[OpenLayers-Commits] r12361 -
sandbox/camptocamp/gpx/openlayers/lib/OpenLayers/Format
commits-20090109 at openlayers.org
Wed Sep 14 03:06:27 EDT 2011
Author: pgiraud
Date: 2011-09-14 00:06:27 -0700 (Wed, 14 Sep 2011)
New Revision: 12361
sandbox/camptocamp/gpx/openlayers/lib/OpenLayers/Format/GPX.js
Small fixes, thanks to marcjansen
Modified: sandbox/camptocamp/gpx/openlayers/lib/OpenLayers/Format/GPX.js
--- sandbox/camptocamp/gpx/openlayers/lib/OpenLayers/Format/GPX.js 2011-09-13 12:08:41 UTC (rev 12360)
+++ sandbox/camptocamp/gpx/openlayers/lib/OpenLayers/Format/GPX.js 2011-09-14 07:06:27 UTC (rev 12361)
@@ -21,21 +21,14 @@
OpenLayers.Format.GPX = OpenLayers.Class(OpenLayers.Format.XML, {
- * APIProperty: waypointsDesc
- * {String} Default description of the waypoints in the case where the
- * feature has no "description" attribute.
- * Default is "No description available".
- waypointsDesc: "No description available",
- * APIProperty: tracksDesc
- * {String} Default description of the tracks in the case where the
+ * APIProperty: defaultDesc
+ * {String} Default description for the waypoints/tracks in the case
+ * where the feature has no "description" attribute.
- tracksDesc: "No description available",
+ defaultDesc: "No description available",
* APIProperty: extractWaypoints
@@ -291,17 +284,22 @@
* geometry - {OpenLayers.Geometry}
buildTrkSegNode: function(geometry) {
+ var node,
+ i,
+ len,
+ point,
+ nodes;
if (geometry.CLASS_NAME == "OpenLayers.Geometry.LineString" ||
geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing") {
- var node = this.createElementNS(this.gpxns, "trkseg");
- for (var i = 0, len=geometry.components.length; i < len; i++) {
- var point = geometry.components[i];
+ node = this.createElementNS(this.gpxns, "trkseg");
+ for (i = 0, len=geometry.components.length; i < len; i++) {
+ point = geometry.components[i];
node.appendChild(this.buildTrkPtNode(point));
return node;
} else {
- var nodes = [];
- for (var i = 0, len = geometry.components.length; i < len; i++) {
+ nodes = [];
+ for (i = 0, len = geometry.components.length; i < len; i++) {
nodes.push(this.buildTrkSegNode(geometry.components[i]));
return nodes;
@@ -354,7 +352,7 @@
appendAttributesNode: function(node, feature) {
var name = this.createElementNS(this.gpxns, 'name');
name.appendChild(this.createTextNode(
- feature.attributes.name || feature.attributes.id));
+ feature.attributes.name || feature.id));
node.appendChild(name);
var desc = this.createElementNS(this.gpxns, 'desc');
desc.appendChild(this.createTextNode(
More information about the Commits
