[OpenLayers-Commits] r12362 - in
sandbox/aabt/openlayers/lib/OpenLayers: Feature Renderer
commits-20090109 at openlayers.org
Wed Sep 14 09:34:23 EDT 2011
Author: aabt
Date: 2011-09-14 06:34:23 -0700 (Wed, 14 Sep 2011)
New Revision: 12362
sandbox/aabt/openlayers/lib/OpenLayers/Feature/Vector.js
sandbox/aabt/openlayers/lib/OpenLayers/Renderer/Canvas.js
Add label outline to canvas renderer
Modified: sandbox/aabt/openlayers/lib/OpenLayers/Feature/Vector.js
--- sandbox/aabt/openlayers/lib/OpenLayers/Feature/Vector.js 2011-09-14 07:06:27 UTC (rev 12361)
+++ sandbox/aabt/openlayers/lib/OpenLayers/Feature/Vector.js 2011-09-14 13:34:23 UTC (rev 12362)
@@ -419,6 +419,8 @@
* labelYOffset - {Number} Pixel offset along the positive y axis for displacing the label. Not supported by the canvas renderer.
* labelSelect - {Boolean} If set to true, labels will be selectable using SelectFeature or similar controls.
* Default is false.
+ * labelOutlineColor - {String} The color of the label outline. Default is 'white'. Only supported by the canvas renderer.
+ * labelOutlineWidth - {Number} The width of the label outline. Default is 3. Only supported by the canvas renderer.
* fontColor - {String} The font color for the label, to be provided like CSS.
* fontOpacity - {Number} Opacity (0-1) for the label
* fontFamily - {String} The font family for the label, to be provided like in CSS.
Modified: sandbox/aabt/openlayers/lib/OpenLayers/Renderer/Canvas.js
--- sandbox/aabt/openlayers/lib/OpenLayers/Renderer/Canvas.js 2011-09-14 07:06:27 UTC (rev 12361)
+++ sandbox/aabt/openlayers/lib/OpenLayers/Renderer/Canvas.js 2011-09-14 13:34:23 UTC (rev 12362)
@@ -1,5 +1,5 @@
-/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
- * full list of contributors). Published under the Clear BSD license.
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
* See http://svn.openlayers.org/trunk/openlayers/license.txt for the
* full text of the license. */
@@ -8,26 +8,26 @@
- * Class: OpenLayers.Renderer.Canvas
+ * Class: OpenLayers.Renderer.Canvas
* A renderer based on the 2D 'canvas' drawing element.
* Inherits:
* - <OpenLayers.Renderer>
OpenLayers.Renderer.Canvas = OpenLayers.Class(OpenLayers.Renderer, {
* APIProperty: hitDetection
* {Boolean} Allow for hit detection of features. Default is true.
hitDetection: true,
* Property: hitOverflow
* {Number} The method for converting feature identifiers to color values
- * supports 16777215 sequential values. Two features cannot be
+ * supports 16777215 sequential values. Two features cannot be
* predictably detected if their identifiers differ by more than this
- * value. The hitOverflow allows for bigger numbers (but the
+ * value. The hitOverflow allows for bigger numbers (but the
* difference in values is still limited).
hitOverflow: 0,
@@ -36,21 +36,21 @@
* Property: canvas
* {Canvas} The canvas context object.
- canvas: null,
+ canvas: null,
* Property: features
* {Object} Internal object of feature/style pairs for use in redrawing the layer.
features: null,
* Property: pendingRedraw
* {Boolean} The renderer needs a redraw call to render features added while
* the renderer was locked.
pendingRedraw: false,
* Constructor: OpenLayers.Renderer.Canvas
@@ -69,13 +69,13 @@
this.hitContext = this.hitCanvas.getContext("2d");
* Method: eraseGeometry
* Erase a geometry from the renderer. Because the Canvas renderer has
* 'memory' of the features that it has drawn, we have to remove the
- * feature so it doesn't redraw.
+ * feature so it doesn't redraw.
* Parameters:
* geometry - {<OpenLayers.Geometry>}
* featureId - {String}
@@ -86,15 +86,15 @@
* APIMethod: supported
* Returns:
* {Boolean} Whether or not the browser supports the renderer class
supported: function() {
var canvas = document.createElement("canvas");
return !!canvas.getContext;
* Method: setSize
* Sets the size of the drawing surface.
@@ -102,7 +102,7 @@
* Once the size is updated, redraw the canvas.
* Parameters:
- * size - {<OpenLayers.Size>}
+ * size - {<OpenLayers.Size>}
setSize: function(size) {
this.size = size.clone();
@@ -120,15 +120,15 @@
hitCanvas.height = size.h;
* Method: drawFeature
* Draw the feature. Stores the feature in the features list,
- * then redraws the layer.
+ * then redraws the layer.
* Parameters:
- * feature - {<OpenLayers.Feature.Vector>}
- * style - {<Object>}
+ * feature - {<OpenLayers.Feature.Vector>}
+ * style - {<Object>}
* Returns:
* {Boolean} The feature has been drawn completely. If the feature has no
@@ -159,14 +159,14 @@
return rendered;
* Method: drawGeometry
* Used when looping (in redraw) over the features; draws
- * the canvas.
+ * the canvas.
* Parameters:
- * geometry - {<OpenLayers.Geometry>}
- * style - {Object}
+ * geometry - {<OpenLayers.Geometry>}
+ * style - {Object}
drawGeometry: function(geometry, style, featureId) {
var className = geometry.CLASS_NAME;
@@ -199,18 +199,18 @@
* Method: drawExternalGraphic
- * Called to draw External graphics.
- * Parameters:
+ * Called to draw External graphics.
+ * Parameters:
* style - {Object}
drawExternalGraphic: function(geometry, style, featureId) {
var img = new Image();
if (style.graphicTitle) {
- img.title = style.graphicTitle;
+ img.title = style.graphicTitle;
var width = style.graphicWidth || style.graphicHeight;
@@ -223,7 +223,7 @@
style.graphicYOffset : -(0.5 * height);
var opacity = style.graphicOpacity || style.fillOpacity;
var onLoad = function() {
if(!this.features[featureId]) {
return;
@@ -266,10 +266,10 @@
* style - {Object} Symbolizer hash
setCanvasStyle: function(type, style) {
- if (type === "fill") {
+ if (type === "fill") {
this.canvas.globalAlpha = style['fillOpacity'];
this.canvas.fillStyle = style['fillColor'];
- } else if (type === "stroke") {
+ } else if (type === "stroke") {
this.canvas.globalAlpha = style['strokeOpacity'];
this.canvas.strokeStyle = style['strokeColor'];
this.canvas.lineWidth = style['strokeWidth'];
@@ -278,7 +278,7 @@
this.canvas.lineWidth = 1;
* Method: featureIdToHex
* Convert a feature ID string into an RGB hex string.
@@ -300,7 +300,7 @@
hex = "#" + hex.substring(len-6, len);
return hex;
* Method: setHitContextStyle
* Prepare the hit canvas for drawing by setting various global settings.
@@ -315,7 +315,7 @@
if (type == "fill") {
this.hitContext.globalAlpha = 1.0;
this.hitContext.fillStyle = hex;
- } else if (type == "stroke") {
+ } else if (type == "stroke") {
this.hitContext.strokeStyle = hex;
// bump up stroke width to deal with antialiasing
@@ -329,12 +329,12 @@
* Method: drawPoint
* This method is only called by the renderer itself.
- * Parameters:
+ * Parameters:
* style - {Object}
drawPoint: function(geometry, style, featureId) {
if(style.graphic !== false) {
if(style.externalGraphic) {
@@ -376,30 +376,30 @@
* Method: drawLineString
- * Parameters:
+ * Parameters:
* style - {Object}
drawLineString: function(geometry, style, featureId) {
style = OpenLayers.Util.applyDefaults({fill: false}, style);
this.drawLinearRing(geometry, style, featureId);
* Method: drawLinearRing
- * Parameters:
+ * Parameters:
* style - {Object}
drawLinearRing: function(geometry, style, featureId) {
if (style.fill !== false) {
this.setCanvasStyle("fill", style);
@@ -419,7 +419,7 @@
this.setCanvasStyle("reset");
* Method: renderPath
* Render a path with stroke and optional fill.
@@ -444,36 +444,36 @@
* Method: drawPolygon
- * Parameters:
+ * Parameters:
* style - {Object}
drawPolygon: function(geometry, style, featureId) {
var components = geometry.components;
var len = components.length;
this.drawLinearRing(components[0], style, featureId);
// erase inner rings
for (var i=1; i<len; ++i) {
- * Note that this is overly agressive. Here we punch holes through
- * all previously rendered features on the same canvas. A better
- * solution for polygons with interior rings would be to draw the
- * polygon on a sketch canvas first. We could erase all holes
- * there and then copy the drawing to the layer canvas.
- * TODO: http://trac.osgeo.org/openlayers/ticket/3130
+ * Note that this is overly agressive. Here we punch holes through
+ * all previously rendered features on the same canvas. A better
+ * solution for polygons with interior rings would be to draw the
+ * polygon on a sketch canvas first. We could erase all holes
+ * there and then copy the drawing to the layer canvas.
+ * TODO: http://trac.osgeo.org/openlayers/ticket/3130
this.canvas.globalCompositeOperation = "destination-out";
if (this.hitDetection) {
this.hitContext.globalCompositeOperation = "destination-out";
- components[i],
+ components[i],
OpenLayers.Util.applyDefaults({stroke: false, fillOpacity: 1.0}, style),
featureId
@@ -482,13 +482,13 @@
this.hitContext.globalCompositeOperation = "source-over";
- components[i],
+ components[i],
OpenLayers.Util.applyDefaults({fill: false}, style),
featureId
* Method: drawText
@@ -500,7 +500,9 @@
drawText: function(location, style) {
style = OpenLayers.Util.extend({
fontColor: "#000000",
- labelAlign: "cm"
+ labelAlign: "cm",
+ labelOutlineColor: "white",
+ labelOutlineWidth: 3
}, style);
var pt = this.getLocalXY(location);
@@ -533,6 +535,11 @@
this.canvas.measureText('xx').width;
pt[1] += lineHeight*vfactor*(numRows-1);
for (var i = 0; i < numRows; i++) {
+ this.canvas.save();
+ this.canvas.strokeStyle = style.labelOutlineColor;
+ this.canvas.lineWidth = style.labelOutlineWidth;
+ this.canvas.strokeText(labelRows[i], pt[0], pt[1] + (lineHeight*i));
+ this.canvas.restore();
this.canvas.fillText(labelRows[i], pt[0], pt[1] + (lineHeight*i));
} else if (this.canvas.mozDrawText) {
@@ -561,12 +568,12 @@
* Method: getLocalXY
* transform geographic xy into pixel xy
- * Parameters:
+ * Parameters:
* point - {<OpenLayers.Geometry.Point>}
getLocalXY: function(point) {
@@ -580,7 +587,7 @@
* Method: clear
* Clear all vectors from the renderer.
clear: function() {
var height = this.root.height;
var width = this.root.width;
@@ -593,13 +600,13 @@
* Method: getFeatureIdFromEvent
- * Returns a feature id from an event on the renderer.
+ * Returns a feature id from an event on the renderer.
* Parameters:
- * evt - {<OpenLayers.Event>}
+ * evt - {<OpenLayers.Event>}
* Returns:
- * {<OpenLayers.Feature.Vector} A feature or null. This method returns a
+ * {<OpenLayers.Feature.Vector} A feature or null. This method returns a
* feature instead of a feature id to avoid an unnecessary lookup on the
* layer.
@@ -622,14 +629,14 @@
return feature;
- * Method: eraseFeatures
+ * Method: eraseFeatures
* This is called by the layer to erase features; removes the feature from
* the list, then redraws the layer.
* Parameters:
- * features - {Array(<OpenLayers.Feature.Vector>)}
+ * features - {Array(<OpenLayers.Feature.Vector>)}
eraseFeatures: function(features) {
if(!(OpenLayers.Util.isArray(features))) {
@@ -673,7 +680,7 @@
item = labelMap[i];
this.drawText(item[0].geometry.getCentroid(), item[1]);
CLASS_NAME: "OpenLayers.Renderer.Canvas"
More information about the Commits
