[OpenLayers-Commits] r12391 - sandbox/jsdoc/jsd/OpenLayers/Layer
commits-20090109 at openlayers.org
Sat Sep 17 15:57:13 EDT 2011
Author: tschaub
Date: 2011-09-17 12:57:12 -0700 (Sat, 17 Sep 2011)
New Revision: 12391
sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
More doc.
Modified: sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 19:53:14 UTC (rev 12390)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js 2011-09-17 19:57:12 UTC (rev 12391)
@@ -9,36 +9,6 @@
* @requires OpenLayers/Tile/Image.js
- * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
- * Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
- * constructor.
- * <pre>
- * // The code below creates a transparent WMS layer with additional options.
- * var wms = new OpenLayers.Layer.WMS(
- * "NASA Global Mosaic",
- * "http://wms.jpl.nasa.gov/wms.cgi",
- * layers: "modis,global_mosaic",
- * transparent: true
- * opacity: 0.5,
- * singleTile: true
- * </pre>
- * @param {string} name A name for the layer
- * @param {string} url Base url for the WMS
- * (e.g. http://wms.jpl.nasa.gov/wms.cgi)
- * @param {Object} params An object with key/value pairs representing the
- * GetMap query string parameters and parameter values.
- * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
- * These options include all properties listed above, plus the ones
- * inherited from superclasses.
- * @constructor OpenLayers.Layer.WMS
- * @extends OpenLayers.Layer.Grid
OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
@@ -99,32 +69,36 @@
yx: {'EPSG:4326': true},
- * Constructor: OpenLayers.Layer.WMS
- * Create a new WMS layer object
- * Examples:
- * The code below creates a simple WMS layer using the image/jpeg format.
- * (code)
- * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
- * {layers: "modis,global_mosaic"});
- * (end)
- * Note the 3rd argument (params). Properties added to this object will be
- * added to the WMS GetMap requests used for this layer's tiles. The only
- * mandatory parameter is "layers". Other common WMS params include
- * "transparent", "styles" and "format". Note that the "srs" param will
- * always be ignored. Instead, it will be derived from the baseLayer's or
- * map's projection.
- * Note that by default, a WMS layer is configured as baseLayer. Setting
- * the "transparent" param to true will apply some magic (see <noMagic>).
- * The default image format changes from image/jpeg to image/png, and the
- * layer is not configured as baseLayer.
- * @methodOf OpenLayers.Layer.WMS.prototype
+ * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
+ * Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
+ * constructor.
+ * <pre>
+ * // The code below creates a transparent WMS layer with additional options.
+ * var wms = new OpenLayers.Layer.WMS(
+ * "NASA Global Mosaic",
+ * "http://wms.jpl.nasa.gov/wms.cgi",
+ * layers: "modis,global_mosaic",
+ * transparent: true
+ * opacity: 0.5,
+ * singleTile: true
+ * </pre>
+ * @param {string} name A name for the layer
+ * @param {string} url Base url for the WMS
+ * (e.g. http://wms.jpl.nasa.gov/wms.cgi)
+ * @param {Object} params An object with key/value pairs representing the
+ * GetMap query string parameters and parameter values.
+ * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
+ * These options include all properties listed above, plus the ones
+ * inherited from superclasses.
+ * @constructor OpenLayers.Layer.WMS
+ * @extends OpenLayers.Layer.Grid
initialize: function(name, url, params, options) {
var newArguments = [];
//uppercase params
More information about the Commits
