c*b.length)]},getFullRequestString:function(a,b){var c=b||this.url,d=OpenLayers.Util.extend({},this.params),d=OpenLayers.Util.extend(d,a),e=OpenLayers.Util.getParameterString(d);c instanceof Array&&(c=this.selectUrl(e,c));var e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),f;for(f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);return OpenLayers.Util.urlAppend(c,e)},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});
+OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(a){alert(a)},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};
+(function(){for(var a=document.getElementsByTagName("script"),b=0,c=a.length;b<c;++b)if(a[b].src.indexOf("firebug.js")!=-1&&console){OpenLayers.Util.extend(OpenLayers.Console,console);break}})();
+OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:!1,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,timerId:null,initialize:function(){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this)},removeMap:function(){if(this.timerId!=null)window.clearTimeout(this.timerId),
+this.timerId=null},destroy:function(){this.clearGrid();this.tileSize=this.grid=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments)},clearGrid:function(){if(this.grid){for(var a=0,b=this.grid.length;a<b;a++)for(var c=this.grid[a],d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}this.grid=[]}},clone:function(a){a==null&&(a=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions()));a=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,
+[a]);if(this.tileSize!=null)a.tileSize=this.tileSize.clone();a.grid=[];return a},moveTo:function(a,b,c){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);a=a||this.map.getExtent();if(a!=null){var d=!this.grid.length||b,e=this.getTilesBounds();this.singleTile?(d||!c&&!e.containsBounds(a))&&this.initSingleTile(a):d||!e.containsBounds(a,!0)?this.initGriddedTiles(a):this.scheduleMoveGriddedTiles()}},moveByPx:function(){this.scheduleMoveGriddedTiles()},scheduleMoveGriddedTiles:function(){this.timerId!=
+null&&window.clearTimeout(this.timerId);this.timerId=window.setTimeout(this._moveGriddedTiles,this.tileLoadingDelay)},setTileSize:function(a){if(this.singleTile)a=this.map.getSize(),a.h=parseInt(a.h*this.ratio),a.w=parseInt(a.w*this.ratio);OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[a])},getGridBounds:function(){OpenLayers.Console.warn("The getGridBounds() function is deprecated. It will be removed in 3.0. Please use getTilesBounds() instead.");return this.getTilesBounds()},getTilesBounds:function(){var a=
+null;if(this.grid.length)var a=this.grid[this.grid.length-1][0],b=this.grid[0][this.grid[0].length-1],a=new OpenLayers.Bounds(a.bounds.left,a.bounds.bottom,b.bounds.right,b.bounds.top);return a},initSingleTile:function(a){var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio,a=a.getHeight()*this.ratio,b=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2),c=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(b.left,b.top));this.grid.length||(this.grid[0]=[]);(a=this.grid[0][0])?a.moveTo(b,
+c):(a=this.addTile(b,c),this.addTileMonitoringHooks(a),a.draw(),this.grid[0][0]=a);this.removeExcessTiles(1,1)},calculateGridLayout:function(a,b,c){var d=c*this.tileSize.w;c*=this.tileSize.h;var e=a.left-b.lon,f=Math.floor(e/d)-this.buffer,a=a.top-(b.lat+c),g=Math.ceil(a/c)+this.buffer;return{tilelon:d,tilelat:c,tileoffsetlon:b.lon+f*d,tileoffsetlat:b.lat+g*c,tileoffsetx:-(e/d-f)*this.tileSize.w,tileoffsety:-(g-a/c)*this.tileSize.h}},getTileOrigin:function(){var a=this.tileOrigin;if(!a)var a=this.getMaxExtent(),
+b={tl:["left","top"],tr:["right","top"],bl:["left","bottom"],br:["right","bottom"]}[this.tileOriginCorner],a=new OpenLayers.LonLat(a[b[0]],a[b[1]]);return a},initGriddedTiles:function(a){var b=this.map.getSize(),c=Math.ceil(b.h/this.tileSize.h)+Math.max(1,2*this.buffer),b=Math.ceil(b.w/this.tileSize.w)+Math.max(1,2*this.buffer),d=this.getTileOrigin(),e=this.map.getResolution(),f=this.calculateGridLayout(a,d,e),d=Math.round(f.tileoffsetx),e=Math.round(f.tileoffsety),g=f.tileoffsetlon,h=f.tileoffsetlat,
+i=f.tilelon,f=f.tilelat;this.origin=new OpenLayers.Pixel(d,e);var j=d,k=g,n=0,l=parseInt(this.map.layerContainerDiv.style.left),s=parseInt(this.map.layerContainerDiv.style.top);do{var o=this.grid[n++];o||(o=[],this.grid.push(o));var g=k,d=j,q=0;do{var r=new OpenLayers.Bounds(g,h,g+i,h+f),p=d;p-=l;var m=e;m-=s;p=new OpenLayers.Pixel(p,m);(m=o[q++])?m.moveTo(r,p,!1):(m=this.addTile(r,p),this.addTileMonitoringHooks(m),o.push(m));g+=i;d+=this.tileSize.w}while(g<=a.right+i*this.buffer||q<b);h-=f;e+=this.tileSize.h}while(h>=
+a.bottom-f*this.buffer||n<c);this.removeExcessTiles(n,q);this.spiralTileLoad()},getMaxExtent:function(){return this.maxExtent},spiralTileLoad:function(){for(var a=[],b=["right","down","left","up"],c=0,d=-1,e=OpenLayers.Util.indexOf(b,"right"),f=0;f<b.length;){var g=c,h=d;switch(b[e]){case "right":h++;break;case "down":g++;break;case "left":h--;break;case "up":g--}var i=null;g<this.grid.length&&g>=0&&h<this.grid[0].length&&h>=0&&(i=this.grid[g][h]);i!=null&&!i.queued?(a.unshift(i),i.queued=!0,f=0,
+c=g,d=h):(e=(e+1)%4,f++)}b=0;for(c=a.length;b<c;b++)i=a[b],i.draw(),i.queued=!1},addTile:function(a,b){return new OpenLayers.Tile.Image(this,b,a,null,this.tileSize,this.tileOptions)},addTileMonitoringHooks:function(a){a.onLoadStart=function(){this.numLoadingTiles==0&&this.events.triggerEvent("loadstart");this.numLoadingTiles++};a.events.register("loadstart",this,a.onLoadStart);a.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");this.numLoadingTiles==0&&this.events.triggerEvent("loadend")};
+a.events.register("loadend",this,a.onLoadEnd);a.events.register("unload",this,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,scope:this})},moveGriddedTiles:function(){var a=!0,b=this.buffer||1,c=this.grid[0][0].position,d=parseInt(this.map.layerContainerDiv.style.left),e=parseInt(this.map.layerContainerDiv.style.top),c=c.add(d,e);c.x>-this.tileSize.w*(b-1)?this.shiftColumn(!0):c.x<-this.tileSize.w*b?this.shiftColumn(!1):
+c.y>-this.tileSize.h*(b-1)?this.shiftRow(!0):c.y<-this.tileSize.h*b?this.shiftRow(!1):a=!1;if(a)this.timerId=window.setTimeout(this._moveGriddedTiles,0)},shiftRow:function(a){var b=this.grid,c=b[a?0:this.grid.length-1],d=this.map.getResolution(),e=a?-this.tileSize.h:this.tileSize.h;d*=-e;for(var f=a?b.pop():b.shift(),g=0,h=c.length;g<h;g++){var i=c[g],j=i.bounds.clone(),i=i.position.clone();j.bottom+=d;j.top+=d;i.y+=e;f[g].moveTo(j,i)}a?b.unshift(f):b.push(f)},shiftColumn:function(a){for(var b=a?
+-this.tileSize.w:this.tileSize.w,c=this.map.getResolution()*b,d=0,e=this.grid.length;d<e;d++){var f=this.grid[d],g=f[a?0:f.length-1],h=g.bounds.clone(),g=g.position.clone();h.left+=c;h.right+=c;g.x+=b;var i=a?this.grid[d].pop():this.grid[d].shift();i.moveTo(h,g);a?f.unshift(i):f.push(i)}},removeExcessTiles:function(a,b){for(;this.grid.length>a;)for(var c=this.grid.pop(),d=0,e=c.length;d<e;d++){var f=c[d];this.removeTileMonitoringHooks(f);f.destroy()}for(;this.grid[0].length>b;){d=0;for(e=this.grid.length;d<
+e;d++)c=this.grid[d],f=c.pop(),this.removeTileMonitoringHooks(f),f.destroy()}},onMapResize:function(){this.singleTile&&(this.clearGrid(),this.setTileSize())},getTileBounds:function(a){var b=this.maxExtent,c=this.getResolution(),d=c*this.tileSize.w;c*=this.tileSize.h;var e=this.getLonLatFromViewPortPx(a),a=b.left+d*Math.floor((e.lon-b.left)/d),b=b.bottom+c*Math.floor((e.lat-b.bottom)/c);return new OpenLayers.Bounds(a,b,a+d,b+c)},CLASS_NAME:"OpenLayers.Layer.Grid"});
+OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:!1,displayClass:"",title:"",autoActivate:!1,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(a){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);if(this.id==
+null)this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){if(this.events)this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy(),this.events=null;this.eventListeners=null;if(this.handler)this.handler.destroy(),this.handler=null;if(this.handlers){for(var a in this.handlers)this.handlers.hasOwnProperty(a)&&typeof this.handlers[a].destroy=="function"&&this.handlers[a].destroy();this.handlers=null}if(this.map)this.map.removeControl(this),this.map=null;
+this.div=null},setMap:function(a){this.map=a;this.handler&&this.handler.setMap(a)},draw:function(a){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection)this.div.className+=" olControlNoSelect",this.div.setAttribute("unselectable","on",0),this.div.onselectstart=OpenLayers.Function.False;if(this.title!="")this.div.title=this.title}if(a!=null)this.position=a.clone();this.moveTo(this.position);return this.div},moveTo:function(a){if(a!=
+null&&this.div!=null)this.div.style.left=a.x+"px",this.div.style.top=a.y+"px"},activate:function(){if(this.active)return!1;this.handler&&this.handler.activate();this.active=!0;this.map&&OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");this.events.triggerEvent("activate");return!0},deactivate:function(){if(this.active)return this.handler&&this.handler.deactivate(),this.active=!1,this.map&&OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,
+"")+"Active"),this.events.triggerEvent("deactivate"),!0;return!1},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;
+OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({removelayer:this.updateAttribution,addlayer:this.updateAttribution,changelayer:this.updateAttribution,changebaselayer:this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({changebaselayer:this.updateAttribution,changelayer:this.updateAttribution,
+addlayer:this.updateAttribution,removelayer:this.updateAttribution,scope:this});this.updateAttribution();return this.div},updateAttribution:function(){var a=[];if(this.map&&this.map.layers){for(var b=0,c=this.map.layers.length;b<c;b++){var d=this.map.layers[b];d.attribution&&d.getVisibility()&&OpenLayers.Util.indexOf(a,d.attribution)===-1&&a.push(d.attribution)}this.div.innerHTML=a.join(this.separator)}},CLASS_NAME:"OpenLayers.Control.Attribution"});
+OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:!1,evt:null,initialize:function(a,b,c){OpenLayers.Util.extend(this,c);this.control=a;this.callbacks=b;(a=this.map||a.map)&&this.setMap(a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},setMap:function(a){this.map=a},checkModifiers:function(a){if(this.keyMask==null)return!0;return((a.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(a.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(a.altKey?OpenLayers.Handler.MOD_ALT:
+0))==this.keyMask},activate:function(){if(this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.register(a[b],this[a[b]]);return this.active=!0},deactivate:function(){if(!this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]]);this.active=!1;return!0},callback:function(a,b){a&&this.callbacks[a]&&this.callbacks[a].apply(this.control,b)},register:function(a,
+b){this.map.events.registerPriority(a,this,b);this.map.events.registerPriority(a,this,this.setEvent)},unregister:function(a,b){this.map.events.unregister(a,this,b);this.map.events.unregister(a,this,this.setEvent)},setEvent:function(a){this.evt=a;return!0},destroy:function(){this.deactivate();this.control=this.map=null},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;
+OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:!0,"double":!1,pixelTolerance:0,dblclickTolerance:13,stopSingle:!1,stopDouble:!1,timerId:null,touch:!1,down:null,last:null,first:null,rightclickTimerId:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments)},touchstart:function(a){if(!this.touch)this.unregisterMouseListeners(),this.touch=!0;this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},touchmove:function(a){this.last=
+this.getEventInfo(a);return!0},touchend:function(a){if(this.down)a.xy=this.last.xy,a.lastTouches=this.last.touches,this.handleSingle(a),this.down=null;return!0},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this})},mousedown:function(a){this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},mouseup:function(a){var b=!0;this.checkModifiers(a)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(a)&&
+(b=this.rightclick(a));return b},rightclick:function(a){if(this.passesTolerance(a))if(this.rightclickTimerId!=null)return this.clearTimer(),this.callback("dblrightclick",[a]),!this.stopDouble;else a=this["double"]?OpenLayers.Util.extend({},a):this.callback("rightclick",[a]),a=OpenLayers.Function.bind(this.delayedRightCall,this,a),this.rightclickTimerId=window.setTimeout(a,this.delay);return!this.stopSingle},delayedRightCall:function(a){this.rightclickTimerId=null;a&&this.callback("rightclick",[a])},
+click:function(a){if(!this.last)this.last=this.getEventInfo(a);this.handleSingle(a);return!this.stopSingle},dblclick:function(a){this.handleDouble(a);return!this.stopDouble},handleDouble:function(a){this["double"]&&this.passesDblclickTolerance(a)&&this.callback("dblclick",[a])},handleSingle:function(a){if(this.passesTolerance(a))this.timerId!=null?(this.last.touches&&this.last.touches.length===1&&(this["double"]&&OpenLayers.Event.stop(a),this.handleDouble(a)),(!this.last.touches||this.last.touches.length!==
+2)&&this.clearTimer()):(this.first=this.getEventInfo(a),this.queuePotentialClick(this.single?OpenLayers.Util.extend({},a):null))},queuePotentialClick:function(a){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay)},passesTolerance:function(a){var b=!0;if(this.pixelTolerance!=null&&this.down&&this.down.xy&&(b=this.pixelTolerance>=this.down.xy.distanceTo(a.xy))&&this.touch&&this.down.touches.length===this.last.touches.length)for(var a=0,c=this.down.touches.length;a<
+c;++a)if(this.getTouchDistance(this.down.touches[a],this.last.touches[a])>this.pixelTolerance){b=!1;break}return b},getTouchDistance:function(a,b){return Math.sqrt(Math.pow(a.clientX-b.clientX,2)+Math.pow(a.clientY-b.clientY,2))},passesDblclickTolerance:function(){var a=!0;this.down&&this.first&&(a=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance);return a},clearTimer:function(){if(this.timerId!=null)window.clearTimeout(this.timerId),this.timerId=null;if(this.rightclickTimerId!=null)window.clearTimeout(this.rightclickTimerId),
+this.rightclickTimerId=null},delayedCall:function(a){this.timerId=null;a&&this.callback("click",[a])},getEventInfo:function(a){var b;if(a.touches){var c=a.touches.length;b=Array(c);for(var d,e=0;e<c;e++)d=a.touches[e],b[e]={clientX:d.clientX,clientY:d.clientY}}return{xy:a.xy,touches:b}},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.clearTimer(),this.last=this.first=this.down=null,this.touch=!1,a=!0;return a},CLASS_NAME:"OpenLayers.Handler.Click"});
+OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:void 0,timerId:void 0,initialize:function(a){OpenLayers.Util.extend(this,a)},begin:function(){clearInterval(this.timerId);this.timerId=void 0;this.points=[]},update:function(a){this.points.unshift({xy:a,tick:(new Date).getTime()});this.points.length>this.nbPoints&&this.points.pop()},end:function(a){for(var b,c=(new Date).getTime(),d=0,e=this.points.length,f;d<e;d++){f=this.points[d];if(c-
+f.tick>this.delay)break;b=f}if(b&&(d=(new Date).getTime()-b.tick,c=Math.sqrt(Math.pow(a.x-b.xy.x,2)+Math.pow(a.y-b.xy.y,2)),d=c/d,!(d==0||d<this.threshold)))return c=Math.asin((a.y-b.xy.y)/c),b.xy.x<=a.x&&(c=Math.PI-c),{speed:d,theta:c}},move:function(a,b){var c=a.speed,d=Math.cos(a.theta),e=-Math.sin(a.theta),f=0,g=(new Date).getTime(),h=0,i=0;this.timerId=window.setInterval(OpenLayers.Function.bind(function(){if(this.timerId!=null){f+=this.interval;var a=(new Date).getTime()-g,a=(f+a)/2,k=-this.deceleration*
+Math.pow(a,2)/2+c*a,n=k*d;k*=e;var l={end:!1};if(-this.deceleration*a+c<=0)clearInterval(this.timerId),this.timerId=null,l.end=!0;l.x=n-h;l.y=k-i;h=n;i=k;b(l.x,l.y,l.end)}},this),this.interval)},CLASS_NAME:"OpenLayers.Kinetic"});
+OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:!0,defaultControl:null,saveState:!1,allowDepress:!1,activeState:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.controls=[];this.activeState={}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var a,b=this.controls.length-1;b>=0;b--)a=this.controls[b],a.events&&a.events.un({activate:this.iconOn,deactivate:this.iconOff}),OpenLayers.Event.stopObservingElement(a.panel_div),
+a.panel_div=null;this.activeState=null},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var a,b=0,c=this.controls.length;b<c;b++)a=this.controls[b],(a===this.defaultControl||this.saveState&&this.activeState[a.id])&&a.activate();if(this.saveState===!0)this.defaultControl=null;this.redraw();return!0}else return!1},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var a,b=0,c=this.controls.length;b<c;b++)a=this.controls[b],
+this.activeState[a.id]=a.deactivate();this.redraw();return!0}else return!1},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.addControlsToMap(this.controls);return this.div},redraw:function(){for(var a=this.div.childNodes.length-1;a>=0;a--)this.div.removeChild(this.div.childNodes[a]);this.div.innerHTML="";if(this.active)for(var a=0,b=this.controls.length;a<b;a++)this.div.appendChild(this.controls[a].panel_div)},activateControl:function(a){if(!this.active)return!1;if(a.type==
+OpenLayers.Control.TYPE_BUTTON)a.trigger();else if(a.type==OpenLayers.Control.TYPE_TOGGLE)a.active?a.deactivate():a.activate();else if(this.allowDepress&&a.active)a.deactivate();else{for(var b,c=0,d=this.controls.length;c<d;c++)b=this.controls[c],b!=a&&(b.type===OpenLayers.Control.TYPE_TOOL||b.type==null)&&b.deactivate();a.activate()}},addControls:function(a){a instanceof Array||(a=[a]);this.controls=this.controls.concat(a);for(var b=0,c=a.length;b<c;b++){var d=document.createElement("div");d.className=
+a[b].displayClass+"ItemInactive";a[b].panel_div=d;if(a[b].title!="")a[b].panel_div.title=a[b].title;OpenLayers.Event.observe(a[b].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,a[b]));OpenLayers.Event.observe(a[b].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,a[b]));OpenLayers.Event.observe(a[b].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop))}this.map&&(this.addControlsToMap(a),this.redraw())},addControlsToMap:function(a){for(var b,
+c=0,d=a.length;c<d;c++)b=a[c],b.autoActivate===!0?(b.autoActivate=!1,this.map.addControl(b),b.autoActivate=!0):(this.map.addControl(b),b.deactivate()),b.events.on({activate:this.iconOn,deactivate:this.iconOff})},iconOn:function(){var a=this.panel_div;a.className=a.className.replace(/ItemInactive$/,"ItemActive")},iconOff:function(){var a=this.panel_div;a.className=a.className.replace(/ItemActive$/,"ItemInactive")},onClick:function(a,b){OpenLayers.Event.stop(b?b:window.event);this.activateControl(a)},
+onDoubleClick:function(a,b){OpenLayers.Event.stop(b?b:window.event)},getControlsBy:function(a,b){var c=typeof b.test=="function";return OpenLayers.Array.filter(this.controls,function(d){return d[a]==b||c&&b.test(d[a])})},getControlsByName:function(a){return this.getControlsBy("name",a)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},CLASS_NAME:"OpenLayers.Control.Panel"});
+OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomIn()},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomOut()},CLASS_NAME:"OpenLayers.Control.ZoomOut"});
+OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map&&this.map.zoomToMaxExtent()},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);this.addControls([new OpenLayers.Control.ZoomIn,new OpenLayers.Control.ZoomToMaxExtent,new OpenLayers.Control.ZoomOut])},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});
+OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!1,pinching:!1,last:null,start:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments)},touchstart:function(a){var b=!0;this.pinching=!1;OpenLayers.Event.isMultiTouch(a)?(this.started=!0,this.last=this.start={distance:this.getDistance(a.touches),delta:0,scale:1},this.callback("start",[a,this.start]),b=!this.stopDown):(this.started=!1,this.last=this.start=null);OpenLayers.Event.stop(a);
+return b},touchmove:function(a){if(this.started&&OpenLayers.Event.isMultiTouch(a)){this.pinching=!0;var b=this.getPinchData(a);this.callback("move",[a,b]);this.last=b;OpenLayers.Event.stop(a)}return!0},touchend:function(a){if(this.started)this.pinching=this.started=!1,this.callback("done",[a,this.start,this.last]),this.last=this.start=null;return!0},activate:function(){var a=!1;if(OpenLayers.Handler.prototype.activate.apply(this,arguments))this.pinching=!1,a=!0;return a},deactivate:function(){var a=
+!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.pinching=this.started=!1,this.last=this.start=null,a=!0;return a},getDistance:function(a){var b=a[0],a=a[1];return Math.sqrt(Math.pow(b.clientX-a.clientX,2)+Math.pow(b.clientY-a.clientY,2))},getPinchData:function(a){a=this.getDistance(a.touches);return{distance:a,delta:this.last.distance-a,scale:a/this.start.distance}},CLASS_NAME:"OpenLayers.Handler.Pinch"});
+OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,autoActivate:!0,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions)},activate:function(){var a=OpenLayers.Control.prototype.activate.apply(this,arguments);a&&(this.map.events.on({moveend:this.updateContainerOrigin,
+scope:this}),this.updateContainerOrigin());return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.apply(this,arguments);this.map&&this.map.events&&this.map.events.un({moveend:this.updateContainerOrigin,scope:this});return a},updateContainerOrigin:function(){var a=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(a.style.left,10),y:parseInt(a.style.top,10)}},pinchStart:function(a){this.currentCenter=this.pinchOrigin=a.xy},pinchMove:function(a,b){var c=b.scale,d=this.containerOrigin,
+e=this.pinchOrigin,f=a.xy;this.applyTransform("translate("+Math.round(f.x-e.x+(c-1)*(d.x-e.x))+"px, "+Math.round(f.y-e.y+(c-1)*(d.y-e.y))+"px) scale("+c+")");this.currentCenter=f},applyTransform:function(a){var b=this.map.layerContainerDiv.style;b["-webkit-transform"]=a;b["-moz-transform"]=a},pinchDone:function(a,b,c){this.applyTransform("");a=this.map.getZoomForResolution(this.map.getResolution()/c.scale,!0);if(a!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){var b=this.map.getResolutionForZoom(a),
+c=this.map.getLonLatFromPixel(this.pinchOrigin),d=this.currentCenter,e=this.map.getSize();c.lon+=b*(e.w/2-d.x);c.lat-=b*(e.h/2-d.y);this.map.setCenter(c,a)}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});
+OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:!1,initialize:function(a,b,c,d,e,f){this.layer=a;this.position=b.clone();this.bounds=c.clone();this.url=d;if(e)this.size=e.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,f)},unload:function(){if(this.isLoading)this.isLoading=!1,
+this.events.triggerEvent("unload")},destroy:function(){this.position=this.size=this.bounds=this.layer=null;this.events.destroy();this.events=null},clone:function(a){a==null&&(a=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size));OpenLayers.Util.applyDefaults(a,this);return a},draw:function(){var a=this.layer.maxExtent;this.shouldDraw=a&&this.bounds.intersectsBounds(a,!1)||this.layer.displayOutsideMaxExtent;this.clear();return this.shouldDraw},moveTo:function(a,b,c){c==null&&
+(c=!0);this.bounds=a.clone();this.position=b.clone();c&&this.draw()},clear:function(){},getBoundsFromBaseLayer:function(a){var b=OpenLayers.i18n("reprojectDeprecated",{layerName:this.layer.name});OpenLayers.Console.warn(b);b=this.layer.map.getLonLatFromLayerPx(a);a=a.clone();a.x+=this.size.w;a.y+=this.size.h;a=this.layer.map.getLonLatFromLayerPx(a);if(b.lon>a.lon)b.lon<0?b.lon=-180-(b.lon+180):a.lon=180+a.lon+180;return new OpenLayers.Bounds(b.lon,a.lat,a.lon,b.lat)},showTile:function(){this.shouldDraw&&
+this.show()},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});
+OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:!1,isFirstDraw:!0,backBufferTile:null,maxGetUrlLength:null,initialize:function(a,b,c,d){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.maxGetUrlLength!=null&&OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);this.url=d;this.frame=document.createElement("div");this.frame.style.overflow="hidden";this.frame.style.position="absolute";this.layerAlphaHack=this.layer.alpha&&
+OpenLayers.Util.alphaHack()},destroy:function(){this.imgDiv!=null&&this.removeImgDiv();this.imgDiv=null;this.frame!=null&&this.frame.parentNode==this.layer.div&&this.layer.div.removeChild(this.frame);this.frame=null;if(this.backBufferTile)this.backBufferTile.destroy(),this.backBufferTile=null;this.layer.events.unregister("loadend",this,this.resetBackBuffer);OpenLayers.Tile.prototype.destroy.apply(this,arguments)},clone:function(a){a==null&&(a=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,
+this.url,this.size));a=OpenLayers.Tile.prototype.clone.apply(this,[a]);a.imgDiv=null;return a},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject)this.bounds=this.getBoundsFromBaseLayer(this.position);var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1||this.layer.singleTile)if(a){if(!this.backBufferTile)this.backBufferTile=this.clone(),this.backBufferTile.hide(),this.backBufferTile.isBackBuffer=
+!0,this.events.register("loadend",this,this.resetBackBuffer),this.layer.events.register("loadend",this,this.resetBackBuffer);this.startTransition()}else this.backBufferTile&&this.backBufferTile.clear();else if(a&&this.isFirstDraw)this.events.register("loadend",this,this.showTile),this.isFirstDraw=!1;if(!a)return!1;this.isLoading?this.events.triggerEvent("reload"):(this.isLoading=!0,this.events.triggerEvent("loadstart"));return this.renderTile()},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&
+(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=!1;var a=this.layer.maxExtent;if(a&&this.bounds.intersectsBounds(a,!1))this.backBufferTile.position=this.position,this.backBufferTile.bounds=this.bounds,this.backBufferTile.size=this.size,this.backBufferTile.imageSize=this.layer.getImageSize(this.bounds)||this.size,this.backBufferTile.imageOffset=this.layer.imageOffset,this.backBufferTile.resolution=this.layer.getResolution(),this.backBufferTile.renderTile();this.backBufferTile.hide()}},
+renderTile:function(){this.layer.async?(this.initImgDiv(),this.layer.getURLasync(this.bounds,this,"url",this.positionImage)):(this.url=this.layer.getURL(this.bounds),this.initImgDiv(),this.positionImage());return!0},positionImage:function(){if(this.layer!==null){OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var a=this.layer.getImageSize(this.bounds);this.layerAlphaHack?OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,a,this.url):(OpenLayers.Util.modifyDOMElement(this.imgDiv,
+null,null,a),this.imgDiv.src=this.url)}},clear:function(){if(this.imgDiv&&(this.hide(),OpenLayers.Tile.Image.useBlankTile))this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif"},initImgDiv:function(){if(this.imgDiv==null){var a=this.layer.imageOffset,b=this.layer.getImageSize(this.bounds);this.imgDiv=this.layerAlphaHack?OpenLayers.Util.createAlphaImageDiv(null,a,b,null,"relative",null,null,null,!0):OpenLayers.Util.createImage(null,a,b,null,"relative",null,null,!0);if(this.layer.url instanceof
+Array)this.imgDiv.urls=this.layer.url.slice();this.imgDiv.className="olTileImage";this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);this.layer.opacity!=null&&OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);this.imgDiv.map=this.layer.map;var c=function(){if(this.isLoading)this.isLoading=!1,this.events.triggerEvent("loadend")};this.layerAlphaHack?OpenLayers.Event.observe(this.imgDiv.childNodes[0],
+"load",OpenLayers.Function.bind(c,this)):OpenLayers.Event.observe(this.imgDiv,"load",OpenLayers.Function.bind(c,this));OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(function(){this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS&&c.call(this)},this))}this.imgDiv.viewRequestID=this.layer.map.viewRequestID},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==this.frame)this.frame.removeChild(this.imgDiv),this.imgDiv.map=null;
+this.imgDiv.urls=null;var a=this.imgDiv.firstChild;a?(OpenLayers.Event.stopObservingElement(a),this.imgDiv.removeChild(a),delete a):this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif"},checkImgURL:function(){this.layer&&(OpenLayers.Util.isEquivalentUrl(this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src,this.url)||this.hide())},startTransition:function(){if(this.backBufferTile&&this.backBufferTile.imgDiv){var a=1;this.backBufferTile.resolution&&(a=this.backBufferTile.resolution/
+this.layer.getResolution());if(a!=1){if(this.layer.transitionEffect=="resize"){var b=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top),c=new OpenLayers.Size(this.backBufferTile.size.w*a,this.backBufferTile.size.h*a),b=this.layer.map.getLayerPxFromLonLat(b);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,b,c);c=this.backBufferTile.imageSize;c=new OpenLayers.Size(c.w*a,c.h*a);(b=this.backBufferTile.imageOffset)&&(b=new OpenLayers.Pixel(b.x*a,b.y*a));
+OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,b,c);this.backBufferTile.show()}}else this.layer.singleTile?this.backBufferTile.show():this.backBufferTile.hide()}},show:function(){this.frame.style.display="";if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1&&OpenLayers.IS_GECKO===!0)this.frame.scrollLeft=this.frame.scrollLeft},hide:function(){this.frame.style.display="none"},CLASS_NAME:"OpenLayers.Tile.Image"});
+OpenLayers.Tile.Image.useBlankTile=OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera";
+OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,sphericalMercator:!1,zoomOffset:0,serverResolutions:null,initialize:function(a,b,c){if(c&&c.sphericalMercator||this.sphericalMercator)c=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-2.003750834E7,-2.003750834E7,2.003750834E7,2.003750834E7),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},c);b=b||this.url;a=a||this.name;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,
+{},c])},clone:function(a){a==null&&(a=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var a=this.getXYZ(a),b=this.url;b instanceof Array&&(b=this.selectUrl(""+a.x+a.y+a.z,b));return OpenLayers.String.format(b,a)},getXYZ:function(a){var b=this.map.getResolution(),c=Math.round((a.left-this.maxExtent.left)/(b*this.tileSize.w)),a=Math.round((this.maxExtent.top-a.top)/(b*this.tileSize.h)),b=this.serverResolutions!=
+null?OpenLayers.Util.indexOf(this.serverResolutions,b):this.map.getZoom()+this.zoomOffset,d=Math.pow(2,b);this.wrapDateLine&&(c=(c%d+d)%d);return{x:c,y:a,z:b}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin)this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom)},CLASS_NAME:"OpenLayers.Layer.XYZ"});
+OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:!0,url:"http://tile.openstreetmap.org/${z}/${x}/${y}.png",clone:function(a){a==null&&(a=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},wrapDateLine:!0,CLASS_NAME:"OpenLayers.Layer.OSM"});
+OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!0,dragging:!1,touch:!1,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:!1,documentEvents:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===!0){var a=this;this._docMove=function(b){a.mousemove({xy:{x:b.clientX,y:b.clientY},element:document})};this._docUp=function(b){a.mouseup({xy:{x:b.clientX,y:b.clientY}})}}},
+dragstart:function(a){var b=!0;this.dragging=!1;if(this.checkModifiers(a)&&(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))){this.started=!0;this.last=this.start=a.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(a);this.callback("down",[a.xy]);OpenLayers.Event.stop(a);if(!this.oldOnselectstart)this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;document.onselectstart=OpenLayers.Function.False;b=!this.stopDown}else this.started=
+!1,this.last=this.start=null;return b},dragmove:function(a){this.lastMoveEvt=a;if(this.started&&!this.timeoutId&&(a.xy.x!=this.last.x||a.xy.y!=this.last.y)){this.documentDrag===!0&&this.documentEvents&&(a.element===document?(this.adjustXY(a),this.setEvent(a)):this.removeDocumentEvents());if(this.interval>0)this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);this.dragging=!0;this.move(a);this.callback("move",[a.xy]);if(!this.oldOnselectstart)this.oldOnselectstart=
+document.onselectstart,document.onselectstart=OpenLayers.Function.False;this.last=a.xy}return!0},dragend:function(a){if(this.started){this.documentDrag===!0&&this.documentEvents&&(this.adjustXY(a),this.removeDocumentEvents());var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(a);this.callback("up",[a.xy]);b&&this.callback("done",[a.xy]);document.onselectstart=this.oldOnselectstart}return!0},down:function(){},move:function(){},
+up:function(){},out:function(){},mousedown:function(a){return this.dragstart(a)},touchstart:function(a){if(!this.touch)this.touch=!0,this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,scope:this});return this.dragstart(a)},mousemove:function(a){return this.dragmove(a)},touchmove:function(a){return this.dragmove(a)},removeTimeout:function(){this.timeoutId=null;this.dragging&&this.mousemove(this.lastMoveEvt)},mouseup:function(a){return this.dragend(a)},
+touchend:function(a){a.xy=this.last;return this.dragend(a)},mouseout:function(a){if(this.started&&OpenLayers.Util.mouseLeft(a,this.map.eventsDiv))if(this.documentDrag===!0)this.addDocumentEvents();else{var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(a);this.callback("out",[]);b&&this.callback("done",[a.xy]);if(document.onselectstart)document.onselectstart=this.oldOnselectstart}return!0},click:function(){return this.start==
+this.last},activate:function(){var a=!1;if(OpenLayers.Handler.prototype.activate.apply(this,arguments))this.dragging=!1,a=!0;return a},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments))this.dragging=this.started=this.touch=!1,this.last=this.start=null,a=!0,OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");return a},adjustXY:function(a){var b=OpenLayers.Util.pagePosition(this.map.viewPortDiv);a.xy.x-=b[0];a.xy.y-=b[1]},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,
+"olDragDown");this.documentEvents=!0;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp)},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=!1;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp)},CLASS_NAME:"OpenLayers.Handler.Drag"});
+OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:!1,interval:25,documentDrag:!1,kinetic:null,enableKinetic:!1,kineticInterval:10,draw:function(){if(this.enableKinetic){var a={interval:this.kineticInterval};typeof this.enableKinetic==="object"&&(a=OpenLayers.Util.extend(a,this.enableKinetic));this.kinetic=new OpenLayers.Kinetic(a)}this.handler=new OpenLayers.Handler.Drag(this,{move:this.panMap,done:this.panMapDone,down:this.panMapStart},{interval:this.interval,
+documentDrag:this.documentDrag})},panMapStart:function(){this.kinetic&&this.kinetic.begin()},panMap:function(a){this.kinetic&&this.kinetic.update(a);this.panned=!0;this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!0,animate:!1})},panMapDone:function(a){if(this.panned){var b=null;this.kinetic&&(b=this.kinetic.end(a));this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!!b,animate:!1});if(b){var c=this;this.kinetic.move(b,function(a,b,f){c.map.pan(a,b,{dragging:!f,
+animate:!1})})}this.panned=!1}},CLASS_NAME:"OpenLayers.Control.DragPan"});
+OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:!1,autoActivate:!0,initialize:function(){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;this.pinchZoom&&(this.pinchZoom.destroy(),delete this.pinchZoom);OpenLayers.Control.prototype.destroy.apply(this,
+arguments)},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments))return this.dragPan.activate(),this.handlers.click.activate(),this.pinchZoom.activate(),!0;return!1},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments))return this.dragPan.deactivate(),this.handlers.click.deactivate(),this.pinchZoom.deactivate(),!0;return!1},draw:function(){var a={click:this.defaultClick,dblclick:this.defaultDblClick},b=OpenLayers.Util.extend({"double":!0,
+stopDouble:!0,pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,a,b);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions))},defaultClick:function(a){a.lastTouches&&a.lastTouches.length==2&&this.map.zoomOut()},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),
+this.map.zoom+1)},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});
+OpenLayers.Layer.SphericalMercator={getExtent:function(){var a=null;return a=this.sphericalMercator?this.map.calculateBounds():OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this)},getLonLatFromViewPortPx:function(){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments)},getViewPortPxFromLonLat:function(){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments)},initMercatorParameters:function(){this.RESOLUTIONS=[];for(var a=0;a<=this.MAX_ZOOM_LEVEL;++a)this.RESOLUTIONS[a]=
+156543.03390625/Math.pow(2,a);this.units="m";this.projection=this.projection||"EPSG:900913"},forwardMercator:function(a,b){var c;c=Math.log(Math.tan((90+b)*Math.PI/360))/(Math.PI/180);return new OpenLayers.LonLat(a*2.003750834E7/180,c*2.003750834E7/180)},inverseMercator:function(a,b){var c;c=180/Math.PI*(2*Math.atan(Math.exp(b/2.003750834E7*180*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(a/2.003750834E7*180,c)},projectForward:function(a){var b=OpenLayers.Layer.SphericalMercator.forwardMercator(a.x,
+a.y);a.x=b.lon;a.y=b.lat;return a},projectInverse:function(a){var b=OpenLayers.Layer.SphericalMercator.inverseMercator(a.x,a.y);a.x=b.lon;a.y=b.lat;return a}};(function(){var a=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"],b=OpenLayers.Projection.addTransform,c=OpenLayers.Layer.SphericalMercator,d=OpenLayers.Projection.nullTransform,e,f,g,h,i;e=0;for(f=a.length;e<f;++e){g=a[e];b("EPSG:4326",g,c.projectForward);b(g,"EPSG:4326",c.projectInverse);for(i=e+1;i<f;++i)h=a[i],b(g,h,d),b(h,g,d)}})();
More information about the Commits
