[OpenLayers-Commits] r12385 - in sandbox/jsdoc: . jsd jsd/OpenLayers jsd/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Sep 17 15:19:50 EDT 2011
Author: tschaub
Date: 2011-09-17 12:19:49 -0700 (Sat, 17 Sep 2011)
New Revision: 12385
Added:
   sandbox/jsdoc/jsd/
   sandbox/jsdoc/jsd/OpenLayers/
   sandbox/jsdoc/jsd/OpenLayers/Layer/
   sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
Starting with WMS.
Added: sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js	                        (rev 0)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js	2011-09-17 19:19:49 UTC (rev 12385)
@@ -0,0 +1,289 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/Grid.js
+ * @requires OpenLayers/Tile/Image.js
+ * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
+ *     Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
+ *     constructor.
+ * Inherits from:
+ *  @extends OpenLayers.Layer.Grid
+ * @constructor OpenLayers.Layer.WMS
+ * @param {string} name  A name for the layer
+ * @param {string} url  Base url for the WMS
+ *                (e.g. http://wms.jpl.nasa.gov/wms.cgi)
+ * @param {Object} params  An object with key/value pairs representing the
+ *                   GetMap query string parameters and parameter values.
+ * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
+ *     These options include all properties listed above, plus the ones
+ *     inherited from superclasses.
+OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
+     * @const Constant: DEFAULT_PARAMS
+     * @type {Object}  Hashtable of default parameter key/value pairs
+    DEFAULT_PARAMS: { service: "WMS",
+                      version: "1.1.1",
+                      request: "GetMap",
+                      styles: "",
+                      format: "image/jpeg"
+     * Property: reproject
+     * *Deprecated*. See http://trac.openlayers.org/wiki/SphericalMercator
+     * for information on the replacement for this functionality.
+     * @type {boolean}  Try to reproject this layer if its coordinate reference system
+     *           is different than that of the base layer.  Default is false.
+     *           Set this in the layer options.  Should be set to false in
+     *           most cases.
+    reproject: false,
+     * Default is true for WMS layer.
+     * @type {boolean}
+     * @memberOf OpenLayers.Layer.WMS.prototype
+    isBaseLayer: true,
+     * APIProperty: encodeBBOX
+     * @type {boolean}  Should the BBOX commas be encoded? The WMS spec says 'no',
+     * but some services want it that way. Default false.
+    encodeBBOX: false,
+     * If true, the image format will not be automagicaly switched
+     *     from image/jpeg to image/png or image/gif when using
+     *     TRANSPARENT=TRUE. Also isBaseLayer will not changed by the
+     *     constructor. Default false.
+     * @type {boolean}
+    noMagic: false,
+     * Property: yx
+     * @type {Object}  Keys in this object are EPSG codes for which the axis order
+     *     is to be reversed (yx instead of xy, LatLon instead of LonLat), with
+     *     true as value. This is only relevant for WMS versions >= 1.3.0.
+    yx: {'EPSG:4326': true},
+     * Constructor: OpenLayers.Layer.WMS
+     * Create a new WMS layer object
+     * Examples:
+     * The code below creates a simple WMS layer using the image/jpeg format.
+     * (code)
+     * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
+     *                                    "http://wms.jpl.nasa.gov/wms.cgi",
+     *                                    {layers: "modis,global_mosaic"});
+     * (end)
+     * Note the 3rd argument (params). Properties added to this object will be
+     * added to the WMS GetMap requests used for this layer's tiles. The only
+     * mandatory parameter is "layers". Other common WMS params include
+     * "transparent", "styles" and "format". Note that the "srs" param will
+     * always be ignored. Instead, it will be derived from the baseLayer's or
+     * map's projection.
+     * The code below creates a transparent WMS layer with additional options.
+     * (code)
+     *                                        layers: "modis,global_mosaic",
+     *                                        transparent: true
+     *                                        opacity: 0.5,
+     *                                        singleTile: true
+     * (end)
+     * Note that by default, a WMS layer is configured as baseLayer. Setting
+     * the "transparent" param to true will apply some magic (see <noMagic>).
+     * The default image format changes from image/jpeg to image/png, and the
+     * layer is not configured as baseLayer.
+    initialize: function(name, url, params, options) {
+        var newArguments = [];
+        //uppercase params
+        params = OpenLayers.Util.upperCaseObject(params);
+        if (parseFloat(params.VERSION) >= 1.3 && !params.EXCEPTIONS) {
+            params.EXCEPTIONS = "INIMAGE";
+        newArguments.push(name, url, params, options);
+        OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
+        OpenLayers.Util.applyDefaults(
+                       this.params,
+                       OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS)
+        //layer is transparent
+        if (!this.noMagic && this.params.TRANSPARENT &&
+            this.params.TRANSPARENT.toString().toLowerCase() == "true") {
+            // unless explicitly set in options, make layer an overlay
+            if ( (options == null) || (!options.isBaseLayer) ) {
+                this.isBaseLayer = false;
+            // jpegs can never be transparent, so intelligently switch the
+            //  format, depending on the browser's capabilities
+            if (this.params.FORMAT == "image/jpeg") {
+                this.params.FORMAT = OpenLayers.Util.alphaHack() ? "image/gif"
+        : "image/png";
+     * Method: destroy
+     * Destroy this layer
+    destroy: function() {
+        // for now, nothing special to do here.
+        OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
+     * Method: clone
+     * Create a clone of this layer
+     * Returns:
+     * @return {OpenLayers.Layer.WMS}  An exact clone of this layer
+    clone: function (obj) {
+        if (obj == null) {
+            obj = new OpenLayers.Layer.WMS(this.name,
+                                           this.url,
+                                           this.params,
+                                           this.getOptions());
+        //get all additions from superclasses
+        obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]);
+        // copy/set any non-init, non-simple values here
+        return obj;
+     * APIMethod: reverseAxisOrder
+     * Returns true if the axis order is reversed for the WMS version and
+     * projection of the layer.
+     * Returns:
+     * @return {boolean}  true if the axis order is reversed, false otherwise.
+    reverseAxisOrder: function() {
+        return (parseFloat(this.params.VERSION) >= 1.3 &&
+            !!this.yx[this.map.getProjectionObject().getCode()]);
+     * Method: getURL
+     * Return a GetMap query string for this layer
+     * Parameters:
+     * @param {OpenLayers.Bounds} bounds  A bounds representing the bbox for the
+     *                                request.
+     * Returns:
+     * @return {string}  A string with the layer's url and parameters and also the
+     *          passed-in bounds and appropriate tile size specified as
+     *          parameters.
+    getURL: function (bounds) {
+        bounds = this.adjustBounds(bounds);
+        var imageSize = this.getImageSize();
+        var newParams = {};
+        // WMS 1.3 introduced axis order
+        var reverseAxisOrder = this.reverseAxisOrder();
+        newParams.BBOX = this.encodeBBOX ?
+            bounds.toBBOX(null, reverseAxisOrder) :
+            bounds.toArray(reverseAxisOrder);
+        newParams.WIDTH = imageSize.w;
+        newParams.HEIGHT = imageSize.h;
+        var requestString = this.getFullRequestString(newParams);
+        return requestString;
+     * APIMethod: mergeNewParams
+     * Catch changeParams and uppercase the new params to be merged in
+     *     before calling changeParams on the super class.
+     *     Once params have been changed, the tiles will be reloaded with
+     *     the new parameters.
+     * Parameters:
+     * @param {Object} newParams  Hashtable of new params to use
+    mergeNewParams:function(newParams) {
+        var upperParams = OpenLayers.Util.upperCaseObject(newParams);
+        var newArguments = [upperParams];
+        return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,
+                                                             newArguments);
+     * APIMethod: getFullRequestString
+     * Combine the layer's url with its params and these newParams.
+     *     Add the SRS parameter from projection -- this is probably
+     *     more eloquently done via a setProjection() method, but this
+     *     works for now and always.
+     * Parameters:
+     * @param {string} altUrl  Use this as the url instead of the layer's url
+     * Returns:
+    getFullRequestString:function(newParams, altUrl) {
+        var mapProjection = this.map.getProjectionObject();
+        var projectionCode = this.projection && this.projection.equals(mapProjection) ?
+            this.projection.getCode() :
+            mapProjection.getCode();
+        var value = (projectionCode == "none") ? null : projectionCode;
+        if (parseFloat(this.params.VERSION) >= 1.3) {
+            this.params.CRS = value;
+        } else {
+            this.params.SRS = value;
+        if (typeof this.params.TRANSPARENT == "boolean") {
+            newParams.TRANSPARENT = this.params.TRANSPARENT ? "TRUE" : "FALSE";
+        return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(
+                                                    this, arguments);
+    CLASS_NAME: "OpenLayers.Layer.WMS"
More information about the Commits mailing list
