[OpenLayers-Commits] r12384 - in trunk/openlayers: lib/OpenLayers lib/OpenLayers/Control lib/OpenLayers/Layer lib/OpenLayers/Marker lib/OpenLayers/Strategy tests tests/Control tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Sep 17 15:09:42 EDT 2011
Author: fredj
Date: 2011-09-17 12:09:40 -0700 (Sat, 17 Sep 2011)
New Revision: 12384
   trunk/openlayers/lib/OpenLayers/Control.js
   trunk/openlayers/lib/OpenLayers/Control/DrawFeature.js
   trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
   trunk/openlayers/lib/OpenLayers/Control/GetFeature.js
   trunk/openlayers/lib/OpenLayers/Control/Measure.js
   trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js
   trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
   trunk/openlayers/lib/OpenLayers/Control/Snapping.js
   trunk/openlayers/lib/OpenLayers/Control/Split.js
   trunk/openlayers/lib/OpenLayers/Control/TransformFeature.js
   trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
   trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
   trunk/openlayers/lib/OpenLayers/Events.js
   trunk/openlayers/lib/OpenLayers/Layer.js
   trunk/openlayers/lib/OpenLayers/Layer/Vector.js
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/lib/OpenLayers/Marker.js
   trunk/openlayers/lib/OpenLayers/Marker/Box.js
   trunk/openlayers/lib/OpenLayers/Request.js
   trunk/openlayers/lib/OpenLayers/Strategy/Save.js
   trunk/openlayers/lib/OpenLayers/Tile.js
   trunk/openlayers/tests/Control/DrawFeature.html
   trunk/openlayers/tests/Events.html
   trunk/openlayers/tests/Layer/Grid.html
   trunk/openlayers/tests/Layer/Text.html
remove event type list from Events (lazy listener initialization) p=tschaub,me r=erilem (closes #2555)
Modified: trunk/openlayers/lib/OpenLayers/Control/DrawFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/DrawFeature.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/DrawFeature.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -32,12 +32,9 @@
     callbacks: null,
-     * Constant: EVENT_TYPES
      * Supported event types:
      * featureadded - Triggered when a feature is added
-    EVENT_TYPES: ["featureadded"],
      * APIProperty: multi
@@ -67,13 +64,6 @@
      * options - {Object}
     initialize: function(layer, handler, options) {
-        // concatenate events specific to vector with those from the base
-        this.EVENT_TYPES =
-            OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(
-            OpenLayers.Control.prototype.EVENT_TYPES
         OpenLayers.Control.prototype.initialize.apply(this, [options]);
         this.callbacks = OpenLayers.Util.extend(
Modified: trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
--- trunk/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -23,14 +23,12 @@
 OpenLayers.Control.Geolocate = OpenLayers.Class(OpenLayers.Control, {
      *  - *locationupdated* Triggered when browser return a new position
      *  - *locationfailed* Triggered when geolocation has failed
      *  - *locationuncapable* Triggered when control is activated on a browser
      *  which doesn't support geolocation
-    EVENT_TYPES: ["locationupdated", "locationfailed", "locationuncapable"],
      * Property: geolocation
@@ -63,15 +61,6 @@
      * Create a new control to deal with browser geolocation API
-    initialize: function(options) {
-        // concatenate events specific to this control with those from the base
-            OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(
-        this.geolocationOptions = {};
-        OpenLayers.Control.prototype.initialize.apply(this, [options]);
      * Method: destroy
Modified: trunk/openlayers/lib/OpenLayers/Control/GetFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/GetFeature.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/GetFeature.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -170,8 +170,6 @@
     filterType: OpenLayers.Filter.Spatial.BBOX,
      * beforefeatureselected - Triggered when <click> is true before a
      *      feature is selected. The event object has a feature property with
@@ -197,9 +195,6 @@
      * outfeature - Triggered when <hover> is true and the mouse moves
      *      moved away from a hover-selected feature
-    EVENT_TYPES: ["featureselected", "featuresselected", "featureunselected",
-        "clickout", "beforefeatureselected", "beforefeaturesselected",
-        "hoverfeature", "outfeature"],
      * Constructor: OpenLayers.Control.GetFeature
@@ -211,12 +206,6 @@
      *     made)
-            OpenLayers.Control.GetFeature.prototype.EVENT_TYPES.concat(
         options.handlerOptions = options.handlerOptions || {};
Modified: trunk/openlayers/lib/OpenLayers/Control/Measure.js
--- trunk/openlayers/lib/OpenLayers/Control/Measure.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/Measure.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -18,9 +18,7 @@
 OpenLayers.Control.Measure = OpenLayers.Class(OpenLayers.Control, {
-     * {Array(String)} Supported application event types.  Register a listener
-     *     for a particular event with the following syntax:
+     * Register a listener for a particular event with the following syntax:
      * (code)
      * control.events.register(type, obj, listener);
      * (end)
@@ -37,7 +35,6 @@
      *      measurement sketch is modified.  Listeners receive an event with measure,
      *      units, order, and geometry.
-    EVENT_TYPES: ['measure', 'measurepartial'],
      * APIProperty: handlerOptions
@@ -120,11 +117,6 @@
     initialize: function(handler, options) {
-        // concatenate events specific to measure with those from the base
-            OpenLayers.Control.Measure.prototype.EVENT_TYPES.concat(
         var callbacks = {done: this.measureComplete,
             point: this.measurePartial};
Modified: trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js
--- trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -24,9 +24,7 @@
 OpenLayers.Control.SLDSelect = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -41,7 +39,6 @@
      *     array of OpenLayers.Filter objects created in order to perform
      *     the particular selection.
-    EVENT_TYPES: ["selected"],
      * APIProperty: clearOnDeactivate
@@ -148,11 +145,6 @@
      *     selection on.
-            OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(
         this.callbacks = OpenLayers.Util.extend({done: this.select,
Modified: trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -22,14 +22,11 @@
 OpenLayers.Control.SelectFeature = OpenLayers.Class(OpenLayers.Control, {
      *  - *beforefeaturehighlighted* Triggered before a feature is highlighted
      *  - *featurehighlighted* Triggered when a feature is highlighted
      *  - *featureunhighlighted* Triggered when a feature is unhighlighted
-    EVENT_TYPES: ["beforefeaturehighlighted", "featurehighlighted", "featureunhighlighted"],
      * Property: multipleKey
@@ -173,11 +170,6 @@
     initialize: function(layers, options) {
-            OpenLayers.Control.SelectFeature.prototype.EVENT_TYPES.concat(
         if(this.scope === null) {
Modified: trunk/openlayers/lib/OpenLayers/Control/Snapping.js
--- trunk/openlayers/lib/OpenLayers/Control/Snapping.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/Snapping.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -18,9 +18,7 @@
 OpenLayers.Control.Snapping = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -45,7 +43,6 @@
      * unsnap - Triggered when a vertex is unsnapped.  Listeners receive an
      *     event with a *point* property.
-    EVENT_TYPES: ["beforesnap", "snap", "unsnap"],
      * CONSTANT: DEFAULTS
@@ -175,10 +172,6 @@
      *     no maximum resolution limit.
-        Array.prototype.push.apply(
-            this.EVENT_TYPES, OpenLayers.Control.prototype.EVENT_TYPES
         this.options = options || {}; // TODO: this could be done by the super
Modified: trunk/openlayers/lib/OpenLayers/Control/Split.js
--- trunk/openlayers/lib/OpenLayers/Control/Split.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/Split.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -19,9 +19,7 @@
 OpenLayers.Control.Split = OpenLayers.Class(OpenLayers.Control, {
      * (code)
      * (end)
@@ -47,7 +45,6 @@
      *     sketch or modified feature used as a splitter.  The features
      *     property is a list of all resulting features.
-    EVENT_TYPES: ["beforesplit", "split", "aftersplit"],
      * APIProperty: layer
@@ -169,10 +166,6 @@
      *     splitting.
Modified: trunk/openlayers/lib/OpenLayers/Control/TransformFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/TransformFeature.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/TransformFeature.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -22,8 +22,6 @@
 OpenLayers.Control.TransformFeature = OpenLayers.Class(OpenLayers.Control, {
      *  - *beforesetfeature* Triggered before a feature is set for
      *      tranformation. The feature will not be set if a listener returns
@@ -51,8 +49,6 @@
      *  - *transformcomplete* Triggered after dragging. Listeners receive
      *      an event object with the transformed *feature*.
-    EVENT_TYPES: ["beforesetfeature", "setfeature", "beforetransform",
-        "transform", "transformcomplete"],
      * APIProperty: geometryTypes
@@ -181,11 +177,6 @@
      *     control.
     initialize: function(layer, options) {
-            OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(
         this.layer = layer;
Modified: trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js
--- trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/WMSGetFeatureInfo.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -155,8 +155,6 @@
     hoverRequest: null,
      * Supported event types (in addition to those from <OpenLayers.Control>):
      * beforegetfeatureinfo - Triggered before the request is sent.
      *      The event object has an *xy* property with the position of the
@@ -172,7 +170,6 @@
      *      layers, *text* and *request* will only contain the response body
      *      and request object of the last request.
-    EVENT_TYPES: ["beforegetfeatureinfo", "nogetfeatureinfo", "getfeatureinfo"],
      * Constructor: <OpenLayers.Control.WMSGetFeatureInfo>
@@ -181,12 +178,6 @@
-            OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(
Modified: trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js
--- trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control/WMTSGetFeatureInfo.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -136,8 +136,6 @@
     hoverRequest: null,
      * beforegetfeatureinfo - Triggered before each request is sent.
@@ -157,7 +155,6 @@
      *      an event with *request*, *xy*, and *layer*  properties.  In the case
      *      of a parsing error, the event will also contain an *error* property.
-    EVENT_TYPES: ["beforegetfeatureinfo", "getfeatureinfo", "exception"],
      * Property: pending
@@ -172,12 +169,6 @@
-            OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(
Modified: trunk/openlayers/lib/OpenLayers/Control.js
--- trunk/openlayers/lib/OpenLayers/Control.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Control.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -145,9 +145,7 @@
     events: null,
      * (code)
      * (end)
@@ -165,7 +163,6 @@
      * activate - Triggered when activated.
      * deactivate - Triggered when deactivated.
-    EVENT_TYPES: ["activate", "deactivate"],
@@ -187,7 +184,7 @@
         OpenLayers.Util.extend(this, options);
-        this.events = new OpenLayers.Events(this, null, this.EVENT_TYPES);
+        this.events = new OpenLayers.Events(this);
         if(this.eventListeners instanceof Object) {
             this.events.on(this.eventListeners);
Modified: trunk/openlayers/lib/OpenLayers/Events.js
--- trunk/openlayers/lib/OpenLayers/Events.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Events.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -420,12 +420,6 @@
     element: null,
-     * Property: eventTypes
-     * {Array(String)}  list of support application events
-    eventTypes: null,
      * Property: eventHandler
      * {Function}  bound event handler attached to elements
@@ -480,7 +474,9 @@
      * Parameters:
      * object - {Object} The js object to which this Events object  is being added
      * element - {DOMElement} A dom element to respond to browser events
-     * eventTypes - {Array(String)} Array of custom application events
+     * eventTypes - {Array(String)} Deprecated.  Array of custom application
+     *     events.  A listener may be registered for any named event, regardless
+     *     of the values provided here.
      * fallThrough - {Boolean} Allow events to fall through after these have
      *                         been handled?
      * options - {Object} Options for the events object.
@@ -490,30 +486,20 @@
         this.object     = object;
         this.fallThrough = fallThrough;
         this.listeners  = {};
-        // keep a bound copy of handleBrowserEvent() so that we can
-        // pass the same function to both Event.observe() and .stopObserving()
-        this.eventHandler = OpenLayers.Function.bindAsEventListener(
-            this.handleBrowserEvent, this
-        // to be used with observe and stopObserving
-        this.clearMouseListener = OpenLayers.Function.bind(
-            this.clearMouseCache, this
-        // if eventTypes is specified, create a listeners list for each
-        // custom application event.
-        this.eventTypes = [];
-        if (eventTypes != null) {
-            for (var i=0, len=eventTypes.length; i<len; i++) {
-                this.addEventType(eventTypes[i]);
         // if a dom element is specified, add a listeners list
         // for browser events on the element and register them
         if (element != null) {
+            // keep a bound copy of handleBrowserEvent() so that we can
+            // pass the same function to both Event.observe() and .stopObserving()
+            this.eventHandler = OpenLayers.Function.bindAsEventListener(
+                this.handleBrowserEvent, this
+            // to be used with observe and stopObserving
+            this.clearMouseListener = OpenLayers.Function.bind(
+                this.clearMouseCache, this
             this.attachToElement(element);
@@ -534,24 +520,18 @@
         this.listeners = null;
         this.object = null;
-        this.eventTypes = null;
         this.fallThrough = null;
         this.eventHandler = null;
      * APIMethod: addEventType
-     * Add a new event type to this events object.
-     * If the event type has already been added, do nothing.
+     * Deprecated.  Any event can be triggered without adding it first.
      * Parameters:
      * eventName - {String}
     addEventType: function(eventName) {
-        if (!this.listeners[eventName]) {
-            this.eventTypes.push(eventName);
-            this.listeners[eventName] = [];
@@ -565,15 +545,11 @@
             OpenLayers.Event.stopObservingElement(this.element);
         this.element = element;
-        for (var i=0, len=this.BROWSER_EVENTS.length; i<len; i++) {
-            var eventType = this.BROWSER_EVENTS[i];
-            // every browser event has a corresponding application event
-            // (whether it's listened for or not).
-            this.addEventType(eventType);
-            // use Prototype to register the event cross-browser
-            OpenLayers.Event.observe(element, eventType, this.eventHandler);
+        for (var i = 0, len = this.BROWSER_EVENTS.length; i < len; i++) {
+            // register the event cross-browser
+            OpenLayers.Event.observe(
+                element, this.BROWSER_EVENTS[i], this.eventHandler
         // disable dragstart in IE so that mousedown/move/up works normally
         OpenLayers.Event.observe(element, "dragstart", OpenLayers.Event.stop);
@@ -610,7 +586,7 @@
     on: function(object) {
         for(var type in object) {
-            if(type != "scope") {
+            if(type != "scope" && object.hasOwnProperty(type)) {
                 this.register(type, object.scope, object[type]);
@@ -640,19 +616,24 @@
      *                     'object' property.
      * func - {Function} The callback function. If no callback is
      *                        specified, this function does nothing.
+     * priority - {Boolean} If true, adds the new listener to the *front* of
+     *                      the events queue instead of to the end.
-    register: function (type, obj, func) {
-        if ( (func != null) &&
-             (OpenLayers.Util.indexOf(this.eventTypes, type) != -1) ) {
+    register: function (type, obj, func, priority) {
+        if (func != null) {
             if (obj == null)  {
                 obj = this.object;
             var listeners = this.listeners[type];
-            listeners.push( {obj: obj, func: func} );
+            if (!listeners) {
+                listeners = [];
+                this.listeners[type] = listeners;
+            if (priority) {
+                listeners.unshift({obj: obj, func: func});
+            } else {
+                listeners.push({obj: obj, func: func});
@@ -674,16 +655,7 @@
     registerPriority: function (type, obj, func) {
-        if (func != null) {
-            if (obj == null)  {
-                obj = this.object;
-            var listeners = this.listeners[type];
-            if (listeners != null) {
-                listeners.unshift( {obj: obj, func: func} );
+        this.register(type, obj, func, true);
@@ -714,7 +686,7 @@
     un: function(object) {
                 this.unregister(type, object.scope, object[type]);
Modified: trunk/openlayers/lib/OpenLayers/Layer/Vector.js
--- trunk/openlayers/lib/OpenLayers/Layer/Vector.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Layer/Vector.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -24,9 +24,7 @@
 OpenLayers.Layer.Vector = OpenLayers.Class(OpenLayers.Layer, {
      * (code)
      * layer.events.register(type, obj, listener);
      * (end)
@@ -111,13 +109,6 @@
      * refresh - Triggered when something wants a strategy to ask the protocol
      *      for a new set of features.
-    EVENT_TYPES: ["beforefeatureadded", "beforefeaturesadded",
-                  "featureadded", "featuresadded", "beforefeatureremoved",
-                  "beforefeaturesremoved", "featureremoved", "featuresremoved",
-                  "beforefeatureselected", "featureselected", "featureunselected",
-                  "beforefeaturemodified", "featuremodified", "afterfeaturemodified",
-                  "vertexmodified", "vertexremoved", "sketchstarted",
-                  "sketchmodified", "sketchcomplete", "refresh"],
      * APIProperty: isBaseLayer
@@ -240,13 +231,6 @@
      * {<OpenLayers.Layer.Vector>} A new vector layer
     initialize: function(name, options) {
-            OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(
-            OpenLayers.Layer.prototype.EVENT_TYPES
         OpenLayers.Layer.prototype.initialize.apply(this, arguments);
         // allow user-set renderer, otherwise assign one
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Layer.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -58,9 +58,7 @@
     alwaysInRange: null,
      * (code)
      * (end)
@@ -89,8 +87,6 @@
      *     will receive an object with a *map* property referencing the map and
      *     a *layer* property referencing the layer.
-    EVENT_TYPES: ["loadstart", "loadend", "loadcancel", "visibilitychanged",
-                  "move", "moveend", "added", "removed"],
      * Constant: RESOLUTION_PROPERTIES
@@ -351,8 +347,7 @@
             this.div.style.height = "100%";
             this.div.dir = "ltr";
-            this.events = new OpenLayers.Events(this, this.div,
-                                                this.EVENT_TYPES);
+            this.events = new OpenLayers.Events(this, this.div);
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -36,9 +36,7 @@
      * (code)
      * map.events.register(type, obj, listener);
      * (end)
@@ -85,13 +83,6 @@
      *  - *mousemove* triggered after mousemove the map
      *  - *changebaselayer* triggered after the base layer changes
-    EVENT_TYPES: [
-        "preaddlayer", "addlayer","preremovelayer", "removelayer",
-        "changelayer", "movestart",
-        "move", "moveend", "zoomend", "popupopen", "popupclose",
-        "addmarker", "removemarker", "clearmarkers", "mouseover",
-        "mouseout", "mousemove", "dragstart", "drag", "dragend",
-        "changebaselayer"],
      * Property: id
@@ -538,7 +529,7 @@
         this.viewPortDiv.appendChild(eventsDiv);
         this.eventsDiv = eventsDiv;
-            this, this.eventsDiv, this.EVENT_TYPES, this.fallThrough,
+            this, this.eventsDiv, null, this.fallThrough,
             {includeXY: true}
Modified: trunk/openlayers/lib/OpenLayers/Marker/Box.js
--- trunk/openlayers/lib/OpenLayers/Marker/Box.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Marker/Box.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -40,7 +40,7 @@
         this.bounds = bounds;
         this.div    = OpenLayers.Util.createDiv();
         this.div.style.overflow = 'hidden';
-        this.events = new OpenLayers.Events(this, this.div, null);
         this.setBorder(borderColor, borderWidth);
Modified: trunk/openlayers/lib/OpenLayers/Marker.js
--- trunk/openlayers/lib/OpenLayers/Marker.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Marker.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -80,7 +80,7 @@
             this.icon.offset = newIcon.offset;
             this.icon.calculateOffset = newIcon.calculateOffset;
-        this.events = new OpenLayers.Events(this, this.icon.imageDiv, null);
+        this.events = new OpenLayers.Events(this, this.icon.imageDiv);
Modified: trunk/openlayers/lib/OpenLayers/Request.js
--- trunk/openlayers/lib/OpenLayers/Request.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Request.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -57,7 +57,7 @@
      * success - Triggered when the HTTP response has a success code (200-299).
      * failure - Triggered when the HTTP response does not have a success code.
-    events: new OpenLayers.Events(this, null, ["complete", "success", "failure"]),
+    events: new OpenLayers.Events(this),
      * APIMethod: issue
Modified: trunk/openlayers/lib/OpenLayers/Strategy/Save.js
--- trunk/openlayers/lib/OpenLayers/Strategy/Save.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Strategy/Save.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -20,19 +20,17 @@
 OpenLayers.Strategy.Save = OpenLayers.Class(OpenLayers.Strategy, {
      * (code)
      * strategy.events.register(type, obj, listener);
      * (end)
+     * Supported event types:
      *  - *start* Triggered before saving
      *  - *success* Triggered after a successful transaction
      *  - *fail* Triggered after a failed transaction
-    EVENT_TYPES: ["start", "success", "fail"],
      * Property: events
@@ -66,7 +64,7 @@
         OpenLayers.Strategy.prototype.initialize.apply(this, [options]);
Modified: trunk/openlayers/lib/OpenLayers/Tile.js
--- trunk/openlayers/lib/OpenLayers/Tile.js	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/lib/OpenLayers/Tile.js	2011-09-17 19:09:40 UTC (rev 12384)
@@ -26,10 +26,12 @@
 OpenLayers.Tile = OpenLayers.Class({
+     *  - *loadstart* Triggered when tile loading starts.
+     *  - *loadend* Triggered when tile loading ends.
+     *  - *reload* Triggered when an already loading tile is reloaded.
+     *  - *unload* Triggered before a tile is unloaded.
-    EVENT_TYPES: [ "loadstart", "loadend", "reload", "unload"],
      * APIProperty: events
@@ -110,7 +112,7 @@
         //give the tile a unique id based on its BBOX.
         this.id = OpenLayers.Util.createUniqueID("Tile_");
Modified: trunk/openlayers/tests/Control/DrawFeature.html
--- trunk/openlayers/tests/Control/DrawFeature.html	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/tests/Control/DrawFeature.html	2011-09-17 19:09:40 UTC (rev 12384)
@@ -4,12 +4,10 @@
     <script type="text/javascript">
     function test_initialize(t) {
-        t.plan(2);
+        t.plan(1);
         var control = new OpenLayers.Control.DrawFeature("foo", function() {});
         t.ok(control instanceof OpenLayers.Control.DrawFeature,
              "constructor returns an instance");
-        t.ok(OpenLayers.Util.indexOf(control.EVENT_TYPES, "featureadded") > -1,
-             "featureadded event in EVENT_TYPES");
     function test_multi(t) {
Modified: trunk/openlayers/tests/Events.html
--- trunk/openlayers/tests/Events.html	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/tests/Events.html	2011-09-17 19:09:40 UTC (rev 12384)
@@ -7,38 +7,22 @@
     var a;
     function test_Events_constructor (t) {
+        t.plan(4);
         var mapDiv = OpenLayers.Util.getElement('map');
         var obj = {result: 0};
-        var eventTypes = ["doThingA", "doThingB", "doThingC"];
-        var browserTypes = OpenLayers.Events.prototype.BROWSER_EVENTS;
-        var totalTests = 4 + 2*eventTypes.length + 2*browserTypes.length;
-        t.plan( totalTests );
-        events = new OpenLayers.Events(obj, mapDiv, eventTypes);
+        events = new OpenLayers.Events(obj, mapDiv);
         t.ok( events instanceof OpenLayers.Events, "new OpenLayers.Control returns object" );
         t.ok(events.object ==obj, " 'object' property correctly set");
         t.ok(events.element == mapDiv, " 'element' property correctly set");
+        events.destroy();
-        for (var i = 0; i < browserTypes.length; i++) {
-            var type = browserTypes[i];
-            t.ok( events.listeners[type] instanceof Array, "browser event: " + type + " correctly registered" );
-            t.ok( OpenLayers.Util.indexOf(events.eventTypes, type) != -1, "browser type " + type + "' correctly added to eventTypes array");
-        for (var i = 0; i < eventTypes.length; i++) {
-            var type = eventTypes[i];
-            t.ok( events.listeners[type] instanceof Array, "custom event: " + type + " correctly registered");
-            t.ok( OpenLayers.Util.indexOf(events.eventTypes, type) != -1, "eventType " + type + "' correctly added to eventTypes array");
         // default/nulls
         events = new OpenLayers.Events(null, null, null);
         t.ok( events.listeners != null,
               "init of Events with null object/element/eventTypes still creates listeners array" );
+        events.destroy();
     function test_Events_register(t){
@@ -59,8 +43,7 @@
                                 gFuncB = options.func;
-            'eventTypes': ['listenerA', 'listenerB']
         var type = null;
@@ -99,13 +82,12 @@
     function test_Events_register_unregister(t) {
-        t.plan( 18 );
+        t.plan(19);
         var func = function () { this.result++ }
         events.register( "doThingA", obj, func );
@@ -136,9 +118,12 @@
         var listenerList = events.listeners["doThingA"];
         t.eq( listenerList.length, 3, "register correctly does not append null callback to event.listeners[doThingA] even when obj passed in is null" );
-        events.register( "chicken", obj, func);
-        t.ok( events.listeners["chicken"] == null, "register() does nothing on attempt to register un-enabled event");
+        events.register("chicken", obj, func);
+        t.eq(events.listeners["chicken"].length, 1, "register() allows listeners for any named event");
+        events.unregister("chicken", obj, func);
+        t.eq(events.listeners["chicken"].length, 0, "unregistering an event that is not in eventTypes list works")
         events.unregister("doThingA", obj, null);
         t.eq( listenerList.length, 3, "trying to unregister a null callback does nothing -- but doesnt crash :-)" );
@@ -174,10 +159,13 @@
         t.ok( (listenerList.length == 1), "unregister does not bomb if you try to remove a null callback" );
-        events.unregister("chicken", null, func3);
-        t.ok( events.listeners["chicken"] == null, "unregistering an event that is not enabled does not wierdly enable it -- or cause a script error")
+        try {
+            events.unregister("asdf", obj, func);
+            t.ok("unregistering for an event with no registered listeners works");
+        } catch (err) {
+            t.fail("unregistering for an event with no registered listeners causes trouble: " + err);
     function test_Events_remove(t) {
@@ -186,9 +174,8 @@
         var func2 = function () { this.result-- }
@@ -213,9 +200,8 @@
@@ -248,7 +234,7 @@
         //no specific t.ok for this one, but if it breaks, you will know it.
         events.triggerEvent("chicken");
-        events = new OpenLayers.Events(null, mapDiv, eventTypes);
+        events = new OpenLayers.Events(null, mapDiv);
         // a is global variable (context-irrelevant)
         a = 0;
@@ -259,8 +245,7 @@
         t.eq(a, 5, "if Events has no object set and an event is registered also with no object, triggerEvent() calls it without trying to set the context to null");
         // trigger events with additional arguments
-        eventTypes = ["something"];
-        events = new OpenLayers.Events(null, null, eventTypes);
+        events = new OpenLayers.Events();
         var instance = {id: Math.random()};
         var listener = function(obj) {
             t.eq(this.id, instance.id,
@@ -309,7 +294,7 @@
     function test_Events_handleBrowserEvent(t) {
         t.plan(2);
-        var events = new OpenLayers.Events({}, null, ['sometouchevent']);
+        var events = new OpenLayers.Events({}, null);
         events.on({'sometouchevent': function() {}});
         // this test verifies that when handling a touch event we correctly
@@ -424,36 +409,6 @@
-    function test_Events_addEventType(t) {
-        t.plan( 8 );
-        var mapDiv = OpenLayers.Util.getElement('map');
-        var obj = {result: 0};
-        var eventTypes = ["doThingA", "doThingB"];
-        t.eq( events.listeners["doThingA"].length, 0, "event type passed as passed as param to OpenLayers.Events constructor correctly set up" );
-        t.eq( events.listeners["doThingB"].length, 0, "event type passed as passed as param to OpenLayers.Events constructor correctly set up" );
-        var newEventType = "onFoo";
-        t.ok( events.listeners[newEventType] == null, "event type not yet registered has null entry in listeners array");
-        t.ok( OpenLayers.Util.indexOf(events.eventTypes, newEventType) == -1, "event type not yet registered not in eventTypes array");
-        events.addEventType(newEventType);
-        t.eq( events.listeners[newEventType].length, 0, "event type passed to addEventType correctly set up" );
-        t.ok( OpenLayers.Util.indexOf(events.eventTypes, newEventType) != -1, "event type passed to addEventType in eventTypes array");
-        var func = function () {};
-        events.register( "doThingA", obj, func );
-        t.eq( events.listeners["doThingA"].length, 1, "listener correctly registered" );
-        events.addEventType("doThingsA");
-        t.eq( events.listeners["doThingA"].length, 1, "event type passed to addEventType correctly does nothing if clashes with already defined event type" );
     /** HACK HACK HACK Deprecated This test should be removed in 3.0 **/
     function test_Events_globalEventObject(t) {
         t.plan(1);
Modified: trunk/openlayers/tests/Layer/Grid.html
--- trunk/openlayers/tests/Layer/Grid.html	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/tests/Layer/Grid.html	2011-09-17 19:09:40 UTC (rev 12384)
@@ -21,19 +21,14 @@
     function test_Layer_Grid_constructor (t) {
-        t.plan( 8 );
+        t.plan( 5 );
         layer = new OpenLayers.Layer.Grid(name, url, params, null);
         t.ok( layer instanceof OpenLayers.Layer.Grid, "returns OpenLayers.Layer.Grid object" );
         t.eq( layer.buffer, 0, "buffer default is 0");
         t.eq( layer.ratio, 1.5, "ratio default is 1.5");
         t.eq( layer.numLoadingTiles, 0, "numLoadingTiles starts at 0");
-        t.ok( layer.events.listeners["tileloaded"] != null, "'tileloaded' event added to layer's event types");
-        t.ok( OpenLayers.Util.indexOf(layer.events.eventTypes, 'tileloaded') != -1 ,"'tileloaded' event added to layer's event types");
-        //regression testing for #1502
-        t.ok( layer.events.listeners['tileloaded'].length == 0, "no listeners for tileloaded preregister");
         var obj = {};
         var func = function() {};
         layer.events.register('tileloaded', obj, func);
Modified: trunk/openlayers/tests/Layer/Text.html
--- trunk/openlayers/tests/Layer/Text.html	2011-09-17 18:41:53 UTC (rev 12383)
+++ trunk/openlayers/tests/Layer/Text.html	2011-09-17 19:09:40 UTC (rev 12384)
@@ -173,7 +173,7 @@
         var event = {};
         t.delay_call( 1, function() {
           t.ok(layer.markers[0].events, "First marker has an events object");
-          t.eq(layer.markers[0].events.listeners['click'].length, 0, "Marker events has one object");
+          t.eq(layer.markers[0].events.listeners['click'], undefined, "Marker events has no object");
           layer.markers[0].events.triggerEvent('click', event);
           t.eq(map.popups.length, 0, "no popup on first marker");
           layer.markers[1].events.triggerEvent('click', event);
More information about the Commits mailing list
