[OpenLayers-Commits] r12386 - in trunk/openlayers/lib/OpenLayers:
Filter Geometry Handler Layer Layer/Vector Popup
commits-20090109 at openlayers.org
Sat Sep 17 15:20:42 EDT 2011
Author: fredj
Date: 2011-09-17 12:20:40 -0700 (Sat, 17 Sep 2011)
New Revision: 12386
trunk/openlayers/lib/OpenLayers/Filter/Function.js
trunk/openlayers/lib/OpenLayers/Filter/Spatial.js
trunk/openlayers/lib/OpenLayers/Geometry/Curve.js
trunk/openlayers/lib/OpenLayers/Geometry/LineString.js
trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js
trunk/openlayers/lib/OpenLayers/Geometry/MultiLineString.js
trunk/openlayers/lib/OpenLayers/Geometry/MultiPoint.js
trunk/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js
trunk/openlayers/lib/OpenLayers/Geometry/Polygon.js
trunk/openlayers/lib/OpenLayers/Geometry/Surface.js
trunk/openlayers/lib/OpenLayers/Handler/Click.js
trunk/openlayers/lib/OpenLayers/Handler/Hover.js
trunk/openlayers/lib/OpenLayers/Handler/Path.js
trunk/openlayers/lib/OpenLayers/Handler/Pinch.js
trunk/openlayers/lib/OpenLayers/Handler/Polygon.js
trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js
trunk/openlayers/lib/OpenLayers/Layer/TMS.js
trunk/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js
trunk/openlayers/lib/OpenLayers/Layer/WMS.js
trunk/openlayers/lib/OpenLayers/Popup/FramedCloud.js
remove unneeded destroy and initialize function. r=erilem (closes #3341)
Modified: trunk/openlayers/lib/OpenLayers/Filter/Function.js
--- trunk/openlayers/lib/OpenLayers/Filter/Function.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Filter/Function.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -43,9 +43,6 @@
* Returns:
* {<OpenLayers.Filter.Function>}
- initialize: function(options) {
- OpenLayers.Filter.prototype.initialize.apply(this, [options]);
CLASS_NAME: "OpenLayers.Filter.Function"
Modified: trunk/openlayers/lib/OpenLayers/Filter/Spatial.js
--- trunk/openlayers/lib/OpenLayers/Filter/Spatial.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Filter/Spatial.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -69,9 +69,6 @@
* Returns:
* {<OpenLayers.Filter.Spatial>}
* Method: evaluate
Modified: trunk/openlayers/lib/OpenLayers/Geometry/Curve.js
--- trunk/openlayers/lib/OpenLayers/Geometry/Curve.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/Curve.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -32,10 +32,6 @@
* Parameters:
* point - {Array(<OpenLayers.Geometry.Point>)}
- initialize: function(points) {
- OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,
- arguments);
* APIMethod: getLength
Modified: trunk/openlayers/lib/OpenLayers/Geometry/LineString.js
--- trunk/openlayers/lib/OpenLayers/Geometry/LineString.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/LineString.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -26,9 +26,6 @@
* generate the linestring
- OpenLayers.Geometry.Curve.prototype.initialize.apply(this, arguments);
* APIMethod: removeComponent
Modified: trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js
--- trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/LinearRing.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -42,10 +42,6 @@
* Parameters:
* points - {Array(<OpenLayers.Geometry.Point>)} points
- OpenLayers.Geometry.LineString.prototype.initialize.apply(this,
- arguments);
* APIMethod: addComponent
Modified: trunk/openlayers/lib/OpenLayers/Geometry/MultiLineString.js
--- trunk/openlayers/lib/OpenLayers/Geometry/MultiLineString.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/MultiLineString.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -36,10 +36,6 @@
* components - {Array(<OpenLayers.Geometry.LineString>)}
- initialize: function(components) {
- OpenLayers.Geometry.Collection.prototype.initialize.apply(this,
- arguments);
* Method: split
Modified: trunk/openlayers/lib/OpenLayers/Geometry/MultiPoint.js
--- trunk/openlayers/lib/OpenLayers/Geometry/MultiPoint.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/MultiPoint.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -38,10 +38,6 @@
* Returns:
* {<OpenLayers.Geometry.MultiPoint>}
- arguments);
* APIMethod: addPoint
Modified: trunk/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js
--- trunk/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/MultiPolygon.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -37,10 +37,6 @@
* used to generate the MultiPolygon
- arguments);
CLASS_NAME: "OpenLayers.Geometry.MultiPolygon"
Modified: trunk/openlayers/lib/OpenLayers/Geometry/Polygon.js
--- trunk/openlayers/lib/OpenLayers/Geometry/Polygon.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/Polygon.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -37,11 +37,7 @@
* Parameters:
* components - {Array(<OpenLayers.Geometry.LinearRing>)}
- arguments);
* APIMethod: getArea
* Calculated by subtracting the areas of the internal holes from the
Modified: trunk/openlayers/lib/OpenLayers/Geometry/Surface.js
--- trunk/openlayers/lib/OpenLayers/Geometry/Surface.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Geometry/Surface.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -9,9 +9,5 @@
OpenLayers.Geometry.Surface = OpenLayers.Class(OpenLayers.Geometry, {
- initialize: function() {
- OpenLayers.Geometry.prototype.initialize.apply(this, arguments);
CLASS_NAME: "OpenLayers.Geometry.Surface"
Modified: trunk/openlayers/lib/OpenLayers/Handler/Click.js
--- trunk/openlayers/lib/OpenLayers/Handler/Click.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Handler/Click.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -146,9 +146,6 @@
* options - {Object} Optional object whose properties will be set on the
* handler.
- initialize: function(control, callbacks, options) {
- OpenLayers.Handler.prototype.initialize.apply(this, arguments);
* Method: touchstart
Modified: trunk/openlayers/lib/OpenLayers/Handler/Hover.js
--- trunk/openlayers/lib/OpenLayers/Handler/Hover.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Handler/Hover.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -69,9 +69,6 @@
* options - {Object} An optional object whose properties will be set on
* the handler.
* Method: mousemove
Modified: trunk/openlayers/lib/OpenLayers/Handler/Path.js
--- trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Handler/Path.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -95,10 +95,7 @@
* cancel - Called when the handler is deactivated while drawing. The
* cancel callback will receive a geometry.
- OpenLayers.Handler.Point.prototype.initialize.apply(this, arguments);
* Method: createFeature
* Add temporary geometries
Modified: trunk/openlayers/lib/OpenLayers/Handler/Pinch.js
--- trunk/openlayers/lib/OpenLayers/Handler/Pinch.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Handler/Pinch.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -74,9 +74,6 @@
* information about scale, distance, and position of touch points.
Modified: trunk/openlayers/lib/OpenLayers/Handler/Polygon.js
--- trunk/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -62,9 +62,6 @@
- OpenLayers.Handler.Path.prototype.initialize.apply(this, arguments);
Modified: trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
--- trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -91,17 +91,7 @@
- * Method: destroy
- * Destroy this layer
- destroy: function() {
- // for now, nothing special to do here.
- OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
* Method: clone
* Create a clone of this layer
Modified: trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Layer/ArcIMS.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -149,18 +149,7 @@
- * Method: destroy
* Method: getURL
* Return an image url this layer.
Modified: trunk/openlayers/lib/OpenLayers/Layer/TMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/TMS.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Layer/TMS.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -123,15 +123,6 @@
- * APIMethod:destroy
* APIMethod: clone
* Create a complete copy of this layer.
Modified: trunk/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js
--- trunk/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Layer/Vector/RootContainer.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -50,9 +50,6 @@
* {<OpenLayers.Layer.Vector.RootContainer>} A new vector layer root
* container
- initialize: function(name, options) {
- OpenLayers.Layer.Vector.prototype.initialize.apply(this, arguments);
* Method: display
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -153,16 +153,6 @@
- * Method: destroy
* Method: clone
Modified: trunk/openlayers/lib/OpenLayers/Popup/FramedCloud.js
--- trunk/openlayers/lib/OpenLayers/Popup/FramedCloud.js 2011-09-17 19:19:49 UTC (rev 12385)
+++ trunk/openlayers/lib/OpenLayers/Popup/FramedCloud.js 2011-09-17 19:20:40 UTC (rev 12386)
@@ -223,12 +223,5 @@
this.contentDiv.className = this.contentDisplayClass;
- * APIMethod: destroy
- OpenLayers.Popup.Framed.prototype.destroy.apply(this, arguments);
CLASS_NAME: "OpenLayers.Popup.FramedCloud"
More information about the Commits
