[OpenLayers-Commits] r12013 - in
sandbox/tschaub/editing/lib/OpenLayers: Control Handler
commits-20090109 at openlayers.org
Wed May 25 17:13:42 EDT 2011
Author: tschaub
Date: 2011-05-25 14:13:41 -0700 (Wed, 25 May 2011)
New Revision: 12013
sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
Add undo/redo for draw control and sketch handlers.
Modified: sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js
--- sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-25 20:51:53 UTC (rev 12012)
+++ sandbox/tschaub/editing/lib/OpenLayers/Control/DrawFeature.js 2011-05-25 21:13:41 UTC (rev 12013)
@@ -119,6 +119,13 @@
this.layer.addFeatures([feature]);
this.featureAdded(feature);
this.events.triggerEvent("featureadded",{feature : feature});
+ if (!this.undoStack) {
+ this.undoStack = [];
+ this.undoStack.push(this.layer.features.length-1);
+ if (!this._redoing) {
+ delete this.redoStack;
@@ -179,8 +186,54 @@
this.handler.insertDeflectionLength(deflection, length);
+ * Method: undo
+ * Remove the most recently added point in the sketch geometry.
+ * Returns:
+ * {Boolean} An edit was undone.
+ undo: function() {
+ var undone = this.handler.undo && this.handler.undo();
+ if (!undone) {
+ var index = this.undoStack && this.undoStack.pop();
+ if (index != null) {
+ var feature = this.layer.features[index];
+ this.layer.removeFeatures([feature]);
+ if (!this.redoStack) {
+ this.redoStack = [];
+ this.redoStack.push(feature.geometry);
+ undone = true;
+ return !!undone;
+ * Method: redo
+ * Reinsert the most recently removed point resulting from an <undo> call.
+ * The undo stack is deleted whenever a point is added by other means.
+ * Returns:
+ * {Boolean} An edit was redone.
+ redo: function() {
+ var redone = false;
+ var geometry = this.redoStack && this.redoStack.pop();
+ if (geometry) {
+ this._redoing = true;
+ this.drawFeature(geometry);
+ delete this._redoing;
+ redone = true;
+ } else {
+ redone = this.handler.redo && this.handler.redo();
+ return !!redone;
* APIMethod: finishSketch
* Finishes the sketch without including the currently drawn point.
* This method can be called to terminate drawing programmatically
Modified: sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
--- sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-25 20:51:53 UTC (rev 12012)
+++ sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-05-25 21:13:41 UTC (rev 12013)
@@ -68,6 +68,12 @@
timerId: null,
+ * Property: redoStack
+ * {Array} Stack containing points removed with <undo>.
+ redoStack: null,
* Constructor: OpenLayers.Handler.Path
* Create a new path hander
@@ -169,6 +175,7 @@
this.callback("point", [this.point.geometry, this.getGeometry()]);
this.callback("modify", [this.point.geometry, this.getSketch()]);
this.drawFeature();
@@ -186,6 +193,7 @@
this.getCurrentPointIndex()
this.drawFeature();
@@ -249,7 +257,51 @@
return this.line.geometry.components.length - 1;
+ * Method: undo
+ * Returns:
+ * {Boolean} A point was removed.
+ var undone = false;
+ var geometry = this.line.geometry;
+ var index = this.getCurrentPointIndex() - 1;
+ var target = geometry.components[index];
+ var count = geometry.components.length;
+ if (count > 1) {
+ undone = true;
+ OpenLayers.Util.removeItem(geometry.components, target);
+ geometry.clearBounds();
+ this.redoStack.push(target);
+ this.drawFeature();
+ return undone;
+ * Method: redo
+ * Returns:
+ * {Boolean} A point was added.
+ var target = this.redoStack && this.redoStack.pop();
+ if (target) {
+ this.line.geometry.addComponent(target, this.getCurrentPointIndex());
+ return !!target;
* Method: freehandMode
* Determine whether to behave in freehand mode or not.
More information about the Commits
